at wit's end and need help
Solved at wit's end and need help
Post by Endall on 13th December 2008, 3:34 am
Hello all. I've got a bug and can't identify or get rid of it. It's been pestering me for almost 2 weeks now. I've gotten a browser highjacker or something. Here is a list of the lovely things it does:
1. redirects links from google or yahoo search results.
2. blocks web site access to any and all anti-virus/malware site.
3. I was running AVG free when it walked in the door and wasn't detected.
4. I downloaded hijackthis to an external drive via my laptop and transfered it to my infected machine, was able to install in safemode but it won't allow the program to actually run.(same experience with another scanner or 2 OR just won't let the setup file run)
5. Windows Defender actually installed and ran, but did not detect it.
6. I found an older version of Spytrap on an old HD, it finally ran and didn't find anything.
7. Tonight the Norton that I reactivated(came with PC when purchased a few months ago) magically managed to connect to update server and then scanned. It found and quarantined "backdoor.Tidserv", main problem still exists.
8. Won't allow a "system recovery" cd to be made. The burn application tells me that no recovery partition is found.(it's there, I can see it)
9. Won't allow use of "system restore" feature.
Needless to say, I've had thoughts of using a 6-8 month old PC for target practice. (Gunsmoke) I can't afford to do that!
I stumbled accross your site and did some reading here and you guys seem to be pretty helpfull. If you can help me, I'd be eternally greatfull! Cheers Mate
Endall
Posts Posts : 19
Joined Joined : 2008-12-13
OS OS : windows xp sp3
Points Points : 29190
Solved Re: at wit's end and need help
Post by Jerry Parnell on 13th December 2008, 7:51 am
Hi Endall,
I am going to be covering for our main tech while he is away. When he gets back, he will probably take over.
First of all, I would like to ask you to read [You must be registered and logged in to see this link.], then post your hijack this log back here.
Thank you, and I hope to hear from you soon! Bow or Thanks
Jerry Parnell
Posts Posts : 670
Joined Joined : 2008-08-04
OS OS : Windows Vista Home Basic
Points Points : 30764
Post by Endall on 13th December 2008, 8:09 am
Hey, thanks for the reply. As I stated in my original post, I can't get HJT to actually run. It completed the install, but whatever it is that's hampering my system won't let me actually RUN HJT. It's very frustrating. I've tried pretty much everything I could think of, all to no end. I've also tried to run it in safemode, which is how I got it to install but it wouldn't run there either.
Endall
Posts Posts : 19
Post by Belahzur on 13th December 2008, 2:17 pm
Thanks Jerry.
Endall -
Points Points : 245111
Post by Endall on 13th December 2008, 7:53 pm
Ok, here's the report that Silent Runners generated. I'll await further instructions. Thanks!
I had to break it into pieces.
"Silent Runners.vbs", revision 59, [You must be registered and logged in to see this link.]
Operating System: Windows XP
Output limited to non-default values, except where indicated by "{++}"
Startup items buried in registry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Run\ {++}
"ctfmon.exe" = "C:\WINDOWS\system32\ctfmon.exe" [MS]
"Aim6" = ""C:\Program Files\AIM6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.] ["AOL LLC"]
"Yahoo! Pager" = ""C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" -quiet" ["Yahoo! Inc."]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ {++}
"Reminder" = "C:\WINDOWS\Creator\Remind_XP.exe"
"RemoteControl" = ""C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"" ["Cyberlink Corp."]
"{0228e555-4f9c-4e35-a3ec-b109a192b4c2}" = "C:\Program Files\Google\Gmail Notifier\gnotify.exe" ["Google Inc."]
"NvCplDaemon" = "RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup" [MS]
"Recguard" = "C:\WINDOWS\SMINST\RECGUARD.EXE"
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\
{5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897}\(Default) = (no title provided)
-> {HKLM...CLSID} = "Yahoo! IE Services Button"
\InProcServer32\(Default) = "C:\Program Files\Yahoo!\Common\yiesrvc.dll" ["Yahoo! Inc."]
