Need help
Solved Re: Need help
Post by Belahzur on 30th December 2008, 9:58 pm
Rename the exe file and try again.
Points Points : 245101
Post by danthemaninthecan on 30th December 2008, 10:28 pm
Malwarebytes' Anti-Malware 1.31
Database version: 1456
2008-12-30 2:25:58 PM
mbam-log-2008-12-30 (14-25-58).txt
Objects scanned: 73318
Time elapsed: 12 minute(s), 35 second(s)
Memory Processes Infected: 2
Registry Keys Infected: 3
Registry Values Infected: 1
Folders Infected: 1
Files Infected: 32
C:\WINDOWS\SYSTEM32\svschost.exe (Trojan.FakeAlert) -> Unloaded process successfully.
C:\WINDOWS\SYSTEM32\svŮshost.exe (Trojan.FakeAlert) -> Unloaded process successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\explorer.exe (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\tdssdata (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\tdss (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\svschost.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Program Files\Microsoft Common (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\SYSTEM32\TDSSarxx.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSScfum.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSfxmp.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSnmxh.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSnrsr.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSnvuo.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSofxh.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSoiqh.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSoitu.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSosvd.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSosvn.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSriqp.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSsbhc.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSvoqm.dll (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\DRIVERS\TDSSmxst.sys (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\DRIVERS\TDSSofxh.sys (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\DRIVERS\TDSSpaxt.sys (Trojan.TDSS) -> Delete on reboot.
C:\Program Files\Microsoft Common\svchost.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\SYSTEM32\DRIVERS\ (Trojan.Agent) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\ieupdates.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\SYSTEM32\winsrc.dll (Adware.Toolbar) -> Quarantined and deleted successfully.
C:\WINDOWS\SYSTEM32\svschost.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\SYSTEM32\svŮshost.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\SYSTEM32\TDSSdxcp.dll (Rootkit.Agent) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSfxwp.dll (Rootkit.Agent) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSkkao.log (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSkpjp.log (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSSrhym.dll (Rootkit.Agent) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\TDSStkdv.log (Trojan.TDSS) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\DRIVERS\TDSSmqlt.sys (Rootkit.Agent) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\DRIVERS\TDSSoeqh.sys (Rootkit.Agent) -> Delete on reboot.
C:\WINDOWS\SYSTEM32\DRIVERS\TDSSserv.sys (Rootkit.Agent) -> Delete on reboot.
danthemaninthecan
Posts Posts : 20
Joined Joined : 2008-12-28
OS OS : windows 2000
Points Points : 29030
Post by Belahzur on 30th December 2008, 10:31 pm
That has probably removed the rootkit, but lets see what this says.
  • Download combofix from here, use the top links - [You must be registered and logged in to see this link.]
  • Please disable your local AV (Anti-virus) by right clicking it's icon in the tray, and exit it.
Post by danthemaninthecan on 30th December 2008, 11:25 pm
ComboFix 08-12-29.02 - Dan 2008-12-30 14:57:13.3 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.228 [GMT -8:00]
Running from: c:\documents and settings\Susie\Desktop\Combofixer.exe
c:\documents and settings\Dan\Application Data\Google\mjkovl.dll
c:\documents and settings\Dan\Application Data\Google\pzpsp23511834.exe
c:\windows\system32\TDSSmtve.dat
c:\windows\system32\TDSSnrsr.dat
c:\windows\system32\TDSSosvd.dat
-------\Legacy_TDSSSERV.SYS
-------\Service_TDSSserv.sys
((((((((((((((((((((((((( Files Created from 2008-11-28 to 2008-12-30 )))))))))))))))))))))))))))))))
2008-12-30 14:10 . 2008-12-30 14:10 d-------- c:\documents and settings\Dan\Application Data\Malwarebytes
2008-12-30 12:55 . 2008-12-30 14:10 d-------- c:\program files\Malwarebytes'Anti-Malware
2008-12-30 00:58 . 2008-12-30 00:58 d-------- c:\windows\ie8updates
2008-12-29 23:28 . 2008-12-29 23:28 39,936 --a------ c:\documents and settings\Andrea\Application Data\casino.exe
2008-12-29 23:16 . 2008-12-29 23:16 d--hs---- c:\documents and settings\Andrea\PrivacIE
2008-12-29 23:12 . 2008-12-29 23:12 0 --a------ c:\windows\SYSTEM32\system32xp.exe.tmp
2008-12-29 19:52 . 2008-12-29 19:52 39,936 --a------ c:\windows\SYSTEM32\CONFIG\systemprofile\Application Data\casino.exe
