How to Remove Astrum Antivirus Pro [Removal Guide]
Page 1 of 1 • Share •
This guide will give you easy instructions on how to remove Astrum Antivirus Pro.
Astrum Antivirus Pro Screenshots:
There are a total of 2 images you can view for this infection. Click the image above to view it in a pop up.
Symptoms in HijackThis logs:
1. Please download Malwarebytes' Anti-Malware.
2. Install Malwarebytes' Anti-Malware by double clicking on Download_mbam-setup.exe
4. Malwarebytes' Anti-Malware will automatically update itself after the install, you can press the OK button to close that box and you will now be at the main program as shown below.
If you are having problems with the updater, you can use this link to manually update MBAM with the latest database
5. Close ALL open Windows, Programs, File or Folders.
6. Make sure you are on the Scanner tab. Select Perform quick scan then click the Scan button as shown above.
8. When the scan is finished a message box will appear, click Ok to continue.
9. Click Show Results.
11. Click on Remove seletced
12. When removing the files, Malwarebytes' Anti-Malware may require you to restart the computer in order to do a complete removal. If it displays a message stating that it needs to restart, please allow it to do so.
13. After that you can close the Malwarebytes' Anti-Malware window, your computer is now cleaned.
If you are still experiencing problems or difficulties following this guide or require any assistance removing this malware, please post your questions in our Malware Removal forums for free help.
You have to be logged in to post questions. Registration is free. By registering you are privileged to other virus removal resources.
- Code:
O4 - HKCU\..\Run: [Astrum] "C:\Program Files\Astrumsoftware\Astrum.exe"
- Spoiler:
- Malwarebytes' Anti-Malwares' latest database
Doctor Inferno- The GeekPolice
Similar topics» Boarding Guide
» Strategical Guide
» FORCE BLADER GUIDE
» Sector And Universe Trader Guide
» W32/Conficker.worm Removal Help...
» Strategical Guide
Page 1 of 1
by
