I NEED HELP WITH Troj/Rustok-N i cant get rid of it!!!
Page 2 of 2 Previous  1, 2
Solved Re: I NEED HELP WITH Troj/Rustok-N i cant get rid of it!!!
Post by AARG12 on Tue Jan 13, 2009 11:01 pm
[2009/01/06 20:48:10 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Apple Computer
[2009/01/06 20:48:10 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Local\Apple Computer
[2009/01/06 20:48:06 | 00,001,804 | ---- | C] () -- C:\Users\Public\Desktop\iTunes.lnk
[2009/01/06 20:47:48 | 00,000,000 | ---D | C] -- C:\Program Files\iPod
[2009/01/06 20:47:47 | 00,000,000 | ---D | C] -- C:\Program Files\iTunes
[2009/01/06 20:47:01 | 00,000,000 | ---D | C] -- C:\Program Files\Bonjour
[2009/01/06 20:46:45 | 00,001,726 | ---- | C] () -- C:\Users\Public\Desktop\QuickTime Player.lnk
[2009/01/06 20:46:31 | 00,000,000 | ---D | C] -- C:\Program Files\QuickTime
[2009/01/06 20:46:29 | 00,000,000 | ---D | C] -- C:\ProgramData\Apple Computer
[2009/01/06 20:46:09 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Local\Apple
[2009/01/06 20:46:04 | 00,000,000 | ---D | C] -- C:\Program Files\Apple Software Update
[2009/01/06 20:45:33 | 00,000,000 | ---D | C] -- C:\Program Files\Common Files\Apple
[2009/01/06 20:45:32 | 00,000,000 | ---D | C] -- C:\ProgramData\Apple
[2009/01/06 20:14:16 | 00,000,000 | ---D | C] -- C:\Users\Angel\Documents\My Received Files
[2009/01/06 20:14:06 | 00,000,000 | -HSD | C] -- C:\Program Files\Common Files\WindowsLiveInstaller
[2009/01/06 20:13:40 | 00,000,000 | ---D | C] -- C:\ProgramData\WLInstaller
[2009/01/06 20:10:47 | 00,000,000 | ---D | C] -- C:\Program Files\Windows Live
[2009/01/05 23:52:46 | 00,004,608 | ---- | C] () -- C:\Users\Angel\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2009/01/05 23:17:04 | 00,078,336 | ---- | C] (S!Ri.URZ) -- C:\Windows\System32\Agent.OMZ.Fix.exe
[2009/01/05 22:17:26 | 00,000,000 | ---D | C] -- C:\Program Files\Exterminate It!
[2009/01/05 21:53:58 | 00,000,000 | ---D | C] -- C:\!KillBox
[2009/01/05 21:32:33 | 00,001,874 | ---- | C] () -- C:\Users\Angel\Desktop\HijackThis.lnk
[2009/01/04 18:16:28 | 00,000,000 | ---D | C] -- C:\Windows\temp
[2009/01/04 18:12:57 | 00,000,540 | ---- | C] () -- C:\Users\Angel\Desktop\ComboFix - Shortcut.lnk
[2009/01/02 16:31:13 | 00,000,000 | ---D | C] -- C:\Windows\Minidump
[2009/01/02 16:26:41 | 00,161,792 | ---- | C] (SteelWerX) -- C:\Windows\SWREG.exe
[2009/01/02 16:26:41 | 00,098,816 | ---- | C] () -- C:\Windows\sed.exe
[2009/01/02 16:26:41 | 00,089,504 | ---- | C] (Smallfrogs Studio) -- C:\Windows\fdsv.exe
[2009/01/02 16:26:41 | 00,080,412 | ---- | C] () -- C:\Windows\grep.exe
[2009/01/02 16:26:41 | 00,068,096 | ---- | C] () -- C:\Windows\zip.exe
[2009/01/02 16:26:41 | 00,049,152 | ---- | C] () -- C:\Windows\VFIND.exe
[2009/01/02 16:26:41 | 00,028,672 | ---- | C] (NirSoft) -- C:\Windows\NIRCMD.exe
[2009/01/02 16:26:40 | 00,212,480 | ---- | C] (SteelWerX) -- C:\Windows\SWXCACLS.exe
[2009/01/02 16:26:40 | 00,136,704 | ---- | C] (SteelWerX) -- C:\Windows\SWSC.exe
[2009/01/02 16:26:34 | 00,000,000 | ---D | C] -- C:\Windows\ERDNT
[2009/01/02 16:26:34 | 00,000,000 | ---D | C] -- C:\Qoobox
[2009/01/02 15:43:49 | 00,731,136 | ---- | C] () -- C:\Users\Angel\Desktop\avenger.exe
[2009/01/01 21:26:47 | 00,001,085 | ---- | C] () -- C:\Users\Angel\Desktop\Spybot - Search & Destroy.lnk
[2009/01/01 21:15:59 | 00,113,896 | ---- | C] (QFX Software Corporation) -- C:\Windows\System32\drivers\keyscrambler.sys
[2009/01/01 21:15:59 | 00,000,000 | ---D | C] -- C:\Program Files\KeyScrambler
[2009/01/01 19:56:33 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\InstallShield
[2009/01/01 19:50:28 | 00,000,000 | ---D | C] -- C:\Update
[2008/12/30 23:18:48 | 00,000,258 | RHS- | C] () -- C:\ProgramData\ntuser.pol
[2008/12/30 22:28:32 | 01,963,676 | -H-- | C] () -- C:\Users\Angel\AppData\Local\IconCache.db
[2008/12/30 21:45:44 | 00,015,504 | ---- | C] (Malwarebytes Corporation) -- C:\Windows\System32\drivers\mbam.sys
[2008/12/30 21:45:44 | 00,000,818 | ---- | C] () -- C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk
[2008/12/30 21:45:42 | 00,038,496 | ---- | C] (Malwarebytes Corporation) -- C:\Windows\System32\drivers\mbamswissarmy.sys
[2008/12/30 21:45:40 | 00,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
[2008/12/28 20:18:50 | 00,000,000 | ---D | C] -- C:\Users\Angel\Documents\Oberon Media
[2008/12/28 15:31:09 | 00,000,000 | ---D | C] -- C:\scscc20
[2008/12/26 16:19:53 | 00,000,000 | ---D | C] -- C:\ProgramData\TEMP
@Alternate Data Stream - 104 bytes -> C:\ProgramData\TEMP:DFC5A2B2
[2008/12/23 23:14:57 | 21,374,48448 | -HS- | C] () -- C:\hiberfil.sys
[2008/12/23 00:53:37 | 00,000,000 | ---D | C] -- C:\ProgramData\Spybot - Search & Destroy
[2008/12/23 00:53:37 | 00,000,000 | ---D | C] -- C:\Program Files\Spybot - Search & Destroy
[2008/12/22 23:40:10 | 00,001,670 | ---- | C] () -- C:\Users\Angel\Desktop\CCleaner.lnk
[2008/12/22 23:40:09 | 00,000,000 | ---D | C] -- C:\Program Files\CCleaner
[2008/12/22 23:39:02 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Malwarebytes
[2008/12/22 23:38:58 | 00,000,000 | ---D | C] -- C:\ProgramData\Malwarebytes
[2008/12/22 23:19:05 | 00,000,000 | ---D | C] -- C:\Windows\Intuit
[2008/12/22 22:31:42 | 00,000,000 | ---D | C] -- C:\Program Files\Trend Micro
[2008/12/17 11:55:51 | 00,001,637 | ---- | C] () -- C:\Users\Angel\Desktop\Paint.lnk
[2008/12/15 21:29:08 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Symantec
[2008/12/15 21:13:10 | 00,023,888 | ---- | C] (Symantec Corporation) -- C:\Windows\System32\drivers\COH_Mon.sys
[2008/12/15 21:13:10 | 00,010,537 | ---- | C] () -- C:\Windows\System32\drivers\COH_Mon.cat
[2008/12/15 21:13:10 | 00,000,706 | ---- | C] () -- C:\Windows\System32\drivers\COH_Mon.inf
[2008/12/15 21:11:52 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Corel
[2008/12/15 21:01:01 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Adobe
[2008/12/15 21:01:01 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Local\Adobe
[2008/12/15 20:50:54 | 00,000,000 | ---D | C] -- C:\Users\Public\Documents\Symantec
[2008/12/15 20:46:07 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Mozilla
[2008/12/15 20:46:07 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Local\Mozilla
[2008/12/15 20:45:54 | 00,001,724 | ---- | C] () -- C:\Users\Public\Desktop\Mozilla Firefox.lnk
[2008/12/15 20:45:44 | 00,000,000 | ---D | C] -- C:\Program Files\Mozilla Firefox
[2008/12/15 20:45:08 | 00,186,256 | ---- | C] (Symantec Corporation) -- C:\Windows\System32\SymNPPWA.dll
[2008/12/15 20:44:17 | 00,000,000 | ---D | C] -- C:\Windows\System32\DRVSTORE
[2008/12/15 20:44:17 | 00,000,000 | ---D | C] -- C:\ProgramData\{3276BE95_AF08_429F_A64F_CA64CB79BCF6}
[2008/12/15 20:28:07 | 00,000,016 | ---- | C] () -- C:\Windows\System32\coh.cache
[2008/12/14 22:37:39 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Local\AOL
[2008/12/14 22:32:08 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Macromedia
[2008/12/14 22:31:59 | 00,072,632 | ---- | C] () -- C:\Users\Angel\AppData\Local\GDIPFONTCACHEV1.DAT
[2008/12/14 22:31:41 | 00,000,432 | -HS- | C] () -- C:\Users\Angel\Desktop\desktop.ini
[2008/12/14 22:31:41 | 00,000,402 | -HS- | C] () -- C:\Users\Angel\Documents\desktop.ini
[2008/12/14 22:31:41 | 00,000,174 | -HS- | C] () -- C:\Users\Angel\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\desktop.ini
[2008/12/14 22:31:38 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Identities
[2008/12/14 22:31:35 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Local\VirtualStore
[2008/12/14 22:28:44 | 00,000,000 | -HSD | C] -- C:\Users\Angel\Documents\My Videos
[2008/12/14 22:28:44 | 00,000,000 | -HSD | C] -- C:\Users\Angel\Documents\My Pictures
[2008/12/14 22:28:44 | 00,000,000 | -HSD | C] -- C:\Users\Angel\Documents\My Music
[2008/12/14 22:28:44 | 00,000,000 | -HSD | C] -- C:\Users\Angel\AppData\Local\Temporary Internet Files
[2008/12/14 22:28:44 | 00,000,000 | -HSD | C] -- C:\Users\Angel\AppData\Local\History
[2008/12/14 22:28:44 | 00,000,000 | -HSD | C] -- C:\Users\Angel\AppData\Local\Application Data
[2008/12/14 22:28:40 | 00,000,000 | --SD | C] -- C:\Users\Angel\AppData\Roaming\Microsoft
[2008/12/14 22:28:40 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Roaming\Media Center Programs
[2008/12/14 22:28:40 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Local\Temp
[2008/12/14 22:28:40 | 00,000,000 | ---D | C] -- C:\Users\Angel\AppData\Local\Microsoft
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\Users\Public\Documents\My Videos
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\Users\Public\Documents\My Pictures
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\Users\Public\Documents\My Music
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\ProgramData\Templates
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\ProgramData\Start Menu
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\ProgramData\Favorites
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\ProgramData\Documents
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\ProgramData\Desktop
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\ProgramData\Application Data
[2008/12/14 22:24:39 | 00,000,000 | -HSD | C] -- C:\Documents and Settings
[2008/12/14 21:18:41 | 00,000,040 | -H-- | C] () -- C:\Windows\System32\ivireg.ivr
[2008/12/14 21:08:55 | 00,001,754 | ---- | C] () -- C:\Users\Public\Desktop\Norton 360.lnk
[2008/12/14 21:06:54 | 00,000,000 | ---D | C] -- C:\Program Files\Norton 360
[2008/12/14 21:06:39 | 00,124,464 | ---- | C] (Symantec Corporation) -- C:\Windows\System32\drivers\SYMEVENT.SYS
[2008/12/14 21:06:39 | 00,010,635 | ---- | C] () -- C:\Windows\System32\drivers\SYMEVENT.CAT
[2008/12/14 21:06:39 | 00,000,806 | ---- | C] () -- C:\Windows\System32\drivers\SYMEVENT.INF
[2008/12/14 21:05:56 | 00,511,328 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\capicom.dll
[2008/12/14 21:05:50 | 00,000,000 | ---D | C] -- C:\ProgramData\Symantec
[2008/12/14 21:05:50 | 00,000,000 | ---D | C] -- C:\Program Files\Symantec
[2008/12/14 21:05:36 | 00,000,000 | ---D | C] -- C:\Program Files\Common Files\Symantec Shared
[2008/12/14 20:55:51 | 00,000,000 | ---D | C] -- C:\Program Files\Common Files\InterVideo
[2008/12/14 20:55:16 | 00,000,000 | ---D | C] -- C:\Program Files\InterVideo
[2008/12/14 20:54:33 | 00,255,848 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xactengine2_6.dll
[2008/12/14 20:54:33 | 00,251,672 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xactengine2_5.dll
[2008/12/14 20:54:32 | 03,426,072 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_32.dll
[2008/12/14 20:54:32 | 00,440,080 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx10.dll
[2008/12/14 20:54:31 | 00,237,848 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xactengine2_4.dll
[2008/12/14 20:54:31 | 00,068,888 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xinput1_3.dll
[2008/12/14 20:54:31 | 00,015,128 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\x3daudio1_1.dll
[2008/12/14 20:54:30 | 02,414,360 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_31.dll
[2008/12/14 20:54:30 | 00,236,824 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xactengine2_3.dll
[2008/12/14 20:54:30 | 00,062,744 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xinput1_2.dll
[2008/12/14 20:54:29 | 00,230,168 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xactengine2_2.dll
[2008/12/14 20:54:29 | 00,062,672 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xinput1_1.dll
[2008/12/14 20:54:28 | 00,229,584 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xactengine2_1.dll
[2008/12/14 20:54:16 | 02,388,176 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_30.dll
[2008/12/14 20:54:14 | 00,230,096 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\xactengine2_0.dll
[2008/12/14 20:54:14 | 00,014,032 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\x3daudio1_0.dll
[2008/12/14 20:54:13 | 02,332,368 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_29.dll
[2008/12/14 20:54:12 | 02,323,664 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_28.dll
[2008/12/14 20:54:11 | 02,319,568 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_27.dll
[2008/12/14 20:54:10 | 02,337,488 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_25.dll
[2008/12/14 20:54:10 | 02,297,552 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_26.dll
[2008/12/14 20:54:08 | 02,222,800 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\d3dx9_24.dll
[2008/12/14 20:50:28 | 00,132,608 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\drivers\usbvideo.sys
[2008/12/14 20:47:32 | 00,000,000 | RH-- | C] () -- C:\Windows\System32\drivers\Sony_VGN-FZ240E.mrk
[2008/12/14 20:46:01 | 00,000,000 | ---D | C] -- C:\ProgramData\Corel
[2008/12/14 20:45:39 | 00,000,000 | ---D | C] -- C:\Program Files\Corel
[2008/12/14 20:45:39 | 00,000,000 | ---D | C] -- C:\Program Files\Common Files\Corel
[2008/12/14 20:45:38 | 01,132,112 | ---- | C] () -- C:\ProgramData\pswi_preloaded.exe
[2008/12/14 20:44:24 | 00,002,152 | ---- | C] () -- C:\Users\Public\Desktop\Microsoft Office - 60 Day Trial.lnk
[2008/12/14 20:44:24 | 00,000,000 | ---D | C] -- C:\ProgramData\{174892B1-CBE7-44F5-86FF-AB555EFD73A3}
[2008/12/14 20:44:21 | 00,000,000 | ---D | C] -- C:\Program Files\Activation Assistant for the 2007 Microsoft Office suites
[2008/12/14 20:43:56 | 00,032,592 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\msonpmon.dll
[2008/12/14 20:43:15 | 00,000,000 | ---D | C] -- C:\Program Files\Common Files\DESIGNER
AARG12
OS : Windows Vista
Post by AARG12 on Tue Jan 13, 2009 11:02 pm
[2008/12/14 20:43:02 | 00,000,000 | ---D | C] -- C:\Windows\PCHEALTH
[2008/12/14 20:43:02 | 00,000,000 | ---D | C] -- C:\Program Files\Microsoft.NET
[2008/12/14 20:41:46 | 00,000,000 | ---D | C] -- C:\ProgramData\Microsoft Help
[2008/12/14 20:41:13 | 00,000,000 | RH-D | C] -- C:\MSOCache
[2008/12/14 20:38:41 | 00,000,000 | ---D | C] -- C:\Program Files\ArcSoft
[2008/12/14 20:37:10 | 00,000,067 | -H-- | C] () -- C:\kernel.pam
[2008/12/14 20:37:10 | 00,000,017 | -H-- | C] () -- C:\initrd.pam
[2008/12/14 20:37:10 | 00,000,000 | -H-D | C] -- C:\InstantON
[2008/12/14 20:32:47 | 00,000,000 | ---D | C] -- C:\Program Files\Common Files\supportsoft
[2008/12/14 20:32:46 | 01,933,312 | ---- | C] (Amyuni Technologies
[You must be registered and logged in to see this link.] -- C:\Windows\System32\cdintf251.dll
[2008/12/14 20:30:53 | 00,000,000 | ---D | C] -- C:\ProgramData\Intuit
[2008/12/14 20:30:53 | 00,000,000 | ---D | C] -- C:\Program Files\Intuit
[2008/12/14 20:30:53 | 00,000,000 | ---D | C] -- C:\Program Files\Common Files\Intuit
[2008/12/14 20:30:44 | 00,000,000 | ---D | C] -- C:\ProgramData\COMMON FILES
[2008/12/14 20:29:01 | 00,000,000 | ---D | C] -- C:\Windows\System32\URTTEMP
[2008/12/14 20:27:43 | 00,000,000 | ---D | C] -- C:\Program Files\Common Files\AOL
[2008/12/14 20:27:43 | 00,000,000 | ---D | C] -- C:\Program Files\AOL
[2008/12/14 20:27:40 | 00,000,347 | -H-- | C] () -- C:\IPH.PH
[2008/12/14 20:27:24 | 00,000,000 | ---D | C] -- C:\Program Files\Online Services
[2008/12/14 20:26:19 | 00,140,914 | ---- | C] () -- C:\Windows\System32\drivers\SnyHDAN.cty
[2008/12/14 20:26:13 | 00,001,658 | ---- | C] () -- C:\Users\Public\Desktop\Microsoft Works.lnk
[2008/12/14 20:24:29 | 00,000,000 | ---D | C] -- C:\Program Files\Microsoft Office
[2008/12/14 20:22:54 | 00,000,000 | ---D | C] -- C:\Program Files\Microsoft Works
[2008/12/14 20:17:53 | 00,000,000 | ---D | C] -- C:\Windows\SoftwareDistribution
[2008/12/14 20:15:48 | 00,000,000 | -HSD | C] -- C:\System Volume Information
[2009/01/13 14:22:50 | 00,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2009/01/13 14:22:50 | 00,003,072 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
[2009/01/13 14:22:50 | 00,003,072 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
[2009/01/12 13:20:41 | 00,729,436 | ---- | M] () -- C:\Windows\System32\PerfStringBackup.INI
[2009/01/12 13:20:41 | 00,626,976 | ---- | M] () -- C:\Windows\System32\perfh009.dat
[2009/01/12 13:20:41 | 00,107,714 | ---- | M] () -- C:\Windows\System32\perfc009.dat
[2009/01/12 13:14:12 | 00,000,006 | -H-- | M] () -- C:\Windows\tasks\SA.DAT
[2009/01/12 13:13:59 | 21,374,48448 | -HS- | M] () -- C:\hiberfil.sys
[2009/01/12 01:17:40 | 00,000,012 | ---- | M] () -- C:\Windows\bthservsdp.dat
[2009/01/12 01:17:17 | 01,963,676 | -H-- | M] () -- C:\Users\Angel\AppData\Local\IconCache.db
[2009/01/11 23:57:44 | 00,053,248 | ---- | M] (Sysinternals) -- C:\Windows\PSEXESVC.EXE
[2009/01/11 23:55:23 | 00,000,215 | ---- | M] () -- C:\Windows\system.ini
[2009/01/11 21:00:04 | 00,268,800 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\es.dll
[2009/01/11 20:10:44 | 00,000,502 | ---- | M] () -- C:\Users\Angel\Desktop\fix.reg
[2009/01/11 18:11:48 | 00,000,691 | ---- | M] () -- C:\Users\Angel\AppData\Roaming\GetValue.vbs
[2009/01/11 18:11:48 | 00,000,035 | ---- | M] () -- C:\Users\Angel\AppData\Roaming\SetValue.bat
[2009/01/11 18:11:42 | 00,290,752 | ---- | M] () -- C:\Windows\System32\drivers\etc\hosts
[2009/01/11 14:08:22 | 00,001,085 | ---- | M] () -- C:\Users\Angel\Desktop\Spybot - Search & Destroy.lnk
[2009/01/10 00:30:04 | 00,000,280 | -HS- | M] () -- C:\Users\Public\Documents\desktop.ini
[2009/01/10 00:30:04 | 00,000,174 | -HS- | M] () -- C:\Users\Public\Desktop\desktop.ini
[2009/01/10 00:30:04 | 00,000,174 | -HS- | M] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\desktop.ini
[2009/01/10 00:25:45 | 00,301,416 | ---- | M] () -- C:\Windows\System32\FNTCACHE.DAT
[2009/01/09 23:11:33 | 00,361,984 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\IPSECSVC.DLL
[2009/01/09 23:11:33 | 00,272,896 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\polstore.dll
[2009/01/09 23:11:33 | 00,061,440 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\winipsec.dll
[2009/01/09 23:11:33 | 00,028,672 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\FwRemoteSvr.dll
[2009/01/09 23:10:50 | 00,467,456 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\riched20.dll
[2009/01/09 23:10:50 | 00,008,192 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\riched32.dll
[2009/01/09 23:10:48 | 00,048,640 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\ndproxy.sys
[2009/01/09 23:10:48 | 00,038,400 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\kmddsp.tsp
[2009/01/09 23:10:48 | 00,020,480 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\ndistapi.sys
[2009/01/09 23:10:47 | 00,564,736 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msftedit.dll
[2009/01/09 23:10:47 | 00,384,000 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\netcfgx.dll
[2009/01/09 23:10:47 | 00,077,824 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\rascfg.dll
[2009/01/09 23:10:47 | 00,061,952 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\wanarp.sys
[2009/01/09 23:10:47 | 00,052,736 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\rasdiag.dll
[2009/01/09 23:10:47 | 00,049,664 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ndptsp.tsp
[2009/01/09 23:10:47 | 00,032,768 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\rasmxs.dll
[2009/01/09 23:10:47 | 00,022,016 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\rasser.dll
[2009/01/09 23:10:47 | 00,001,820 | ---- | M] () -- C:\Windows\System32\rasctrnm.h
[2009/01/09 23:10:46 | 00,286,208 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ipnathlp.dll
[2009/01/09 23:10:46 | 00,013,824 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\icsunattend.exe
[2009/01/09 23:10:45 | 00,694,784 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\localspl.dll
[2009/01/09 23:10:45 | 00,619,008 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\dxgkrnl.sys
[2009/01/09 23:10:45 | 00,070,144 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\pacer.sys
[2009/01/09 23:10:45 | 00,033,280 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\traffic.dll
[2009/01/09 23:10:45 | 00,015,360 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\pacerprf.dll
[2009/01/09 23:10:45 | 00,013,824 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wshqos.dll
[2009/01/09 23:10:44 | 00,134,656 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dps.dll
[2009/01/09 23:10:44 | 00,036,864 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\cdd.dll
[2009/01/09 23:10:02 | 00,241,152 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\PortableDeviceApi.dll
[2009/01/09 23:10:02 | 00,160,768 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\PortableDeviceTypes.dll
[2009/01/09 23:10:02 | 00,095,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\PortableDeviceClassExtension.dll
[2009/01/09 23:09:25 | 00,704,000 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\PhotoScreensaver.scr
[2009/01/09 23:09:23 | 00,024,064 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wtsapi32.dll
[2009/01/09 23:09:22 | 00,258,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\acpi.sys
[2009/01/09 23:09:22 | 00,020,920 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\compbatt.sys
[2009/01/09 23:09:21 | 00,028,344 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\battc.sys
[2009/01/09 23:09:21 | 00,014,208 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\CmBatt.sys
[2009/01/09 23:09:20 | 00,542,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\sysmain.dll
[2009/01/09 23:09:19 | 01,655,289 | ---- | M] () -- C:\Windows\System32\wlan.tmf
AARG12
OS : Windows Vista
[2009/01/09 23:09:19 | 00,714,240 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\timedate.cpl
[2009/01/09 23:09:19 | 00,290,816 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wlanmsm.dll
[2009/01/09 23:09:19 | 00,067,584 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wlanhlp.dll
[2009/01/09 23:09:19 | 00,047,104 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wlanapi.dll
[2009/01/09 23:09:18 | 00,502,784 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wlansvc.dll
[2009/01/09 23:09:18 | 00,297,984 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wlansec.dll
[2009/01/09 23:08:09 | 00,194,560 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\WebClnt.dll
[2009/01/09 23:08:09 | 00,110,080 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\mrxdav.sys
[2009/01/09 23:06:38 | 01,244,672 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mcmde.dll
[2009/01/09 23:06:37 | 00,428,032 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\EncDec.dll
[2009/01/09 23:06:37 | 00,292,352 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\psisdecd.dll
[2009/01/09 23:06:37 | 00,217,088 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\psisrndr.ax
[2009/01/09 23:06:37 | 00,177,152 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mpg2splt.ax
[2009/01/09 23:06:37 | 00,080,896 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\MSNP.ax
[2009/01/09 23:06:37 | 00,068,608 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\Mpeg2Data.ax
[2009/01/09 23:06:37 | 00,057,856 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\MSDvbNP.ax
[2009/01/09 23:05:13 | 00,297,472 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\gdi32.dll
[2009/01/09 23:04:39 | 01,060,920 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\ntfs.sys
[2009/01/09 23:04:39 | 00,041,984 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\monitor.sys
[2009/01/09 23:01:27 | 03,593,216 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mshtml.dll
[2009/01/09 23:01:27 | 01,383,424 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mshtml.tlb
[2009/01/09 23:00:40 | 00,211,456 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\mrxsmb10.sys
[2009/01/09 23:00:09 | 00,374,456 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mcupdate_GenuineIntel.dll
[2009/01/09 22:59:31 | 00,028,672 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\Apphlpdm.dll
[2009/01/09 22:59:28 | 04,247,552 | ---- | M] (Microsoft) -- C:\Windows\System32\GameUXLegacyGDFs.dll
[2009/01/09 22:59:28 | 01,687,040 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\gameux.dll
[2009/01/09 22:58:50 | 00,303,616 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wmpeffects.dll
[2009/01/09 22:58:18 | 02,027,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\win32k.sys
[2009/01/09 22:57:47 | 01,194,496 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msxml3.dll
[2009/01/09 22:57:47 | 00,002,048 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msxml3r.dll
[2009/01/09 22:57:10 | 08,147,968 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wmploc.DLL
[2009/01/09 22:57:09 | 10,617,344 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wmp.dll
[2009/01/09 22:57:09 | 00,007,680 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\spwmp.dll
[2009/01/09 22:57:08 | 00,356,864 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\MediaMetadataHandler.dll
[2009/01/09 22:57:08 | 00,004,096 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msdxm.ocx
[2009/01/09 22:57:08 | 00,004,096 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dxmasf.dll
[2009/01/09 22:56:35 | 00,396,800 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\MPSSVC.dll
[2009/01/09 22:56:35 | 00,392,192 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\FirewallAPI.dll
[2009/01/09 22:56:35 | 00,063,488 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\mpsdrv.sys
[2009/01/09 22:56:34 | 00,178,688 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\iphlpsvc.dll
