Updating Problem
Updating Problem
Post by sagangwee on Wed Dec 31, 2008 1:08 am
I have trouble updating Windows and a lot of my programs, except for Avira for some reason. Anyway, When i update Windows, my Internet Explorer doesn't work and it displays the check your network configuration settings page, if you know what that is. So i just restore it back. BUT, i really need to update my computer. It is a Windows Home Premium. Plus, Malware Bytes Anti-Malware and my security program can't update either. Thisis what it say for MBAM.
Update Failed.Make sure you are connected to the internet and your firewall is set to allow Malwarebytes Anti-Malware to access the internet.
It says similar things with other programs to.
Here is a MBAM's log file.
Malwarebytes' Anti-Malware 1.31
Database version: 1456
Windows 6.0.6000
12/30/2008 4:37:24 PM
mbam-log-2008-12-30 (16-37-24).txt
Scan type: Full Scan (C:\|D:\|E:\|F:\|G:\|H:\|I:\|)
Objects scanned: 158249
Time elapsed: 1 hour(s), 6 minute(s), 32 second(s)
Files Infected: 4
C:\Users\Owner\AppData\Local\Temp\wz11d2\keygen.exe (Backdoor.SDBot) -> Quarantined and deleted successfully.
C:\Users\Owner\AppData\Local\Temp\wz2459\keygen.exe (Backdoor.SDBot) -> Quarantined and deleted successfully.
C:\Users\Owner\AppData\Local\Temp\wz94d6\keygen.exe (Backdoor.SDBot) -> Quarantined and deleted successfully.
C:\Users\Owner\AppData\Local\Temp\wz9b2d\keygen.exe (Backdoor.SDBot) -> Quarantined and deleted successfully.
PLEASE help, thanks.
sagangwee
Posts Posts : 56
Joined Joined : 2008-12-30
OS OS : Windows Vista Home Premium
Points Points : 28980
Re: Updating Problem
Post by Belahzur on Wed Dec 31, 2008 1:18 am
Have asked a colleague to take a look at this, hold tight.
Points Points : 245069
Post by sagangwee on Wed Dec 31, 2008 1:22 am
Ok, hope he/she can fix it
sagangwee
Posts Posts : 56
Oh by the way, did MBAM fix the backdoor? or is that unfixable?
sagangwee
Posts Posts : 56
Post by Belahzur on Wed Dec 31, 2008 1:46 am
Hopefully there was no real damage since it was just a temp file.
Post by sagangwee on Wed Dec 31, 2008 3:55 am
ok
sagangwee
Posts Posts : 56
Post by sagangwee on Wed Dec 31, 2008 3:56 am
but how do i fix my updating problem?
sagangwee
Posts Posts : 56
Post by Belahzur on Wed Dec 31, 2008 2:41 pm
Lets see if this works.
In the Start Menu type in windows firewall, select the normal windows firewall without advanced security. On the left hand panel select Allow a program through Windows Firewall.
Find MBAM in the list and place a check beside it, if it is not listed there and If you have UAC enabled you may need to click on the Change Settings button before you click Add Program. When you click Add Program browser for MBAM.
Now Add Port >> Name: wu1 Port: 80 Protocol: UDP. Add Port >> wu2 Port: 443 Protocol: UDP.
Post by sagangwee on Fri Jan 02, 2009 4:35 am
um, what was that supposed to do? and that didn't work
sagangwee
Posts Posts : 56
Post by Belahzur on Fri Jan 02, 2009 2:27 pm
It was supposed to let it through the firewall.
Can you try uninstalling it and re-installing?
Post by Doctor Inferno on Sat Feb 21, 2009 9:54 am
Due to lack of feedback, this topic is closed.
Points Points : 104600