{602ADB0E-4AFF-4217-8AA1-95DAC4DFA408}\(Default) = "Symantec NCO BHO"
-> {HKLM...CLSID} = "Symantec NCO BHO"
\InProcServer32\(Default) = "C:\Program Files\Norton Internet Security\Engine\16.1.0.33\coIEPlg.dll" ["Symantec Corporation"]
{6D53EC84-6AAE-4787-AEEE-F4628F01010C}\(Default) = "Symantec Intrusion Prevention"
-> {HKLM...CLSID} = "Symantec Intrusion Prevention"
\InProcServer32\(Default) = "C:\Program Files\Norton Internet Security\Engine\16.1.0.33\IPSBHO.DLL" ["Symantec Corporation"]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\
"{42071714-76d4-11d1-8b24-00a0c9068ff3}" = "Display Panning CPL Extension"
-> {HKLM...CLSID} = "Display Panning CPL Extension"
\InProcServer32\(Default) = "deskpan.dll" [file not found]
"{88895560-9AA2-1069-930E-00AA0030EBC8}" = "HyperTerminal Icon Ext"
-> {HKLM...CLSID} = "HyperTerminal Icon Ext"
\InProcServer32\(Default) = "C:\WINDOWS\system32\hticons.dll" ["Hilgraeve, Inc."]
"{A70C977A-BF00-412C-90B7-034C51DA2439}" = "NvCpl DesktopContext Class"
-> {HKLM...CLSID} = "DesktopContext Class"
\InProcServer32\(Default) = "C:\WINDOWS\system32\nvcpl.dll" ["NVIDIA Corporation"]
"{7F67036B-66F1-411A-AD85-759FB9C5B0DB}" = "SampleView"
-> {HKLM...CLSID} = "SampleView"
\InProcServer32\(Default) = "C:\WINDOWS\system32\ShellvRTF.dll" ["XSS"]
"{1CDB2949-8F65-4355-8456-263E7C208A5D}" = "Desktop Explorer"
-> {HKLM...CLSID} = "Desktop Explorer"
\InProcServer32\(Default) = "C:\WINDOWS\system32\nvshell.dll" ["NVIDIA Corporation"]
"{1E9B04FB-F9E5-4718-997B-B8DA88302A47}" = "Desktop Explorer Menu"
-> {HKLM...CLSID} = (no title provided)
"{1E9B04FB-F9E5-4718-997B-B8DA88302A48}" = "nView Desktop Context Menu"
-> {HKLM...CLSID} = "nView Desktop Context Menu"
"{e57ce731-33e8-4c51-8354-bb4de9d215d1}" = "Universal Plug and Play Devices"
-> {HKLM...CLSID} = "Universal Plug and Play Devices"
\InProcServer32\(Default) = "C:\WINDOWS\system32\upnpui.dll" [MS]
"{5464D816-CF16-4784-B9F3-75C0DB52B499}" = "Yahoo! Mail"
-> {HKLM...CLSID} = "Yahoo! Mail Shell Extension"
\InProcServer32\(Default) = "C:\Program Files\Yahoo!\Common\YMMAPI.dll" ["Yahoo! Inc."]
"{C41662BB-1FA0-4CE0-8DC5-9B7F8279FF97}" = "Microsoft Office Thumbnail Handler"
-> {HKLM...CLSID} = "Microsoft Office Thumbnail Handler"
\InProcServer32\(Default) = "C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\msoshext.dll" [MS]
"{993BE281-6695-4BA5-8A2A-7AACBFAAB69E}" = "Microsoft Office Metadata Handler"
-> {HKLM...CLSID} = "Microsoft Office Metadata Handler"
"{42042206-2D85-11D3-8CFF-005004838597}" = "Microsoft Office HTML Icon Handler"
\InProcServer32\(Default) = "C:\Program Files\Microsoft Office\Office12\msohevi.dll" [MS]
"{5858A72C-C2B4-4dd7-B2BF-B76DB1BD9F6C}" = "Microsoft Office OneNote Namespace Extension for Windows Desktop Search"
-> {HKLM...CLSID} = "Microsoft Office OneNote Namespace Extension for Windows Desktop Search"
\InProcServer32\(Default) = "C:\PROGRA~1\MICROS~3\Office12\ONFILTER.DLL" [MS]