[2009/01/09 22:56:34 | 00,086,016 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\icfupgd.dll
[2009/01/09 22:56:34 | 00,061,952 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\cmifw.dll
[2009/01/09 22:56:34 | 00,023,040 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\tunnel.sys
[2009/01/09 22:56:34 | 00,016,896 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wfapigp.dll
[2009/01/09 22:56:34 | 00,015,360 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\TUNMP.SYS
[2009/01/09 22:56:05 | 00,425,472 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\netapi32.dll
[2009/01/09 22:55:32 | 00,002,048 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\tzres.dll
[2009/01/09 22:54:15 | 11,315,712 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\shell32.dll
[2009/01/09 22:51:45 | 00,021,560 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\atapi.sys
[2009/01/09 22:51:44 | 00,211,000 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\volsnap.sys
[2009/01/09 22:51:44 | 00,109,624 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\ataport.sys
[2009/01/09 22:51:44 | 00,045,112 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\pciidex.sys
[2009/01/09 22:51:44 | 00,017,464 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\intelide.sys
[2009/01/09 22:51:43 | 00,154,624 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\nwifi.sys
[2009/01/09 22:51:17 | 02,923,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\explorer.exe
[2009/01/09 22:49:25 | 00,383,488 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ieapfltr.dll
[2009/01/09 22:49:25 | 00,124,928 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\advpack.dll
[2009/01/09 22:49:24 | 00,826,368 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wininet.dll
[2009/01/09 22:49:24 | 00,027,648 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\jsproxy.dll
[2009/01/09 22:49:23 | 00,347,136 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dxtmsft.dll
[2009/01/09 22:49:23 | 00,214,528 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dxtrans.dll
[2009/01/09 22:49:22 | 06,066,176 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ieframe.dll
[2009/01/09 22:49:22 | 00,180,736 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ieui.dll
[2009/01/09 22:49:20 | 00,477,696 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mshtmled.dll
[2009/01/09 22:49:18 | 00,671,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mstime.dll
[2009/01/09 22:49:17 | 01,831,424 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\inetcpl.cpl
[2009/01/09 22:49:17 | 00,063,488 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\icardie.dll
[2009/01/09 22:49:16 | 00,026,624 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ieUnatt.exe
[2009/01/09 22:49:15 | 01,160,192 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\urlmon.dll
[2009/01/09 22:49:15 | 00,044,544 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\pngfilt.dll
[2009/01/09 22:49:14 | 00,267,776 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\iertutil.dll
[2009/01/09 22:49:14 | 00,070,656 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ie4uinit.exe
[2009/01/09 22:49:14 | 00,056,320 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\iesetup.dll
[2009/01/09 22:49:14 | 00,044,544 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\iernonce.dll
[2009/01/09 22:48:22 | 00,803,328 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\tcpip.sys
[2009/01/09 22:48:22 | 00,216,632 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\netio.sys
[2009/01/09 22:48:22 | 00,167,424 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\tcpipcfg.dll
[2009/01/09 22:48:22 | 00,024,064 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\netcfg.exe
[2009/01/09 22:48:22 | 00,022,016 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\netiougc.exe
AARG12
OS : Windows Vista
Post by AARG12 on Tue Jan 13, 2009 11:03 pm
[2009/01/09 22:47:04 | 01,808,896 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0046.dll
[2009/01/09 22:47:04 | 01,793,536 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0045.dll
[2009/01/09 22:47:04 | 01,558,016 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0049.dll
[2009/01/09 22:47:04 | 01,411,072 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0047.dll
[2009/01/09 22:47:04 | 01,236,992 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0020.dll
[2009/01/09 22:47:03 | 05,499,904 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0022.dll
[2009/01/09 22:47:03 | 02,136,064 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0021.dll
[2009/01/09 22:47:03 | 01,782,272 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0039.dll
[2009/01/09 22:47:02 | 07,964,672 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0024.dll
[2009/01/09 22:47:01 | 06,224,896 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0027.dll
[2009/01/09 22:47:01 | 05,791,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0026.dll
[2009/01/09 22:47:00 | 04,175,872 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0010.dll
[2009/01/09 22:46:59 | 04,981,248 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0013.dll
[2009/01/09 22:46:59 | 02,466,816 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0011.dll
[2009/01/09 22:46:58 | 06,781,440 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0019.dll
[2009/01/09 22:46:58 | 03,331,072 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0018.dll
[2009/01/09 22:46:57 | 11,722,752 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0001.dll
[2009/01/09 22:46:56 | 04,164,096 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0002.dll
[2009/01/09 22:46:55 | 12,240,896 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0007.dll
[2009/01/09 22:46:55 | 02,644,480 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0009.dll
[2009/01/09 22:46:55 | 01,452,544 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0003.dll
[2009/01/09 22:46:54 | 04,093,440 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons004c.dll
[2009/01/09 22:46:54 | 03,419,136 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons004a.dll
[2009/01/09 22:46:54 | 01,702,912 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons004b.dll
[2009/01/09 22:46:53 | 04,045,824 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons003e.dll
[2009/01/09 22:46:53 | 01,972,736 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons004e.dll
[2009/01/09 22:46:52 | 06,585,856 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons001b.dll
[2009/01/09 22:46:52 | 06,014,976 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons001a.dll
[2009/01/09 22:46:52 | 00,004,096 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons002a.dll
[2009/01/09 22:46:51 | 09,892,864 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons000a.dll
[2009/01/09 22:46:51 | 06,346,240 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons001d.dll
[2009/01/09 22:46:50 | 06,237,696 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons000c.dll
[2009/01/09 22:46:50 | 01,722,368 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons000d.dll
[2009/01/09 22:46:49 | 05,654,528 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons000f.dll
[2009/01/09 22:46:48 | 05,090,816 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0416.dll
[2009/01/09 22:46:48 | 04,616,192 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0414.dll
[2009/01/09 22:46:47 | 07,042,560 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons081a.dll
[2009/01/09 22:46:47 | 05,071,872 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsModels0011.dll
[2009/01/09 22:46:47 | 05,031,936 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0816.dll
[2009/01/09 22:46:46 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0047.dll
[2009/01/09 22:46:46 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0046.dll
[2009/01/09 22:46:46 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0045.dll
[2009/01/09 22:46:45 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0049.dll
[2009/01/09 22:46:45 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0039.dll
[2009/01/09 22:46:45 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0020.dll
[2009/01/09 22:46:44 | 01,965,056 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0027.dll
[2009/01/09 22:46:44 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0026.dll
[2009/01/09 22:46:44 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0024.dll
[2009/01/09 22:46:44 | 01,799,168 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0022.dll
[2009/01/09 22:46:44 | 01,799,168 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0021.dll
[2009/01/09 22:46:43 | 04,493,312 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0010.dll
[2009/01/09 22:46:43 | 02,655,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0011.dll
[2009/01/09 22:46:42 | 04,495,360 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0019.dll
[2009/01/09 22:46:42 | 03,464,704 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0013.dll
[2009/01/09 22:46:42 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0018.dll
[2009/01/09 22:46:42 | 01,523,200 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0000.dll
[2009/01/09 22:46:41 | 02,597,888 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0001.dll
[2009/01/09 22:46:41 | 02,241,024 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0007.dll
[2009/01/09 22:46:41 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0003.dll
[2009/01/09 22:46:41 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0002.dll
[2009/01/09 22:46:40 | 04,874,240 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0009.dll
[2009/01/09 22:46:40 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData004a.dll
[2009/01/09 22:46:39 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData004e.dll
[2009/01/09 22:46:39 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData004c.dll
[2009/01/09 22:46:39 | 03,102,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData004b.dll
[2009/01/09 22:46:38 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData001b.dll
[2009/01/09 22:46:38 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData001a.dll
[2009/01/09 22:46:38 | 01,799,168 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData003e.dll
[2009/01/09 22:46:38 | 01,799,168 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData002a.dll
[2009/01/09 22:46:37 | 09,845,248 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData000a.dll
[2009/01/09 22:46:37 | 04,493,312 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData001d.dll
[2009/01/09 22:46:36 | 02,641,408 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData000c.dll
[2009/01/09 22:46:36 | 02,340,864 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData000d.dll
[2009/01/09 22:46:35 | 04,493,312 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0416.dll
[2009/01/09 22:46:35 | 04,493,312 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0414.dll
[2009/01/09 22:46:35 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData000f.dll
[2009/01/09 22:46:34 | 04,493,312 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0816.dll
[2009/01/09 22:46:34 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData081a.dll
[2009/01/09 22:46:34 | 00,797,696 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NaturalLanguage6.dll
[2009/01/09 22:46:33 | 06,917,120 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsLexicons0c1a.dll
[2009/01/09 22:46:33 | 01,963,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\NlsData0c1a.dll
[2009/01/09 22:44:00 | 01,585,664 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\setupapi.dll
[2009/01/09 22:43:36 | 00,010,752 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\en-US\i8042prt.sys.mui
[2009/01/09 22:43:36 | 00,005,632 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\en-US\sermouse.sys.mui
[2009/01/09 22:43:36 | 00,004,608 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\en-US\mouclass.sys.mui
[2009/01/09 22:43:36 | 00,004,608 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\en-US\kbdclass.sys.mui
[2009/01/09 22:43:36 | 00,003,072 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\en-US\mouhid.sys.mui
[2009/01/09 22:43:36 | 00,003,072 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\en-US\kbdhid.sys.mui
[2009/01/09 22:43:34 | 00,905,400 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\winresume.exe
[2009/01/09 22:43:34 | 00,613,888 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wpd_ci.dll
[2009/01/09 22:43:34 | 00,371,712 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\srcore.dll
[2009/01/09 22:43:34 | 00,313,856 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\rstrui.exe
[2009/01/09 22:43:34 | 00,040,960 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\srclient.dll
[2009/01/09 22:43:34 | 00,019,000 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\kd1394.dll
[2009/01/09 22:43:34 | 00,016,384 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\srdelayed.exe
[2009/01/09 22:43:33 | 00,944,184 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\winload.exe
AARG12
OS : Windows Vista
Post by AARG12 on Tue Jan 13, 2009 11:04 pm
[2009/01/09 22:43:33 | 00,620,088 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ci.dll
[2009/01/09 22:43:33 | 00,224,824 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\clfs.sys
[2009/01/09 22:43:33 | 00,101,888 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drvinst.exe
[2009/01/09 22:43:33 | 00,019,456 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\cfgmgr32.dll
[2009/01/09 22:43:32 | 00,558,080 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\oleaut32.dll
[2009/01/09 22:43:32 | 00,260,096 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dpx.dll
[2009/01/09 22:43:32 | 00,221,696 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\umpnpmgr.dll
[2009/01/09 22:43:32 | 00,023,552 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\nshhttp.dll
[2009/01/09 22:43:32 | 00,006,656 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\kbd106n.dll
[2009/01/09 22:43:31 | 00,115,200 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\loadperf.dll
[2009/01/09 22:43:31 | 00,039,424 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\lodctr.exe
[2009/01/09 22:43:31 | 00,032,256 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\unlodctr.exe
[2009/01/09 22:43:31 | 00,017,408 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\prflbmsg.dll
[2009/01/09 22:43:30 | 00,595,456 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\schedsvc.dll
[2009/01/09 22:43:30 | 00,495,160 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\Wdf01000.sys
[2009/01/09 22:43:30 | 00,035,384 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\WdfLdr.sys
[2009/01/09 22:43:30 | 00,035,328 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dispci.dll
[2009/01/09 22:43:30 | 00,012,800 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\batt.dll
[2009/01/09 22:43:30 | 00,007,168 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\f3ahvoas.dll
[2009/01/09 22:43:29 | 00,054,784 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\i8042prt.sys
[2009/01/09 22:43:29 | 00,035,384 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\kbdclass.sys
[2009/01/09 22:43:29 | 00,034,360 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\mouclass.sys
[2009/01/09 22:43:29 | 00,019,968 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\sermouse.sys
[2009/01/09 22:42:05 | 00,223,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\WMASF.DLL
[2009/01/09 22:42:05 | 00,009,728 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\LAPRXY.DLL
[2009/01/09 22:42:05 | 00,002,048 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\asferror.dll
[2009/01/09 22:41:52 | 00,290,304 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\srv.sys
[2009/01/09 22:41:34 | 00,268,288 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mcbuilder.exe
[2009/01/09 22:41:34 | 00,223,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\SLC.dll
[2009/01/09 22:41:34 | 00,033,280 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\slwmi.dll
[2009/01/09 22:41:33 | 00,566,784 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\SLCommDlg.dll
[2009/01/09 22:41:33 | 00,351,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\SLUI.exe
[2009/01/09 22:41:33 | 00,186,368 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\SLLUA.exe
[2009/01/09 22:41:32 | 00,057,856 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\SLUINotify.dll
[2009/01/09 22:41:31 | 02,605,568 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\SLsvc.exe
[2009/01/09 22:41:31 | 00,039,936 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\slcinst.dll
[2009/01/09 22:41:08 | 00,712,192 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\WindowsCodecs.dll
[2009/01/09 22:41:08 | 00,425,472 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\PhotoMetadataHandler.dll
[2009/01/09 22:41:07 | 00,347,136 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\WindowsCodecsExt.dll
[2009/01/09 22:40:04 | 00,269,824 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\schannel.dll
[2009/01/09 22:40:04 | 00,061,440 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ntprint.exe
[2009/01/09 22:40:03 | 00,220,160 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ntprint.dll
[2009/01/09 22:40:02 | 00,010,240 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dhcpcmonitor.dll
[2009/01/09 22:40:01 | 01,984,512 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\authui.dll
[2009/01/09 22:40:01 | 00,204,800 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dhcpcsvc.dll
[2009/01/09 22:40:01 | 00,120,320 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dhcpcsvc6.dll
[2009/01/09 22:40:00 | 00,123,904 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msvfw32.dll
[2009/01/09 22:40:00 | 00,088,576 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\avifil32.dll
[2009/01/09 22:40:00 | 00,082,944 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mciavi32.dll
[2009/01/09 22:40:00 | 00,065,024 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\avicap32.dll
[2009/01/09 22:39:59 | 00,069,632 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\sendmail.dll
[2009/01/09 22:39:59 | 00,031,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msvidc32.dll
[2009/01/09 22:39:59 | 00,012,800 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msrle32.dll
[2009/01/09 22:39:57 | 08,138,240 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ssBranded.scr
[2009/01/09 22:39:40 | 00,441,856 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\win32spl.dll
[2009/01/09 22:39:40 | 00,037,376 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\printcom.dll
[2009/01/09 22:39:32 | 00,113,664 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\rmcast.sys
[2009/01/09 22:39:32 | 00,014,848 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wshrm.dll
[2009/01/09 22:39:23 | 00,011,776 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\sbunattend.exe
[2009/01/09 22:39:07 | 00,162,816 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dnsapi.dll
[2009/01/09 22:39:07 | 00,083,968 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dnsrslvr.dll
[2009/01/09 22:39:07 | 00,024,576 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\dnscacheugc.exe
[2009/01/09 22:35:25 | 02,855,424 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mf.dll
[2009/01/09 22:35:25 | 00,098,816 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mfps.dll
[2009/01/09 22:35:25 | 00,052,736 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\rrinstaller.exe
[2009/01/09 22:35:25 | 00,024,576 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mfpmp.exe
[2009/01/09 22:35:25 | 00,002,048 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\mferror.dll
[2009/01/09 22:35:24 | 00,996,352 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\WMNetMgr.dll
[2009/01/09 22:35:24 | 00,094,720 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\logagent.exe
[2009/01/09 22:35:23 | 02,433,536 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\WMVCORE.DLL
[2009/01/09 22:35:13 | 00,130,048 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\srv2.sys
[2009/01/09 22:35:13 | 00,101,888 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\mrxsmb.sys
[2009/01/09 22:35:13 | 00,084,992 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\srvnet.sys
[2009/01/09 22:35:13 | 00,058,368 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\mrxsmb20.sys
[2009/01/09 22:35:07 | 00,148,992 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\ks.sys
[2009/01/09 22:35:03 | 00,788,992 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\rpcrt4.dll
AARG12
OS : Windows Vista
[2009/01/09 22:34:16 | 00,737,792 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\inetcomm.dll
[2009/01/09 22:34:16 | 00,084,480 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\INETRES.dll
[2009/01/09 22:34:04 | 01,645,568 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\connect.dll
[2009/01/09 22:33:43 | 01,327,104 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\quartz.dll
[2009/01/09 22:32:45 | 03,505,208 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ntkrnlpa.exe
[2009/01/09 22:32:44 | 03,470,904 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\ntoskrnl.exe
[2009/01/09 22:32:22 | 01,341,440 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msxml6.dll
[2009/01/09 22:32:22 | 00,002,048 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\msxml6r.dll
[2009/01/09 22:31:41 | 00,750,080 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\qmgr.dll
[2009/01/09 22:27:46 | 00,001,724 | ---- | M] () -- C:\Users\Public\Desktop\Mozilla Firefox.lnk
[2009/01/07 20:11:47 | 01,809,944 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wuaueng.dll
[2009/01/07 20:11:47 | 01,524,736 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wucltux.dll
[2009/01/07 20:11:47 | 00,051,224 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wuauclt.exe
[2009/01/07 20:11:47 | 00,043,544 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wups2.dll
[2009/01/07 20:11:18 | 00,561,688 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wuapi.dll
[2009/01/07 20:11:18 | 00,083,456 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wudriver.dll
[2009/01/07 20:11:18 | 00,034,328 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wups.dll
[2009/01/07 20:10:47 | 00,162,064 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wuwebv.dll
[2009/01/07 20:10:47 | 00,031,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\wuapp.exe
[2009/01/06 20:48:06 | 00,001,804 | ---- | M] () -- C:\Users\Public\Desktop\iTunes.lnk
[2009/01/06 20:46:45 | 00,001,726 | ---- | M] () -- C:\Users\Public\Desktop\QuickTime Player.lnk
[2009/01/05 23:52:48 | 00,004,608 | ---- | M] () -- C:\Users\Angel\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2009/01/05 21:32:33 | 00,001,874 | ---- | M] () -- C:\Users\Angel\Desktop\HijackThis.lnk
[2009/01/05 18:18:12 | 00,124,464 | ---- | M] (Symantec Corporation) -- C:\Windows\System32\drivers\SYMEVENT.SYS
[2009/01/05 18:18:12 | 00,010,635 | ---- | M] () -- C:\Windows\System32\drivers\SYMEVENT.CAT
[2009/01/05 18:18:12 | 00,000,806 | ---- | M] () -- C:\Windows\System32\drivers\SYMEVENT.INF
[2009/01/04 18:38:22 | 00,038,496 | ---- | M] (Malwarebytes Corporation) -- C:\Windows\System32\drivers\mbamswissarmy.sys
[2009/01/04 18:38:18 | 00,015,504 | ---- | M] (Malwarebytes Corporation) -- C:\Windows\System32\drivers\mbam.sys
[2009/01/04 18:12:59 | 00,000,540 | ---- | M] () -- C:\Users\Angel\Desktop\ComboFix - Shortcut.lnk
[2009/01/02 15:43:49 | 00,731,136 | ---- | M] () -- C:\Users\Angel\Desktop\avenger.exe
[2008/12/30 23:20:10 | 00,000,258 | RHS- | M] () -- C:\ProgramData\ntuser.pol
[2008/12/30 21:45:44 | 00,000,818 | ---- | M] () -- C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk
[2008/12/22 23:40:10 | 00,001,670 | ---- | M] () -- C:\Users\Angel\Desktop\CCleaner.lnk
[2008/12/22 23:26:37 | 00,072,632 | ---- | M] () -- C:\Users\Angel\AppData\Local\GDIPFONTCACHEV1.DAT
[2008/12/17 11:55:51 | 00,001,637 | ---- | M] () -- C:\Users\Angel\Desktop\Paint.lnk
[2008/12/17 11:55:51 | 00,000,432 | -HS- | M] () -- C:\Users\Angel\Desktop\desktop.ini
[2008/12/15 20:28:10 | 00,000,016 | ---- | M] () -- C:\Windows\System32\coh.cache
[2008/12/14 22:31:41 | 00,000,402 | -HS- | M] () -- C:\Users\Angel\Documents\desktop.ini
[2008/12/14 22:31:41 | 00,000,174 | -HS- | M] () -- C:\Users\Angel\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\desktop.ini
[2008/12/14 21:19:11 | 00,000,000 | RH-- | M] () -- C:\Windows\System32\drivers\Sony_VGN-FZ240E.mrk
[2008/12/14 21:18:43 | 00,000,040 | -H-- | M] () -- C:\Windows\System32\ivireg.ivr
[2008/12/14 21:08:55 | 00,001,754 | ---- | M] () -- C:\Users\Public\Desktop\Norton 360.lnk
[2008/12/14 20:50:28 | 00,132,608 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\drivers\usbvideo.sys
[2008/12/14 20:46:12 | 01,132,112 | ---- | M] () -- C:\ProgramData\pswi_preloaded.exe
[2008/12/14 20:44:24 | 00,002,152 | ---- | M] () -- C:\Users\Public\Desktop\Microsoft Office - 60 Day Trial.lnk
[2008/12/14 20:27:44 | 00,000,347 | -H-- | M] () -- C:\IPH.PH
[2008/12/14 20:26:13 | 00,001,658 | ---- | M] () -- C:\Users\Public\Desktop\Microsoft Works.lnk
AARG12
OS : Windows Vista
jajaj ok finnally dats it
AARG12
OS : Windows Vista
Post by Belahzur on Tue Jan 13, 2009 11:13 pm
Lets try this.
