HELP!!! W32.Tidserv aka Backdoor.Tidserv!inf HELP!!
Page 2 of 2 Previous  1, 2
Solved Re: HELP!!! W32.Tidserv aka Backdoor.Tidserv!inf HELP!!
Post by ginobwoy on Tue Dec 23, 2008 2:08 am
ok then.. thanks for everything I really appreciate it ... Merry Christmas and a Happy new year Smile
ginobwoy
OS : Windows XP
# Likes : 0
Post by Belahzur on Tue Dec 23, 2008 2:11 am
# Likes : 1
Post by Doctor Inferno on Sat Jan 24, 2009 10:22 am
# Likes : 0
