Another Computer, Same Problems. Please Help!!!
Solved Re: Another Computer, Same Problems. Please Help!!!
Post by Belahzur on 2nd January 2009, 12:08 am
Lets try from the creators link, it's more updated and may work.
Points Points : 245091
Post by DIADEM on 2nd January 2009, 12:13 am
JavaRa 1.12 Removal Log.
Report follows after line.
The JavaRa removal process was started on Thu Jan 01 17:54:40 2009
Found and removed: C:\Program Files\Java\j2re1.4.2_05
Found and removed: C:\Program Files\Java\j2re1.4.2_06
Found and removed: C:\Windows\Installer\{7148F0A8-6813-11D6-A77B-00B0D0142050}
Found and removed: C:\Windows\Installer\{7148F0A8-6813-11D6-A77B-00B0D0142060}
The JavaRa removal process was started on Thu Jan 01 17:57:09 2009
The JavaRa removal process was started on Thu Jan 01 18:01:17 2009
The JavaRa removal process was started on Thu Jan 01 18:02:45 2009
JavaRa 1.13 Removal Log.
The JavaRa removal process was started on Thu Jan 01 18:11:50 2009
Found and removed: C:\Program Files\JavaSoft
Finished reporting.
DIADEM
Posts Posts : 73
Joined Joined : 2008-12-07
OS OS : windows xp
Points Points : 29245
Post by Belahzur on 2nd January 2009, 12:16 am
Looks good now.
Post by Doctor Inferno on 21st February 2009, 9:53 am