"{8FF88D21-7BD0-11D1-BFB7-00AA00262A11}" = "WinAce Archiver 2.69 Context Menu Shell Extension"
-> {HKLM...CLSID} = "WinAceContext Menu Extension"
\InProcServer32\(Default) = "C:\Program Files\WinAce\arcext.dll" ["e-merge GmbH"]
"{8FF88D25-7BD0-11D1-BFB7-00AA00262A11}" = "WinAce Archiver 2.69 DragDrop Shell Extension"
-> {HKLM...CLSID} = "WinAceDrag-Drop Extension"
"{8FF88D27-7BD0-11D1-BFB7-00AA00262A11}" = "WinAce Archiver 2.69 Context Menu Shell Extension"
-> {HKLM...CLSID} = "WinAceContext Menu (Add) Extension"
"{8FF88D23-7BD0-11D1-BFB7-00AA00262A11}" = "WinAce Archiver 2.69 Property Sheet Shell Extension"
-> {HKLM...CLSID} = "WinAceProperty Sheet Extension"
"{FFB699E0-306A-11d3-8BD1-00104B6F7516}" = "Play on my TV helper"
-> {HKLM...CLSID} = "NVIDIA CPL Extension"
"{FA010552-4A27-4cb1-A1BB-3E2D697F1639}" = "SpySubtract Shell Extension"
-> {HKLM...CLSID} = "SpySubtract Shell Extension"
\InProcServer32\(Default) = "c:\Program Files\interMute\SpySubtract\sshook.dll" ["InterMute, Inc."]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks\
<> "{FA010552-4A27-4cb1-A1BB-3E2D697F1639}" = "SpySubtract Shell Extension"
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\
"WPDShServiceObj" = "{AAA288BA-9A4C-45B0-95D7-94D524869DB5}"
-> {HKLM...CLSID} = "WPDShServiceObj Class"
\InProcServer32\(Default) = "C:\WINDOWS\system32\WPDShServiceObj.dll" [MS]
HKLM\SOFTWARE\Classes\PROTOCOLS\Filter\
<> text/xml\CLSID = "{807563E5-5146-11D5-A672-00B0D022E945}"
-> {HKLM...CLSID} = "Microsoft Office InfoPath XML Mime Filter"
\InProcServer32\(Default) = "C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\MSOXMLMF.DLL" [MS]
HKLM\SOFTWARE\Classes\Folder\shellex\ColumnHandlers\
{F9DB5320-233E-11D1-9F84-707F02C10627}\(Default) = "PDF Column Info"
-> {HKLM...CLSID} = "PDF Shell Extension"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll" ["Adobe Systems, Inc."]
HKLM\SOFTWARE\Classes\*\shellex\ContextMenuHandlers\
Symantec.Norton.Antivirus.IEContextMenu\(Default) = "{FAD61B3D-699D-49B2-BE16-7F82CB4C59CA}"
-> {HKLM...CLSID} = "IEContextMenu Class"
\InProcServer32\(Default) = ""C:\Program Files\Norton Internet Security\Engine\16.1.0.33\NavShExt.dll"" ["Symantec Corporation"]
Yahoo! Mail\(Default) = "{5464D816-CF16-4784-B9F3-75C0DB52B499}"
ZFAdd\(Default) = "{8FF88D27-7BD0-11D1-BFB7-00AA00262A11}"
HKLM\SOFTWARE\Classes\Directory\shellex\ContextMenuHandlers\
HKLM\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\
MBAMShlExt\(Default) = "{57CE581A-0CB6-4266-9CA0-19364C90A0B3}"
-> {HKLM...CLSID} = "MBAMShlExt Class"
\InProcServer32\(Default) = "C:\Program Files\Malwarebytes' Anti-Malware\mbamext.dll" ["Malwarebytes Corporation"]
HKLM\SOFTWARE\Classes\AllFilesystemObjects\shellex\ContextMenuHandlers\
Endall
Posts Posts : 19
Post by Endall on 13th December 2008, 7:54 pm
part 2
Group Policies {policy setting}:
Note: detected settings may not have any effect.
HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\
"NoBandCustomize" = (REG_DWORD) dword:0x00000000
{Disable customizing browser toolbars}
"NoToolbarCustomize" = (REG_DWORD) dword:0x00000000
{Disable customizing browser toolbar buttons}
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\
{unrecognized setting}
HKCU\Software\Policies\Microsoft\Internet Explorer\Infodelivery\Restrictions\
"NoSplash" = (REG_DWORD) dword:0x00000000
"NoJITSetup" = (REG_DWORD) dword:0x00000000
HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer\Infodelivery\Restrictions\
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\
"shutdownwithoutlogon" = (REG_DWORD) dword:0x00000001
{Shutdown: Allow system to be shut down without having to log on}
"undockwithoutlogon" = (REG_DWORD) dword:0x00000001
{Devices: Allow undock without having to log on}
Active Desktop and Wallpaper:
Active Desktop may be disabled at this entry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellState
Displayed if Active Desktop enabled and wallpaper not set by Group Policy:
HKCU\Software\Microsoft\Internet Explorer\Desktop\General\
"Wallpaper" = "C:\WINDOWS\system32\config\systemprofile\Local Settings\Application Data\Microsoft\Wallpaper1.bmp"
Displayed if Active Desktop disabled and wallpaper not set by Group Policy:
HKCU\Control Panel\Desktop\
"Wallpaper" = "C:\Documents and Settings\Owner\Application Data\Microsoft\Internet Explorer\Internet Explorer Wallpaper.bmp"
Enabled Screen Saver:
"SCRNSAVE.EXE" = "C:\WINDOWS\system32\scrnsave.scr" [MS]
Autostart via AUTORUN.INF on local fixed drives:
D:\
<> D:\AUTORUN.INF -> "SHELLEXECUTE=Info.exe folder.htt 480 480" ["XSS"]
Endall
Posts Posts : 19
part 3
Windows Portable Device AutoPlay Handlers
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers\Handlers\
MSWPDShellNamespaceHandler\
"Provider" = "@%SystemRoot%\System32\WPDShextRes.dll,-501"
"CLSID" = "{A55803CC-4D53-404c-8557-FD63DBA95D24}"
"InitCmdLine" = " "
-> {HKLM...CLSID} = "WPDShextAutoplay"
\LocalServer32\(Default) = "C:\WINDOWS\system32\WPDShextAutoplay.exe" [MS]
P2GCDBurningOnArrival\
"Provider" = "Power2Go"
"InvokeProgID" = "Picture"
"InvokeVerb" = "OpenWithPower2Go"
HKLM\SOFTWARE\Classes\Picture\shell\OpenWithPower2Go\Command\(Default) = ""C:\Program Files\CyberLink\Power2Go\Power2Go.exe"" ["Cyberlink"]
PDVDPlayCDAudioOnArrival\
"Provider" = "PowerDVD"
"InvokeProgID" = "AudioCD"
"InvokeVerb" = "PlayWithPowerDVD"
HKLM\SOFTWARE\Classes\AudioCD\shell\PlayWithPowerDVD\Command\(Default) = ""C:\Program Files\CyberLink\PowerDVD\PowerDVD.exe" "%L"" ["CyberLink Corp."]
PDVDPlayDVDMovieOnArrival\
"InvokeProgID" = "DVD"
HKLM\SOFTWARE\Classes\DVD\shell\PlayWithPowerDVD\Command\(Default) = ""C:\Program Files\CyberLink\PowerDVD\PowerDVD.exe" "%l"" ["CyberLink Corp."]
PDVDPlayVCDMovieOnArrival\
"InvokeProgID" = "VCD"
HKLM\SOFTWARE\Classes\VCD\shell\PlayWithPowerDVD\Command\(Default) = ""C:\Program Files\CyberLink\PowerDVD\PowerDVD.exe" "%l"" ["CyberLink Corp."]
PStarterBlankCDArrival\
"Provider" = "DVD Suite"
"InvokeVerb" = "OpenWithPowerStarter"
HKLM\SOFTWARE\Classes\Picture\shell\OpenWithPowerStarter\Command\(Default) = ""C:\Program Files\CyberLink\DVD Suite\PowerStarter.exe"" [empty string]
PStarterMixedCDArrival\
"InvokeProgID" = "MixedContent"
HKLM\SOFTWARE\Classes\MixedContent\shell\OpenWithPowerStarter\Command\(Default) = ""C:\Program Files\CyberLink\DVD Suite\PowerStarter.exe"" [empty string]
PStarterMusicFilesArrival\
"InvokeProgID" = "MusicFiles"
HKLM\SOFTWARE\Classes\MusicFiles\shell\OpenWithPowerStarter\Command\(Default) = ""C:\Program Files\CyberLink\DVD Suite\PowerStarter.exe"" [empty string]
PStarterPicturesArrival\
PStarterPlayCDAudioOnArrival\
"InvokeVerb" = "PlayWithPowerStarter"
HKLM\SOFTWARE\Classes\AudioCD\shell\PlayWithPowerStarter\Command\(Default) = ""C:\Program Files\CyberLink\DVD Suite\PowerStarter.exe" "%L"" [empty string]
PStarterPlayDVDMovieOnArrival\
HKLM\SOFTWARE\Classes\DVD\shell\PlayWithPowerStarter\Command\(Default) = ""C:\Program Files\CyberLink\DVD Suite\PowerStarter.exe" "%L"" [empty string]
PStarterVideoFilesArrival\
"InvokeProgID" = "VideoFiles"
HKLM\SOFTWARE\Classes\VideoFiles\shell\OpenWithPowerStarter\Command\(Default) = ""C:\Program Files\CyberLink\DVD Suite\PowerStarter.exe"" [empty string]
Startup items in "Owner" & "All Users" startup folders:
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
"SpySubtract" -> shortcut to: "C:\Program Files\interMute\SpySubtract\SpySub.exe -autostart" ["InterMute, Inc."]
