Photoshop cs2 problem!!!
Solved Photoshop cs2 problem!!!
Post by vikneshwaren on Fri Dec 26, 2008 3:21 pm
when i open my photoshop cs2..it shows that "Adobe updater Could not be started..please re-install the application and components"...When i re-install also the same problem occurs...does anyone know why? and please give me a adobe photoshop cs2 updater file..so that i can past it in my photoshop directory... Sad tearing
See this below image:
http://i34.tinypic.com/rjqczt.jpg
vikneshwaren
Posts Posts : 251
Joined Joined : 2008-12-23
OS OS : Microsoft Windows 7 Ultimate
Points Points : 29415
Solved Re: Photoshop cs2 problem!!!
Post by Doctor Inferno on Fri Dec 26, 2008 3:32 pm
Hello, please post your questions in the appropriate sections, I have been moving your topics here and there and everywhere.
Moved from computer security.
Try to run the updater manually by double clicking the AdobeUpdater.exe file, located at the C:\Programmer\Fælles filer\Adobe\Updater folder
See it it works.
Post by vikneshwaren on Fri Dec 26, 2008 4:12 pm
no i did not worked..it would be helpfull for me when anyone give me photoshop cs2 updater file...if anyone have cs2 installed then plz copy the updater file and plz uploadit to any hosting service and give me the link if possible.. Smile
vikneshwaren
Posts Posts : 251
Post by Doctor Inferno on Sat Dec 27, 2008 2:39 pm
Let's try to change the security permissions to allow full access to the Shared Documents folder, and then run the common files installer.
Complete one of the following procedures to change the security permissions.
1. Choose Start > Run.
2. Type %allusersprofile% in the Open box, and click OK.
3. Right-click the Shared Documents folder, and choose Properties.
4. Click the Security tab.
5. Select Everyone in Group Or User Names, and then select Allow next to Full Control in the Permissions. (For more information on changing permissions, see Windows Help.)
6. Click Advanced, and select Replace Permission Entries On All Child Objects With Entries Shown Here That Apply To Child Objects.
7. Click OK, click Yes, and then click OK to close the Shared Documents Properties dialog box.
Edit the file permissions for the All Users folder and the Windows\Installer folder by running the CALCS commands. Then, run the common files installer to complete the Adobe Updater utility installation.
To edit file permissions:
2. Type cmd in the Open box, and click OK.
3. Type the following CACLS commands for your operating system exactly as they appear, pressing Enter at the end of each command line:
Important:Enter spaces before and after /T, /E, /C, and /G in each line.
cacls c:\windows\installer /T /E /C /G administrators:F
cacls "c:\documents and settings\all users" /T /E /C /G administrators:F
exit
Post by vikneshwaren on Sat Dec 27, 2008 4:13 pm
I've downloaded a new copy of photoshop cs2 and installed and this problem no more persists..thanks your very much for your assistance. Thank You!
vikneshwaren
Posts Posts : 251