2008-12-29 19:26 . 2008-12-29 19:26 d--hs---- c:\documents and settings\Susie\PrivacIE
2008-12-29 14:24 . 2008-12-29 14:24 d--hs---- c:\documents and settings\Dan\PrivacIE
2008-12-29 13:32 . 2008-12-29 13:34 d--h-c--- c:\windows\ie8
2008-12-29 11:05 . 2008-12-30 14:32 d-------- c:\documents and settings\Dan\Tracing
2008-12-29 11:02 . 2008-12-29 11:02 d-------- c:\program files\Windows Live SkyDrive
2008-12-29 11:02 . 2008-12-29 11:02 d-------- c:\program files\Microsoft
2008-12-29 11:01 . 2008-12-29 11:02 d-------- c:\program files\Windows Live
2008-12-29 10:55 . 2008-12-29 10:55 d-------- c:\program files\Common Files\Windows Live
2008-12-29 10:52 . 2008-12-30 00:50 d-------- c:\program files\filehippo.com
2008-12-29 10:44 . 2008-12-29 13:38 d-------- c:\program files\Spybot - Search & Destroy
2008-12-29 10:37 . 2008-12-29 10:44 d-------- c:\program files\SpywareGuard
2008-12-29 10:08 . 2008-12-29 10:08 410,984 --a------ c:\windows\SYSTEM32\deploytk.dll
2008-12-29 10:08 . 2008-12-29 10:08 73,728 --a------ c:\windows\SYSTEM32\javacpl.cpl
2008-12-29 09:50 . 2008-12-29 09:53 d-------- c:\documents and settings\Dan\.SunDownloadManager
2008-12-29 00:19 . 2008-12-29 00:19 d-------- C:\New Folder
2008-12-28 15:45 . 2008-12-28 15:45 d-------- c:\documents and settings\Susie\Application Data\Malwarebytes
2008-12-28 15:44 . 2008-12-30 12:35 d-------- c:\program files\Malwarebytes' Anti-Malware
2008-12-28 15:44 . 2008-12-28 15:44 d-------- c:\documents and settings\All Users\Application Data\Malwarebytes
2008-12-28 15:44 . 2008-12-03 19:59 38,496 --a------ c:\windows\SYSTEM32\DRIVERS\mbamswissarmy.sys
2008-12-28 15:44 . 2008-12-03 19:59 15,504 --a------ c:\windows\SYSTEM32\DRIVERS\mbam.sys
2008-12-28 15:21 . 2008-12-28 15:42 d-------- c:\documents and settings\Susie\Contacts
2008-12-28 10:22 . 2008-12-29 11:13 d-a------ c:\documents and settings\All Users\Application Data\TEMP
2008-12-28 10:21 . 2008-12-28 10:21 d-------- c:\program files\Common Files\Download Manager
2008-12-22 19:49 . 2008-12-22 19:51 31 --a------ c:\documents and settings\Dan\jagex_runescape_preferences.dat
2008-12-13 11:49 . 2008-12-13 12:17 d-------- c:\windows\SYSTEM32\Adobe
2008-12-02 22:37 . 2008-12-02 22:37 49,480 --a------ c:\windows\SYSTEM32\sirenacm.dll
2008-11-25 08:07 . 2008-11-25 08:07 d-------- c:\program files\iTunes
2008-11-25 08:07 . 2008-11-25 08:07 d-------- c:\program files\iPod
2008-11-25 08:07 . 2008-11-25 08:07 d-------- c:\documents and settings\All Users\Application Data\{3276BE95_AF08_429F_A64F_CA64CB79BCF6}
2008-11-25 08:04 . 2008-11-25 08:05 d-------- c:\program files\QuickTime
2008-11-11 12:46 . 2008-10-24 03:21 455,296 --------- c:\windows\SYSTEM32\DLLCACHE\mrxsmb.sys
2008-11-11 12:42 . 2008-09-04 09:15 1,106,944 --------- c:\windows\SYSTEM32\DLLCACHE\msxml3.dll
2008-11-04 10:30 . 2008-11-04 10:30 90,112 --a------ c:\windows\SYSTEM32\QuickTimeVR.qtx
2008-11-04 10:30 . 2008-11-04 10:30 57,344 --a------ c:\windows\SYSTEM32\QuickTime.qts
2008-12-30 09:12 6,656 ----a-w c:\windows\system32\drivers\aec.sys
2008-12-29 22:21 --------- d-----w c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
2008-12-29 18:14 --------- d-----w c:\program files\Java
2008-12-27 07:33 --------- d-----w c:\documents and settings\All Users\Application Data\Lavasoft
2008-12-27 07:29 --------- d-----w c:\documents and settings\Dan\Application Data\Apple Computer
2008-12-17 23:27 --------- d-----w c:\program files\Google
2008-11-25 16:07 --------- d-----w c:\program files\Common Files\Apple
2007-07-10 16:06 60,968 ----a-w c:\documents and settings\Susie\GoToAssistDownloadHelper.exe
2008-09-16 04:58 32,768 --sha-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\History\History.IE5\MSHist012008091520080916\index.dat
+ 2005-10-21 04:02:28 163,328 ----a-w c:\windows\ERDNT\subs\ERDNT.EXE
+ 2007-08-14 01:39:20 71,680 -c--a-w c:\windows\ie8\admparse.dll
+ 2008-10-16 20:38:34 124,928 -c--a-w c:\windows\ie8\advpack.dll
+ 2008-04-14 00:11:51 35,328 -c--a-w c:\windows\ie8\corpol.dll
+ 2008-10-16 20:38:34 347,136 -c--a-w c:\windows\ie8\dxtmsft.dll
+ 2008-10-16 20:38:34 214,528 -c--a-w c:\windows\ie8\dxtrans.dll
+ 2007-08-14 01:18:02 60,416 -c--a-w c:\windows\ie8\hmmapi.dll
+ 2008-10-16 20:38:35 63,488 -c--a-w c:\windows\ie8\icardie.dll
+ 2008-10-16 13:11:09 70,656 -c--a-w c:\windows\ie8\ie4uinit.exe
+ 2008-10-16 20:38:35 153,088 -c--a-w c:\windows\ie8\ieakeng.dll
+ 2008-10-16 20:38:35 230,400 -c--a-w c:\windows\ie8\ieaksie.dll
+ 2008-10-15 07:04:53 161,792 -c--a-w c:\windows\ie8\ieakui.dll
+ 2007-04-17 09:28:12 2,455,488 -c--a-w c:\windows\ie8\ieapfltr.dat
+ 2008-10-16 20:38:35 383,488 -c--a-w c:\windows\ie8\ieapfltr.dll
+ 2008-10-16 20:38:35 384,512 -c--a-w c:\windows\ie8\iedkcs32.dll
+ 2008-04-14 00:11:54 81,920 -c--a-w c:\windows\ie8\ieencode.dll
+ 2008-10-16 20:38:37 6,066,176 -c--a-w c:\windows\ie8\ieframe.dll
+ 2007-08-14 01:54:10 191,488 -c--a-w c:\windows\ie8\iepeers.dll