Enabled Scheduled Tasks:
"AdwareAlert Scheduled Scan" -> launches: "C:\Program Files\AdwareAlert\AdwareAlert.exe scheduled" [file not found]
"GoogleUpdateTaskUser" -> launches: "C:\Documents and Settings\Owner\Local Settings\Application Data\Google\Update\GoogleUpdate.exe /c" ["Google Inc."]
"MP Scheduled Scan" -> launches: "C:\Program Files\Windows Defender\MpCmdRun.exe Scan -RestrictPrivileges" [MS]
"Norton Internet Security - Owner - Full System Scan" -> launches: "C:\Program Files\Norton Internet Security\Engine\16.1.0.33\Navw32.exe /L" ["Symantec Corporation"]
Winsock2 Service Provider DLLs:
Namespace Service Providers
HKLM\SYSTEM\CurrentControlSet\Services\Winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\ {++}
000000000001\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
000000000002\LibraryPath = "%SystemRoot%\System32\winrnr.dll" [MS]
000000000003\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
Transport Service Providers
HKLM\SYSTEM\CurrentControlSet\Services\Winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\ {++}
0000000000##\PackedCatalogItem (contains) DLL [Company Name], (at) ## range:
%SystemRoot%\system32\mswsock.dll [MS], 01 - 03, 06 - 13
%SystemRoot%\system32\rsvpsp.dll [MS], 04 - 05
Toolbars, Explorer Bars, Extensions:
Toolbars
HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\
"{F2CF5485-4E02-4F68-819C-B92DE9277049}"
-> {HKLM...CLSID} = "&Links"
\InProcServer32\(Default) = "C:\WINDOWS\system32\ieframe.dll" [MS]
"{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA}"
-> {HKLM...CLSID} = "Norton Toolbar"
HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar\
"{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA}" = "Norton Toolbar"
Explorer Bars
HKLM\SOFTWARE\Microsoft\Internet Explorer\Explorer Bars\
HKLM\SOFTWARE\Classes\CLSID\{2E5E800E-6AC0-411E-940A-369530A35E43}\(Default) = "The Weather Channel Toolbar"
Implemented Categories\{00021493-0000-0000-C000-000000000046}\ [vertical bar]
InProcServer32\(Default) = "C:\WINDOWS\system32\TwcToolbarIe7.dll" [null data]
Implemented Categories\{00021494-0000-0000-C000-000000000046}\ [horizontal bar]
HKLM\SOFTWARE\Classes\CLSID\{FF059E31-CC5A-4E2E-BF3B-96E929D65503}\(Default) = "&Research"
InProcServer32\(Default) = "C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL" [MS]
Extensions (Tools menu items, main toolbar menu buttons)
HKLM\SOFTWARE\Microsoft\Internet Explorer\Extensions\
{2670000A-7350-4F3C-8081-5663EE0C6C49}\
"ButtonText" = "Send to OneNote"
"MenuText" = "S&end to OneNote"
"CLSIDExtension" = "{48E73304-E1D6-4330-914C-F5F514E3486C}"
-> {HKLM...CLSID} = "Send to OneNote from Internet Explorer button"
\InProcServer32\(Default) = "C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll" [MS]
"ButtonText" = "The Weather Channel"
"MenuText" = "The Weather Channel"
"ButtonText" = "Yahoo! Services"
"CLSIDExtension" = "{5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897}"
{E59EB121-F339-4851-A3BA-FE49C35617C2}\
"ButtonText" = "ICQ6"
"MenuText" = "ICQ6"
"Exec" = "C:\Program Files\ICQ6\ICQ.exe" ["ICQ, Inc."]