If you still have Combofix, please delete it and download from the link we used before.
DO NOT run it yet.
Now open a new notepad file.
Registry::
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
"DhcpNameServer"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{f3190096-33e1-494f-8233-2fe9ece13e18}]
"DhcpNameServer"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Tcpip\Parameters]
"DhcpNameServer"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Tcpip\Parameters\Interfaces\{f3190096-33e1-494f-8233-2fe9ece13e18}]
"DhcpNameServer"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\Interfaces\{f3190096-33e1-494f-8233-2fe9ece13e18}]
"DhcpNameServer"=-
This will open combofix.exe again, agree to it's terms and allow it to run, it may want to reboot after it's done. Post the resulting log back here.
Post by AARG12 on Wed Jan 14, 2009 6:06 am
ComboFix 09-01-13.03 - Angel 2009-01-13 21:53:28.6 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6000.0.1252.1.1033.18.2038.1027 [GMT -8:00]
Running from: c:\users\Angel\Downloads\ComboFix.exe
Command switches used :: c:\users\Angel\Desktop\CFscript.txt
AV: Norton 360 *On-access scanning disabled* (Outdated)
FW: Norton 360 *enabled*
* Created a new restore point
c:\windows\system32\Agent.OMZ.Fix.exe
((((((((((((((((((((((((( Files Created from 2008-12-14 to 2009-01-14 )))))))))))))))))))))))))))))))
2009-01-11 21:00 . 2009-01-11 21:00 268,800 --a------ c:\windows\System32\es.dll
2009-01-11 18:11 . 2009-01-11 18:11 691 --a------ c:\users\Angel\AppData\Roaming\GetValue.vbs
2009-01-11 18:11 . 2009-01-11 18:11 35 --a------ c:\users\Angel\AppData\Roaming\SetValue.bat
2009-01-09 23:11 . 2009-01-09 23:11 361,984 --a------ c:\windows\System32\IPSECSVC.DLL
2009-01-09 23:11 . 2009-01-09 23:11 272,896 --a------ c:\windows\System32\polstore.dll
2009-01-09 23:11 . 2009-01-09 23:11 61,440 --a------ c:\windows\System32\winipsec.dll
2009-01-09 23:11 . 2009-01-09 23:11 28,672 --a------ c:\windows\System32\FwRemoteSvr.dll
2009-01-09 23:09 . 2009-01-09 23:09 1,655,289 --a------ c:\windows\System32\wlan.tmf
2009-01-09 23:08 . 2009-01-09 23:08 194,560 --a------ c:\windows\System32\WebClnt.dll
2009-01-09 23:08 . 2009-01-09 23:08 110,080 --a------ c:\windows\System32\drivers\mrxdav.sys
2009-01-09 23:06 . 2009-01-09 23:06 1,244,672 --a------ c:\windows\System32\mcmde.dll
2009-01-09 23:06 . 2009-01-09 23:06 428,032 --a------ c:\windows\System32\EncDec.dll
2009-01-09 23:06 . 2009-01-09 23:06 292,352 --a------ c:\windows\System32\psisdecd.dll
2009-01-09 23:06 . 2009-01-09 23:06 217,088 --a------ c:\windows\System32\psisrndr.ax
2009-01-09 23:06 . 2009-01-09 23:06 177,152 --a------ c:\windows\System32\mpg2splt.ax
2009-01-09 23:06 . 2009-01-09 23:06 80,896 --a------ c:\windows\System32\MSNP.ax
2009-01-09 23:06 . 2009-01-09 23:06 68,608 --a------ c:\windows\System32\Mpeg2Data.ax
2009-01-09 23:06 . 2009-01-09 23:06 57,856 --a------ c:\windows\System32\MSDvbNP.ax
2009-01-09 23:05 . 2009-01-09 23:05 297,472 --a------ c:\windows\System32\gdi32.dll
2009-01-09 23:04 . 2009-01-09 23:04 1,060,920 --a------ c:\windows\System32\drivers\ntfs.sys
2009-01-09 23:04 . 2009-01-09 23:04 41,984 --a------ c:\windows\System32\drivers\monitor.sys
2009-01-09 23:01 . 2009-01-09 23:01 1,383,424 --a------ c:\windows\System32\mshtml.tlb
2009-01-09 23:00 . 2009-01-09 23:00 374,456 --a------ c:\windows\System32\mcupdate_GenuineIntel.dll
2009-01-09 23:00 . 2009-01-09 23:00 211,456 --a------ c:\windows\System32\drivers\mrxsmb10.sys
2009-01-09 22:59 . 2009-01-09 22:59 4,247,552 --a------ c:\windows\System32\GameUXLegacyGDFs.dll
2009-01-09 22:59 . 2009-01-09 22:59 1,687,040 --a------ c:\windows\System32\gameux.dll
2009-01-09 22:59 . 2009-01-09 22:59 28,672 --a------ c:\windows\System32\Apphlpdm.dll
2009-01-09 22:58 . 2009-01-09 22:58 2,027,520 --a------ c:\windows\System32\win32k.sys
2009-01-09 22:58 . 2009-01-09 22:58 303,616 --a------ c:\windows\System32\wmpeffects.dll
2009-01-09 22:57 . 2009-01-09 22:57 8,147,968 --a------ c:\windows\System32\wmploc.DLL
2009-01-09 22:57 . 2009-01-09 22:57 1,194,496 --a------ c:\windows\System32\msxml3.dll
2009-01-09 22:57 . 2009-01-09 22:57 356,864 --a------ c:\windows\System32\MediaMetadataHandler.dll
2009-01-09 22:57 . 2009-01-09 22:57 7,680 --a------ c:\windows\System32\spwmp.dll
2009-01-09 22:57 . 2009-01-09 22:57 4,096 --a------ c:\windows\System32\msdxm.ocx
2009-01-09 22:57 . 2009-01-09 22:57 4,096 --a------ c:\windows\System32\dxmasf.dll
2009-01-09 22:57 . 2009-01-09 22:57 2,048 --a------ c:\windows\System32\msxml3r.dll
2009-01-09 22:56 . 2009-01-09 22:56 396,800 --a------ c:\windows\System32\MPSSVC.dll
2009-01-09 22:56 . 2009-01-09 22:56 392,192 --a------ c:\windows\System32\FirewallAPI.dll
2009-01-09 22:56 . 2009-01-09 22:56 178,688 --a------ c:\windows\System32\iphlpsvc.dll
2009-01-09 22:56 . 2009-01-09 22:56 86,016 --a------ c:\windows\System32\icfupgd.dll
2009-01-09 22:56 . 2009-01-09 22:56 63,488 --a------ c:\windows\System32\drivers\mpsdrv.sys
2009-01-09 22:56 . 2009-01-09 22:56 61,952 --a------ c:\windows\System32\cmifw.dll
2009-01-09 22:56 . 2009-01-09 22:56 23,040 --a------ c:\windows\System32\drivers\tunnel.sys
2009-01-09 22:56 . 2009-01-09 22:56 16,896 --a------ c:\windows\System32\wfapigp.dll
2009-01-09 22:56 . 2009-01-09 22:56 15,360 --a------ c:\windows\System32\drivers\TUNMP.SYS
2009-01-09 22:55 . 2009-01-09 22:55 2,048 --a------ c:\windows\System32\tzres.dll
2009-01-09 22:51 . 2009-01-09 22:51 2,923,520 --a------ c:\windows\explorer.exe
2009-01-09 22:51 . 2009-01-09 22:51 211,000 --a------ c:\windows\System32\drivers\volsnap.sys
2009-01-09 22:51 . 2009-01-09 22:51 154,624 --a------ c:\windows\System32\drivers\nwifi.sys
2009-01-09 22:51 . 2009-01-09 22:51 109,624 --a------ c:\windows\System32\drivers\ataport.sys
2009-01-09 22:51 . 2009-01-09 22:51 45,112 --a------ c:\windows\System32\drivers\pciidex.sys
2009-01-09 22:51 . 2009-01-09 22:51 21,560 --a------ c:\windows\System32\drivers\atapi.sys
2009-01-09 22:51 . 2009-01-09 22:51 17,464 --a------ c:\windows\System32\drivers\intelide.sys
2009-01-09 22:48 . 2009-01-09 22:48 803,328 --a------ c:\windows\System32\drivers\tcpip.sys
2009-01-09 22:48 . 2009-01-09 22:48 216,632 --a------ c:\windows\System32\drivers\netio.sys
2009-01-09 22:48 . 2009-01-09 22:48 167,424 --a------ c:\windows\System32\tcpipcfg.dll
2009-01-09 22:48 . 2009-01-09 22:48 24,064 --a------ c:\windows\System32\netcfg.exe
2009-01-09 22:48 . 2009-01-09 22:48 22,016 --a------ c:\windows\System32\netiougc.exe
2009-01-09 22:47 . 2009-01-09 22:47 7,964,672 --a------ c:\windows\System32\NlsLexicons0024.dll
2009-01-09 22:47 . 2009-01-09 22:47 6,224,896 --a------ c:\windows\System32\NlsLexicons0027.dll
2009-01-09 22:47 . 2009-01-09 22:47 5,791,232 --a------ c:\windows\System32\NlsLexicons0026.dll
2009-01-09 22:47 . 2009-01-09 22:47 5,499,904 --a------ c:\windows\System32\NlsLexicons0022.dll
2009-01-09 22:47 . 2009-01-09 22:47 4,175,872 --a------ c:\windows\System32\NlsLexicons0010.dll
2009-01-09 22:47 . 2009-01-09 22:47 2,136,064 --a------ c:\windows\System32\NlsLexicons0021.dll
2009-01-09 22:47 . 2009-01-09 22:47 1,808,896 --a------ c:\windows\System32\NlsLexicons0046.dll
2009-01-09 22:47 . 2009-01-09 22:47 1,793,536 --a------ c:\windows\System32\NlsLexicons0045.dll
2009-01-09 22:47 . 2009-01-09 22:47 1,782,272 --a------ c:\windows\System32\NlsLexicons0039.dll
2009-01-09 22:47 . 2009-01-09 22:47 1,558,016 --a------ c:\windows\System32\NlsLexicons0049.dll
2009-01-09 22:47 . 2009-01-09 22:47 1,411,072 --a------ c:\windows\System32\NlsLexicons0047.dll
2009-01-09 22:47 . 2009-01-09 22:47 1,236,992 --a------ c:\windows\System32\NlsLexicons0020.dll
2009-01-09 22:44 . 2009-01-09 22:44 1,585,664 --a------ c:\windows\System32\setupapi.dll
2009-01-09 22:42 . 2009-01-09 22:42 223,232 --a------ c:\windows\System32\WMASF.DLL
2009-01-09 22:42 . 2009-01-09 22:42 9,728 --a------ c:\windows\System32\LAPRXY.DLL
2009-01-09 22:42 . 2009-01-09 22:42 2,048 --a------ c:\windows\System32\asferror.dll
2009-01-09 22:40 . 2009-01-09 22:40 1,984,512 --a------ c:\windows\System32\authui.dll
2009-01-09 22:40 . 2009-01-09 22:40 269,824 --a------ c:\windows\System32\schannel.dll
2009-01-09 22:40 . 2009-01-09 22:40 220,160 --a------ c:\windows\System32\ntprint.dll
2009-01-09 22:40 . 2009-01-09 22:40 123,904 --a------ c:\windows\System32\msvfw32.dll
2009-01-09 22:40 . 2009-01-09 22:40 120,320 --a------ c:\windows\System32\dhcpcsvc6.dll
2009-01-09 22:40 . 2009-01-09 22:40 88,576 --a------ c:\windows\System32\avifil32.dll
2009-01-09 22:40 . 2009-01-09 22:40 82,944 --a------ c:\windows\System32\mciavi32.dll
2009-01-09 22:40 . 2009-01-09 22:40 65,024 --a------ c:\windows\System32\avicap32.dll
2009-01-09 22:40 . 2009-01-09 22:40 61,440 --a------ c:\windows\System32\ntprint.exe
2009-01-09 22:40 . 2009-01-09 22:40 10,240 --a------ c:\windows\System32\dhcpcmonitor.dll
2009-01-09 22:39 . 2009-01-09 22:39 8,138,240 --a------ c:\windows\System32\ssBranded.scr
2009-01-09 22:39 . 2009-01-09 22:39 441,856 --a------ c:\windows\System32\win32spl.dll
2009-01-09 22:39 . 2009-01-09 22:39 113,664 --a------ c:\windows\System32\drivers\rmcast.sys
2009-01-09 22:39 . 2009-01-09 22:39 83,968 --a------ c:\windows\System32\dnsrslvr.dll
2009-01-09 22:39 . 2009-01-09 22:39 69,632 --a------ c:\windows\System32\sendmail.dll
2009-01-09 22:39 . 2009-01-09 22:39 37,376 --a------ c:\windows\System32\printcom.dll
2009-01-09 22:39 . 2009-01-09 22:39 31,232 --a------ c:\windows\System32\msvidc32.dll
2009-01-09 22:39 . 2009-01-09 22:39 24,576 --a------ c:\windows\System32\dnscacheugc.exe
2009-01-09 22:39 . 2009-01-09 22:39 14,848 --a------ c:\windows\System32\wshrm.dll
2009-01-09 22:39 . 2009-01-09 22:39 12,800 --a------ c:\windows\System32\msrle32.dll
2009-01-09 22:39 . 2009-01-09 22:39 11,776 --a------ c:\windows\System32\sbunattend.exe
2009-01-09 22:34 . 2009-01-09 22:34 1,645,568 --a------ c:\windows\System32\connect.dll
2009-01-09 22:34 . 2009-01-09 22:34 737,792 --a------ c:\windows\System32\inetcomm.dll
2009-01-09 22:34 . 2009-01-09 22:34 84,480 --a------ c:\windows\System32\INETRES.dll
2009-01-09 22:33 . 2009-01-09 22:33 1,327,104 --a------ c:\windows\System32\quartz.dll
2009-01-09 22:32 . 2009-01-09 22:32 3,505,208 --a------ c:\windows\System32\ntkrnlpa.exe
2009-01-09 22:32 . 2009-01-09 22:32 3,470,904 --a------ c:\windows\System32\ntoskrnl.exe
2009-01-09 22:32 . 2009-01-09 22:32 1,341,440 --a------ c:\windows\System32\msxml6.dll
2009-01-09 22:32 . 2009-01-09 22:32 2,048 --a------ c:\windows\System32\msxml6r.dll
2009-01-09 22:31 . 2009-01-09 22:31 750,080 --a------ c:\windows\System32\qmgr.dll
2009-01-07 20:11 . 2009-01-07 20:11 1,809,944 --a------ c:\windows\System32\wuaueng.dll
2009-01-07 20:11 . 2009-01-07 20:11 1,524,736 --a------ c:\windows\System32\wucltux.dll
2009-01-07 20:11 . 2009-01-07 20:11 561,688 --a------ c:\windows\System32\wuapi.dll
2009-01-07 20:11 . 2009-01-07 20:11 83,456 --a------ c:\windows\System32\wudriver.dll
2009-01-07 20:11 . 2009-01-07 20:11 51,224 --a------ c:\windows\System32\wuauclt.exe
2009-01-07 20:11 . 2009-01-07 20:11 43,544 --a------ c:\windows\System32\wups2.dll
2009-01-07 20:11 . 2009-01-07 20:11 34,328 --a------ c:\windows\System32\wups.dll
2009-01-07 20:10 . 2009-01-07 20:10 162,064 --a------ c:\windows\System32\wuwebv.dll
2009-01-07 20:10 . 2009-01-07 20:10 31,232 --a------ c:\windows\System32\wuapp.exe
2009-01-06 20:48 . 2009-01-06 20:48 d-------- c:\users\Angel\AppData\Roaming\Apple Computer
2009-01-06 20:47 . 2009-01-06 20:48 d-------- c:\program files\iTunes
2009-01-06 20:47 . 2009-01-06 20:47 d-------- c:\program files\iPod
2009-01-06 20:47 . 2009-01-06 20:47 d-------- c:\program files\Bonjour
2009-01-06 20:46 . 2009-01-06 20:47 d-------- c:\users\All Users\Apple Computer
2009-01-06 20:46 . 2009-01-06 20:47 d-------- c:\programdata\Apple Computer
2009-01-06 20:46 . 2009-01-06 20:46 d-------- c:\program files\QuickTime
2009-01-06 20:46 . 2009-01-06 20:46 d-------- c:\program files\Apple Software Update
2009-01-06 20:45 . 2009-01-06 20:45 d-------- c:\users\All Users\Apple
2009-01-06 20:45 . 2009-01-06 20:45 d-------- c:\programdata\Apple
2009-01-06 20:45 . 2009-01-06 20:47 d-------- c:\program files\Common Files\Apple
2009-01-06 20:14 . 2009-01-06 20:14 d--hsc--- c:\program files\Common Files\WindowsLiveInstaller
AARG12
OS : Windows Vista
Solved Re: I NEED HELP WITH Troj/Rustok-N i cant get rid of it!!!
2009-01-10 08:30 174 --sha-w c:\program files\desktop.ini
2009-01-10 08:23 --------- d-----w c:\program files\Windows Sidebar
2009-01-10 08:23 --------- d-----w c:\program files\Windows Mail
2009-01-10 08:23 --------- d-----w c:\program files\Windows Calendar
2009-01-10 08:21 --------- d-----w c:\program files\Apoint
2009-01-10 07:09 704,000 ----a-w c:\windows\System32\PhotoScreensaver.scr
2009-01-10 07:09 67,584 ----a-w c:\windows\System32\wlanhlp.dll
2009-01-10 07:09 542,720 ----a-w c:\windows\System32\sysmain.dll
2009-01-10 07:09 502,784 ----a-w c:\windows\System32\wlansvc.dll
2009-01-10 07:09 47,104 ----a-w c:\windows\System32\wlanapi.dll
2009-01-10 07:09 297,984 ----a-w c:\windows\System32\wlansec.dll
2009-01-10 07:09 290,816 ----a-w c:\windows\System32\wlanmsm.dll
2009-01-10 07:09 28,344 ----a-w c:\windows\system32\drivers\battc.sys
2009-01-10 07:09 258,232 ----a-w c:\windows\system32\drivers\acpi.sys
2009-01-10 07:09 24,064 ----a-w c:\windows\System32\wtsapi32.dll
2009-01-10 07:09 20,920 ----a-w c:\windows\system32\drivers\compbatt.sys
2009-01-10 07:09 14,208 ----a-w c:\windows\system32\drivers\CmBatt.sys
2009-01-10 06:59 537,600 ----a-w c:\windows\AppPatch\AcLayers.dll
2009-01-10 06:59 52,736 ----a-w c:\windows\AppPatch\iebrshim.dll
2009-01-10 06:59 449,536 ----a-w c:\windows\AppPatch\AcSpecfc.dll
2009-01-10 06:59 2,560 ----a-w c:\windows\AppPatch\AcRes.dll
2009-01-10 06:59 2,144,256 ----a-w c:\windows\AppPatch\AcGenral.dll
2009-01-10 06:59 173,056 ----a-w c:\windows\AppPatch\AcXtrnal.dll
2009-01-10 06:49 826,368 ----a-w c:\windows\System32\wininet.dll
2009-01-10 06:49 56,320 ----a-w c:\windows\System32\iesetup.dll
2009-01-10 06:49 26,624 ----a-w c:\windows\System32\ieUnatt.exe
2009-01-10 06:43 944,184 ----a-w c:\windows\System32\winload.exe
2009-01-10 06:41 712,192 ----a-w c:\windows\System32\WindowsCodecs.dll
2009-01-10 06:41 57,856 ----a-w c:\windows\System32\SLUINotify.dll
2009-01-10 06:41 566,784 ----a-w c:\windows\System32\SLCommDlg.dll
2009-01-10 06:41 425,472 ----a-w c:\windows\System32\PhotoMetadataHandler.dll
2009-01-10 06:41 39,936 ----a-w c:\windows\System32\slcinst.dll
2009-01-10 06:41 351,232 ----a-w c:\windows\System32\SLUI.exe
2009-01-10 06:41 347,136 ----a-w c:\windows\System32\WindowsCodecsExt.dll
2009-01-10 06:41 33,280 ----a-w c:\windows\System32\slwmi.dll
2009-01-10 06:41 290,304 ----a-w c:\windows\system32\drivers\srv.sys
2009-01-10 06:41 268,288 ----a-w c:\windows\System32\mcbuilder.exe
2009-01-10 06:41 223,232 ----a-w c:\windows\System32\SLC.dll
2009-01-10 06:41 2,605,568 ----a-w c:\windows\System32\SLsvc.exe
2009-01-10 06:41 186,368 ----a-w c:\windows\System32\SLLUA.exe
2009-01-02 03:58 --------- d-----w c:\program files\Common Files\Sony Shared
2009-01-02 03:57 --------- d--h--w c:\program files\InstallShield Installation Information
2009-01-02 03:57 --------- d-----w c:\program files\Sony
2009-01-02 03:56 --------- d-----w c:\programdata\Sony Corporation
2008-12-16 06:03 --------- d-----w c:\program files\Java
2008-12-15 06:24 --------- d-sh--w c:\programdata\Templates
2008-12-15 06:24 --------- d-sh--w c:\programdata\Start Menu
2008-12-15 06:24 --------- d-sh--w c:\programdata\Favorites
2008-12-15 06:24 --------- d-sh--w c:\programdata\Documents
2008-12-15 06:24 --------- d-sh--w c:\programdata\Desktop
2008-12-15 06:24 --------- d-sh--w c:\programdata\Application Data
2008-12-15 04:38 --------- d-----w c:\program files\Common Files\InstallShield
((((((((((((((((((((((((((((( snapshot_2009-01-11_23.55.50.18 )))))))))))))))))))))))))))))))))))))))))
+ 2009-01-14 05:52:57 6,189,056 ----a-w c:\windows\ERDNT\Hiv-backup\SCHEMA.DAT
- 2000-08-31 16:00:00 28,672 ----a-w c:\windows\NIRCMD.exe
+ 2000-08-31 16:00:00 29,696 ----a-w c:\windows\NIRCMD.exe
- 2009-01-12 07:01:32 2,048 --sha-w c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2009-01-12 21:14:06 2,048 --sha-w c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
- 2009-01-12 07:01:32 2,048 --sha-w c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2009-01-12 21:14:06 2,048 --sha-w c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
- 2009-01-12 07:02:12 262,144 --sha-w c:\windows\ServiceProfiles\LocalService\NTUSER.DAT
+ 2009-01-12 21:15:42 262,144 --sha-w c:\windows\ServiceProfiles\LocalService\NTUSER.DAT
- 2009-01-12 07:02:17 262,144 --sha-w c:\windows\ServiceProfiles\NetworkService\NTUSER.DAT
+ 2009-01-12 21:15:37 262,144 --sha-w c:\windows\ServiceProfiles\NetworkService\NTUSER.DAT
- 2009-01-12 07:02:52 32,768 --sha-w c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2009-01-14 03:30:51 32,768 --sha-w c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2009-01-12 07:02:52 147,456 --sha-w c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-01-14 03:30:51 163,840 --sha-w c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2009-01-12 07:02:52 32,768 --sha-w c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-01-14 03:30:51 32,768 --sha-w c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2009-01-06 05:22:11 262,144 ----a-w c:\windows\System32\config\systemprofile\ntuser.dat
+ 2009-01-14 05:53:02 262,144 ----a-w c:\windows\System32\config\systemprofile\ntuser.dat
- 2009-01-12 07:08:05 107,714 ----a-w c:\windows\System32\perfc009.dat
+ 2009-01-12 21:20:41 107,714 ----a-w c:\windows\System32\perfc009.dat
- 2009-01-12 07:08:05 626,976 ----a-w c:\windows\System32\perfh009.dat
+ 2009-01-12 21:20:41 626,976 ----a-w c:\windows\System32\perfh009.dat
- 2009-01-12 07:00:44 6,291,456 ----a-w c:\windows\System32\SMI\Store\Machine\SCHEMA.DAT
+ 2009-01-14 02:03:48 6,291,456 ----a-w c:\windows\System32\SMI\Store\Machine\SCHEMA.DAT
- 2009-01-12 07:03:21 5,966 ----a-w c:\windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-712910195-2065108488-2920947175-1002_UserData.bin
+ 2009-01-12 21:16:04 6,018 ----a-w c:\windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-712910195-2065108488-2920947175-1002_UserData.bin
- 2009-01-12 07:03:21 67,228 ----a-w c:\windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
+ 2009-01-12 21:16:04 67,228 ----a-w c:\windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
- 2009-01-12 07:03:20 34,156 ----a-w c:\windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2009-01-12 21:16:03 34,220 ----a-w c:\windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2009-01-14 02:04:09 91,249 ----a-w c:\windows\winsxs\ManifestCache\6.0.6001.18000_001c50b5_blobs.bin
-- Snapshot reset to current date --
"Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2009-01-09 1232896]
"MsnMsgr"="c:\program files\Windows Live\Messenger\MsnMsgr.Exe" [2007-10-18 5724184]
"SpybotSD TeaTimer"="c:\program files\Spybot - Search & Destroy\TeaTimer.exe" [2008-09-16 1833296]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2007-06-29 137752]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2007-06-29 154136]
"Persistence"="c:\windows\system32\igfxpers.exe" [2007-06-29 133656]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2007-05-11 40048]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2008-12-15 136600]
"VAIO Center Access Bar"="c:\program files\sony\VAIO Center Access Bar\VCAB.exe" [2007-06-21 53248]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2007-01-09 115816]
"Symantec PIF AlertEng"="c:\program files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" [2008-01-29 583048]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2008-11-04 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-11-20 290088]
"Apoint"="c:\program files\Apoint\Apoint.exe" [2007-06-08 118784]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\VESWinlogon]
2007-07-24 18:26 98304 c:\windows\System32\VESWinlogon.dll
"VIDC.dvsd"= c:\program files\Common Files\Sony Shared\VideoLib\sonydv.dll
"AntiVirusDisableNotify"="0x00000000"
"UpdatesDisableNotify"="0x00000000"
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\DomainProfile]
"DefaultOutboundAction"= 0 (0x0)
"DefaultInboundAction"= 1 (0x1)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\FirewallRules]
"{1980A3A3-72DB-4E3F-9F05-2191AA5DB79A}"= UDP:c:\program files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{0816D0DF-B54B-4F22-AD54-EF92FB51704A}"= TCP:c:\program files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{00D323C8-E223-4115-B226-39A64557D821}"= c:\program files\Windows Live\Messenger\livecall.exe:Windows Live Messenger (Phone)
"{516FF797-A0CA-43D6-A288-6A38B1835483}"= c:\program files\Windows Live\Messenger\livecall.exe:Windows Live Messenger (Phone)
"{F67C3699-D469-4522-851C-F156159CCFE6}"= UDP:c:\program files\Bonjour\mDNSResponder.exe:Bonjour
"{D2100068-A81F-4DFA-A023-89A8E6C91F13}"= TCP:c:\program files\Bonjour\mDNSResponder.exe:Bonjour
"{AE100143-A4AF-4F19-A255-1F87AACED5C4}"= UDP:c:\program files\iTunes\iTunes.exe:iTunes
"{BC772F8E-19BD-44C7-9AE8-77DBB2AEC02E}"= TCP:c:\program files\iTunes\iTunes.exe:iTunes
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\PublicProfile]
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\RestrictedServices\Static\System]
"DFSR-1"= RPort=5722|UDP:%SystemRoot%\system32\svchost.exe|Svc=DFSR:Allow inbound TCP traffic|
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\StandardProfile]
R1 IDSvix86;Symantec Intrusion Prevention Driver;c:\progra~2\Symantec\DEFINI~1\SymcData\idsdefs\20090102.001\IDSvix86.sys [2009-01-09 270384]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [2008-12-15 99376]
R3 KeyScrambler;KeyScrambler;c:\windows\System32\drivers\keyscrambler.sys [2009-01-01 113896]
R3 R5U870FLx86;R5U870 UVC Lower Filter ;c:\windows\System32\drivers\R5U870FLx86.sys [2007-08-01 75008]
R3 R5U870FUx86;R5U870 UVC Upper Filter ;c:\windows\System32\drivers\R5U870FUx86.sys [2007-08-01 43904]
R3 SonyImgF;Sony Image Conversion Filter Driver;c:\windows\System32\drivers\SonyImgF.sys [2007-08-01 31104]
R3 SYMNDISV;SYMNDISV;c:\windows\System32\drivers\symndisv.sys [2007-01-09 38200]
R3 ti21sony;ti21sony;c:\windows\System32\drivers\ti21sony.sys [2007-08-01 812544]
R4 regi;regi;c:\windows\System32\drivers\regi.sys [2007-04-17 11032]
S3 VcmIAlzMgr;VAIO Content Metadata Intelligent Analyzing Manager;c:\program files\Sony\VCM Intelligent Analyzing Manager\VcmIAlzMgr.exe [2009-01-01 333088]
S3 VcmXmlIfHelper;VAIO Content Metadata XML Interface;c:\program files\Common Files\Sony Shared\VcmXml\VcmXmlIfHelper.exe [2007-08-01 79736]
*NewlyCreated* - COMHOST
bthsvcs REG_MULTI_SZ BthServ
FF - ProfilePath - c:\users\Angel\AppData\Roaming\Mozilla\Firefox\Profiles\rafdrutm.default\
FF - component: c:\users\Angel\AppData\Roaming\Mozilla\Firefox\Profiles\rafdrutm.default\extensions\keyscrambler@qfx.software.corporation\components\KeyScramblerIE.dll
---- FIREFOX POLICIES ----
Rootkit scan 2009-01-13 21:55:38
Windows 6.0.6000 NTFS
Completion time: 2009-01-13 21:57:49
ComboFix-quarantined-files.txt 2009-01-14 05:57:47
ComboFix2.txt 2009-01-12 07:57:41
ComboFix3.txt 2009-01-06 05:25:56
ComboFix4.txt 2009-01-05 02:16:28
ComboFix5.txt 2009-01-14 05:51:34
Pre-Run: 218,168,745,984 bytes free
Post-Run: 218,141,712,384 bytes free
333 --- E O F --- 2009-01-12 06:35:31
AARG12
OS : Windows Vista
Post by Belahzur on Wed Jan 14, 2009 2:07 pm
Hmmm.