+ 2007-08-14 01:54:10 287,744 -c--a-w c:\windows\ie8\ieproxy.dll
+ 2008-10-16 20:38:37 44,544 -c--a-w c:\windows\ie8\iernonce.dll
+ 2008-10-16 20:38:37 267,776 -c--a-w c:\windows\ie8\iertutil.dll
+ 2007-08-14 01:39:12 55,296 -c--a-w c:\windows\ie8\iesetup.dll
+ 2007-08-14 01:54:10 180,736 -c--a-w c:\windows\ie8\ieui.dll
+ 2008-10-15 07:06:26 633,632 -c--a-w c:\windows\ie8\iexplore.exe
+ 2007-08-14 01:36:06 36,352 -c--a-w c:\windows\ie8\imgutil.dll
+ 2007-08-14 01:39:02 92,672 -c--a-w c:\windows\ie8\inseng.dll
+ 2008-05-09 10:53:39 512,000 -c--a-w c:\windows\ie8\jscript.dll
+ 2008-10-16 20:38:37 27,648 -c--a-w c:\windows\ie8\jsproxy.dll
+ 2007-08-14 01:44:18 40,960 -c--a-w c:\windows\ie8\licmgr10.dll
+ 2008-10-16 20:38:37 459,264 -c--a-w c:\windows\ie8\msfeeds.dll
+ 2008-10-16 20:38:37 52,224 -c--a-w c:\windows\ie8\msfeedsbs.dll
+ 2007-08-14 01:36:40 12,288 -c--a-w c:\windows\ie8\msfeedssync.exe
+ 2007-08-14 01:32:30 45,568 -c--a-w c:\windows\ie8\mshta.exe
+ 2008-12-13 06:40:02 3,593,216 -c--a-w c:\windows\ie8\mshtml.dll
+ 2008-10-16 20:38:38 477,696 -c--a-w c:\windows\ie8\mshtmled.dll
+ 2007-08-14 01:01:12 48,128 -c--a-w c:\windows\ie8\mshtmler.dll
+ 2007-08-14 01:54:10 156,160 -c--a-w c:\windows\ie8\msls31.dll
+ 2008-10-16 20:38:38 193,024 -c--a-w c:\windows\ie8\msrating.dll
+ 2008-10-16 20:38:39 671,232 -c--a-w c:\windows\ie8\mstime.dll
+ 2008-10-16 20:38:39 102,912 -c--a-w c:\windows\ie8\occache.dll
+ 2008-10-16 20:38:39 44,544 -c--a-w c:\windows\ie8\pngfilt.dll
+ 2006-09-07 00:43:16 213,216 -c--a-w c:\windows\ie8\spuninst.exe
+ 2008-08-22 11:21:04 49,736 -c--a-w c:\windows\ie8\spuninst\iecustom.dll
+ 2008-06-12 19:27:58 231,456 -c--a-w c:\windows\ie8\spuninst\spuninst.exe
+ 2008-06-12 19:28:00 382,496 -c--a-w c:\windows\ie8\spuninst\updspapi.dll
+ 2008-10-16 20:38:39 105,984 -c--a-w c:\windows\ie8\url.dll
+ 2008-10-16 20:38:39 1,160,192 -c--a-w c:\windows\ie8\urlmon.dll
+ 2008-05-09 10:53:40 430,080 -c--a-w c:\windows\ie8\vbscript.dll
+ 2007-07-12 23:31:54 765,952 -c--a-w c:\windows\ie8\vgx.dll
+ 2008-10-16 20:38:39 233,472 -c--a-w c:\windows\ie8\webcheck.dll
+ 2007-08-14 01:45:16 206,336 -c--a-w c:\windows\ie8\winfxdocobj.exe
+ 2008-10-16 20:38:40 826,368 -c--a-w c:\windows\ie8\wininet.dll
+ 2008-08-22 11:09:32 5,699,584 -c----w c:\windows\ie8updates\KB960714-IE8\mshtml.dll
+ 2008-07-09 07:38:25 231,288 -c----w c:\windows\ie8updates\KB960714-IE8\spuninst\spuninst.exe
+ 2008-07-09 07:38:37 382,840 -c----w c:\windows\ie8updates\KB960714-IE8\spuninst\updspapi.dll
+ 2008-12-29 19:01:57 62,288 ----a-r c:\windows\Installer\{020D8396-D6D9-4B53-A9A1-83C47E2E27AA}\IconWlc.exe
+ 2008-12-29 19:03:04 80,395 ----a-r c:\windows\Installer\{0AAA9C97-74D4-47CE-B089-0B147EF3553C}\MsblIco.Exe
- 2008-11-25 16:07:56 102,400 ----a-r c:\windows\Installer\{318AB667-3230-41B5-A617-CB3BF748D371}\iTunesIco.exe
+ 2008-12-30 07:15:47 102,400 ----a-r c:\windows\Installer\{318AB667-3230-41B5-A617-CB3BF748D371}\iTunesIco.exe
- 2007-08-14 01:39:20 71,680 ----a-w c:\windows\SYSTEM32\admparse.dll
+ 2008-08-22 11:06:30 72,704 ----a-w c:\windows\SYSTEM32\admparse.dll
- 2008-10-16 20:38:34 124,928 ----a-w c:\windows\SYSTEM32\advpack.dll
+ 2008-08-22 11:06:16 128,512 ----a-w c:\windows\SYSTEM32\advpack.dll
- 2008-09-16 04:59:28 16,384 -c--a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Cookies\INDEX.DAT
+ 2008-12-30 20:43:47 16,384 -c--a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Cookies\INDEX.DAT
+ 2008-12-30 07:13:00 32,768 --sha-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Feeds Cache\index.dat
+ 2008-12-30 09:24:31 17,796 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Internet Explorer\frameiconcache.dat
+ 2008-12-30 07:13:27 16,384 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Internet Explorer\MSIMGSIZ.DAT
+ 2008-12-30 04:28:37 16,384 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Internet Explorer\Recovery\Active\{50BA5B4B-D62A-11DD-8BA0-0011113A7BEB}.dat
+ 2008-12-30 05:27:16 16,384 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Internet Explorer\Recovery\Active\{82D21DA5-D632-11DD-8BA0-0011113A7BEB}.dat
+ 2008-12-30 04:28:37 16,384 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Internet Explorer\Recovery\Active\RecoveryStore.{50BA5B4A-D62A-11DD-8BA0-0011113A7BEB}.dat
+ 2008-12-30 05:27:16 16,384 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Internet Explorer\Recovery\Active\RecoveryStore.{82D21DA4-D632-11DD-8BA0-0011113A7BEB}.dat
+ 2008-12-30 20:46:49 5,632 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Internet Explorer\Recovery\Last Active\{F8FE8D1D-D6B2-11DD-8BA8-0011113A7BEB}.dat
+ 2008-12-30 20:46:49 4,608 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Application Data\Microsoft\Internet Explorer\Recovery\Last Active\RecoveryStore.{F8FE8D1C-D6B2-11DD-8BA8-0011113A7BEB}.dat
- 2008-09-16 04:59:28 32,768 -c--a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\History\History.IE5\INDEX.DAT
+ 2008-12-30 20:43:47 32,768 -c--a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\History\History.IE5\INDEX.DAT
