not to beat a dead horse, but Rustok-N problems...
Solved Re: not to beat a dead horse, but Rustok-N problems...
Post by Belahzur on Mon Dec 29, 2008 7:39 pm
Vundofix isn't bad, just part of the components that make up the tool are flagged.
Many scanners will flag part of combofix too because of what they do.
Let avast deletes everything it finds.
Still having problems?
Post by davidisinaband on Mon Dec 29, 2008 7:43 pm
okay.. it deleted everything.. firefox still down... will try to install over it since we got rid of some bad stuff.. and see if that fixes it... everything else is fixed though, including the annoying hp popup and some registry errors that the eusing registry cleaner missed...
davidisinaband
OS : windows vista
Post by davidisinaband on Mon Dec 29, 2008 7:49 pm
alright... that fixed it this time.. I guess I had to get all that other junk off before it would properly install over!! Thanks for all your help, problems solved!!
davidisinaband
OS : windows vista
Post by Belahzur on Mon Dec 29, 2008 7:51 pm
Updating Java:
Please download JavaRa from [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
  • First, unzip it.
  • Then run JavaRa.
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
Post by Doctor Inferno on Sat Feb 14, 2009 4:02 am
