problem in msn
Solved problem in msn
Post by crazy_5n1p3r on Mon Dec 22, 2008 9:35 pm
when am trying to install msn the latest verision
the installitation stops at 99%
any help plz
crazy_5n1p3r
Posts Posts : 80
Joined Joined : 2008-09-17
OS OS : egypt
Points Points : 30056
Solved Re: problem in msn
Post by Nazzgull on Mon Dec 22, 2008 9:40 pm
  • Download latest version from HERE
  • Go to "C:\Program Files\Windows Live" and remove "Messenger" folder (note: replace "C" with your root drive letter)
  • Go to "C:ProgramData" (note: replace "C" with your root drive letter)
    and delete both Windows Live Installer and WLInstaller if you have any
  • Restart PC
  • Run the installer
If this not work, go to Start > Run > type this "regsvr32 wups2.dll"
Don't use " and put space between regsvr32 and wups2.dll
Now try to install MSN again Smile Hope it works now
Points Points : 40445
Post by crazy_5n1p3r on Mon Dec 22, 2008 9:45 pm
so where is ProgramData?
crazy_5n1p3r
Posts Posts : 80
OS OS : egypt
Post by Nazzgull on Mon Dec 22, 2008 10:11 pm
Only if you have it.If you don't go to the next step.
Post by crazy_5n1p3r on Mon Dec 22, 2008 10:30 pm
thx
u really helped me
done
crazy_5n1p3r
Posts Posts : 80
OS OS : egypt