+ 2008-12-30 07:26:46 293,372 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\AntiPhishing\2B8F14AB-9FC4-4763-84C0-AA9C8323BFCB.dat
+ 2008-12-30 04:19:50 39,936 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\4BSPEZOF\soft[1].exe
+ 2008-12-30 03:52:20 85,504 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\6JYLAZOX\162[1].exe
+ 2008-12-30 04:15:41 85,504 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\6JYLAZOX\162[2].exe
- 2008-09-16 04:59:28 32,768 -c--a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\INDEX.DAT
+ 2008-12-30 20:45:53 32,768 -c--a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\INDEX.DAT
+ 2008-12-30 20:39:08 159,744 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\O9YJK1IJ\167[1].exe
+ 2008-12-30 03:52:38 39,936 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\O9YJK1IJ\soft[1].exe
+ 2008-12-30 04:15:58 39,936 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\O9YJK1IJ\soft[2].exe
+ 2008-12-30 03:52:03 135,168 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\OT2JQP0H\install[1].exe
+ 2008-12-30 04:15:23 135,168 ----a-w c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\OT2JQP0H\install[2].exe
- 2008-04-14 00:11:51 35,328 ------w c:\windows\SYSTEM32\corpol.dll
+ 2008-08-22 11:07:08 18,944 ----a-w c:\windows\SYSTEM32\corpol.dll
danthemaninthecan
Posts Posts : 20
Post by danthemaninthecan on 30th December 2008, 11:26 pm
- 2007-08-14 01:39:20 71,680 ------w c:\windows\SYSTEM32\DLLCACHE\admparse.dll
+ 2008-08-22 11:06:30 72,704 ----a-w c:\windows\SYSTEM32\DLLCACHE\admparse.dll
- 2008-10-16 20:38:34 124,928 ------w c:\windows\SYSTEM32\DLLCACHE\advpack.dll
+ 2008-08-22 11:06:16 128,512 ----a-w c:\windows\SYSTEM32\DLLCACHE\advpack.dll
+ 2008-06-12 19:27:52 1,022,976 ------w c:\windows\SYSTEM32\DLLCACHE\browseui.dll
+ 2008-08-22 11:07:08 18,944 ------w c:\windows\SYSTEM32\DLLCACHE\corpol.dll
- 2008-10-16 20:38:34 347,136 ----a-w c:\windows\SYSTEM32\DLLCACHE\dxtmsft.dll
+ 2008-08-22 11:05:16 346,624 ----a-w c:\windows\SYSTEM32\DLLCACHE\dxtmsft.dll
- 2008-10-16 20:38:34 214,528 ------w c:\windows\SYSTEM32\DLLCACHE\dxtrans.dll
+ 2008-08-22 11:05:10 217,088 ----a-w c:\windows\SYSTEM32\DLLCACHE\dxtrans.dll
- 2007-08-14 01:18:02 60,416 ------w c:\windows\SYSTEM32\DLLCACHE\hmmapi.dll
+ 2008-08-22 11:00:28 68,608 ----a-w c:\windows\SYSTEM32\DLLCACHE\hmmapi.dll
- 2008-10-16 20:38:35 63,488 ------w c:\windows\SYSTEM32\DLLCACHE\icardie.dll
+ 2008-08-22 11:05:20 61,952 ----a-w c:\windows\SYSTEM32\DLLCACHE\icardie.dll
- 2008-10-16 13:11:09 70,656 ------w c:\windows\SYSTEM32\DLLCACHE\ie4uinit.exe
+ 2008-08-22 11:06:24 162,304 ----a-w c:\windows\SYSTEM32\DLLCACHE\ie4uinit.exe
- 2008-10-16 20:38:35 153,088 ------w c:\windows\SYSTEM32\DLLCACHE\ieakeng.dll
+ 2008-08-22 11:06:36 124,928 ----a-w c:\windows\SYSTEM32\DLLCACHE\ieakeng.dll
- 2008-10-16 20:38:35 230,400 ------w c:\windows\SYSTEM32\DLLCACHE\ieaksie.dll
+ 2008-08-22 11:06:40 228,864 ----a-w c:\windows\SYSTEM32\DLLCACHE\ieaksie.dll
- 2008-10-15 07:04:53 161,792 ------w c:\windows\SYSTEM32\DLLCACHE\ieakui.dll
+ 2008-08-22 11:06:24 163,840 ----a-w c:\windows\SYSTEM32\DLLCACHE\ieakui.dll
- 2007-04-17 09:28:12 2,455,488 -c----w c:\windows\SYSTEM32\DLLCACHE\ieapfltr.dat
+ 2008-07-30 06:58:08 3,670,112 ----a-w c:\windows\SYSTEM32\DLLCACHE\ieapfltr.dat
- 2008-10-16 20:38:35 383,488 ------w c:\windows\SYSTEM32\DLLCACHE\ieapfltr.dll
+ 2008-08-22 10:42:22 443,392 ----a-w c:\windows\SYSTEM32\DLLCACHE\ieapfltr.dll
- 2008-10-16 20:38:35 384,512 ------w c:\windows\SYSTEM32\DLLCACHE\iedkcs32.dll
+ 2008-08-22 11:06:44 385,024 ----a-w c:\windows\SYSTEM32\DLLCACHE\iedkcs32.dll
- 2008-10-16 20:38:37 6,066,176 ------w c:\windows\SYSTEM32\DLLCACHE\ieframe.dll
+ 2008-08-22 11:10:34 11,985,408 ----a-w c:\windows\SYSTEM32\DLLCACHE\ieframe.dll
- 2007-08-14 01:54:10 191,488 ----a-w c:\windows\SYSTEM32\DLLCACHE\iepeers.dll
+ 2008-08-22 11:05:24 186,880 ----a-w c:\windows\SYSTEM32\DLLCACHE\iepeers.dll
- 2008-10-16 20:38:37 44,544 ------w c:\windows\SYSTEM32\DLLCACHE\iernonce.dll
+ 2008-08-22 11:06:20 55,808 ----a-w c:\windows\SYSTEM32\DLLCACHE\iernonce.dll
- 2008-10-16 20:38:37 267,776 ------w c:\windows\SYSTEM32\DLLCACHE\iertutil.dll
+ 2008-08-22 11:06:02 1,778,688 ----a-w c:\windows\SYSTEM32\DLLCACHE\iertutil.dll
- 2007-08-14 01:39:12 55,296 ------w c:\windows\SYSTEM32\DLLCACHE\iesetup.dll
+ 2008-08-22 11:06:24 71,680 ----a-w c:\windows\SYSTEM32\DLLCACHE\iesetup.dll
- 2008-10-15 07:06:26 633,632 ------w c:\windows\SYSTEM32\DLLCACHE\iexplore.exe
+ 2008-08-22 11:16:40 637,984 ----a-w c:\windows\SYSTEM32\DLLCACHE\iexplore.exe
- 2007-08-14 01:36:06 36,352 ------w c:\windows\SYSTEM32\DLLCACHE\imgutil.dll
+ 2008-08-22 11:05:14 35,840 ----a-w c:\windows\SYSTEM32\DLLCACHE\imgutil.dll
- 2007-08-14 01:39:02 92,672 ----a-w c:\windows\SYSTEM32\DLLCACHE\inseng.dll
+ 2008-08-22 11:06:16 94,720 ----a-w c:\windows\SYSTEM32\DLLCACHE\inseng.dll
- 2008-05-09 10:53:39 512,000 ------w c:\windows\SYSTEM32\DLLCACHE\jscript.dll
