kaspersky problem!!!
Post by vikneshwaren on 27th December 2008, 9:22 am
I've KIS installed in my pc and why does it slows down my pc???? (RAM:1.5 GB) (I also use MBAM with KIS) Sad tearing
vikneshwaren
Posts Posts : 251
Joined Joined : 2008-12-23
OS OS : Microsoft Windows 7 Ultimate
Points Points : 29465
Re: kaspersky problem!!!
Post by Nazzgull on 27th December 2008, 10:02 am
Kaspersky is too strong, and you should be carefully when you using it. I think he use 126 Mb of RAM memory, if you don't like it, use NOD32.
Posts Posts : 2330
Points Points : 40495
Post by vikneshwaren on 27th December 2008, 10:05 am
which is the next rated antivirus next to NOD32?
vikneshwaren
Posts Posts : 251
Post by Digitalocksmith on 27th December 2008, 10:07 am
What exactly do you mean by 'slows down my PC'?
Is your internet browsing slower, data transfer, boot up or what?
What browser are you using?
What version of kaspersky.....is it the security suite?
Regards
Digitalocksmith
Posts Posts : 625
Joined Joined : 2007-12-22
Points Points : 48961
Post by Nazzgull on 27th December 2008, 10:23 am
@vikneshwaren wrote:which is the next rated antivirus next to NOD32?
Norton
Posts Posts : 2330
Post by vikneshwaren on 27th December 2008, 10:28 am
actually when i run .exe file, my pc crashes and i use kaspersky internet security and my browser is firefox.. Sad tearing
vikneshwaren
Posts Posts : 251
Post by Nazzgull on 27th December 2008, 11:08 am
O man, you have 1000 problems. Try to reinstall Windows, if that not work, try to check your hardware, maybe some component crash. You have some serious problem with your PC, you should go to some PC service, or something like that, to check you computer hardware.
Posts Posts : 2330
Post by vikneshwaren on 27th December 2008, 11:14 am
ok. i will do it
vikneshwaren
Posts Posts : 251
Post by shihabsharia on 28th July 2009, 4:55 am
i Buy a key but after some days it saying it blocked. now what i do. help me
shihabsharia
Posts Posts : 5
Joined Joined : 2009-07-24
OS OS : xp sp2
Points Points : 26971
Post by Doctor Inferno on 28th July 2009, 7:22 am
@shihabsharia wrote:i Buy a key but after some days it saying it blocked. now what i do. help me
Please contact Kasperky for that, there's nothing we can do.
Points Points : 104640