I wonder if that did it.
Still having problems?
Post by AARG12 on Wed Jan 14, 2009 8:34 pm
i still cannot uPDte but now spybot only finds two trojans instead of four and malware sometimes finds two sometimes it doesnt instead of the six or foud it used it. but when i do erase them without restarting i can do updates but once i restart its back to the same. i think that it has to do with my internet connection because when thats restarted too the viruses comeback
AARG12
OS : Windows Vista
Post by Belahzur on Wed Jan 14, 2009 8:48 pm
Okay, do this:
Do a spybot scan, remove everything it found.
DO NOT reboot yet.
Press Start > Run
Type in:
cmd
Press enter
Type in:
ipconfig /release
Press enter. (your net connection will die for now, but this next command fixes it)
Then type in:
ipconfig /renew
Press enter.
Then type in:
ipconfig /flushdns
Then close the command prompt.
Reboot now.
Does Spybot still find anything now?
Post by AARG12 on Fri Jan 16, 2009 2:22 am
when i do the ipconfig /release it says the required operation requires elevation
AARG12
OS : Windows Vista
Post by Belahzur on Fri Jan 16, 2009 4:51 pm
Darn Vista.
Press Start > All Programs > Accessories > Command Prompt > right click > "Run as administrator"
Post by AARG12 on Sat Jan 17, 2009 12:30 am
it says this when i try:
windows ip configuration
no operation can be performed on Local Area Connection while it has its media disconnected
AARG12
OS : Windows Vista
Post by Belahzur on Sat Jan 17, 2009 12:54 am
I'm gonna get in touch with my colleagues and see if we can come up with anything.
While I'm doing that, you said after that CF run, the number of stuff that Spybot found has dropped, can you post a log of what Spybot is still finding?
Post by AARG12 on Sun Jan 18, 2009 4:02 am
Sorry idk how to find the log for the findings!! can you help me?
AARG12
OS : Windows Vista
Post by AARG12 on Sun Jan 18, 2009 4:54 am
This is all i can find :
Malwarebytes' Anti-Malware 1.32
Database version: 1643
Windows 6.0.6000
1/17/2009 20:53:47
mbam-log-2009-01-17 (20-53-47).txt
Objects scanned: 49053
Time elapsed: 3 minute(s), 3 second(s)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\DhcpNameServer (Trojan.DNSChanger) -> Data: 85.255.112.178 85.255.112.102 -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\Interfaces\{f3190096-33e1-494f-8233-2fe9ece13e18}\DhcpNameServer (Trojan.DNSChanger) -> Data: 85.255.112.178 85.255.112.102 -> Quarantined and deleted successfully.
AARG12
OS : Windows Vista
Post by Belahzur on Sun Jan 18, 2009 1:20 pm
Okay, we'll use combofix again.
Delete combofix you have and download a new copy.
Registry::
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters]
"DhcpNameServer"=-
"DhcpNameServer"=-
Post by AARG12 on Mon Jan 19, 2009 7:14 pm
ComboFix 09-01-19.01 - Angel 2009-01-19 11:03:27.7 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6000.0.1252.1.1033.18.2038.1143 [GMT -8:00]
Command switches used :: c:\users\Angel\Desktop\CFScript.txt
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:16 pm
((((((((((((((((((((((((( Files Created from 2008-12-19 to 2009-01-19 )))))))))))))))))))))))))))))))
2009-01-16 22:54 . 2009-01-16 22:54 d-------- c:\program files\Microsoft Silverlight
2009-01-13 18:04 . 2008-12-15 19:14 290,304 --a------ c:\windows\System32\drivers\srv.sys
2009-01-09 22:41 . 2009-01-09 22:41 2,605,568 --a------ c:\windows\System32\SLsvc.exe
2009-01-09 22:41 . 2009-01-09 22:41 712,192 --a------ c:\windows\System32\WindowsCodecs.dll
2009-01-09 22:41 . 2009-01-09 22:41 566,784 --a------ c:\windows\System32\SLCommDlg.dll
2009-01-09 22:41 . 2009-01-09 22:41 425,472 --a------ c:\windows\System32\PhotoMetadataHandler.dll
2009-01-09 22:41 . 2009-01-09 22:41 351,232 --a------ c:\windows\System32\SLUI.exe
2009-01-09 22:41 . 2009-01-09 22:41 347,136 --a------ c:\windows\System32\WindowsCodecsExt.dll
2009-01-09 22:41 . 2009-01-09 22:41 268,288 --a------ c:\windows\System32\mcbuilder.exe
2009-01-09 22:41 . 2009-01-09 22:41 223,232 --a------ c:\windows\System32\SLC.dll
2009-01-09 22:41 . 2009-01-09 22:41 186,368 --a------ c:\windows\System32\SLLUA.exe
2009-01-09 22:41 . 2009-01-09 22:41 57,856 --a------ c:\windows\System32\SLUINotify.dll
2009-01-09 22:41 . 2009-01-09 22:41 39,936 --a------ c:\windows\System32\slcinst.dll
2009-01-09 22:41 . 2009-01-09 22:41 33,280 --a------ c:\windows\System32\slwmi.dll
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:17 pm
2009-01-14 11:02 --------- d-----w c:\program files\Windows Mail
2009-01-14 08:37 --------- d-----w c:\programdata\Sony Corporation
2009-01-10 07:12 --------- d-----w c:\programdata\Microsoft Help
2009-01-10 06:35 996,352 ----a-w c:\windows\System32\WMNetMgr.dll
2009-01-10 06:35 98,816 ----a-w c:\windows\System32\mfps.dll
2009-01-10 06:35 94,720 ----a-w c:\windows\System32\logagent.exe
2009-01-10 06:35 84,992 ----a-w c:\windows\system32\drivers\srvnet.sys
2009-01-10 06:35 788,992 ----a-w c:\windows\System32\rpcrt4.dll
2009-01-10 06:35 58,368 ----a-w c:\windows\system32\drivers\mrxsmb20.sys
2009-01-10 06:35 52,736 ----a-w c:\windows\System32\rrinstaller.exe
2009-01-10 06:35 24,576 ----a-w c:\windows\System32\mfpmp.exe
2009-01-10 06:35 2,855,424 ----a-w c:\windows\System32\mf.dll
2009-01-10 06:35 2,048 ----a-w c:\windows\System32\mferror.dll
2009-01-10 06:35 148,992 ----a-w c:\windows\system32\drivers\ks.sys
2009-01-10 06:35 130,048 ----a-w c:\windows\system32\drivers\srv2.sys
2009-01-10 06:35 101,888 ----a-w c:\windows\system32\drivers\mrxsmb.sys
2009-01-08 03:24 --------- d-----w c:\programdata\Symantec
2009-01-06 02:18 806 ----a-w c:\windows\system32\drivers\SYMEVENT.INF
2009-01-06 02:18 124,464 ----a-w c:\windows\system32\drivers\SYMEVENT.SYS
2009-01-06 02:18 10,635 ----a-w c:\windows\system32\drivers\SYMEVENT.CAT
2009-01-06 02:18 --------- d-----w c:\program files\Symantec
2008-12-31 06:49 --------- d-----w c:\program files\Common Files\AOL
2008-12-23 21:58 --------- d-----w c:\program files\Norton 360
2008-12-23 07:18 --------- d-----w c:\programdata\Intuit
2008-12-23 07:18 --------- d-----w c:\program files\Common Files\Intuit
2008-12-16 06:03 410,984 ----a-w c:\windows\System32\deploytk.dll
2008-12-16 05:29 --------- d-----w c:\users\Angel\AppData\Roaming\Symantec
2008-12-16 05:19 --------- d-----w c:\users\Angel\AppData\Roaming\Corel
2008-12-16 04:44 --------- d-----w c:\programdata\{3276BE95_AF08_429F_A64F_CA64CB79BCF6}
2008-12-16 04:43 --------- d-----w c:\program files\Common Files\Symantec Shared
2008-12-16 04:38 --------- d-----w c:\users\Angel\AppData\Roaming\Sony Corporation
2008-12-15 05:19 0 ---ha-r c:\windows\system32\drivers\Sony_VGN-FZ240E.mrk
2008-12-15 04:55 --------- d-----w c:\program files\InterVideo
2008-12-15 04:55 --------- d-----w c:\program files\Common Files\InterVideo
2008-12-15 04:50 132,608 ----a-w c:\windows\system32\drivers\usbvideo.sys
2008-12-15 04:46 1,132,112 ----a-w c:\users\All Users\pswi_preloaded.exe
2008-12-15 04:46 1,132,112 ----a-w c:\programdata\pswi_preloaded.exe
2008-12-15 04:46 --------- d-----w c:\programdata\Corel
2008-12-15 04:46 --------- d-----w c:\program files\Corel
2008-12-15 04:45 --------- d-----w c:\program files\Common Files\Corel
2008-12-15 04:44 --------- d-----w c:\programdata\{174892B1-CBE7-44F5-86FF-AB555EFD73A3}
2008-12-15 04:44 --------- d-----w c:\program files\Activation Assistant for the 2007 Microsoft Office suites
2008-12-15 04:43 --------- d-----w c:\program files\Microsoft.NET
2008-12-15 04:38 --------- d-----w c:\program files\ArcSoft
2008-12-15 04:32 --------- d-----w c:\program files\Intuit
2008-12-15 04:32 --------- d-----w c:\program files\Common Files\supportsoft
2008-12-15 04:30 --------- d-----w c:\programdata\COMMON FILES
2008-12-15 04:24 --------- d-----w c:\program files\Microsoft Works
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:19 pm
((((((((((((((((((((((((((((( snapshot_2009-01-13_21.56.03.93 )))))))))))))))))))))))))))))))))))))))))
- 2009-01-12 21:14:06 2,048 --sha-w c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2009-01-19 18:47:44 2,048 --sha-w c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
- 2009-01-12 21:14:06 2,048 --sha-w c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2009-01-19 18:47:44 2,048 --sha-w c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
- 2009-01-12 21:15:42 262,144 --sha-w c:\windows\ServiceProfiles\LocalService\NTUSER.DAT
+ 2009-01-19 18:49:24 262,144 --sha-w c:\windows\ServiceProfiles\LocalService\NTUSER.DAT
- 2009-01-12 21:15:37 262,144 --sha-w c:\windows\ServiceProfiles\NetworkService\NTUSER.DAT
+ 2009-01-19 18:49:30 262,144 --sha-w c:\windows\ServiceProfiles\NetworkService\NTUSER.DAT
- 2009-01-14 03:30:51 32,768 --sha-w c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2009-01-19 18:49:34 32,768 --sha-w c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2009-01-14 03:30:51 163,840 --sha-w c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-01-19 18:49:34 163,840 --sha-w c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2009-01-14 03:30:51 32,768 --sha-w c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-01-19 18:49:34 32,768 --sha-w c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2009-01-14 05:53:02 262,144 ----a-w c:\windows\System32\config\systemprofile\ntuser.dat
+ 2009-01-19 19:03:01 262,144 ----a-w c:\windows\System32\config\systemprofile\ntuser.dat
- 2008-12-09 23:24:38 17,593,280 ----a-w c:\windows\System32\mrt.exe
+ 2009-01-10 01:35:28 20,853,704 ----a-w c:\windows\System32\mrt.exe
- 2009-01-12 21:20:41 107,714 ----a-w c:\windows\System32\perfc009.dat
+ 2009-01-19 19:00:44 107,714 ----a-w c:\windows\System32\perfc009.dat
- 2009-01-12 21:20:41 626,976 ----a-w c:\windows\System32\perfh009.dat
+ 2009-01-19 19:00:44 626,976 ----a-w c:\windows\System32\perfh009.dat
- 2009-01-14 02:03:48 6,291,456 ----a-w c:\windows\System32\SMI\Store\Machine\SCHEMA.DAT
+ 2009-01-17 07:18:09 6,291,456 ----a-w c:\windows\System32\SMI\Store\Machine\SCHEMA.DAT
- 2009-01-12 21:16:04 6,018 ----a-w c:\windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-712910195-2065108488-2920947175-1002_UserData.bin
+ 2009-01-19 18:49:48 6,516 ----a-w c:\windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-712910195-2065108488-2920947175-1002_UserData.bin
- 2009-01-12 21:16:04 67,228 ----a-w c:\windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
+ 2009-01-19 18:49:48 67,502 ----a-w c:\windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
- 2009-01-12 21:16:03 34,220 ----a-w c:\windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2009-01-19 18:49:46 34,526 ----a-w c:\windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:20 pm
- 2009-01-14 02:04:09 91,249 ----a-w c:\windows\winsxs\ManifestCache\6.0.6001.18000_001c50b5_blobs.bin
+ 2009-01-17 04:55:01 126,270,543 ----a-w c:\windows\winsxs\ManifestCache\6.0.6001.18000_001c50b5_blobs.bin
+ 2006-11-02 12:35:28 77,824 ----a-w c:\windows\winsxs\msil_ehiextens_31bf3856ad364e35_6.0.6001.18000_none_fdcbbc4906dd2f5d\ehiExtens.dll
+ 2009-01-10 06:44:37 19,456 ----a-w c:\windows\winsxs\x86_bth.inf_31bf3856ad364e35_6.0.6001.18000_none_7244c43bbb913795\bthenum.sys
+ 2006-11-02 09:46:02 24,576 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..ence-infrastructure_31bf3856ad364e35_6.0.6001.18000_none_d51103be4cb9d6c3\aelupsvc.dll
+ 2006-11-02 09:45:39 20,992 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..ence-infrastructure_31bf3856ad364e35_6.0.6001.18000_none_d51103be4cb9d6c3\sdbinst.exe
+ 2006-11-02 09:46:13 111,104 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..ence-infrastructure_31bf3856ad364e35_6.0.6001.18000_none_d51103be4cb9d6c3\shimeng.dll
+ 2006-11-02 07:11:38 2,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..ence-mitigations-c1_31bf3856ad364e35_6.0.6001.18000_none_0c223829f24c6bcd\AcRes.dll
+ 2006-11-02 09:46:02 38,912 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.0.6001.18000_none_94ca2703a87213b1\acppage.dll
+ 2006-11-02 07:11:39 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.0.6001.18000_none_94ca2703a87213b1\acprgwiz.dll
+ 2006-11-02 09:45:32 8,192 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.0.6001.18000_none_94ca2703a87213b1\pcaelv.exe
+ 2006-11-02 09:45:32 7,680 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.0.6001.18000_none_94ca2703a87213b1\pcalua.exe
+ 2006-11-02 09:45:32 14,336 ----a-w c:\windows\winsxs\x86_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.0.6001.18000_none_94ca2703a87213b1\pcaui.exe
+ 2006-11-02 12:34:33 30,208 ----a-w c:\windows\winsxs\x86_microsoft-windows-audio-dmusic_31bf3856ad364e35_6.0.6001.18000_none_45f41bf18fa2cf5a\dmband.dll
+ 2006-11-02 12:34:33 62,976 ----a-w c:\windows\winsxs\x86_microsoft-windows-audio-dmusic_31bf3856ad364e35_6.0.6001.18000_none_45f41bf18fa2cf5a\dmcompos.dll
+ 2006-11-02 12:34:33 105,472 ----a-w c:\windows\winsxs\x86_microsoft-windows-audio-dmusic_31bf3856ad364e35_6.0.6001.18000_none_45f41bf18fa2cf5a\dmstyle.dll
+ 2006-11-02 12:34:33 20,992 ----a-w c:\windows\winsxs\x86_microsoft-windows-audio-dmusic_31bf3856ad364e35_6.0.6001.18000_none_45f41bf18fa2cf5a\dswave.dll
+ 2006-11-02 09:46:05 52,224 ----a-w c:\windows\winsxs\x86_microsoft-windows-audio-mmecore-other_31bf3856ad364e35_6.0.6001.18000_none_8cfdc804108fe1a6\mmci.dll
+ 2006-11-02 09:46:05 12,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-audio-mmecore-other_31bf3856ad364e35_6.0.6001.18000_none_8cfdc804108fe1a6\mmcico.dll
+ 2006-11-02 09:46:13 185,856 ----a-w c:\windows\winsxs\x86_microsoft-windows-audio-volumecontrol_31bf3856ad364e35_6.0.6001.18000_none_c62871670779ffa4\SndVolSSO.dll
+ 2006-11-02 09:41:17 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-basic-misc-tools_31bf3856ad364e35_6.0.6001.18000_none_175cb770bf6b8f77\netmsg.dll
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:21 pm
+ 2006-11-02 09:46:11 14,848 ----a-w c:\windows\winsxs\x86_microsoft-windows-basic-misc-tools_31bf3856ad364e35_6.0.6001.18000_none_175cb770bf6b8f77\netrap.dll
+ 2006-11-02 09:44:52 34,304 ----a-w c:\windows\winsxs\x86_microsoft-windows-bth-user_31bf3856ad364e35_6.0.6001.18000_none_65193febd52e137a\bthudtask.exe
+ 2006-11-02 09:46:14 34,304 ----a-w c:\windows\winsxs\x86_microsoft-windows-bth-user_31bf3856ad364e35_6.0.6001.18000_none_65193febd52e137a\wshbth.dll
+ 2006-11-02 09:46:02 41,984 ----a-w c:\windows\winsxs\x86_microsoft-windows-certutil_31bf3856ad364e35_6.0.6001.18000_none_b58507ed335c92cc\certenc.dll
+ 2006-11-02 09:46:03 7,168 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-base_31bf3856ad364e35_6.0.6001.18000_none_0dee367726857e43\comcat.dll
+ 2006-11-02 07:28:57 22,528 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-base_31bf3856ad364e35_6.0.6001.18000_none_0dee367726857e43\oleres.dll
+ 2006-11-02 09:46:02 23,552 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-complus-runtime_31bf3856ad364e35_6.0.6001.18000_none_59cabf11d4b18d8a\catsrvps.dll
+ 2006-09-18 21:27:45 61,440 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-complus-runtime_31bf3856ad364e35_6.0.6001.18000_none_59cabf11d4b18d8a\comempty.dat
+ 2006-11-02 09:46:11 7,168 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-complus-runtime_31bf3856ad364e35_6.0.6001.18000_none_59cabf11d4b18d8a\mtxex.dll
+ 2006-11-02 09:45:00 8,704 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-complus-ui_31bf3856ad364e35_6.0.6001.18000_none_b0a7c3b54838915e\dcomcnfg.exe
+ 2006-09-18 21:27:12 19,429 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-dtc-tracing_31bf3856ad364e35_6.0.6001.18000_none_17df4ac2f2cf5440\msdtcvtr.bat
+ 2006-09-18 21:35:10 27,792 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-legacyole_31bf3856ad364e35_6.0.6001.18000_none_3f1ba507d2463833\compobj.dll
+ 2006-11-02 09:39:39 3,072 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-legacyole_31bf3856ad364e35_6.0.6001.18000_none_3f1ba507d2463833\iprop.dll
+ 2006-09-18 21:35:13 42,592 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-legacyole_31bf3856ad364e35_6.0.6001.18000_none_3f1ba507d2463833\ole2.dll
+ 2006-09-18 21:35:14 169,520 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-legacyole_31bf3856ad364e35_6.0.6001.18000_none_3f1ba507d2463833\ole2disp.dll
+ 2006-09-18 21:35:15 153,008 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-legacyole_31bf3856ad364e35_6.0.6001.18000_none_3f1ba507d2463833\ole2nls.dll
+ 2006-09-18 21:35:15 4,208 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-legacyole_31bf3856ad364e35_6.0.6001.18000_none_3f1ba507d2463833\storage.dll
+ 2006-09-18 21:35:15 177,856 ----a-w c:\windows\winsxs\x86_microsoft-windows-com-legacyole_31bf3856ad364e35_6.0.6001.18000_none_3f1ba507d2463833\typelib.dll
+ 2006-11-02 09:46:03 31,232 ----a-w c:\windows\winsxs\x86_microsoft-windows-convert_31bf3856ad364e35_6.0.6001.18000_none_9cd54abba85233ff\cnvfat.dll
+ 2006-11-02 09:44:15 5,120 ----a-w c:\windows\winsxs\x86_microsoft-windows-coreos_31bf3856ad364e35_6.0.6001.18000_none_255246473e514737\wmi.dll
+ 2006-11-02 09:44:59 19,968 ----a-w c:\windows\winsxs\x86_microsoft-windows-corruptedfilerecovery_31bf3856ad364e35_6.0.6001.18000_none_87b9b7e028c74e65\cofire.exe
+ 2006-11-02 09:45:20 36,352 ----a-w c:\windows\winsxs\x86_microsoft-windows-d..-japanese-utilities_31bf3856ad364e35_6.0.6001.18000_none_ed313ee5721aa9bc\IMJPUEX.EXE
+ 2006-11-02 09:46:05 11,264 ----a-w c:\windows\winsxs\x86_microsoft-windows-d..ime-eashared-imepad_31bf3856ad364e35_6.0.6001.18000_none_3a8c422a9f3101c4\padrs404.dll
+ 2006-11-02 09:46:05 11,776 ----a-w c:\windows\winsxs\x86_microsoft-windows-d..ime-eashared-imepad_31bf3856ad364e35_6.0.6001.18000_none_3a8c422a9f3101c4\padrs804.dll
+ 2006-11-02 09:46:13 26,624 ----a-w c:\windows\winsxs\x86_microsoft-windows-d..oryservices-ntdsapi_31bf3856ad364e35_6.0.6001.18000_none_cedd4665f13650d7\w32topl.dll
+ 2006-11-02 09:46:05 4,608 ----a-w c:\windows\winsxs\x86_microsoft-windows-d..tshow-kernelsupport_31bf3856ad364e35_6.0.6001.18000_none_e8019c5c974c4491\ksuser.dll
+ 2006-11-02 12:36:25 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-dfsr-core-clientonly_31bf3856ad364e35_6.0.6001.18000_none_b6798caa9a04157b\dfsrres.dll
+ 2006-11-02 09:46:03 10,240 ----a-w c:\windows\winsxs\x86_microsoft-windows-dhcp-client-dll_31bf3856ad364e35_6.0.6001.18000_none_d75a29a02e8fcf7a\dhcpcmonitor.dll
+ 2006-11-02 09:46:05 36,352 ----a-w c:\windows\winsxs\x86_microsoft-windows-directshow-other_31bf3856ad364e35_6.0.6001.18000_none_0d5187f9e0ba9013\mciqtz32.dll
+ 2006-11-02 09:46:03 593,920 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-direct3d_31bf3856ad364e35_6.0.6001.18000_none_eb4e0e435578fd76\d3dramp.dll
+ 2006-11-02 09:46:03 11,264 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-direct3d9_31bf3856ad364e35_6.0.6001.18000_none_c24d6ca560c635f9\d3d8thk.dll
+ 2006-11-02 09:46:03 30,208 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directdraw_31bf3856ad364e35_6.0.6001.18000_none_0505a2ecc0013ebd\ddrawex.dll
+ 2006-11-02 12:34:30 136,192 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directinput_31bf3856ad364e35_6.0.6001.18000_none_1d981a3c0baebdc7\dinput.dll
+ 2006-11-02 12:34:30 120,832 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directinput_31bf3856ad364e35_6.0.6001.18000_none_1d981a3c0baebdc7\gcdef.dll
+ 2006-11-02 12:34:30 36,352 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directinput_31bf3856ad364e35_6.0.6001.18000_none_1d981a3c0baebdc7\pid.dll