+ 2008-08-22 11:06:30 552,960 ----a-w c:\windows\SYSTEM32\DLLCACHE\jscript.dll
- 2008-10-16 20:38:37 27,648 ------w c:\windows\SYSTEM32\DLLCACHE\jsproxy.dll
+ 2008-08-22 11:06:58 28,672 ----a-w c:\windows\SYSTEM32\DLLCACHE\jsproxy.dll
- 2007-08-14 01:44:18 40,960 ------w c:\windows\SYSTEM32\DLLCACHE\licmgr10.dll
+ 2008-08-22 11:08:00 43,008 ----a-w c:\windows\SYSTEM32\DLLCACHE\licmgr10.dll
- 2008-10-16 20:38:37 459,264 ------w c:\windows\SYSTEM32\DLLCACHE\msfeeds.dll
+ 2008-08-22 11:05:48 580,608 ----a-w c:\windows\SYSTEM32\DLLCACHE\msfeeds.dll
- 2008-10-16 20:38:37 52,224 ------w c:\windows\SYSTEM32\DLLCACHE\msfeedsbs.dll
+ 2008-08-22 11:05:22 53,760 ----a-w c:\windows\SYSTEM32\DLLCACHE\msfeedsbs.dll
- 2007-08-14 01:32:30 45,568 ------w c:\windows\SYSTEM32\DLLCACHE\mshta.exe
+ 2008-08-22 11:04:54 45,568 ----a-w c:\windows\SYSTEM32\DLLCACHE\mshta.exe
- 2008-12-13 06:40:02 3,593,216 ------w c:\windows\SYSTEM32\DLLCACHE\mshtml.dll
+ 2008-12-14 13:59:44 5,699,584 ----a-w c:\windows\SYSTEM32\DLLCACHE\mshtml.dll
- 2008-10-16 20:38:38 477,696 ------w c:\windows\SYSTEM32\DLLCACHE\mshtmled.dll
+ 2008-08-22 11:05:08 70,656 ----a-w c:\windows\SYSTEM32\DLLCACHE\mshtmled.dll
- 2007-08-14 01:01:12 48,128 ------w c:\windows\SYSTEM32\DLLCACHE\mshtmler.dll
+ 2008-08-22 11:05:00 48,128 ----a-w c:\windows\SYSTEM32\DLLCACHE\mshtmler.dll
- 2007-08-14 01:54:10 156,160 ------w c:\windows\SYSTEM32\DLLCACHE\msls31.dll
+ 2008-08-22 10:57:56 156,160 ----a-w c:\windows\SYSTEM32\DLLCACHE\msls31.dll
- 2008-10-16 20:38:38 193,024 ------w c:\windows\SYSTEM32\DLLCACHE\msrating.dll
+ 2008-08-22 11:07:50 193,536 ----a-w c:\windows\SYSTEM32\DLLCACHE\msrating.dll
- 2008-10-16 20:38:39 671,232 ------w c:\windows\SYSTEM32\DLLCACHE\mstime.dll
+ 2008-08-22 11:05:34 630,272 ----a-w c:\windows\SYSTEM32\DLLCACHE\mstime.dll
- 2008-10-16 20:38:39 102,912 ------w c:\windows\SYSTEM32\DLLCACHE\occache.dll
+ 2008-08-22 11:07:50 116,224 ----a-w c:\windows\SYSTEM32\DLLCACHE\occache.dll
- 2008-10-16 20:38:39 44,544 ----a-w c:\windows\SYSTEM32\DLLCACHE\pngfilt.dll
+ 2008-08-22 11:05:14 45,056 ----a-w c:\windows\SYSTEM32\DLLCACHE\pngfilt.dll
+ 2008-06-12 19:27:52 1,497,088 ------w c:\windows\SYSTEM32\DLLCACHE\shdocvw.dll
+ 2008-06-12 19:27:52 474,112 ------w c:\windows\SYSTEM32\DLLCACHE\shlwapi.dll
+ 2008-06-12 19:27:56 134,144 ------w c:\windows\SYSTEM32\DLLCACHE\sqmapi.dll
- 2008-10-16 20:38:39 105,984 ------w c:\windows\SYSTEM32\DLLCACHE\url.dll
+ 2008-08-22 11:07:58 105,984 ----a-w c:\windows\SYSTEM32\DLLCACHE\url.dll
- 2008-10-16 20:38:39 1,160,192 ------w c:\windows\SYSTEM32\DLLCACHE\urlmon.dll
+ 2008-08-22 11:08:22 1,206,784 ----a-w c:\windows\SYSTEM32\DLLCACHE\urlmon.dll
- 2008-05-09 10:53:40 430,080 ------w c:\windows\SYSTEM32\DLLCACHE\vbscript.dll
+ 2008-08-22 11:06:36 434,176 ----a-w c:\windows\SYSTEM32\DLLCACHE\vbscript.dll
- 2007-07-12 23:31:54 765,952 ----a-w c:\windows\SYSTEM32\DLLCACHE\vgx.dll
+ 2008-08-22 11:07:20 755,200 ----a-w c:\windows\SYSTEM32\DLLCACHE\VGX.dll
- 2008-10-16 20:38:39 233,472 ------w c:\windows\SYSTEM32\DLLCACHE\webcheck.dll
+ 2008-08-22 11:08:08 236,544 ----a-w c:\windows\SYSTEM32\DLLCACHE\webcheck.dll
- 2008-10-16 20:38:40 826,368 ------w c:\windows\SYSTEM32\DLLCACHE\wininet.dll
+ 2008-08-22 11:08:06 878,592 ----a-w c:\windows\SYSTEM32\DLLCACHE\wininet.dll
- 2008-10-16 20:38:34 347,136 ----a-w c:\windows\SYSTEM32\dxtmsft.dll
+ 2008-08-22 11:05:16 346,624 ----a-w c:\windows\SYSTEM32\dxtmsft.dll
- 2008-10-16 20:38:34 214,528 ----a-w c:\windows\SYSTEM32\dxtrans.dll
+ 2008-08-22 11:05:10 217,088 ----a-w c:\windows\SYSTEM32\dxtrans.dll
- 2008-10-15 08:11:49 293,272 ----a-w c:\windows\SYSTEM32\FNTCACHE.DAT
+ 2008-12-29 21:38:47 296,456 ----a-w c:\windows\SYSTEM32\FNTCACHE.DAT
- 2008-10-16 20:38:35 63,488 ----a-w c:\windows\SYSTEM32\icardie.dll
+ 2008-08-22 11:05:20 61,952 ----a-w c:\windows\SYSTEM32\icardie.dll
- 2006-06-29 15:05:44 26,112 ------w c:\windows\SYSTEM32\idndl.dll
+ 2008-06-12 19:27:42 26,112 ----a-w c:\windows\SYSTEM32\idndl.dll
- 2008-10-16 13:11:09 70,656 ------w c:\windows\SYSTEM32\ie4uinit.exe
+ 2008-08-22 11:06:24 162,304 ----a-w c:\windows\SYSTEM32\ie4uinit.exe
- 2008-10-16 20:38:35 153,088 ------w c:\windows\SYSTEM32\ieakeng.dll
+ 2008-08-22 11:06:36 124,928 ----a-w c:\windows\SYSTEM32\ieakeng.dll
- 2008-10-16 20:38:35 230,400 ------w c:\windows\SYSTEM32\ieaksie.dll
+ 2008-08-22 11:06:40 228,864 ----a-w c:\windows\SYSTEM32\ieaksie.dll
- 2008-10-15 07:04:53 161,792 ------w c:\windows\SYSTEM32\ieakui.dll
+ 2008-08-22 11:06:24 163,840 ----a-w c:\windows\SYSTEM32\ieakui.dll
- 2007-04-17 09:32:38 2,455,488 ----a-w c:\windows\SYSTEM32\ieapfltr.dat
+ 2008-07-30 06:58:08 3,670,112 ----a-w c:\windows\SYSTEM32\ieapfltr.dat
- 2008-10-16 20:38:35 383,488 ----a-w c:\windows\SYSTEM32\ieapfltr.dll
+ 2008-08-22 10:42:22 443,392 ----a-w c:\windows\SYSTEM32\ieapfltr.dll
- 2008-10-16 20:38:35 384,512 ------w c:\windows\SYSTEM32\iedkcs32.dll
+ 2008-08-22 11:06:44 385,024 ----a-w c:\windows\SYSTEM32\iedkcs32.dll