{FB5F1910-F110-11D2-BB9E-00C04F795683}\
"ButtonText" = "Messenger"
"MenuText" = "Windows Messenger"
"Exec" = "C:\Program Files\Messenger\msmsgs.exe" [MS]
Running Services (Display Name, Service Name, Path {Service DLL}Crying
Cyberlink RichVideo Service(CRVS), RichVideo, ""C:\Program Files\CyberLink\Shared Files\RichVideo.exe"" [empty string]
LexBce Server, LexBceS, "C:\WINDOWS\system32\LEXBCES.EXE" ["Lexmark International, Inc."]
Norton Internet Security, Norton Internet Security, ""C:\Program Files\Norton Internet Security\Engine\16.1.0.33\ccSvcHst.exe" /s "Norton Internet Security" /m "C:\Program Files\Norton Internet Security\Engine\16.1.0.33\diMaster.dll" /prefetch:1" ["Symantec Corporation"]
NVIDIA Display Driver Service, NVSvc, "C:\WINDOWS\system32\nvsvc32.exe" ["NVIDIA Corporation"]
PrismXL, PrismXL, "C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS" ["New Boundary Technologies, Inc."]
Windows Defender, WinDefend, ""C:\Program Files\Windows Defender\MsMpEng.exe"" [MS]
Print Monitors:
HKLM\SYSTEM\CurrentControlSet\Control\Print\Monitors\
Lexmark Network Port\Driver = "LEXLMPM.DLL" ["Lexmark International, Inc."]
PrintServer\Driver = "prtserv.dll" [null data]
Send To Microsoft OneNote Monitor\Driver = "msonpmon.dll" [MS]
---------- (launch time: 2008-12-13 13:45:53)
<>: Suspicious data at a malware launch point.
+ This report excludes default entries except where indicated.
+ To see *everywhere* the script checks and *everything* it finds,
launch it from a command prompt or a shortcut with the -all parameter.
+ To search all directories of local fixed drives for DESKTOP.INI
DLL launch points, use the -supp parameter or answer "No" at the
first message box and "Yes" at the second message box.
---------- (total run time: 34 seconds, including 10 seconds for message boxes)
Endall
Posts Posts : 19
Post by Belahzur on 13th December 2008, 8:00 pm
  • Download random's system information tool (RSIT) by random/random from [You must be registered and logged in to see this link.] and save it to your desktop.
  • Double click on RSIT.exe to run RSIT.
  • Click Continue at the disclaimer screen.
  • Once it has finished, two logs will open. Please post the contents of both log.txt (<< will be maximized) and info.txt (<< will be minimized)
Post by Endall on 13th December 2008, 8:05 pm
the beast is blocking the website. can't get it downloaded which is one of the problems I've been having all along.
suggestions?
Endall
Posts Posts : 19
Post by Belahzur on 13th December 2008, 8:15 pm
Hello. Yep, lets try it this way.
Now open a new notepad file.
start cmd
cd\
attrib autorun.inf -s -h -r
del autorun.inf
d:
del autorun.inf
Save this as fix.bat, save it to your desktop.
Double click fix.bat and the black cmd window will open (I think 2 may open, tested this myself)
One will have "delete autorun.inf y/n", this is the one we want. Close the other.
Type y and press enter.
Can you run Hijack This now?
Post by Endall on 13th December 2008, 8:26 pm
still won't install... it shows up in the Task Manager but isn't doing anything.
next?
Endall
Posts Posts : 19
Post by Endall on 13th December 2008, 8:33 pm
wait... you said that it should open 2 cmd windows... it pops one open and closes it and the one that stays open is showing c:docs and settings\owner\desktop
that doesn't sound right
Endall
Posts Posts : 19
Post by Belahzur on 13th December 2008, 8:37 pm
I bet it blocks this website too.
Link: [You must be registered and logged in to see this link.].
Files to delete:
D:\autorun.inf
5. Please copy/paste the content of c:\avenger.txt into your reply.
Post by Endall on 13th December 2008, 8:40 pm
you got it... blocked! is there anywhere else the file can be downloaded from? maybe a site that won't be recognized and blocked?
Endall
Posts Posts : 19
Post by Belahzur on 13th December 2008, 8:41 pm
Thank you.
I know what's going on now though.
Uploaded to here:
Post by Endall on 13th December 2008, 8:46 pm
hmmm.... the page loaded, but it's stuck on
Download Link: Please wait... link is loading...