+ 2006-11-02 09:03:41 3,072 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directplay8_31bf3856ad364e35_6.0.6001.18000_none_78d68814bebf2d3b\dpnaddr.dll
+ 2006-11-02 09:46:04 56,832 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directplay8_31bf3856ad364e35_6.0.6001.18000_none_78d68814bebf2d3b\dpnathlp.dll
+ 2006-11-02 09:46:04 7,168 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directplay8_31bf3856ad364e35_6.0.6001.18000_none_78d68814bebf2d3b\dpnhpast.dll
+ 2006-11-02 09:46:04 7,168 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directplay8_31bf3856ad364e35_6.0.6001.18000_none_78d68814bebf2d3b\dpnhupnp.dll
+ 2006-11-02 09:03:41 3,072 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directplay8_31bf3856ad364e35_6.0.6001.18000_none_78d68814bebf2d3b\dpnlobby.dll
+ 2006-11-02 09:45:03 23,040 ----a-w c:\windows\winsxs\x86_microsoft-windows-directx-directplay8_31bf3856ad364e35_6.0.6001.18000_none_78d68814bebf2d3b\dpnsvr.exe
+ 2006-11-02 09:39:16 536,576 ----a-w c:\windows\winsxs\x86_microsoft-windows-diskmanagement_31bf3856ad364e35_6.0.6001.18000_none_0197b5b76fbd3f60\dmdskres.dll
+ 2006-11-02 09:46:03 23,040 ----a-w c:\windows\winsxs\x86_microsoft-windows-diskmanagement_31bf3856ad364e35_6.0.6001.18000_none_0197b5b76fbd3f60\dmintf.dll
+ 2006-09-18 21:39:30 215,943 ----a-w c:\windows\winsxs\x86_microsoft-windows-dssec_31bf3856ad364e35_6.0.6001.18000_none_5a65d782fc87d29e\dssec.dat
+ 2009-01-10 07:06:35 6,656 ----a-w c:\windows\winsxs\x86_microsoft-windows-ehome-devices-mcrmgr_31bf3856ad364e35_6.0.6001.18000_none_3429e869d9fa322b\McrMgr.dll
+ 2006-11-02 12:35:32 21,504 ----a-w c:\windows\winsxs\x86_microsoft-windows-ehome-ehdebug_31bf3856ad364e35_6.0.6001.18000_none_2fddb7218242099b\ehdebug.dll
+ 2006-11-02 12:35:33 16,384 ----a-w c:\windows\winsxs\x86_microsoft-windows-ehome-ehssetup_31bf3856ad364e35_6.0.6001.18000_none_91c1b8b7b69b880e\ehssetup.dll
+ 2006-11-02 09:46:11 15,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-font-registrysettings_31bf3856ad364e35_6.0.6001.18000_none_95b1533bb11caa04\muifontsetup.dll
+ 2006-11-02 09:46:02 34,304 ----a-w c:\windows\winsxs\x86_microsoft-windows-gdi_31bf3856ad364e35_6.0.6001.18000_none_a9d318785a865d4c\atmlib.dll
+ 2006-11-02 09:46:03 10,240 ----a-w c:\windows\winsxs\x86_microsoft-windows-gdi_31bf3856ad364e35_6.0.6001.18000_none_a9d318785a865d4c\dciman32.dll
+ 2006-11-02 09:46:05 158,208 ----a-w c:\windows\winsxs\x86_microsoft-windows-htmlhelp-infotech_31bf3856ad364e35_6.0.6001.18000_none_f6a3ed1413ba3d1f\itircl.dll
+ 2006-11-02 09:45:13 14,848 ----a-w c:\windows\winsxs\x86_microsoft-windows-htmlhelp_31bf3856ad364e35_6.0.6001.18000_none_c855f6b284bc7b14\hh.exe
+ 2006-11-02 09:46:05 43,008 ----a-w c:\windows\winsxs\x86_microsoft-windows-htmlhelp_31bf3856ad364e35_6.0.6001.18000_none_c855f6b284bc7b14\hhsetup.dll
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:23 pm
+ 2006-11-02 09:46:05 58,368 ----a-w c:\windows\winsxs\x86_microsoft-windows-i..hinese-imepadapplet_31bf3856ad364e35_6.0.6001.18000_none_fb2914a7fb7f05d4\IMTCDIC.dll
+ 2006-11-02 07:33:43 19,991,040 ----a-w c:\windows\winsxs\x86_microsoft-windows-i..hinese-imepadapplet_31bf3856ad364e35_6.0.6001.18000_none_fb2914a7fb7f05d4\MSHWCHTR.dll
+ 2006-11-02 09:45:17 144,384 ----a-w c:\windows\winsxs\x86_microsoft-windows-i..i_initiator_service_31bf3856ad364e35_6.0.6001.18000_none_da73ab3e1517f045\iscsicli.exe
+ 2006-11-02 09:46:05 49,152 ----a-w c:\windows\winsxs\x86_microsoft-windows-i..i_initiator_service_31bf3856ad364e35_6.0.6001.18000_none_da73ab3e1517f045\iscsidsc.dll
+ 2006-11-02 12:36:18 120,320 ----a-w c:\windows\winsxs\x86_microsoft-windows-i..integration-support_31bf3856ad364e35_6.0.6001.18000_none_2834ca37a387d4a3\idq.dll
+ 2006-11-02 06:58:59 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_6.0.6001.18000_none_15475676099210e3\tzres.dll
+ 2009-01-10 06:55:31 18,944 ----a-w c:\windows\winsxs\x86_microsoft-windows-i..rnational-timezones_31bf3856ad364e35_6.0.6001.18000_none_15475676099210e3\tzupd.exe
+ 2006-11-02 09:46:13 32,256 ----a-w c:\windows\winsxs\x86_microsoft-windows-icm-base_31bf3856ad364e35_6.0.6001.18000_none_22c7ea5489633945\WcsPlugInService.dll
+ 2006-11-02 09:44:59 84,992 ----a-w c:\windows\winsxs\x86_microsoft-windows-icm-ui_31bf3856ad364e35_6.0.6001.18000_none_3a58b76aa0cf669e\colorcpl.exe
+ 2006-11-02 09:46:05 21,504 ----a-w c:\windows\winsxs\x86_microsoft-windows-icm-ui_31bf3856ad364e35_6.0.6001.18000_none_3a58b76aa0cf669e\icmui.dll
+ 2006-11-02 12:34:31 15,616 ----a-w c:\windows\winsxs\x86_microsoft-windows-identitycrl_31bf3856ad364e35_6.0.6001.18000_none_518dd3eb3e5e6f23\ppcrlconfig.dll
+ 2006-11-02 12:34:31 254,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-identitycrl_31bf3856ad364e35_6.0.6001.18000_none_518dd3eb3e5e6f23\ppcrlui.dll
+ 2006-11-02 09:39:30 161,792 ----a-w c:\windows\winsxs\x86_microsoft-windows-ie-adminkitmostfiles_31bf3856ad364e35_6.0.6001.18000_none_ae3221cd06c5e98c\ieakui.dll
+ 2009-01-10 06:49:25 2,455,488 ----a-w c:\windows\winsxs\x86_microsoft-windows-ie-antiphishfilter_31bf3856ad364e35_6.0.6001.18000_none_fb9216576bbe8c39\ieapfltr.dat
+ 2006-11-02 07:33:30 48,128 ----a-w c:\windows\winsxs\x86_microsoft-windows-ie-htmleditingsupport_31bf3856ad364e35_6.0.6001.18000_none_f36d8680ba269c41\mshtmler.dll
+ 2006-11-02 09:45:13 26,624 ----a-w c:\windows\winsxs\x86_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_6.0.6001.18000_none_2f62000919fe80c9\ieUnatt.exe
+ 2006-11-02 09:46:05 16,384 ----a-w c:\windows\winsxs\x86_microsoft-windows-ie-runoncessetup_31bf3856ad364e35_6.0.6001.18000_none_88eec871cb19b965\iessetup.dll
+ 2009-01-10 06:49:07 129,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_6.0.6001.18000_none_47a3aa598c843043\sqmapi.dll
+ 2009-01-10 06:49:13 180,736 ----a-w c:\windows\winsxs\x86_microsoft-windows-ieframe_31bf3856ad364e35_6.0.6001.18000_none_64a26c9fae1f0949\ieui.dll
+ 2006-11-02 12:36:24 98,133 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-legacyscripts_31bf3856ad364e35_6.0.6001.18000_none_7e466ce97736febd\adsutil.vbs
+ 2006-11-02 12:36:24 4,346 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-legacyscripts_31bf3856ad364e35_6.0.6001.18000_none_7e466ce97736febd\clusftp.vbs
+ 2006-11-02 12:36:24 4,341 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-legacyscripts_31bf3856ad364e35_6.0.6001.18000_none_7e466ce97736febd\clusweb.vbs
+ 2006-11-02 12:36:24 41,401 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-legacyscripts_31bf3856ad364e35_6.0.6001.18000_none_7e466ce97736febd\IIsExt.vbs
+ 2006-11-02 12:36:24 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-legacysnapin_31bf3856ad364e35_6.0.6001.18000_none_8120d407b205fdca\iismui.dll
+ 2006-11-02 12:36:24 22,528 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-legacysnapin_31bf3856ad364e35_6.0.6001.18000_none_8120d407b205fdca\InetMgr6.exe
+ 2006-11-02 12:36:21 16,384 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-metabase_31bf3856ad364e35_6.0.6001.18000_none_3931f7d521f321a6\infoadmn.dll
+ 2006-11-02 12:36:21 9,728 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-metabase_31bf3856ad364e35_6.0.6001.18000_none_3931f7d521f321a6\infoctrs.dll
+ 2006-11-02 12:36:21 19,968 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-metabase_31bf3856ad364e35_6.0.6001.18000_none_3931f7d521f321a6\iscomlog.dll
+ 2006-11-02 12:36:21 7,680 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-metabase_31bf3856ad364e35_6.0.6001.18000_none_3931f7d521f321a6\rpcref.dll
+ 2006-11-02 12:36:19 8,192 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-sharedlibraries_31bf3856ad364e35_6.0.6001.18000_none_10e972c4b4d2574c\iisrstap.dll
+ 2006-11-02 12:36:20 10,752 ----a-w c:\windows\winsxs\x86_microsoft-windows-iis-sharedlibraries_31bf3856ad364e35_6.0.6001.18000_none_10e972c4b4d2574c\wamregps.dll
+ 2006-11-02 07:15:56 2,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-installer-engine_31bf3856ad364e35_6.0.6001.18000_none_037a7e2bb384bf01\msimsg.dll
+ 2006-11-02 08:33:06 2,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-international-core_31bf3856ad364e35_6.0.6001.18000_none_e9aa6488d9c10036\normaliz.dll
+ 2006-11-02 09:46:11 10,240 ----a-w c:\windows\winsxs\x86_microsoft-windows-lpksetup_31bf3856ad364e35_6.0.6001.18000_none_215961096c78771c\MUILanguageCleanup.dll
+ 2006-11-02 09:46:09 323,584 ----a-w c:\windows\winsxs\x86_microsoft-windows-m..-components-jet2x3x_31bf3856ad364e35_6.0.6001.18000_none_e79f2d93ba6ffee6\msrd2x40.dll
+ 2006-11-02 12:35:27 8,704 ----a-w c:\windows\winsxs\x86_microsoft-windows-m..essagingcoreservice_31bf3856ad364e35_6.0.6001.18000_none_e309c7bbe82e39d1\mqsvc.exe
+ 2006-11-02 09:46:06 413,696 ----a-w c:\windows\winsxs\x86_microsoft-windows-m..onents-jetexchlotus_31bf3856ad364e35_6.0.6001.18000_none_c33bb5404d731490\msexch40.dll
+ 2006-11-02 12:35:09 3,295,232 ----a-w c:\windows\winsxs\x86_microsoft-windows-m..onwizardapplication_31bf3856ad364e35_6.0.6001.18000_none_ba7b16e99455464b\MIGUIImg.dll
+ 2006-11-02 12:35:09 82,944 ----a-w c:\windows\winsxs\x86_microsoft-windows-m..onwizardapplication_31bf3856ad364e35_6.0.6001.18000_none_ba7b16e99455464b\MIGUIRes.dll
+ 2006-11-02 12:34:36 24,064 ----a-w c:\windows\winsxs\x86_microsoft-windows-mail-app_31bf3856ad364e35_6.0.6001.18000_none_f1582d884fb532fb\DirectDB.dll
+ 2009-01-10 06:34:16 84,480 ----a-w c:\windows\winsxs\x86_microsoft-windows-mail-comm-dll_31bf3856ad364e35_6.0.6001.18000_none_79b12a6a588ca469\INETRES.dll
+ 2006-11-02 12:34:36 2,836,992 ----a-w c:\windows\winsxs\x86_microsoft-windows-mail-core-dll_31bf3856ad364e35_6.0.6001.18000_none_587ec186254a22ac\MSOERES.dll
+ 2006-11-02 07:28:10 39,424 ----a-w c:\windows\winsxs\x86_microsoft-windows-mail-core_31bf3856ad364e35_6.0.6001.18000_none_e9286d318a269033\ACCTRES.dll
+ 2006-11-02 12:35:51 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-mediafoundation_31bf3856ad364e35_6.0.6001.18000_none_9c5f2f3c0cc1aa83\mferror.dll
+ 2009-01-10 06:35:22 24,576 ----a-w c:\windows\winsxs\x86_microsoft-windows-mediafoundation_31bf3856ad364e35_6.0.6001.18000_none_9c5f2f3c0cc1aa83\mfpmp.exe
+ 2009-01-10 06:35:23 98,816 ----a-w c:\windows\winsxs\x86_microsoft-windows-mediafoundation_31bf3856ad364e35_6.0.6001.18000_none_9c5f2f3c0cc1aa83\mfps.dll
+ 2009-01-10 06:35:23 53,248 ----a-w c:\windows\winsxs\x86_microsoft-windows-mediafoundation_31bf3856ad364e35_6.0.6001.18000_none_9c5f2f3c0cc1aa83\rrinstaller.exe
+ 2006-11-02 12:35:54 16,384 ----a-w c:\windows\winsxs\x86_microsoft-windows-mediaplayer-ssetup_31bf3856ad364e35_6.0.6001.18000_none_13b1244660e5fd4e\wmssetup.dll
+ 2006-11-02 12:35:57 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-mediaplayer-wmasf_31bf3856ad364e35_6.0.6001.18000_none_a7b5f0a040680d4c\asferror.dll
+ 2006-11-02 12:35:57 9,728 ----a-w c:\windows\winsxs\x86_microsoft-windows-mediaplayer-wmasf_31bf3856ad364e35_6.0.6001.18000_none_a7b5f0a040680d4c\LAPRXY.DLL
+ 2006-11-02 12:35:09 9,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-migrationengine_31bf3856ad364e35_6.0.6001.18000_none_58a7d7b2db3ffcd4\migres.dll
+ 2006-09-18 21:33:22 673,088 ----a-w c:\windows\winsxs\x86_microsoft-windows-mlang_31bf3856ad364e35_6.0.6001.18000_none_56df4b78e3fe4e3f\mlang.dat
+ 2006-11-02 12:36:06 150,016 ----a-w c:\windows\winsxs\x86_microsoft-windows-moviemaker_31bf3856ad364e35_6.0.6001.18000_none_f261ec400d1da6d8\MOVIEMK.exe
+ 2006-11-02 12:36:05 23,040 ----a-w c:\windows\winsxs\x86_microsoft-windows-moviemaker_31bf3856ad364e35_6.0.6001.18000_none_f261ec400d1da6d8\WMM2EXT.dll
+ 2006-11-02 09:40:16 145,920 ----a-w c:\windows\winsxs\x86_microsoft-windows-msauditevtlog_31bf3856ad364e35_6.0.6001.18000_none_c7427a4e786d74bc\msaudite.dll
+ 2006-11-02 12:35:28 13,824 ----a-w c:\windows\winsxs\x86_microsoft-windows-msmq-admin_31bf3856ad364e35_6.0.6001.18000_none_b74e019e3d6c64b6\mqcertui.dll
+ 2009-01-10 06:57:46 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-msxml30_31bf3856ad364e35_6.0.6001.18000_none_886e409a96d6223c\msxml3r.dll
+ 2009-01-10 06:32:20 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-msxml60_31bf3856ad364e35_6.0.6001.18000_none_886dfc4296d66f1f\msxml6r.dll
+ 2006-11-02 09:46:10 34,304 ----a-w c:\windows\winsxs\x86_microsoft-windows-mulanttsvoicecommon_31bf3856ad364e35_6.0.6001.18000_none_e1e971f061eb63bb\MSTTSCommon.dll
+ 2006-11-02 09:46:10 47,104 ----a-w c:\windows\winsxs\x86_microsoft-windows-mulanttsvoicecommon_31bf3856ad364e35_6.0.6001.18000_none_e1e971f061eb63bb\MSTTSDecWrp.dll
+ 2006-11-02 09:46:10 8,704 ----a-w c:\windows\winsxs\x86_microsoft-windows-mulanttsvoicecommon_31bf3856ad364e35_6.0.6001.18000_none_e1e971f061eb63bb\MSTTSLoc.dll
+ 2009-01-10 07:11:32 28,672 ----a-w c:\windows\winsxs\x86_microsoft-windows-n..-domain-clients-svc_31bf3856ad364e35_6.0.6001.18000_none_440e77d1ec053e6c\FwRemoteSvr.dll
+ 2009-01-10 07:11:32 272,896 ----a-w c:\windows\winsxs\x86_microsoft-windows-n..-domain-clients-svc_31bf3856ad364e35_6.0.6001.18000_none_440e77d1ec053e6c\polstore.dll
+ 2009-01-10 07:11:32 61,440 ----a-w c:\windows\winsxs\x86_microsoft-windows-n..-domain-clients-svc_31bf3856ad364e35_6.0.6001.18000_none_440e77d1ec053e6c\winipsec.dll
+ 2006-11-02 09:46:11 11,776 ----a-w c:\windows\winsxs\x86_microsoft-windows-n..iagnosticsframework_31bf3856ad364e35_6.0.6001.18000_none_dc5ac24ae0ca36fc\ndproxystub.dll
+ 2006-11-02 12:34:31 268,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-nap-oobsha_31bf3856ad364e35_6.0.6001.18000_none_93e3b78243a9d8c2\msshavmsg.dll
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:24 pm
+ 2009-01-10 06:45:37 1,523,712 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0000.dll
+ 2009-01-10 06:45:36 2,599,936 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0001.dll
+ 2009-01-10 06:45:36 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0002.dll
+ 2009-01-10 06:45:35 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0003.dll
+ 2009-01-10 06:45:35 2,243,072 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0007.dll
+ 2009-01-10 06:45:34 4,875,776 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0009.dll
+ 2009-01-10 06:45:31 9,847,296 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData000a.dll
+ 2009-01-10 06:45:30 2,643,456 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData000c.dll
+ 2009-01-10 06:45:30 2,342,912 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData000d.dll
+ 2009-01-10 06:45:30 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData000f.dll
+ 2009-01-10 06:45:38 4,495,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0010.dll
+ 2009-01-10 06:45:38 2,657,280 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0011.dll
+ 2009-01-10 06:45:37 3,466,752 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0013.dll
+ 2009-01-10 06:45:37 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0018.dll
+ 2009-01-10 06:45:36 4,497,408 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0019.dll
+ 2009-01-10 06:45:32 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData001a.dll
+ 2009-01-10 06:45:32 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData001b.dll
+ 2009-01-10 06:45:31 4,495,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData001d.dll
+ 2009-01-10 06:45:39 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0020.dll
+ 2009-01-10 06:45:39 1,801,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0021.dll
+ 2009-01-10 06:45:39 1,801,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0022.dll
+ 2009-01-10 06:45:39 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0024.dll
+ 2009-01-10 06:45:38 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0026.dll
+ 2009-01-10 06:45:38 1,966,592 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0027.dll
+ 2009-01-10 06:45:32 1,801,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData002a.dll
+ 2009-01-10 06:45:40 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0039.dll
+ 2009-01-10 06:45:33 1,801,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData003e.dll
+ 2009-01-10 06:45:41 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0045.dll
+ 2009-01-10 06:45:41 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0046.dll
+ 2009-01-10 06:45:40 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0047.dll
+ 2009-01-10 06:45:40 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0049.dll
+ 2009-01-10 06:45:34 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData004a.dll
+ 2009-01-10 06:45:33 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData004b.dll
+ 2009-01-10 06:45:33 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData004c.dll
+ 2009-01-10 06:45:33 3,104,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData004e.dll
+ 2009-01-10 06:45:30 4,495,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0414.dll
+ 2009-01-10 06:45:29 4,495,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0416.dll
+ 2009-01-10 06:45:28 4,495,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0816.dll
+ 2009-01-10 06:45:28 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData081a.dll
+ 2009-01-10 06:45:27 1,965,056 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsData0c1a.dll
+ 2006-11-02 08:21:55 11,722,752 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0001.dll
+ 2006-11-02 08:22:34 4,164,096 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0002.dll
+ 2006-11-02 08:22:13 1,452,544 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0003.dll
+ 2006-11-02 08:22:07 12,038,656 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0007.dll
+ 2006-11-02 08:22:05 2,628,608 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0009.dll
+ 2006-11-02 08:22:11 9,892,864 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons000a.dll
+ 2006-11-02 08:22:06 6,237,696 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons000c.dll
+ 2006-11-02 08:22:09 1,722,368 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons000d.dll
+ 2006-11-02 08:22:17 5,654,528 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons000f.dll
+ 2006-11-02 08:22:18 4,175,872 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0010.dll
+ 2006-11-02 08:22:10 2,466,816 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0011.dll
+ 2006-11-02 08:21:58 4,981,248 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0013.dll
+ 2006-11-02 08:22:25 3,331,072 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0018.dll
+ 2006-11-02 08:22:26 6,781,440 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0019.dll
+ 2006-11-02 08:22:14 6,014,976 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons001a.dll
+ 2006-11-02 08:22:47 6,585,856 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons001b.dll
+ 2006-11-02 08:22:31 6,346,240 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons001d.dll
+ 2006-11-02 08:22:45 1,236,992 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0020.dll
+ 2006-11-02 08:22:12 2,136,064 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0021.dll
+ 2006-11-02 08:22:44 5,499,904 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0022.dll
+ 2006-11-02 08:22:49 7,964,672 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0024.dll
+ 2006-11-02 08:22:42 5,791,232 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0026.dll
+ 2006-11-02 08:22:19 6,224,896 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0027.dll
+ 2006-11-02 08:22:41 4,096 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons002a.dll
+ 2006-11-02 08:22:16 1,782,272 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0039.dll