- 2008-10-16 20:38:37 6,066,176 ----a-w c:\windows\SYSTEM32\ieframe.dll
+ 2008-08-22 11:10:34 11,985,408 ----a-w c:\windows\SYSTEM32\ieframe.dll
- 2007-08-14 01:54:10 191,488 ----a-w c:\windows\SYSTEM32\iepeers.dll
+ 2008-08-22 11:05:24 186,880 ----a-w c:\windows\SYSTEM32\iepeers.dll
- 2008-10-16 20:38:37 44,544 ------w c:\windows\SYSTEM32\iernonce.dll
+ 2008-08-22 11:06:20 55,808 ----a-w c:\windows\SYSTEM32\iernonce.dll
- 2008-10-16 20:38:37 267,776 ----a-w c:\windows\SYSTEM32\iertutil.dll
+ 2008-08-22 11:06:02 1,778,688 ----a-w c:\windows\SYSTEM32\iertutil.dll
- 2007-08-14 01:39:12 55,296 ----a-w c:\windows\SYSTEM32\iesetup.dll
+ 2008-08-22 11:06:24 71,680 ----a-w c:\windows\SYSTEM32\iesetup.dll
- 2008-10-16 13:11:09 13,824 ----a-w c:\windows\SYSTEM32\ieudinit.exe
+ 2008-08-22 11:06:24 36,864 ----a-w c:\windows\SYSTEM32\ieudinit.exe
- 2007-08-14 01:54:10 180,736 ------w c:\windows\SYSTEM32\ieui.dll
+ 2008-08-22 10:58:12 181,760 ----a-w c:\windows\SYSTEM32\ieui.dll
- 2007-08-14 01:36:06 36,352 ----a-w c:\windows\SYSTEM32\imgutil.dll
+ 2008-08-22 11:05:14 35,840 ----a-w c:\windows\SYSTEM32\imgutil.dll
- 2007-08-14 01:39:02 92,672 ----a-w c:\windows\SYSTEM32\inseng.dll
+ 2008-08-22 11:06:16 94,720 ----a-w c:\windows\SYSTEM32\inseng.dll
- 2007-07-12 08:22:00 135,168 ----a-w c:\windows\SYSTEM32\java.exe
+ 2008-12-29 18:08:23 144,792 ----a-w c:\windows\SYSTEM32\java.exe
- 2007-07-12 08:22:04 135,168 ----a-w c:\windows\SYSTEM32\javaw.exe
+ 2008-12-29 18:08:23 144,792 ----a-w c:\windows\SYSTEM32\javaw.exe
- 2007-07-12 09:22:38 139,264 ----a-w c:\windows\SYSTEM32\javaws.exe
+ 2008-12-29 18:08:23 148,888 ----a-w c:\windows\SYSTEM32\javaws.exe
- 2008-05-09 10:53:39 512,000 ----a-w c:\windows\SYSTEM32\jscript.dll
+ 2008-08-22 11:06:30 552,960 ----a-w c:\windows\SYSTEM32\jscript.dll
- 2008-10-16 20:38:37 27,648 ------w c:\windows\SYSTEM32\jsproxy.dll
+ 2008-08-22 11:06:58 28,672 ----a-w c:\windows\SYSTEM32\jsproxy.dll
- 2007-10-11 22:12:48 1,468,968 ----a-w c:\windows\SYSTEM32\LegitCheckControl.dll
+ 2008-03-21 02:06:36 1,480,232 ----a-w c:\windows\SYSTEM32\LegitCheckControl.dll
- 2007-08-14 01:44:18 40,960 ----a-w c:\windows\SYSTEM32\licmgr10.dll
+ 2008-08-22 11:08:00 43,008 ----a-w c:\windows\SYSTEM32\licmgr10.dll
- 2008-12-02 21:26:30 17,593,280 ----a-w c:\windows\SYSTEM32\MRT.exe
+ 2008-12-09 23:24:38 17,593,280 ----a-w c:\windows\SYSTEM32\MRT.exe
+ 2008-08-06 01:55:38 265,720 ----a-w c:\windows\SYSTEM32\msdbg2.dll
- 2008-10-16 20:38:37 459,264 ----a-w c:\windows\SYSTEM32\msfeeds.dll
+ 2008-08-22 11:05:48 580,608 ----a-w c:\windows\SYSTEM32\msfeeds.dll
- 2008-10-16 20:38:37 52,224 ----a-w c:\windows\SYSTEM32\msfeedsbs.dll
+ 2008-08-22 11:05:22 53,760 ----a-w c:\windows\SYSTEM32\msfeedsbs.dll
- 2007-08-14 01:36:40 12,288 ------w c:\windows\SYSTEM32\msfeedssync.exe
+ 2008-08-22 11:05:22 13,312 ----a-w c:\windows\SYSTEM32\msfeedssync.exe
- 2007-08-14 01:32:30 45,568 ----a-w c:\windows\SYSTEM32\mshta.exe
+ 2008-08-22 11:04:54 45,568 ----a-w c:\windows\SYSTEM32\mshta.exe
- 2008-12-13 06:40:02 3,593,216 ----a-w c:\windows\SYSTEM32\mshtml.dll
+ 2008-12-14 13:59:44 5,699,584 ----a-w c:\windows\SYSTEM32\mshtml.dll
- 2008-10-16 20:38:38 477,696 ----a-w c:\windows\SYSTEM32\mshtmled.dll
+ 2008-08-22 11:05:08 70,656 ----a-w c:\windows\SYSTEM32\mshtmled.dll
- 2007-08-14 01:01:12 48,128 ----a-w c:\windows\SYSTEM32\mshtmler.dll
+ 2008-08-22 11:05:00 48,128 ----a-w c:\windows\SYSTEM32\mshtmler.dll
- 2007-08-14 01:54:10 156,160 ----a-w c:\windows\SYSTEM32\msls31.dll
+ 2008-08-22 10:57:56 156,160 ----a-w c:\windows\SYSTEM32\msls31.dll
- 2008-10-16 20:38:38 193,024 ----a-w c:\windows\SYSTEM32\msrating.dll
+ 2008-08-22 11:07:50 193,536 ----a-w c:\windows\SYSTEM32\msrating.dll
- 2008-10-16 20:38:39 671,232 ------w c:\windows\SYSTEM32\mstime.dll
+ 2008-08-22 11:05:34 630,272 ----a-w c:\windows\SYSTEM32\mstime.dll
- 2006-06-29 00:59:26 24,576 ------w c:\windows\SYSTEM32\nlsdl.dll
+ 2008-06-12 19:27:44 24,576 ----a-w c:\windows\SYSTEM32\nlsdl.dll
danthemaninthecan
Posts Posts : 20
- 2006-06-29 15:05:44 23,552 ------w c:\windows\SYSTEM32\normaliz.dll
+ 2008-06-12 19:27:42 23,552 ----a-w c:\windows\SYSTEM32\normaliz.dll
- 2008-10-16 20:38:39 102,912 ------w c:\windows\SYSTEM32\occache.dll
+ 2008-08-22 11:07:50 116,224 ----a-w c:\windows\SYSTEM32\occache.dll
- 2008-10-16 20:38:39 44,544 ----a-w c:\windows\SYSTEM32\pngfilt.dll
+ 2008-08-22 11:05:14 45,056 ----a-w c:\windows\SYSTEM32\pngfilt.dll
+ 2008-08-22 11:05:00 48,640 ------w c:\windows\SYSTEM32\PrivacIE.dll
- 2007-11-30 12:39:22 17,272 ------w c:\windows\SYSTEM32\spmsg.dll
+ 2008-06-12 19:27:58 16,928 ------w c:\windows\SYSTEM32\spmsg.dll
- 2007-08-11 03:46:18 26,488 ----a-w c:\windows\SYSTEM32\spupdsvc.exe
+ 2008-06-12 19:27:58 26,144 ----a-w c:\windows\SYSTEM32\spupdsvc.exe
- 2008-10-16 20:38:39 105,984 ----a-w c:\windows\SYSTEM32\url.dll
+ 2008-08-22 11:07:58 105,984 ----a-w c:\windows\SYSTEM32\url.dll
- 2008-10-16 20:38:39 1,160,192 ----a-w c:\windows\SYSTEM32\urlmon.dll