Endall
Posts Posts : 19
Post by Endall on 13th December 2008, 8:49 pm
refreshed and it came up
wish me luck
Endall
Posts Posts : 19
Post by Endall on 13th December 2008, 8:58 pm
Looks like you're onto something here! The first bit of success I've had in trying to deal with this. Here's the log file:
Platform: Windows XP
Rootkit scan active.
Hidden driver "TDSSserv.sys" found!
ImagePath: \systemroot\system32\drivers\TDSSrvdc.sys
Driver disabled successfully.
Rootkit scan completed.
Error: file "D:\autorun.inf" not found!
Deletion of file "D:\autorun.inf" failed!
--> the object does not exist
Completed script processing.
Finished! Terminate.
Endall
Posts Posts : 19
Post by Belahzur on 13th December 2008, 9:09 pm
Hooray! Hooray!
The rookit has been disabled.
  • Download combofix from here, use the top links - [You must be registered and logged in to see this link.]
  • You will this next prompt that asks if you want to continue the malware scan, select yes
Post by Endall on 13th December 2008, 9:31 pm
here's the report in parts.
ComboFix 08-12-12.05 - Owner 2008-12-13 15:18:09.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.895.507 [GMT -6:00]
Running from: c:\documents and settings\Owner\Desktop\ComboFix.exe
* Created a new restore point
c:\windows\system32\TDSSkfkl.dll
c:\windows\system32\TDSSqrdn.log
c:\windows\system32\TDSSweat.dat
c:\windows\system32\TDSSxehr.dll
-------\Legacy_TDSSSERV.SYS
-------\Service_TDSSserv.sys
((((((((((((((((((((((((( Files Created from 2008-11-13 to 2008-12-13 )))))))))))))))))))))))))))))))
2008-12-13 15:13 . 2008-12-13 15:14 d-------- C:\32788R22FWJFW
2008-12-12 22:01 . 2008-04-13 18:11 1,689,088 ---h---t- c:\windows\system32\e207c46.dll
2008-12-12 22:01 . 2008-04-13 18:11 1,689,088 ---h---t- c:\windows\system32\7dea562.dll
2008-12-12 22:01 . 2008-04-13 18:12 82,432 ---h---t- c:\windows\system32\d0c960a.dll
2008-12-12 22:01 . 2008-04-13 18:12 82,432 ---h---t- c:\windows\system32\175dfb5d.dll
2008-12-12 20:35 . 2008-12-12 20:35 d-------- c:\documents and settings\Owner\Application Data\InterMute
2008-12-11 21:38 . 2008-12-11 21:40 d-------- c:\documents and settings\Owner\Application Data\Uniblue
2008-12-11 21:37 . 2008-12-11 21:37 d-------- c:\program files\Uniblue
2008-12-11 19:09 . 2008-12-11 19:09 d-------- c:\program files\Malwarebytes' Anti-Malware
2008-12-11 19:09 . 2008-12-11 19:09 d-------- c:\documents and settings\All Users\Application Data\Malwarebytes
2008-12-11 19:09 . 2008-12-03 19:52 38,496 --a------ c:\windows\system32\drivers\mbamswissarmy.sys
2008-12-11 19:09 . 2008-12-03 19:52 15,504 --a------ c:\windows\system32\drivers\mbam.sys
2008-12-11 19:07 . 2006-06-30 23:30 d-------- c:\documents and settings\Administrator.REDDWARF\WINDOWS
2008-12-11 19:07 . 2007-11-09 22:13 d-------- c:\documents and settings\Administrator.REDDWARF\Application Data\Symantec
2008-12-11 19:07 . 2007-11-20 16:50 d-------- c:\documents and settings\Administrator.REDDWARF\Application Data\Spare Backup
2008-12-11 19:07 . 2007-11-09 22:11 d-------- c:\documents and settings\Administrator.REDDWARF\Application Data\SampleView
2008-12-11 19:07 . 2008-05-17 16:17 d-------- c:\documents and settings\Administrator.REDDWARF\Application Data\Gtek
2008-12-11 19:07 . 2008-12-11 19:07 d-------- c:\documents and settings\Administrator.REDDWARF