+ 2006-11-02 08:22:20 4,045,824 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons003e.dll
+ 2006-11-02 08:22:33 1,793,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0045.dll
+ 2006-11-02 08:22:25 1,808,896 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0046.dll
+ 2006-11-02 08:22:15 1,411,072 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0047.dll
+ 2006-11-02 08:22:39 1,558,016 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0049.dll
+ 2006-11-02 08:22:39 3,419,136 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons004a.dll
+ 2006-11-02 08:22:36 1,702,912 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons004b.dll
+ 2006-11-02 08:22:46 4,093,440 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons004c.dll
+ 2006-11-02 08:22:37 1,972,736 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons004e.dll
+ 2006-11-02 08:22:21 4,616,192 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0414.dll
+ 2006-11-02 08:22:24 5,090,816 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0416.dll
+ 2006-11-02 08:22:22 5,031,936 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0816.dll
AARG12
OS : Windows Vista
+ 2006-11-02 08:22:29 7,042,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons081a.dll
+ 2006-11-02 08:22:27 6,917,120 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsLexicons0c1a.dll
+ 2006-11-02 08:21:54 5,071,872 ----a-w c:\windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.0.6001.18000_none_9ddad43a2abbd52d\NlsModels0011.dll
+ 2006-11-02 09:41:16 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-net-command-line-tool_31bf3856ad364e35_6.0.6001.18000_none_5232518072770fdb\neth.dll
+ 2006-11-02 09:46:14 11,264 ----a-w c:\windows\winsxs\x86_microsoft-windows-netbios_31bf3856ad364e35_6.0.6001.18000_none_59e1b82a6b1f4ec0\wshnetbs.dll
+ 2006-09-19 11:41:49 2,456 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\bench_24.bin
+ 2006-09-19 11:41:49 4,280 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\bench_32.bin
+ 2006-09-19 11:41:49 9,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\bench_48.bin
+ 2006-09-19 11:41:49 2,456 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\house_24.bin
+ 2006-09-19 11:41:49 4,280 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\house_32.bin
+ 2006-09-19 11:41:49 9,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\house_48.bin
+ 2006-09-19 11:41:49 2,456 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\office_24.bin
+ 2006-09-19 11:41:49 4,280 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\office_32.bin
+ 2006-09-19 11:41:49 9,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-netshell_31bf3856ad364e35_6.0.6001.18000_none_d5836ad30e0ac92d\office_48.bin
+ 2006-11-02 09:46:02 24,064 ----a-w c:\windows\winsxs\x86_microsoft-windows-networkbridge_31bf3856ad364e35_6.0.6001.18000_none_07e9f0db06159927\brdgcfg.dll
+ 2006-11-02 07:38:48 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-networkbridge_31bf3856ad364e35_6.0.6001.18000_none_07e9f0db06159927\bridgeres.dll
+ 2006-11-02 09:46:11 11,264 ----a-w c:\windows\winsxs\x86_microsoft-windows-networkprofile_31bf3856ad364e35_6.0.6001.18000_none_789b515a7625c7d5\nlmsprep.dll
+ 2006-11-02 09:46:12 16,384 ----a-w c:\windows\winsxs\x86_microsoft-windows-networkprofile_31bf3856ad364e35_6.0.6001.18000_none_789b515a7625c7d5\npmproxy.dll
+ 2006-11-02 12:36:04 51,712 ----a-w c:\windows\winsxs\x86_microsoft-windows-networkprojection_31bf3856ad364e35_6.0.6001.18000_none_e3c78331f0bd2d51\CRPPresentation.dll
+ 2006-11-02 12:36:04 89,600 ----a-w c:\windows\winsxs\x86_microsoft-windows-networkprojection_31bf3856ad364e35_6.0.6001.18000_none_e3c78331f0bd2d51\NetProj.exe
+ 2006-11-02 07:38:59 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-networktopology_31bf3856ad364e35_6.0.6001.18000_none_d155f734fa7d6b4f\lltdres.dll
+ 2006-11-02 09:45:30 74,752 ----a-w c:\windows\winsxs\x86_microsoft-windows-newdev_31bf3856ad364e35_6.0.6001.18000_none_11764b5450a917b3\newdev.exe
+ 2006-11-02 07:09:42 9,029 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\ANSI.SYS
+ 2006-11-02 07:09:49 12,498 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\append.exe
+ 2006-11-02 07:10:16 10,544 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\COMM.drv
+ 2006-11-02 07:09:49 50,648 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\COMMAND.COM
+ 2006-11-02 07:10:28 32,816 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\COMMDLG.DLL
+ 2006-11-02 07:09:45 27,097 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\country.sys
+ 2006-09-18 21:43:37 27,200 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\ctl3dv2.dll
+ 2006-11-02 07:10:32 39,424 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\DDEML.DLL
+ 2006-11-02 07:09:52 20,634 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\debug.exe
+ 2006-11-02 07:10:37 53,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\dosx.exe
+ 2006-11-02 07:10:29 28,112 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\DRWATSON.EXE
+ 2006-09-18 21:43:40 69,886 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\edit.com
+ 2006-11-02 07:09:50 12,642 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\edlin.exe
+ 2006-11-02 07:09:51 8,424 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\exe2bin.exe
+ 2006-11-02 07:10:13 24,576 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\GDI.EXE
+ 2006-11-02 07:09:59 19,694 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\GRAPHICS.COM
+ 2006-11-02 07:09:41 4,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\HIMEM.SYS
+ 2006-11-02 07:09:57 14,710 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\KB16.COM
+ 2006-11-02 07:09:44 42,809 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\KEY01.SYS
+ 2006-11-02 07:10:15 2,000 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\keyboard.drv
+ 2006-11-02 07:09:44 42,537 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\KEYBOARD.SYS
+ 2006-11-02 07:10:07 92,320 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\krnl386.exe
+ 2006-09-18 21:43:37 221,600 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\lanman.drv
+ 2006-09-18 21:43:37 9,936 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\lzexpand.dll
+ 2006-11-02 07:09:55 39,274 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\mem.exe
+ 2006-11-02 07:10:21 68,992 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\MMSYSTEM.DLL
+ 2006-11-02 07:10:18 2,032 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\mouse.drv
+ 2006-09-18 21:43:37 108,464 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\netapi.dll
+ 2006-11-02 07:09:56 7,052 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\nlsfunc.exe
+ 2006-11-02 07:09:29 27,866 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTDOS.SYS
+ 2006-11-02 07:09:35 29,146 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTDOS404.SYS
+ 2006-11-02 07:09:38 29,370 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTDOS411.SYS
+ 2006-11-02 07:09:40 29,274 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTDOS412.SYS
+ 2006-11-02 07:09:31 29,146 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTDOS804.SYS
+ 2006-11-02 07:09:20 33,952 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTIO.SYS
+ 2006-11-02 07:09:23 34,672 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTIO404.SYS
+ 2006-11-02 07:09:24 35,776 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTIO411.SYS
+ 2006-11-02 07:09:26 35,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTIO412.SYS
+ 2006-11-02 07:09:22 34,672 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\NTIO804.SYS
+ 2006-11-02 09:46:12 14,848 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\ntvdmd.dll
+ 2006-09-18 21:43:37 82,944 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\olecli.dll
+ 2006-11-02 07:10:34 24,064 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\OLESVR.DLL
+ 2006-09-18 21:43:37 46,592 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\pmspl.dll
+ 2006-11-02 07:10:00 2,842 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\redir.exe
+ 2006-11-02 07:09:53 11,753 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\setver.exe
+ 2006-11-02 07:10:14 5,120 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\SHELL.DLL
+ 2006-11-02 07:10:16 1,744 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\sound.drv
+ 2006-09-18 21:43:37 18,896 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\sysedit.exe
+ 2006-11-02 07:10:14 3,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\system.drv
+ 2006-11-02 07:10:26 4,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\TIMER.DRV
+ 2006-11-02 07:10:25 13,888 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\TOOLHELP.DLL
AARG12
OS : Windows Vista
Solved Re: I NEED HELP WITH Troj/Rustok-N i cant get rid of it!!!
Post by AARG12 on Mon Jan 19, 2009 7:25 pm
+ 2006-11-02 07:10:12 47,840 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\USER.EXE
+ 2006-09-18 21:43:37 9,008 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\ver.dll
+ 2006-11-02 07:10:17 2,176 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\vga.drv
+ 2006-11-02 07:10:30 12,704 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\WFWNET.DRV
+ 2006-11-02 07:10:35 9,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\WIFEMAN.DLL
+ 2006-11-02 08:35:53 6,656 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\win.com
+ 2006-09-18 21:43:37 13,312 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\win87em.dll
+ 2006-09-18 21:43:37 256,192 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\winhelp.exe
+ 2006-11-02 07:10:35 5,120 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\WINNLS.DLL
+ 2006-11-02 07:10:22 2,864 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\WINSOCK.DLL
+ 2006-11-02 07:10:18 2,112 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\WINSPOOL.EXE
+ 2006-11-02 07:10:27 2,864 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\WOWDEB.EXE
+ 2006-11-02 07:10:24 8,960 ----a-w c:\windows\winsxs\x86_microsoft-windows-ntvdm-system32_31bf3856ad364e35_6.0.6001.18000_none_fe0d791a728dd79c\WOWEXEC.EXE
+ 2008-12-08 23:22:10 2,410,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-oespamfilter-dat_31bf3856ad364e35_6.0.6000.16787_none_f052600a6e8e5046\OESpamFilter.dat
+ 2008-12-08 23:23:32 2,410,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-oespamfilter-dat_31bf3856ad364e35_6.0.6000.20972_none_f0e1cd3587a85293\OESpamFilter.dat
+ 2008-12-09 23:54:42 2,410,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-oespamfilter-dat_31bf3856ad364e35_6.0.6001.18182_none_f2339d3e6bb96284\OESpamFilter.dat
+ 2008-12-09 23:55:37 2,410,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-oespamfilter-dat_31bf3856ad364e35_6.0.6001.22327_none_f3031ce984a1d682\OESpamFilter.dat
+ 2006-11-02 09:45:33 60,416 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..installerandprintui_31bf3856ad364e35_6.0.6001.18000_none_d6543f9ff5ec4aec\printui.exe
+ 2006-11-02 09:45:02 17,408 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ncetoolscommandline_31bf3856ad364e35_6.0.6001.18000_none_61237ad0fed51e58\diskperf.exe
+ 2006-11-02 09:45:35 37,376 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ncetoolscommandline_31bf3856ad364e35_6.0.6001.18000_none_61237ad0fed51e58\relog.exe
+ 2006-11-02 09:45:49 39,936 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ncetoolscommandline_31bf3856ad364e35_6.0.6001.18000_none_61237ad0fed51e58\typeperf.exe
+ 2009-01-10 06:39:40 37,888 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ooler-networkclient_31bf3856ad364e35_6.0.6001.18000_none_39733ab970ea03f2\printcom.dll
+ 2006-11-02 09:46:12 39,424 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ormancebasecounters_31bf3856ad364e35_6.0.6001.18000_none_31733dc35d19d298\perfctrs.dll
+ 2006-11-02 09:46:12 31,744 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ormancebasecounters_31bf3856ad364e35_6.0.6001.18000_none_31733dc35d19d298\perfdisk.dll
+ 2006-11-02 09:46:12 28,672 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ormancebasecounters_31bf3856ad364e35_6.0.6001.18000_none_31733dc35d19d298\perfos.dll
+ 2006-11-02 09:46:12 35,840 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ormancebasecounters_31bf3856ad364e35_6.0.6001.18000_none_31733dc35d19d298\perfproc.dll
+ 2006-11-02 09:45:31 61,440 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..randprintui-ntprint_31bf3856ad364e35_6.0.6001.18000_none_f0037a3c7d6c36a4\ntprint.exe
+ 2006-11-02 09:45:32 7,680 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..rastructureconsumer_31bf3856ad364e35_6.0.6001.18000_none_b3dc8e9f30720cdd\plasrv.exe
+ 2006-11-02 12:36:18 20,992 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ting-lprportmonitor_31bf3856ad364e35_6.0.6001.18000_none_b403a1813dce9905\lprmon.dll
+ 2006-11-02 12:36:18 11,776 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..ting-lprportmonitor_31bf3856ad364e35_6.0.6001.18000_none_b403a1813dce9905\lprmonui.dll
+ 2006-11-02 12:35:39 1,486,848 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..topeeradhocmeetings_31bf3856ad364e35_6.0.6001.18000_none_aa47d5c4002219b8\WinCollabRes.dll
+ 2009-01-10 06:43:31 30,674 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..unterinfrastructure_31bf3856ad364e35_6.0.6001.18000_none_7185fd57fee6c971\perfc.dat
+ 2009-01-10 06:43:31 30,674 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..unterinfrastructure_31bf3856ad364e35_6.0.6001.18000_none_7185fd57fee6c971\perfd.dat
+ 2009-01-10 06:43:31 287,440 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..unterinfrastructure_31bf3856ad364e35_6.0.6001.18000_none_7185fd57fee6c971\perfh.dat
+ 2009-01-10 06:43:31 287,440 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..unterinfrastructure_31bf3856ad364e35_6.0.6001.18000_none_7185fd57fee6c971\perfi.dat
+ 2006-11-02 09:42:44 17,408 ----a-w c:\windows\winsxs\x86_microsoft-windows-p..unterinfrastructure_31bf3856ad364e35_6.0.6001.18000_none_7185fd57fee6c971\prflbmsg.dll
+ 2006-11-02 12:35:38 18,944 ----a-w c:\windows\winsxs\x86_microsoft-windows-peertopeerpnrp_31bf3856ad364e35_6.0.6001.18000_none_717f15b322749509\pnrpperf.dll
+ 2006-11-02 09:45:32 13,312 ----a-w c:\windows\winsxs\x86_microsoft-windows-ping-utilities_31bf3856ad364e35_6.0.6001.18000_none_a931a5078fdac855\PATHPING.EXE
+ 2006-11-02 09:45:49 12,288 ----a-w c:\windows\winsxs\x86_microsoft-windows-ping-utilities_31bf3856ad364e35_6.0.6001.18000_none_a931a5078fdac855\TRACERT.EXE
+ 2006-11-02 09:46:12 15,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-qos_31bf3856ad364e35_6.0.6001.18000_none_ae4b689057a4a1e3\pacerprf.dll
+ 2006-11-02 09:46:13 33,280 ----a-w c:\windows\winsxs\x86_microsoft-windows-qos_31bf3856ad364e35_6.0.6001.18000_none_ae4b689057a4a1e3\traffic.dll
+ 2006-11-02 09:46:14 13,824 ----a-w c:\windows\winsxs\x86_microsoft-windows-qos_31bf3856ad364e35_6.0.6001.18000_none_ae4b689057a4a1e3\wshqos.dll
+ 2006-11-02 12:36:25 7,168 ----a-w c:\windows\winsxs\x86_microsoft-windows-r..emanagement-service_31bf3856ad364e35_6.0.6001.18000_none_0e3e31f00e12b007\mll_hp.dll
+ 2006-11-02 12:36:25 17,408 ----a-w c:\windows\winsxs\x86_microsoft-windows-r..emanagement-service_31bf3856ad364e35_6.0.6001.18000_none_0e3e31f00e12b007\ntmsevt.dll
+ 2006-11-02 12:36:25 43,008 ----a-w c:\windows\winsxs\x86_microsoft-windows-r..emanagement-service_31bf3856ad364e35_6.0.6001.18000_none_0e3e31f00e12b007\rsm.exe
+ 2006-11-02 12:36:25 26,624 ----a-w c:\windows\winsxs\x86_microsoft-windows-r..emanagement-service_31bf3856ad364e35_6.0.6001.18000_none_0e3e31f00e12b007\rsmmllsv.exe
+ 2006-11-02 12:36:25 22,016 ----a-w c:\windows\winsxs\x86_microsoft-windows-r..emanagement-service_31bf3856ad364e35_6.0.6001.18000_none_0e3e31f00e12b007\rsmsink.exe
+ 2006-11-02 12:36:25 54,272 ----a-w c:\windows\winsxs\x86_microsoft-windows-r..emanagement-service_31bf3856ad364e35_6.0.6001.18000_none_0e3e31f00e12b007\rsmui.exe
+ 2006-11-02 09:46:12 10,240 ----a-w c:\windows\winsxs\x86_microsoft-windows-rasautodial_31bf3856ad364e35_6.0.6001.18000_none_0fd9feb665531f63\rasadhlp.dll
+ 2006-11-02 09:45:34 16,896 ----a-w c:\windows\winsxs\x86_microsoft-windows-rasautodial_31bf3856ad364e35_6.0.6001.18000_none_0fd9feb665531f63\rasautou.exe
+ 2006-11-02 09:46:12 32,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-rasbase_31bf3856ad364e35_6.0.6001.18000_none_0de067e17a6f4519\rasmxs.dll
+ 2006-11-02 09:46:12 22,016 ----a-w c:\windows\winsxs\x86_microsoft-windows-rasbase_31bf3856ad364e35_6.0.6001.18000_none_0de067e17a6f4519\rasser.dll
+ 2006-11-02 09:45:34 16,896 ----a-w c:\windows\winsxs\x86_microsoft-windows-rasclienttools_31bf3856ad364e35_6.0.6001.18000_none_6f46cfc8a8b142a0\rasdial.exe
+ 2006-11-02 09:46:12 36,352 ----a-w c:\windows\winsxs\x86_microsoft-windows-rasrtutils_31bf3856ad364e35_6.0.6001.18000_none_0d159410ea7a8f9d\rtutils.dll
AARG12
OS : Windows Vista
+ 2006-11-02 09:46:02 13,824 ----a-w c:\windows\winsxs\x86_microsoft-windows-registry-editor_31bf3856ad364e35_6.0.6001.18000_none_f42eb564dbd8a697\clb.dll
+ 2006-11-02 09:45:35 9,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-registry-editor_31bf3856ad364e35_6.0.6001.18000_none_f42eb564dbd8a697\regedt32.exe
+ 2006-11-02 12:35:24 40,960 ----a-w c:\windows\winsxs\x86_microsoft-windows-remoteassistance-exe_31bf3856ad364e35_6.0.6001.18000_none_3758172c01e5ce47\racpldlg.dll
+ 2006-11-02 09:45:37 14,848 ----a-w c:\windows\winsxs\x86_microsoft-windows-restartmanager_31bf3856ad364e35_6.0.6001.18000_none_803567cb241e9c20\RmClient.exe
+ 2009-01-10 06:39:32 14,848 ----a-w c:\windows\winsxs\x86_microsoft-windows-rmcast_31bf3856ad364e35_6.0.6001.18000_none_547dcc3187eaff70\wshrm.dll
+ 2006-11-02 09:46:03 10,240 ----a-w c:\windows\winsxs\x86_microsoft-windows-s..gevolumewmiprovider_31bf3856ad364e35_6.0.6001.18000_none_17d3c60709ecb009\dfrgifps.dll
+ 2006-11-02 12:35:38 12,555,776 ----a-w c:\windows\winsxs\x86_microsoft-windows-s..inboxgames-shanghai_31bf3856ad364e35_6.0.6001.18000_none_c0a3fbb5ef29fe27\Mahjong.dll
+ 2006-11-02 12:35:37 29,001,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-s..iuminboxgames-chess_31bf3856ad364e35_6.0.6001.18000_none_74d4a1cd7e673a2e\Chess.dll
+ 2006-11-02 12:35:35 4,305,408 ----a-w c:\windows\winsxs\x86_microsoft-windows-s..oxgames-minesweeper_31bf3856ad364e35_6.0.6001.18000_none_a2611d5c392f48a1\MineSweeper.dll
+ 2006-11-02 12:35:36 28,665,856 ----a-w c:\windows\winsxs\x86_microsoft-windows-s..oxgames-purbleplace_31bf3856ad364e35_6.0.6001.18000_none_062b7e7afe71e492\PurblePlace.dll
+ 2006-11-02 12:35:35 8,384,512 ----a-w c:\windows\winsxs\x86_microsoft-windows-s..oxgames-purbleplace_31bf3856ad364e35_6.0.6001.18000_none_062b7e7afe71e492\PurblePlace2.dll
+ 2006-11-02 09:46:12 42,496 ----a-w c:\windows\winsxs\x86_microsoft-windows-s..ty-protectedstorage_31bf3856ad364e35_6.0.6001.18000_none_4849149a305ec4a4\pstorec.dll
+ 2006-11-02 09:46:12 23,040 ----a-w c:\windows\winsxs\x86_microsoft-windows-s..ty-protectedstorage_31bf3856ad364e35_6.0.6001.18000_none_4849149a305ec4a4\pstorsvc.dll
+ 2006-11-02 09:46:14 8,192 ----a-w c:\windows\winsxs\x86_microsoft-windows-session0viewer_31bf3856ad364e35_6.0.6001.18000_none_e1e6e80246adfe72\WlS0WndH.dll
+ 2006-11-02 09:43:11 2,928,640 ----a-w c:\windows\winsxs\x86_microsoft-windows-setup-component_31bf3856ad364e35_6.0.6001.18000_none_322c7e4ead424897\W32UIImg.dll
+ 2006-11-02 09:46:13 4,608 ----a-w c:\windows\winsxs\x86_microsoft-windows-sfc_31bf3856ad364e35_6.0.6001.18000_none_a735c34c5c31a578\sfc.dll
