Need help with removing a virus[Still Need Help][Nothing worked, at least I think]
Re: Need help with removing a virus[Still Need Help][Nothing worked, at least I think]
Post by Belahzur on 29th December 2008, 6:34 pm
Press Start > Run
Type in:
%userprofile%
Press enter.
Are you able to do it that way.
Points Points : 245101
Post by Stephon on 29th December 2008, 6:37 pm
[You must be registered and logged in to see this link.] wrote:Press Start > Run
Type in:
%userprofile%
Press enter.
Yeah..
But.. It puts me into Austen.AUSTEN-LABTOP when there's another folder named Austen(witch I can't go inside of..).
Might be nothing but don't really know..
Stephon
Posts Posts : 93
Joined Joined : 2008-09-06
Points Points : 30200
Post by Belahzur on 29th December 2008, 6:41 pm
Ah, so there is more than one user profile.
You are on Austen.AUSTEN-LABTOP right now?
If so, and you don't use the Austen user profile, then do this and just leave it as it's not a threat nor in use.
Right click the normal Austen folder > Properties > Tick the "Hidden" attributes box.
You may get an alert box that asks how you want the hidden attribute to work.
Select it to that folder only (the first option I think)
Post by Stephon on 29th December 2008, 6:43 pm
[You must be registered and logged in to see this link.] wrote:Ah, so there is more than one user profile.
I just did that now and it said it had nothing in it. Could this be because I did a system restore?
Stephon
Posts Posts : 93
Post by Belahzur on 29th December 2008, 6:48 pm
No.
I didn't get the alert either when I made sure my instructions were right, but I did on my other machine.
Aside from the profile that is likely corrupt, but I'd rather not fix something that's not broken.
What other problems remain?
Post by Stephon on 29th December 2008, 6:50 pm
[You must be registered and logged in to see this link.] wrote:No.
So, should I delete it or just leave it be?
One more thing ;)
If ESET detects something messing with the svchost, what should I do?
Stephon
Posts Posts : 93
Post by Belahzur on 29th December 2008, 6:56 pm
I can see from the drivers list a legit driver is using svchost.exe to run it, so chances are if Nod32 warns you of it, allow it to.
Post by Stephon on 29th December 2008, 6:59 pm
[You must be registered and logged in to see this link.] wrote:I can see from the drivers list a legit driver is using svchost.exe to run it, so chances are if Nod32 warns you of it, allow it to.
Alright, thanks for all the help. Thank You! Bow or Thanks
Stephon
Posts Posts : 93
Post by Doctor Inferno on 14th February 2009, 4:04 am
Points Points : 104630