+ 2008-08-22 11:08:22 1,206,784 ----a-w c:\windows\SYSTEM32\urlmon.dll
- 2008-05-09 10:53:40 430,080 ----a-w c:\windows\SYSTEM32\vbscript.dll
+ 2008-08-22 11:06:36 434,176 ----a-w c:\windows\SYSTEM32\vbscript.dll
- 2008-10-16 20:38:39 233,472 ----a-w c:\windows\SYSTEM32\webcheck.dll
+ 2008-08-22 11:08:08 236,544 ----a-w c:\windows\SYSTEM32\webcheck.dll
- 2007-08-14 01:45:16 206,336 ------w c:\windows\SYSTEM32\WinFXDocObj.exe
+ 2008-08-22 11:08:22 208,384 ----a-w c:\windows\SYSTEM32\WinFXDocObj.exe
- 2008-10-16 20:38:40 826,368 ----a-w c:\windows\SYSTEM32\wininet.dll
+ 2008-08-22 11:08:06 878,592 ----a-w c:\windows\SYSTEM32\wininet.dll
- 2008-04-14 00:12:11 121,856 ------w c:\windows\SYSTEM32\xmllite.dll
+ 2008-06-12 19:28:02 121,856 ----a-w c:\windows\SYSTEM32\xmllite.dll
+ 2007-11-07 04:23:58 224,768 ----a-w c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_d08d0375\msvcm90.dll
+ 2007-11-07 09:19:34 568,832 ----a-w c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_d08d0375\msvcp90.dll
+ 2007-11-07 09:19:34 655,872 ----a-w c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_d08d0375\msvcr90.dll
-- Snapshot reset to current date --
"ctfmon.exe"="c:\windows\system32\ctfmon.exe" [2008-04-13 15360]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-06-02 68856]
"ares"="c:\program files\Ares\Ares.exe" [2008-12-16 887808]
"SpybotSD TeaTimer"="c:\program files\Spybot - Search & Destroy\TeaTimer.exe" [2008-09-16 1833296]
"ClamWin"="c:\program files\ClamWin\bin\ClamTray.exe" [2008-09-04 86016]
"igfxtray"="c:\windows\system32\igfxtray.exe" [2005-09-20 94208]
"igfxhkcmd"="c:\windows\system32\hkcmd.exe" [2005-09-20 77824]
"igfxpers"="c:\windows\system32\igfxpers.exe" [2005-09-20 114688]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2008-11-04 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-11-20 290088]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2008-12-29 136600]
"MSMSGS"="c:\program files\Messenger\msmsgs.exe" [2004-02-13 1587512]
"RunNarrator"="Narrator.exe" [2008-04-13 c:\windows\SYSTEM32\narrator.exe]
c:\documents and settings\Dan\Start Menu\Programs\Startup\
SpywareGuard.lnk - c:\program files\SpywareGuard\sgmain.exe [2003-08-29 360448]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2006-02-19 288472]
HP Photosmart Premier Fast Start.lnk - c:\program files\HP\Digital Imaging\bin\hpqthb08.exe [2006-02-10 73728]
NkVwMon.exe.lnk - c:\program files\Nikon\NkView4\NkVwMon.exe [2006-07-20 114688]
"MSACM.qmpeg"= qmpeg.acm
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
backup=c:\windows\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^EPSON Status Monitor 3 Environment Check 2.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\EPSON Status Monitor 3 Environment Check 2.lnk
backup=c:\windows\pss\EPSON Status Monitor 3 Environment Check 2.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^TELUS eCare.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\TELUS eCare.lnk
backup=c:\windows\pss\TELUS eCare.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^Dan^Start Menu^Programs^Startup^uefa.com Alerts.lnk]
path=c:\documents and settings\Dan\Start Menu\Programs\Startup\uefa.com Alerts.lnk
backup=c:\windows\pss\uefa.com Alerts.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ares]
--a------ 2008-12-16 18:08 887808 c:\program files\Ares\Ares.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HP Software Update]
--a------ 2006-02-19 01:41 49152 c:\program files\HP\HP Software Update\hpwuSchd2.exe
--a------ 2008-11-20 13:20 290088 c:\program files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Motive SmartBridge]
--a------ 2008-02-18 11:57 393216 c:\progra~1\TELUSE~1\SMARTB~1\MotiveSB.exe
--a------ 2008-11-04 10:30 413696 c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\swg]
--a------ 2007-06-02 19:45 68856 c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\TkBellExe]
--a------ 2004-12-21 16:50 180269 c:\program files\Common Files\Real\Update_OB\realsched.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\updateMgr]
-ra------ 2006-03-30 15:45 313472 c:\program files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\WMPNSCFG]
--------- 2006-10-18 20:05 204288 c:\program files\Windows Media Player\wmpnscfg.exe
"Avg7UpdSvc"=2 (0x2)
"Avg7Alrt"=2 (0x2)
"AntiVirusDisableNotify"=dword:00000001
"c:\\Program Files\\Ares\\Ares.exe"=
"c:\\WINDOWS\\SYSTEM32\\LEXPPS.EXE"=
"c:\\WINDOWS\\system32\\sessmgr.exe"=
R2 LicCtrlService;LicCtrl Service;c:\windows\runservice.exe [2005-01-29 2560]
S2 DP1112;DP1112;\??\c:\windows\system32\Drivers\DP.sys []
2008-12-26 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 11:34]
2008-12-30 c:\windows\Tasks\User_Feed_Synchronization-{EDD7FCEA-5638-4D79-A3A5-8C3847FC8AC4}.job
- c:\windows\system32\msfeedssync.exe [2008-08-22 03:05]
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O16 -: Microsoft XML Parser for Java - [You must be registered and logged in to see this link.]