+ 2006-11-02 12:35:15 66,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-sidebar_31bf3856ad364e35_6.0.6001.18000_none_cedcabbd26a81ad6\sbdrop.dll
+ 2006-11-02 09:46:12 66,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-smartcardsubsystem_31bf3856ad364e35_6.0.6001.18000_none_17fd3fa469f2e862\SCardDlg.dll
+ 2008-12-16 03:14:37 290,304 ----a-w c:\windows\winsxs\x86_microsoft-windows-smbserver-v1_31bf3856ad364e35_6.0.6000.16789_none_d7c3afd4f985c7a2\srv.sys
+ 2008-12-16 03:07:02 290,816 ----a-w c:\windows\winsxs\x86_microsoft-windows-smbserver-v1_31bf3856ad364e35_6.0.6000.20976_none_d8551d94129dfc9d\srv.sys
+ 2008-12-16 02:42:39 288,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-smbserver-v1_31bf3856ad364e35_6.0.6001.18185_none_d9a5ed52f6aff337\srv.sys
+ 2008-12-16 01:53:56 288,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-smbserver-v1_31bf3856ad364e35_6.0.6001.22331_none_da619a780fa89f17\srv.sys
+ 2006-11-02 09:46:13 9,728 ----a-w c:\windows\winsxs\x86_microsoft-windows-smbserver_31bf3856ad364e35_6.0.6001.18000_none_f8f4e8f8eadb7d91\sscore.dll
+ 2006-11-02 09:45:46 12,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-snmp-trap-service_31bf3856ad364e35_6.0.6001.18000_none_cf8afedd3f67da88\snmptrap.exe
+ 2006-11-02 12:34:32 16,384 ----a-w c:\windows\winsxs\x86_microsoft-windows-speech-userexperience_31bf3856ad364e35_6.0.6001.18000_none_1c09f00b4bcc9fbc\SpeechUXPS.DLL
+ 2006-11-02 09:46:13 151,040 ----a-w c:\windows\winsxs\x86_microsoft-windows-sqlliteoledb_31bf3856ad364e35_6.0.6001.18000_none_be7f06c980d3ea88\sqlceoledb30.dll
+ 2006-11-02 09:39:30 3,072 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..-platform-libraries_31bf3856ad364e35_6.0.6001.18000_none_ea70eae59b4e2b12\icmp.dll
+ 2006-11-02 07:39:56 1,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\penchs.dll
+ 2006-11-02 07:39:56 1,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\pencht.dll
+ 2006-11-02 07:39:56 1,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\penjpn.dll
+ 2006-11-02 07:39:56 1,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\penkor.dll
+ 2006-11-02 07:39:56 1,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\penusa.dll
+ 2006-11-02 09:45:32 6,656 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\pipanel.exe
+ 2006-11-02 07:39:56 1,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\pipres.dll
+ 2006-11-02 07:39:56 1,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\skchobj.dll
+ 2006-11-02 07:39:56 1,536 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6001.18000_none_41f1cbcb89954931\skchui.dll
+ 2006-11-02 12:35:47 19,968 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..c-journalnotewriter_31bf3856ad364e35_6.0.6001.18000_none_4264ef6a4d057d2c\jnwmon.dll
+ 2006-11-02 12:35:47 22,528 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..c-journalnotewriter_31bf3856ad364e35_6.0.6001.18000_none_4264ef6a4d057d2c\jnwppr.dll
+ 2006-11-02 12:35:47 47,104 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..c-journalnotewriter_31bf3856ad364e35_6.0.6001.18000_none_4264ef6a4d057d2c\PDIALOG.exe
+ 2006-11-02 12:35:44 1,495,040 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..krecognition.zh-chs_31bf3856ad364e35_6.0.6001.18000_none_fd484d54658ae209\chslm.lex.bin
+ 2006-11-02 12:35:44 10,335,843 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..krecognition.zh-chs_31bf3856ad364e35_6.0.6001.18000_none_fd484d54658ae209\chslm.wdic2.bin
+ 2006-11-02 12:35:44 21,963,264 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..krecognition.zh-chs_31bf3856ad364e35_6.0.6001.18000_none_fd484d54658ae209\mshwchsr.dll
+ 2006-11-02 12:35:46 2,187,264 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..krecognition.zh-cht_31bf3856ad364e35_6.0.6001.18000_none_fd48368c658afbaa\chtlm.lex.bin
+ 2006-11-02 12:35:45 11,300,913 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..krecognition.zh-cht_31bf3856ad364e35_6.0.6001.18000_none_fd48368c658afbaa\chtlm.wdic2.bin
+ 2006-11-02 12:35:45 19,991,040 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..krecognition.zh-cht_31bf3856ad364e35_6.0.6001.18000_none_fd48368c658afbaa\mshwchtr.dll
+ 2006-11-02 12:35:47 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..nputpersonalization_31bf3856ad364e35_6.0.6001.18000_none_3fac12f5c6543548\IPSEventLogMsg.dll
+ 2006-11-02 12:35:47 19,456 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..nputpersonalization_31bf3856ad364e35_6.0.6001.18000_none_3fac12f5c6543548\TabIpsps.dll
+ 2006-11-02 12:35:48 19,968 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..ournalnotewriterqfe_31bf3856ad364e35_6.0.6001.18000_none_4d983a117ea4cea6\jnwmon.dll
+ 2006-11-02 12:35:48 22,528 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..ournalnotewriterqfe_31bf3856ad364e35_6.0.6001.18000_none_4d983a117ea4cea6\jnwppr.dll
+ 2006-11-02 12:35:24 68,096 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..platform-input-core_31bf3856ad364e35_6.0.6001.18000_none_d1104c78dccde5fe\TabSvc.dll
+ 2006-11-02 12:35:24 2,073,600 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..platform-input-core_31bf3856ad364e35_6.0.6001.18000_none_d1104c78dccde5fe\TouchX.dll
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:26 pm
+ 2006-11-02 12:35:40 13,577,657 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..reinkrecognition.ja_31bf3856ad364e35_6.0.6001.18000_none_03ed68ae2c4994ef\dicjp.bin
+ 2006-11-02 12:35:41 8,704 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..reinkrecognition.ja_31bf3856ad364e35_6.0.6001.18000_none_03ed68ae2c4994ef\dicjp.dll
+ 2006-11-02 12:35:40 21,462,016 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..reinkrecognition.ja_31bf3856ad364e35_6.0.6001.18000_none_03ed68ae2c4994ef\mshwjpnr.dll
+ 2006-11-02 12:35:41 21,827,584 ----a-w c:\windows\winsxs\x86_microsoft-windows-t..reinkrecognition.ko_31bf3856ad364e35_6.0.6001.18000_none_03ed2a082c4a1514\mshwkorr.dll
+ 2006-11-02 12:35:47 114,688 ----a-w c:\windows\winsxs\x86_microsoft-windows-tabletpc-inputpanel_31bf3856ad364e35_6.0.6001.18000_none_118f15c677824d1e\TipBand.dll
+ 2006-11-02 12:35:47 1,149,440 ----a-w c:\windows\winsxs\x86_microsoft-windows-tabletpc-inputpanel_31bf3856ad364e35_6.0.6001.18000_none_118f15c677824d1e\TipRes.dll
+ 2006-11-02 12:35:48 47,104 ----a-w c:\windows\winsxs\x86_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.0.6001.18000_none_17b18851a49835e5\NBMapTIP.dll
+ 2006-11-02 12:35:43 149,504 ----a-w c:\windows\winsxs\x86_microsoft-windows-tabletpc-softkeyboard_31bf3856ad364e35_6.0.6001.18000_none_d1b1affa515cd235\tabskb.dll
+ 2006-11-02 09:46:13 858,112 ----a-w c:\windows\winsxs\x86_microsoft-windows-tapi3_31bf3856ad364e35_6.0.6001.18000_none_6148b1ca8f906dbb\tapi3.dll
+ 2006-11-02 09:46:13 9,216 ----a-w c:\windows\winsxs\x86_microsoft-windows-tapisetup_31bf3856ad364e35_6.0.6001.18000_none_69f32ac39b2a05e1\TapiSysprep.dll
+ 2006-11-02 09:45:48 10,752 ----a-w c:\windows\winsxs\x86_microsoft-windows-tapisetup_31bf3856ad364e35_6.0.6001.18000_none_69f32ac39b2a05e1\TapiUnattend.exe
+ 2006-11-02 09:44:50 19,968 ----a-w c:\windows\winsxs\x86_microsoft-windows-tcpip-utility_31bf3856ad364e35_6.0.6001.18000_none_32c6f3aa4ede22b3\ARP.EXE
+ 2006-11-02 09:45:07 10,240 ----a-w c:\windows\winsxs\x86_microsoft-windows-tcpip-utility_31bf3856ad364e35_6.0.6001.18000_none_32c6f3aa4ede22b3\finger.exe
+ 2006-11-02 09:45:13 8,704 ----a-w c:\windows\winsxs\x86_microsoft-windows-tcpip-utility_31bf3856ad364e35_6.0.6001.18000_none_32c6f3aa4ede22b3\HOSTNAME.EXE
+ 2006-11-02 09:45:25 11,264 ----a-w c:\windows\winsxs\x86_microsoft-windows-tcpip-utility_31bf3856ad364e35_6.0.6001.18000_none_32c6f3aa4ede22b3\MRINFO.EXE
+ 2006-11-02 09:45:30 27,136 ----a-w c:\windows\winsxs\x86_microsoft-windows-tcpip-utility_31bf3856ad364e35_6.0.6001.18000_none_32c6f3aa4ede22b3\NETSTAT.EXE
+ 2006-11-02 09:45:49 9,728 ----a-w c:\windows\winsxs\x86_microsoft-windows-tcpip-utility_31bf3856ad364e35_6.0.6001.18000_none_32c6f3aa4ede22b3\TCPSVCS.EXE
+ 2006-11-02 12:35:38 57,856 ----a-w c:\windows\winsxs\x86_microsoft-windows-telnet-server_31bf3856ad364e35_6.0.6001.18000_none_9307dcf14f15ce10\tlntadmn.exe
AARG12
OS : Windows Vista
+ 2006-11-02 09:46:13 40,960 ----a-w c:\windows\winsxs\x86_microsoft-windows-tpm-adminsnapin_31bf3856ad364e35_6.0.6001.18000_none_777d16eedf412426\tpmcompc.dll
+ 2006-11-02 09:46:13 34,816 ----a-w c:\windows\winsxs\x86_microsoft-windows-unimodem-config_31bf3856ad364e35_6.0.6001.18000_none_f501a18e1eaabcb9\uicom.dll
+ 2006-11-02 09:46:13 16,384 ----a-w c:\windows\winsxs\x86_microsoft-windows-unimodem-core_31bf3856ad364e35_6.0.6001.18000_none_949832cbd48def6a\uniplat.dll
+ 2006-11-02 09:46:13 41,472 ----a-w c:\windows\winsxs\x86_microsoft-windows-upnpdevicehost_31bf3856ad364e35_6.0.6001.18000_none_c1e834753483fdcf\udhisapi.dll
+ 2006-11-02 09:46:13 37,888 ----a-w c:\windows\winsxs\x86_microsoft-windows-upnpssdp_31bf3856ad364e35_6.0.6001.18000_none_7fc972ebd13849b5\ssdpapi.dll
+ 2006-11-02 09:46:02 65,024 ----a-w c:\windows\winsxs\x86_microsoft-windows-video-for-windows_31bf3856ad364e35_6.0.6001.18000_none_9231f0ab88c213e9\avicap32.dll
+ 2006-11-02 09:46:05 82,944 ----a-w c:\windows\winsxs\x86_microsoft-windows-video-for-windows_31bf3856ad364e35_6.0.6001.18000_none_9231f0ab88c213e9\mciavi32.dll
+ 2006-11-02 09:46:10 12,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-video-for-windows_31bf3856ad364e35_6.0.6001.18000_none_9231f0ab88c213e9\msrle32.dll
+ 2006-11-02 12:34:41 198,144 ----a-w c:\windows\winsxs\x86_microsoft-windows-w..sition-coreservices_31bf3856ad364e35_6.0.6001.18000_none_32943b11b3535c07\sti.dll
+ 2006-11-02 12:34:41 12,800 ----a-w c:\windows\winsxs\x86_microsoft-windows-w..sition-coreservices_31bf3856ad364e35_6.0.6001.18000_none_32943b11b3535c07\wiatrace.dll
+ 2006-11-02 09:45:51 516,096 ----a-w c:\windows\winsxs\x86_microsoft-windows-wab-app_31bf3856ad364e35_6.0.6001.18000_none_42a95d80d7929e62\wab.exe
+ 2006-11-02 09:46:13 33,280 ----a-w c:\windows\winsxs\x86_microsoft-windows-wab-app_31bf3856ad364e35_6.0.6001.18000_none_42a95d80d7929e62\wabfind.dll
+ 2006-11-02 09:45:51 66,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-wab-app_31bf3856ad364e35_6.0.6001.18000_none_42a95d80d7929e62\wabmig.exe
+ 2006-11-02 07:28:12 1,098,752 ----a-w c:\windows\winsxs\x86_microsoft-windows-wab-core_31bf3856ad364e35_6.0.6001.18000_none_55236d7549c923f0\wab32res.dll
+ 2006-11-02 09:46:13 41,984 ----a-w c:\windows\winsxs\x86_microsoft-windows-wab-core_31bf3856ad364e35_6.0.6001.18000_none_55236d7549c923f0\wabimp.dll
+ 2006-11-02 09:46:14 10,752 ----a-w c:\windows\winsxs\x86_microsoft-windows-wininit_31bf3856ad364e35_6.0.6001.18000_none_30f2b8cf0450a6a2\wmsgapi.dll
+ 2006-11-02 09:46:13 15,360 ----a-w c:\windows\winsxs\x86_microsoft-windows-winlogon-sysntfy_31bf3856ad364e35_6.0.6001.18000_none_5572f3220fb3454e\sysntfy.dll
+ 2006-11-02 09:46:14 9,728 ----a-w c:\windows\winsxs\x86_microsoft-windows-winrsplugins_31bf3856ad364e35_6.0.6001.18000_none_1636766731a74faf\winrssrv.dll
+ 2006-11-02 09:43:00 2,560 ----a-w c:\windows\winsxs\x86_microsoft-windows-winsock-legacy_31bf3856ad364e35_6.0.6001.18000_none_e36536a91186bed0\rnr20.dll
+ 2006-11-02 09:46:13 36,352 ----a-w c:\windows\winsxs\x86_microsoft-windows-wmi-consumers_31bf3856ad364e35_6.0.6001.18000_none_4ad2276858e160c5\SMTPCons.dll
+ 2006-11-02 07:14:23 6,144 ----a-w c:\windows\winsxs\x86_microsoft-windows-wmi-core_31bf3856ad364e35_6.0.6001.18000_none_b95403151f989ff3\WinMgmtR.dll
+ 2006-11-02 07:15:27 2,048 ----a-w c:\windows\winsxs\x86_microsoft-windows-wmi-core_31bf3856ad364e35_6.0.6001.18000_none_b95403151f989ff3\WmiApRes.dll
+ 2006-11-02 09:46:05 35,840 ----a-w c:\windows\winsxs\x86_microsoft-windows-wmi-krnlprov-provider_31bf3856ad364e35_6.0.6001.18000_none_e3b0c3fff516edba\KrnlProv.dll
+ 2006-11-02 09:46:05 18,944 ----a-w c:\windows\winsxs\x86_microsoft-windows-wmi-management-snapins_31bf3856ad364e35_6.0.6001.18000_none_9be5ddb8baf2bc00\MMFUtil.dll
+ 2006-11-02 09:46:14 43,520 ----a-w c:\windows\winsxs\x86_microsoft-windows-wmi-time-provider_31bf3856ad364e35_6.0.6001.18000_none_ed321ab4287c62df\wmitimep.dll
+ 2006-11-02 09:46:14 39,936 ----a-w c:\windows\winsxs\x86_microsoft-windows-wmi-win32-provider_31bf3856ad364e35_6.0.6001.18000_none_c6cb05b6765124d9\wmipdfs.dll
+ 2006-11-02 09:46:14 43,520 ----a-w c:\windows\winsxs\x86_microsoft-windows-wmi-win32-provider_31bf3856ad364e35_6.0.6001.18000_none_c6cb05b6765124d9\WMIPSESS.dll
+ 2006-11-02 12:35:58 31,744 ----a-w c:\windows\winsxs\x86_microsoft-windows-wpd-legacywmdmapi_31bf3856ad364e35_6.0.6001.18000_none_59aa91436faa8e2e\wmdmlog.dll
+ 2006-11-02 12:35:58 36,864 ----a-w c:\windows\winsxs\x86_microsoft-windows-wpd-legacywmdmapi_31bf3856ad364e35_6.0.6001.18000_none_59aa91436faa8e2e\wmdmps.dll
+ 2009-01-10 07:10:01 94,720 ----a-w c:\windows\winsxs\x86_microsoft-windows-wpd-portabledeviceapi_31bf3856ad364e35_6.0.6001.18000_none_4b00c645ec09f02d\PortableDeviceClassExtension.dll
+ 2009-01-10 07:10:01 160,768 ----a-w c:\windows\winsxs\x86_microsoft-windows-wpd-portabledeviceapi_31bf3856ad364e35_6.0.6001.18000_none_4b00c645ec09f02d\PortableDeviceTypes.dll
+ 2006-11-02 09:46:12 32,768 ----a-w c:\windows\winsxs\x86_microsoft.windows.h...sdhost-driverclass_31bf3856ad364e35_6.0.6001.18000_none_c2f17878c82f85ef\sdhcinst.dll
+ 2006-11-02 09:46:02 39,936 ----a-w c:\windows\winsxs\x86_microsoft.windows.h..uetooth-driverclass_31bf3856ad364e35_6.0.6001.18000_none_84e4ea4562dcf212\bthserv.dll
+ 2006-11-02 12:41:20 1,327,104 ----a-w c:\windows\winsxs\x86_networking-mpssvc-admin.resources_31bf3856ad364e35_6.0.6001.18000_en-us_40f01b7c96c997a3\AuthFWSnapIn.Resources.dll
+ 2006-11-02 09:46:48 274,432 ----a-w c:\windows\winsxs\x86_networking-mpssvc-admin_31bf3856ad364e35_6.0.6001.18000_none_a5522df381cef60a\AuthFWWizFwk.dll
+ 2006-11-02 09:45:10 263,680 ----a-w c:\windows\winsxs\x86_networking-mpssvc_31bf3856ad364e35_6.0.6001.18000_none_0a7986d9b92aa27a\FirewallSettings.exe
+ 2006-11-02 12:34:32 16,488 ----a-w c:\windows\winsxs\x86_security-malware-windows-defender_31bf3856ad364e35_6.0.6001.18000_none_57bcb0ca582f18c5\MpAsDesc.dll
+ 2006-11-02 12:34:32 11,368 ----a-w c:\windows\winsxs\x86_security-malware-windows-defender_31bf3856ad364e35_6.0.6001.18000_none_57bcb0ca582f18c5\MsMpLics.dll
+ 2006-11-02 12:34:32 653,928 ----a-w c:\windows\winsxs\x86_security-malware-windows-defender_31bf3856ad364e35_6.0.6001.18000_none_57bcb0ca582f18c5\MsMpRes.dll
+ 2006-11-02 06:29:53 18,271 ----a-w c:\windows\winsxs\x86_windowssearchengine..uredqueryschema.bin_31bf3856ad364e35_6.0.6001.18000_none_9784d4f858e3c74e\StructuredQuerySchemaTrivial.bin
-- Snapshot reset to current date --
"Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2009-01-09 1232896]
"MsnMsgr"="c:\program files\Windows Live\Messenger\MsnMsgr.Exe" [2007-10-18 5724184]
"SpybotSD TeaTimer"="c:\program files\Spybot - Search & Destroy\TeaTimer.exe" [2008-09-16 1833296]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2007-06-29 137752]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2007-06-29 154136]
"Persistence"="c:\windows\system32\igfxpers.exe" [2007-06-29 133656]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2007-05-11 40048]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2008-12-15 136600]
"VAIO Center Access Bar"="c:\program files\sony\VAIO Center Access Bar\VCAB.exe" [2007-06-21 53248]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2007-01-09 115816]
"Symantec PIF AlertEng"="c:\program files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" [2008-01-29 583048]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2008-11-04 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-11-20 290088]
"Apoint"="c:\program files\Apoint\Apoint.exe" [2007-06-08 118784]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\VESWinlogon]
2007-07-24 18:26 98304 c:\windows\System32\VESWinlogon.dll
"VIDC.dvsd"= c:\program files\Common Files\Sony Shared\VideoLib\sonydv.dll
"AntiVirusDisableNotify"="0x00000000"
"UpdatesDisableNotify"="0x00000000"
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\DomainProfile]
"DefaultOutboundAction"= 0 (0x0)
"DefaultInboundAction"= 1 (0x1)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\FirewallRules]
"{1980A3A3-72DB-4E3F-9F05-2191AA5DB79A}"= UDP:c:\program files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{0816D0DF-B54B-4F22-AD54-EF92FB51704A}"= TCP:c:\program files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{00D323C8-E223-4115-B226-39A64557D821}"= c:\program files\Windows Live\Messenger\livecall.exe:Windows Live Messenger (Phone)
"{516FF797-A0CA-43D6-A288-6A38B1835483}"= c:\program files\Windows Live\Messenger\livecall.exe:Windows Live Messenger (Phone)
"{F67C3699-D469-4522-851C-F156159CCFE6}"= UDP:c:\program files\Bonjour\mDNSResponder.exe:Bonjour
"{D2100068-A81F-4DFA-A023-89A8E6C91F13}"= TCP:c:\program files\Bonjour\mDNSResponder.exe:Bonjour
"{AE100143-A4AF-4F19-A255-1F87AACED5C4}"= UDP:c:\program files\iTunes\iTunes.exe:iTunes
"{BC772F8E-19BD-44C7-9AE8-77DBB2AEC02E}"= TCP:c:\program files\iTunes\iTunes.exe:iTunes
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\PublicProfile]
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\RestrictedServices\Static\System]
"DFSR-1"= RPort=5722|UDP:%SystemRoot%\system32\svchost.exe|Svc=DFSR:Allow inbound TCP traffic|
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\StandardProfile]
R1 IDSvix86;Symantec Intrusion Prevention Driver;c:\progra~2\Symantec\DEFINI~1\SymcData\idsdefs\20090113.002\IDSvix86.sys [2009-01-15 270384]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [2008-12-15 99376]
R3 KeyScrambler;KeyScrambler;c:\windows\System32\drivers\keyscrambler.sys [2009-01-01 113896]
R3 R5U870FLx86;R5U870 UVC Lower Filter ;c:\windows\System32\drivers\R5U870FLx86.sys [2007-08-01 75008]
R3 R5U870FUx86;R5U870 UVC Upper Filter ;c:\windows\System32\drivers\R5U870FUx86.sys [2007-08-01 43904]
R3 SonyImgF;Sony Image Conversion Filter Driver;c:\windows\System32\drivers\SonyImgF.sys [2007-08-01 31104]
R3 SYMNDISV;SYMNDISV;c:\windows\System32\drivers\symndisv.sys [2007-01-09 38200]
R3 ti21sony;ti21sony;c:\windows\System32\drivers\ti21sony.sys [2007-08-01 812544]
R4 regi;regi;c:\windows\System32\drivers\regi.sys [2007-04-17 11032]
S3 VcmIAlzMgr;VAIO Content Metadata Intelligent Analyzing Manager;c:\program files\Sony\VCM Intelligent Analyzing Manager\VcmIAlzMgr.exe [2009-01-01 333088]
S3 VcmXmlIfHelper;VAIO Content Metadata XML Interface;c:\program files\Common Files\Sony Shared\VcmXml\VcmXmlIfHelper.exe [2007-08-01 79736]
*NewlyCreated* - COMHOST
bthsvcs REG_MULTI_SZ BthServ
FF - ProfilePath - c:\users\Angel\AppData\Roaming\Mozilla\Firefox\Profiles\rafdrutm.default\
FF - component: c:\users\Angel\AppData\Roaming\Mozilla\Firefox\Profiles\rafdrutm.default\extensions\keyscrambler@qfx.software.corporation\components\KeyScramblerIE.dll
---- FIREFOX POLICIES ----
Rootkit scan 2009-01-19 11:05:45
Windows 6.0.6000 NTFS
Completion time: 2009-01-19 11:07:46
ComboFix-quarantined-files.txt 2009-01-19 19:07:44
ComboFix2.txt 2009-01-14 05:57:50
ComboFix3.txt 2009-01-12 07:57:41
ComboFix4.txt 2009-01-06 05:25:56
ComboFix5.txt 2009-01-19 19:02:16
Pre-Run: 212,437,590,016 bytes free
Post-Run: 212,408,815,616 bytes free
813 --- E O F --- 2009-01-14 11:02:59
AARG12
OS : Windows Vista
Post by Belahzur on Mon Jan 19, 2009 7:39 pm
Hopefully that has taken care of the last two items MBAM found, try windows updates now.
