at wit's end and need help
Solved Re: at wit's end and need help
Post by Belahzur on 14th December 2008, 12:33 am
Tis okay, CF removed it's folder along with it's files, so that is gone.
Points Points : 245111
Post by Endall on 14th December 2008, 12:39 am
much better thanks!!! I haven't noticed anything like what was going on. It's so nice to end up on the page for the link you clicked in a google search and not bounced to who-knows-where.
I am so happy I found this site. You have been the MOST help I've ever gotten for any such problem!
I don't know how to thank you for the help. I know I'm gonna keep a book mark for the site and will direct others I may come accross with similar problems here.
Now, one more question... What's a decent anti-virus/malare package to run? I was using AVG Free at the time I became infected, so my confidence is a bit low with it now. I'm currently running a trial version of Norton. Should I just spend the money and stick with it or is there something better out there?
Endall
Posts Posts : 19
Joined Joined : 2008-12-13
OS OS : windows xp sp3
Points Points : 29190
Post by Belahzur on 14th December 2008, 12:43 am
In my opinion - Norton drags the system down because it's a large program, I would stick with AVG, much smaller and lighter on the system.
Post by Endall on 14th December 2008, 1:16 am
heh, I've got firefox too.. it was also affected by the bug...
so far, all seems well!
I really do appreciate the help.
Endall
Posts Posts : 19
Post by Jerry Parnell on 14th December 2008, 1:16 am
Wow Bel! Very nice fix, fastest for this rootkit so far! Right On!
Jerry Parnell
Posts Posts : 670
Joined Joined : 2008-08-04
OS OS : Windows Vista Home Basic
Points Points : 30764
Post by Doctor Inferno on 17th January 2009, 10:26 am
Points Points : 104640