c:\windows\Downloaded Program Files\Microsoft XML Parser for Java.osd
Rootkit scan 2008-12-30 15:07:11
c:\windows\SYSTEM32\LEXBCES.EXE
c:\windows\SYSTEM32\LEXPPS.EXE
c:\program files\Lavasoft\Ad-Aware 2007\aawservice.exe
c:\program files\Symantec\LiveUpdate\AluSchedulerSvc.exe
c:\program files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
c:\windows\SYSTEM32\CTSVCCDA.EXE
c:\program files\Common Files\EPSON\EBAPI\SAgent2.exe
c:\program files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
c:\program files\Microsoft SQL Server\MSSQL.1\MSSQL\Binn\sqlservr.exe
c:\windows\SYSTEM32\HPZipm12.exe
c:\program files\Microsoft SQL Server\90\Shared\sqlwriter.exe
c:\program files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
c:\windows\SYSTEM32\MsPMSPSv.exe
c:\windows\SYSTEM32\fxssvc.exe
c:\program files\Windows Media Player\wmpnetwk.exe
c:\program files\Canon\CAL\CALMAIN.exe
c:\program files\HP\Digital Imaging\bin\hpqimzone.exe
c:\program files\SpywareGuard\sgbhp.exe
c:\program files\HP\Digital Imaging\bin\hpqste08.exe
Completion time: 2008-12-30 15:16:20 - machine was rebooted
ComboFix-quarantined-files.txt 2008-12-30 23:16:16
ComboFix2.txt 2008-12-29 03:52:09
ComboFix3.txt 2008-12-29 01:13:49
Pre-Run: 33,612,378,112 bytes free
Post-Run: 33,604,083,712 bytes free
502 --- E O F --- 2008-12-29 22:25:41
danthemaninthecan
Posts Posts : 20
Post by Belahzur on 30th December 2008, 11:39 pm
Looks good, just leftovers to get rid.
We need to use the OTMoveIt again.
  • Please double-click OTMoveIt3.exe to run it.
  • Copy the file paths below to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose CopyCrying
    :processes
    explorer.exe
    :files
    :commands
    [purity]
    [emptytemp]
    [start explorer]
    [reboot]
  • Return to OTMoveIt3, right click in the "Paste instructions for items to be Moved" window (under the light blue bar) and choose Paste.
  • Close OTMoveIt3
Please post the OTMoveIt log.
Post by danthemaninthecan on 30th December 2008, 11:59 pm
========== PROCESSES ==========
Process explorer.exe killed successfully.
========== FILES ==========
c:\documents and settings\Andrea\Application Data\casino.exe moved successfully.
c:\windows\SYSTEM32\system32xp.exe.tmp moved successfully.
c:\windows\SYSTEM32\CONFIG\systemprofile\Application Data\casino.exe moved successfully.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\hpodvd09.log scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF10B1.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF10FE.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF27E1.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF4D7E.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF672C.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF6A0F.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF9594.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DFCBD8.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DFE4B5.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DFEE0.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Dan\LOCALS~1\Temp\~DFEEB.tmp scheduled to be deleted on reboot.
User's Temp folder emptied.
User's Temporary Internet Files folder emptied.
User's Internet Explorer cache folder emptied.
Local Service Temp folder emptied.
File delete failed. C:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\INDEX.DAT scheduled to be deleted on reboot.
Local Service Temporary Internet Files folder emptied.
File delete failed. C:\WINDOWS\temp\Perflib_Perfdata_7c8.dat scheduled to be deleted on reboot.
Windows Temp folder emptied.
Java cache emptied.
Temp folders emptied.
Explorer started successfully
OTMoveIt3 by OldTimer - Version 1.0.7.2 log created on 12302008_154348
Files moved on Reboot...
C:\DOCUME~1\Dan\LOCALS~1\Temp\hpodvd09.log moved successfully.
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF10B1.tmp not found!
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF10FE.tmp not found!
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF27E1.tmp not found!
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF4D7E.tmp not found!
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF672C.tmp not found!
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF6A0F.tmp not found!
C:\DOCUME~1\Dan\LOCALS~1\Temp\~DF9594.tmp moved successfully.
C:\DOCUME~1\Dan\LOCALS~1\Temp\~DFCBD8.tmp moved successfully.
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DFE4B5.tmp not found!
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DFEE0.tmp not found!
File C:\DOCUME~1\Dan\LOCALS~1\Temp\~DFEEB.tmp not found!
File move failed. C:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\INDEX.DAT scheduled to be moved on reboot.
File C:\WINDOWS\temp\Perflib_Perfdata_7c8.dat not found!
danthemaninthecan
Posts Posts : 20
Post by Belahzur on 31st December 2008, 12:08 am
Looks good, what problems remain?
Post by danthemaninthecan on 31st December 2008, 12:10 am
everything seems to be working fine.
thanks very much
danthemaninthecan
Posts Posts : 20
Post by Belahzur on 31st December 2008, 12:11 am
Please delete these folders in bold:
C:\_OTMoveIt
C:\Qoobox
Updating Java:
Please download JavaRa from [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
  • First, unzip it.
  • Then run JavaRa.
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
Post by danthemaninthecan on 31st December 2008, 12:31 am
JavaRa 1.12 Removal Log.
Report follows after line.
The JavaRa removal process was started on Mon Dec 29 10:14:18 2008
Found and removed: C:\Program Files\Java\j2re1.4.2_03
Found and removed: C:\Program Files\Java\j2re1.4.2_06
Found and removed: C:\Program Files\Java\jre1.5.0_02
Found and removed: C:\Program Files\Java\jre1.6.0_02
The JavaRa removal process was started on Mon Dec 29 10:19:27 2008
Found and removed: Software\JavaSoft\Java2D\1.5.0_02
Found and removed: Software\JavaSoft\Java2D\1.5.0_05
Found and removed: Software\JavaSoft\Java2D\1.5.0_06
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\JavaPlugin.150_02
Found and removed: SOFTWARE\Classes\JavaPlugin.150_05
Found and removed: SOFTWARE\Classes\JavaPlugin.150_06
Found and removed: SOFTWARE\Classes\JavaWebStart.isInstalled.1.5.0.0
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F841731866D117AB7000B0D410203
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F841731866D117AB7000B0D410206
Found and removed: SOFTWARE\Classes\JavaPlugin.142_03
Found and removed: SOFTWARE\Classes\JavaPlugin.142_06
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.5.0_02\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_02\
Finished reporting.
The JavaRa removal process was started on Tue Dec 30 16:28:28 2008
Finished reporting.
danthemaninthecan
Posts Posts : 20
Post by Belahzur on 31st December 2008, 12:32 am
Post by Doctor Inferno on 14th February 2009, 4:08 am
Points Points : 104630