Post by AARG12 on Mon Jan 19, 2009 7:43 pm
no =/ i still cant do updates........and spybot is still finding it.
error code : 80244019
AARG12
OS : Windows Vista
Solved this is spybot log
Post by AARG12 on Mon Jan 19, 2009 7:45 pm
Zlob.DNSChanger: [SBI $041D1396] TCP/IP Settings #1 (Undefined) (Registry change, fixed)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\DhcpNameServer=208.67.220.220,208.67.222.222
Zlob.DNSChanger: [SBI $041D1396] TCP/IP Settings #2 (Undefined) (Registry change, fixed)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{f3190096-33e1-494f-8233-2fe9ece13e18}\DhcpNameServer=208.67.220.220,208.67.222.222
User abort!: Scan was not completed successfully. ()
--- Spybot - Search & Destroy version: 1.6.0 (build: 20080707) ---
2008-07-07 blindman.exe (1.0.0.8)
2008-07-07 SDFiles.exe (1.6.0.4)
2008-07-07 SDMain.exe (1.0.0.6)
2008-07-07 SDShred.exe (1.0.2.3)
2008-07-07 SDUpdate.exe (1.6.0.8)
2008-07-07 SDWinSec.exe (1.0.0.12)
2008-07-07 SpybotSD.exe (1.6.0.30)
2008-09-16 TeaTimer.exe (1.6.3.25)
2009-01-01 unins000.exe (51.49.0.0)
2008-07-07 Update.exe (1.6.0.7)
2008-10-22 advcheck.dll (1.6.2.13)
2007-04-02 aports.dll (2.1.0.0)
2008-06-14 DelZip179.dll (1.79.11.1)
2008-09-15 SDHelper.dll (1.6.2.14)
2008-06-19 sqlite3.dll
2008-10-22 Tools.dll (2.1.6.8)
2008-11-04 Includes\Adware.sbi (*)
2008-12-29 Includes\AdwareC.sbi (*)
2008-06-03 Includes\Cookies.sbi (*)
2009-01-06 Includes\Dialer.sbi (*)
2009-01-06 Includes\DialerC.sbi (*)
2008-07-23 Includes\HeavyDuty.sbi (*)
2008-11-18 Includes\Hijackers.sbi (*)
2009-01-05 Includes\HijackersC.sbi (*)
2008-12-09 Includes\Keyloggers.sbi (*)
2008-12-22 Includes\KeyloggersC.sbi (*)
2004-11-29 Includes\LSP.sbi (*)
2008-11-18 Includes\Malware.sbi (*)
2009-01-06 Includes\MalwareC.sbi (*)
2008-12-15 Includes\PUPS.sbi (*)
2009-01-06 Includes\PUPSC.sbi (*)
2007-11-07 Includes\Revision.sbi (*)
2008-06-18 Includes\Security.sbi (*)
2008-12-29 Includes\SecurityC.sbi (*)
2008-06-03 Includes\Spybots.sbi (*)
2008-06-03 Includes\SpybotsC.sbi (*)
2008-12-10 Includes\Spyware.sbi (*)
2009-01-06 Includes\SpywareC.sbi (*)
2008-06-03 Includes\Tracks.uti
2009-01-05 Includes\Trojans.sbi (*)
2009-01-06 Includes\TrojansC.sbi (*)
2008-03-04 Plugins\Chai.dll
2008-03-05 Plugins\Fennel.dll
2008-02-26 Plugins\Mate.dll
2007-12-24 Plugins\TCPIPAddress.dll
--- System information ---
Windows Vista (Build: 6000) (6.0.6000)
/ .NETFramework / 1.1: Microsoft .NET Framework 1.1 Hotfix (KB929729)
/ .NETFramework / 1.1: Microsoft .NET Framework 1.1 Service Pack 1 (KB867460)
/ MSXML4SP2: FIX: ASP stops responding when calling Response.Redirect to another server using msxml4 sp2
/ MSXML4SP2: Security update for MSXML4 SP2 (KB954430)
--- Startup entries list ---
Located: HK_LM:Run, Adobe Reader Speed Launcher
command: "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
file: C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe
MD5: 66D4456C920E21BD2188F8CC33680DF5
Located: HK_LM:Run, Apoint
command: C:\Program Files\Apoint\Apoint.exe
file: C:\Program Files\Apoint\Apoint.exe
MD5: 6FC8ECA367679C2AEBBA09A416B4C18D
Located: HK_LM:Run, ccApp
command: "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
file: C:\Program Files\Common Files\Symantec Shared\ccApp.exe
MD5: 25BE770865658CB79100117112819A7C
Located: HK_LM:Run, HotKeysCmds
command: C:\Windows\system32\hkcmd.exe
file: C:\Windows\system32\hkcmd.exe
MD5: 161E3038BFE9AD04B9F35F7E83AFD20E
Located: HK_LM:Run, IgfxTray
command: C:\Windows\system32\igfxtray.exe
file: C:\Windows\system32\igfxtray.exe
MD5: 0ADD73DDAAD83314B0F32453B83F7F9C
Located: HK_LM:Run, iTunesHelper
command: "C:\Program Files\iTunes\iTunesHelper.exe"
file: C:\Program Files\iTunes\iTunesHelper.exe
MD5: E6A4E341E4304B34AA280D3E73818C90
Located: HK_LM:Run, Persistence
command: C:\Windows\system32\igfxpers.exe
file: C:\Windows\system32\igfxpers.exe
MD5: 39AFBBC65BF0469946EBA8C0C2884B76
Located: HK_LM:Run, QuickTime Task
command: "C:\Program Files\QuickTime\QTTask.exe" -atboottime
file: C:\Program Files\QuickTime\QTTask.exe
MD5: 9C9B6807425CEF840C117654D8B033D1
Located: HK_LM:Run, SunJavaUpdateSched
command: "C:\Program Files\Java\jre6\bin\jusched.exe"
file: C:\Program Files\Java\jre6\bin\jusched.exe
MD5: B98FFA8288EFAABC436C30D198608345
Located: HK_LM:Run, Symantec PIF AlertEng
command: "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll"
file: C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
MD5: 2D1389E05A807D956829F44BD4B60389
Located: HK_LM:Run, VAIO Center Access Bar
command: "c:\program files\sony\VAIO Center Access Bar\VCAB.exe" 1
file: c:\program files\sony\VAIO Center Access Bar\VCAB.exe
MD5: 15168B31FDCD5D90EFE641CBD243608A
Located: HK_CU:Run, MsnMsgr
where: S-1-5-21-712910195-2065108488-2920947175-1002...
command: "C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe" /background
file: C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe
MD5: A8972A2F9A744DD5EE0BFE429D767F1C
Located: HK_CU:Run, Sidebar
command: C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
file: C:\Program Files\Windows Sidebar\sidebar.exe
MD5: 582F3A0BA61D8F0D50C66B592808B6D6
Located: HK_CU:Run, SpybotSD TeaTimer
command: C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
file: C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
MD5: 63B3FF83B87AFCEBA89CED54695DA0F6
Located: WinLogon, igfxcui
command: igfxdev.dll
file: igfxdev.dll
MD5: D41D8CD98F00B204E9800998ECF8427E
Warning: if the file is actually larger than 0 bytes,
the checksum could not be properly calculated!
Located: WinLogon, VESWinlogon
command: VESWinlogon.dll
file: VESWinlogon.dll
--- Browser helper object list ---
{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} (Adobe PDF Reader Link Helper)
location: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\
BHO name:
CLSID name: Adobe PDF Reader Link Helper
description: Adobe Acrobat reader
classification: Legitimate
known filename: AcroIEhelper.ocx
AcroIEhelper.dll
info link: [You must be registered and logged in to see this link.]
info source: TonyKlein
Path: C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\
Long name: AcroIEHelper.dll
Short name: ACROIE~1.DLL
Date (created): 10/22/2006 22:08:42
Date (last access): 8/1/2007 18:44:58
Date (last write): 10/22/2006 22:08:42
Filesize: 62080
Attributes: archive
MD5: C11F6A1F61481E24BE3FDC06EA6F7D2A
CRC32: E388508F
Version: 8.0.0.456
{1E8A6170-7264-4D0F-BEAE-D42A53123C75} ()
BHO name:
CLSID name:
Path: C:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.5\
Long name: NppBHO.dll
Short name:
Date (created): 2/18/2007 20:22:56
Date (last access): 12/14/2008 21:08:24
Date (last write): 2/18/2007 20:22:56
Filesize: 97960
Attributes: readonly archive
MD5: FE48BB4C64B6D42EB637732D9D2962E4
CRC32: 9D5C5BBE
Version: 2007.1.7.4
{2B9F5787-88A5-4945-90E7-C4B18563BC5E} (QFX Software KeyScrambler)
BHO name: QFX Software KeyScrambler
CLSID name: CKeyScramblerBHO Object
Path: C:\Program Files\KeyScrambler\
Long name: KeyScramblerIE.dll
Short name: KEYSCR~1.DLL
Date (created): 1/1/2009 21:16:02
Date (last access): 1/1/2009 21:16:02
Date (last write): 6/1/2008 23:24:58
Filesize: 808936
Attributes: archive
MD5: 0D29B9DA7774E34DB6E84C159A16FFF8
CRC32: 2486FAA4
Version: 2.1.0.1
{53707962-6F74-2D53-2644-206D7942484F} (Spybot-S&D IE Protection)
BHO name:
CLSID name: Spybot-S&D IE Protection
description: Spybot-S&D IE Browser plugin
known filename: SDhelper.dll
info source: Patrick M. Kolla
Path: C:\PROGRA~1\SPYBOT~1\
Long name: SDHelper.dll
Short name:
Date (created): 1/5/2009 20:37:56
Date (last access): 1/5/2009 20:37:56
Date (last write): 9/15/2008 14:25:44
Filesize: 1562960
Attributes: readonly hidden sysfile archive
MD5: 35F73F1936BDE91F1B6995510A61E7A8
CRC32: BE6A5D15
Version: 1.6.2.14
{761497BB-D6F0-462C-B6EB-D4DAF1D92D43} (Java(tm) Plug-In SSV Helper)
BHO name:
CLSID name: Java(tm) Plug-In SSV Helper
Path: C:\Program Files\Java\jre6\bin\
Long name: ssv.dll
Short name:
Date (created): 12/15/2008 22:03:32
Date (last access): 12/15/2008 22:03:32
Date (last write): 12/15/2008 22:03:32
Filesize: 320920
Attributes: archive
MD5: 35E6FB6E6003BD54A5D69C9C1C762192
CRC32: 9699660C
Version: 6.0.110.3
{7E853D72-626A-48EC-A868-BA8D5E23E045} ()
BHO name:
CLSID name:
{DBC80044-A445-435b-BC74-9C25C1C588A9} (Java(tm) Plug-In 2 SSV Helper)
BHO name:
CLSID name: Java(tm) Plug-In 2 SSV Helper
Long name: jp2ssv.dll
Short name:
Date (created): 12/15/2008 22:03:30
Date (last access): 12/15/2008 22:03:30
Date (last write): 12/15/2008 22:03:30
Filesize: 34816
Attributes: archive
MD5: 5D57FD3DF32DC69CEC3D1D54B4C43162
CRC32: D7C13FB2
Version: 6.0.110.3
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:46 pm
--- ActiveX list ---
{8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0)
DPF name: Java Runtime Environment 1.6.0
CLSID name: Java Plug-in 1.6.0_11
Installer:
Codebase: [You must be registered and logged in to see this link.]
description: Sun Java
known filename: %PROGRAM FILES%\JabaSoft\JRE\*\Bin\npjava131.dll
info link:
Long name: jp2iexp.dll
Short name:
Filesize: 94208
Attributes: archive
MD5: 3DA696FCE470365F830726A5DB33733F
CRC32: F0FC81C2
Version: 6.0.110.3
{BDBDE413-7B1C-4C68-A8FF-C5B2B4090876} ()
DPF name:
CLSID name:
Installer:
Codebase:
{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
Installer:
description:
known filename: npjpi160.dll
info link:
info source: Safer Networking Ltd.
Short name:
Filesize: 94208
Attributes: archive
CRC32: F0FC81C2
Version: 6.0.110.3
{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
Installer:
Short name:
Filesize: 94208
Attributes: archive
CRC32: F0FC81C2
Version: 6.0.110.3
{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
Installer:
description:
known filename: npjpi150_06.dll
info link:
Long name: npjpi160_11.dll
Short name: NPJPI1~1.DLL
Filesize: 132504
Attributes: archive
MD5: D400116F6776ACB6EDB6B1F5EEB9F92D
CRC32: CECB5751
Version: 6.0.110.3
{D0C0F75C-683A-4390-A791-1ACFD5599AB8} ()
DPF name:
CLSID name:
Installer:
Codebase:
AARG12
OS : Windows Vista
--- Process list ---
PID: 1848 (1040) C:\Windows\system32\Dwm.exe
MD5: E87B968F3D49117445893EB0503FE34F
PID: 1876 (1828) C:\Windows\Explorer.EXE
MD5: 37440D09DEAE0B672A04DCCF7ABF06BE
PID: 300 (1052) C:\Windows\system32\taskeng.exe
MD5: 1226E9FAE5B8508801EC974E3C9D9C14
PID: 480 (1052) C:\Windows\system32\taskeng.exe
PID: 600 (1876) C:\Windows\System32\hkcmd.exe
PID: 796 (1876) C:\Windows\System32\igfxpers.exe
PID: 1384 (1876) C:\Program Files\Java\jre6\bin\jusched.exe
PID: 1508 (1876) C:\Program Files\Common Files\Symantec Shared\ccApp.exe
PID: 1608 (1876) C:\Program Files\iTunes\iTunesHelper.exe
PID: 1872 (1876) C:\Program Files\Apoint\Apoint.exe
PID: 620 (1876) C:\Program Files\Windows Sidebar\sidebar.exe
PID: 1976 (1876) C:\Program Files\Windows Live\Messenger\msnmsgr.exe
PID: 272 (1876) C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
PID: 3256 ( 820) C:\Windows\system32\igfxsrvc.exe
MD5: 0B0161799AAB35ABC3C42590E65491CC
PID: 3684 ( 480) C:\Program Files\Sony\VAIO Update 3\VAIOUpdt.exe
MD5: 661EC6D57E040003CAB8AC0280B36940
PID: 3728 ( 480) C:\Program Files\Sony\Wireless Switch Setting Utility\Switcher.exe
MD5: AF334CA84536E743D6AEF32548223403
PID: 4036 (1872) C:\Program Files\Apoint\ApMsgFwd.exe
MD5: 42370C1DE2B83844B253478DB8A907D5
PID: 3632 (1748) C:\Program Files\Apoint\Apntex.exe
MD5: 99A7B10500920E5CC79B700927B18BC1
PID: 4004 (1876) C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe
MD5: 3B1B5D09D3C9C4CD39D4DB06ED7A0855
PID: 3924 ( 820) C:\Windows\System32\mobsync.exe
MD5: 9C632DC0F1B6D79B05F46A4A5349CEF4
PID: 5828 (5816) C:\Program Files\Internet Explorer\IEUser.exe
MD5: CC3BC04443E65FEB28B5A043420610BA
PID: 4856 (1876) C:\Program Files\Mozilla Firefox\firefox.exe
MD5: 8DA0A66CB74FCBB393038E37E0F691BA
PID: 0 ( 0) [System Process]
PID: 4 ( 0) System
PID: 392 ( 4) smss.exe
PID: 520 ( 508) csrss.exe
PID: 560 ( 508) wininit.exe
PID: 568 ( 552) csrss.exe
PID: 604 ( 560) services.exe
PID: 624 ( 560) lsass.exe
PID: 636 ( 560) lsm.exe
PID: 732 ( 552) winlogon.exe
PID: 820 ( 604) svchost.exe
PID: 876 ( 604) svchost.exe
PID: 908 ( 604) svchost.exe
PID: 1016 ( 604) svchost.exe
PID: 1040 ( 604) svchost.exe
PID: 1052 ( 604) svchost.exe
PID: 1160 (1016) audiodg.exe
PID: 1192 ( 604) SLsvc.exe
PID: 1232 ( 604) svchost.exe
PID: 1396 ( 604) svchost.exe
PID: 1568 ( 604) ccSvcHst.exe
PID: 1928 ( 604) spoolsv.exe
PID: 1952 ( 604) svchost.exe
PID: 244 ( 604) AppleMobileDeviceService.exe
PID: 1108 ( 604) mDNSResponder.exe
PID: 1500 ( 604) svchost.exe
PID: 2056 ( 604) iviRegMgr.exe
PID: 2172 ( 604) svchost.exe
PID: 2212 ( 604) stacsv.exe
PID: 2312 ( 604) svchost.exe
PID: 2436 ( 604) VESMgr.exe
PID: 2500 ( 604) VCSW.exe
PID: 2584 ( 604) svchost.exe
PID: 2616 ( 604) SearchIndexer.exe
PID: 2720 ( 604) XAudio.exe
PID: 2744 ( 604) VzCdbSvc.exe
PID: 2772 (1040) WUDFHost.exe
PID: 2828 ( 604) VzFw.exe
PID: 3320 (2436) VESMgrSub.exe
PID: 3480 ( 820) igfxext.exe
PID: 3508 ( 820) igfxsrvc.exe
PID: 3676 (1052) taskeng.exe
PID: 1832 (3320) SPMgr.exe
PID: 3348 ( 604) iPodService.exe
PID: 4208 ( 604) TrustedInstaller.exe
PID: 1664 ( 820) WmiPrvSE.exe
--- Browser start & search pages list ---
Spybot - Search & Destroy browser pages report, 1/19/2009 11:43:50
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Local Page
C:\windows\system32\blank.htm
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Search Page
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Start Page
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\Local Page
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\Search Page
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\Start Page
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\Default_Page_URL
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\Default_Search_URL
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\SearchAssistant
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Search\SearchAssistant
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Search\CustomizeSearch
--- Winsock Layered Service Provider list ---
Protocol 0: MSAFD Tcpip [TCP/IP]
GUID: {E70F1AA0-AB8B-11CF-8CA3-00805F48A192}
Filename: %SystemRoot%\system32\mswsock.dll
Description: Microsoft Windows NT/2k/XP IP protocol
DB filename: %SystemRoot%\system32\mswsock.dll
DB protocol: MSAFD Tcpip [*]
Protocol 1: MSAFD Tcpip [UDP/IP]
Protocol 2: MSAFD Tcpip [RAW/IP]
Protocol 3: MSAFD Tcpip [TCP/IPv6]
GUID: {F9EAB0C0-26D4-11D0-BBBF-00AA006C34E4}
Description: Microsoft Windows NT/2k/XP IPv6 protocol
Protocol 4: MSAFD Tcpip [UDP/IPv6]
Protocol 5: MSAFD Tcpip [RAW/IPv6]
Protocol 6: RSVP TCPv6 Service Provider
GUID: {9D60A9E0-337A-11D0-BD88-0000C082E69A}
Description: Microsoft Windows NT/2k/XP RVSP
DB filename: %SystemRoot%\system32\rsvpsp.dll
DB protocol: RSVP * Service Provider
Protocol 7: RSVP TCP Service Provider
Protocol 8: RSVP UDPv6 Service Provider
Protocol 9: RSVP UDP Service Provider
Protocol 10: MSAFD RfComm [Bluetooth]
GUID: {9FC48064-7298-43E4-B7BD-181F2089792A}
Description: Bluetooth
DB protocol: MSAFD RfComm [Bluetooth]
Protocol 11: MSAFD NetBIOS [\Device\NetBT_Tcpip_{FAECE2F7-4527-429B-AF36-B0C020A0926C}] SEQPACKET 0
GUID: {8D5F1830-C273-11CF-95C8-00805F48A192}
Description: Microsoft Windows NT/2k/XP NetBios protocol
DB protocol: MSAFD NetBIOS *
Protocol 12: MSAFD NetBIOS [\Device\NetBT_Tcpip_{FAECE2F7-4527-429B-AF36-B0C020A0926C}] DATAGRAM 0
Protocol 13: MSAFD NetBIOS [\Device\NetBT_Tcpip_{F3190096-33E1-494F-8233-2FE9ECE13E18}] SEQPACKET 4
Protocol 14: MSAFD NetBIOS [\Device\NetBT_Tcpip_{F3190096-33E1-494F-8233-2FE9ECE13E18}] DATAGRAM 4
Protocol 15: MSAFD NetBIOS [\Device\NetBT_Tcpip6_{FAECE2F7-4527-429B-AF36-B0C020A0926C}] SEQPACKET 1
Protocol 16: MSAFD NetBIOS [\Device\NetBT_Tcpip6_{FAECE2F7-4527-429B-AF36-B0C020A0926C}] DATAGRAM 1
Protocol 17: MSAFD NetBIOS [\Device\NetBT_Tcpip6_{F3190096-33E1-494F-8233-2FE9ECE13E18}] SEQPACKET 5
Protocol 18: MSAFD NetBIOS [\Device\NetBT_Tcpip6_{F3190096-33E1-494F-8233-2FE9ECE13E18}] DATAGRAM 5
Namespace Provider 0: Network Location Awareness Legacy (NLAv1) Namespace
GUID: {6642243A-3BA8-4AA6-BAA5-2E0BD71FDD83}
Filename:
Description: Microsoft Windows NT/2k/XP name space provider
DB protocol: NLA-Namespace
Namespace Provider 1: Tcpip
GUID: {22059D40-7E9E-11CF-AE5A-00AA00A7112B}
Filename:
Description: Microsoft Windows NT/2k/XP TCP/IP name space provider
DB protocol: TCP/IP
Namespace Provider 2: NTDS
GUID: {3B2637EE-E580-11CF-A555-00C04FD8D4AC}
Filename: %SystemRoot%\System32\winrnr.dll
DB filename: %SystemRoot%\system32\winrnr.dll
DB protocol: NTDS
Namespace Provider 3: E-mail Naming Shim Provider
GUID: {964ACBA2-B2BC-40EB-8C6A-A6DB40161CAE}
Filename:
Namespace Provider 4: PNRP Cloud Namespace Provider
GUID: {03FE89CE-766D-4976-B9C1-BB9BC42C7B4D}
Filename:
Namespace Provider 5: PNRP Name Namespace Provider
GUID: {03FE89CD-766D-4976-B9C1-BB9BC42C7B4D}
Filename:
Namespace Provider 6: Bluetooth Namespace
GUID: {06AA63E0-7D60-41FF-AFB2-3EE6D2D9392D}
Filename: %SystemRoot%\system32\wshbth.dll
DB filename: %SystemRoot%\system32\wshbth.dll
DB protocol: Bluetooth-Namespace
Namespace Provider 7: mdnsNSP
GUID: {B600E6E9-553B-4A19-8696-335E5C896153}
Filename: C:\Program Files\Bonjour\mdnsNSP.dll
Description: Apple Rendezvous protocol
DB filename: %ProgramFiles%\Rendezvous\bin\mdnsNSP.dll
DB protocol: mdnsNSP
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:51 pm
Malwarebytes' Anti-Malware 1.32
Database version: 1643
Windows 6.0.6000
1/19/2009 11:51:09
mbam-log-2009-01-19 (11-51-09).txt
Objects scanned: 49297
Time elapsed: 3 minute(s), 8 second(s)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\DhcpNameServer (Trojan.DNSChanger) -> Data: 85.255.112.178 85.255.112.102 -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\Interfaces\{f3190096-33e1-494f-8233-2fe9ece13e18}\DhcpNameServer (Trojan.DNSChanger) -> Data: 85.255.112.178 85.255.112.102 -> Quarantined and deleted successfully.
AARG12
OS : Windows Vista
Post by AARG12 on Mon Jan 19, 2009 7:53 pm
right now since i ran both of those, its clean and i can do updates i have learned, but once the comp is restarted. the trojans are still there. and i have to rerun both the programs to delete them once again.
AARG12
OS : Windows Vista
Post by Belahzur on Mon Jan 19, 2009 7:55 pm
Hold on, I'm gonna go back to my colleagues. That IP isn't part of the wareout, it's openDNS, I don't why Spybot detects it, but it's not malicious.
I honestly think it's something in your network that blocks it.
Post by Belahzur on Mon Jan 19, 2009 8:05 pm
Back again, just been reading a Vista forum on this infection.
The infection isn't on your machine, it's on your router.
Instead of hijacking the machines DNS, they hijack the router, so the machine is clean, but the router is infected.
THAT is why it returns.
You may need to call up your internet provider and talk with them to reset your router to defaults and set the settings back to them.
Post by Doctor Inferno on Sat May 02, 2009 6:34 am
Since this issue has been addressed, a "solved" tag will be added and this topic will be closed.
Page 2 of 2 Previous  1, 2