2008-12-11 14:36 . 2007-07-03 11:53 24,576 --a------ c:\windows\system32\BAZLib.dll
2008-12-11 14:26 . 2008-12-11 14:26 d-------- c:\documents and settings\All Users\Application Data\Ascentive
2008-12-11 14:03 . 2008-12-11 19:50 d-------- c:\program files\Ascentive
2008-12-11 14:03 . 2008-05-16 10:41 208,896 --a------ c:\windows\system32\ConTest.dll
2008-12-11 14:03 . 2008-08-20 17:44 45,056 --a------ c:\windows\system32\CreateLog.dll
2008-12-11 14:03 . 2007-07-03 11:48 36,864 --a------ c:\windows\system32\ascbalon.dll
2008-12-11 14:03 . 2007-07-03 11:48 20,480 --a------ c:\windows\system32\SysRestore.dll
2008-12-05 20:22 . 2008-12-05 20:22 d-------- c:\program files\Symantec
2008-12-05 20:22 . 2008-12-05 20:22 124,464 --a------ c:\windows\system32\drivers\SYMEVENT.SYS
2008-12-05 20:22 . 2008-12-05 20:22 60,808 --a------ c:\windows\system32\S32EVNT1.DLL
2008-12-05 20:22 . 2008-12-05 20:22 35,888 -ra------ c:\windows\system32\drivers\SymIM.sys
2008-12-05 20:22 . 2008-12-05 20:22 10,635 --a------ c:\windows\system32\drivers\SYMEVENT.CAT
2008-12-05 20:22 . 2008-12-05 20:22 806 --a------ c:\windows\system32\drivers\SYMEVENT.INF
2008-12-05 20:21 . 2008-12-05 20:21 d-------- c:\windows\system32\drivers\NIS
2008-12-05 20:21 . 2008-12-05 20:21 d-------- c:\program files\Windows Sidebar
2008-12-05 20:21 . 2008-12-05 20:21 d-------- c:\program files\Norton Internet Security
2008-12-05 20:21 . 2008-12-05 20:22 d-------- c:\documents and settings\All Users\Application Data\Norton
2008-12-05 20:16 . 2008-12-05 20:21 d-------- c:\program files\NortonInstaller
2008-12-05 20:16 . 2008-12-05 20:16 d-------- c:\documents and settings\All Users\Application Data\NortonInstaller
2008-12-04 21:44 . 2008-12-04 22:00 d-------- c:\program files\Browser Hijack Recover
2008-12-04 21:44 . 2008-12-04 21:44 0 --a------ c:\windows\system32\8104297.jun
2008-12-04 21:05 . 2008-12-04 21:05 0 --a------ c:\windows\nsreg.dat
2008-12-03 14:39 . 2008-12-03 19:48 d-------- c:\program files\Windows Live Safety Center
2008-12-01 20:22 . 2008-12-01 20:22 d-------- c:\program files\Webroot
2008-12-01 20:22 . 2008-12-01 20:22 d-------- c:\documents and settings\Owner\Application Data\Webroot
2008-12-01 20:22 . 2008-12-01 20:22 d-------- c:\documents and settings\All Users\Application Data\Webroot
2008-12-01 20:22 . 2008-11-13 17:11 1,553,272 --a------ c:\windows\WRSetup.dll
2008-12-01 16:02 . 2008-12-01 16:02 d-------- c:\program files\Windows Defender
2008-12-01 08:37 . 2008-12-01 08:37 d-------- c:\program files\Microsoft Silverlight
2008-12-01 07:27 . 2008-12-01 07:27 d-------- c:\program files\Safer Networking
2008-12-01 07:23 . 2008-12-01 07:23 d-------- c:\program files\interMute
2008-12-01 07:23 . 2008-12-12 20:35 2,154 --a------ c:\windows\system32\ssmute.ini
2008-12-01 06:58 . 2008-12-01 06:58 d-------- c:\documents and settings\Owner\Application Data\AdwareAlert
2008-11-16 20:59 . 2008-11-16 20:59 d-------- C:\NVIDIA
2008-11-16 20:59 . 2008-10-07 13:33 201,157 --a------ c:\windows\system32\nvapps.nvb
2008-11-16 20:48 . 2008-11-16 20:48 d-------- c:\program files\SystemRequirementsLab
2008-11-16 15:40 . 2008-10-24 05:21 455,296 --a--c--- c:\windows\system32\dllcache\mrxsmb.sys
2008-11-16 15:39 . 2008-09-04 11:15 1,106,944 --a--c--- c:\windows\system32\dllcache\msxml3.dll
Endall
Posts Posts : 19
and the rest:
2008-12-13 19:39 --------- d-----w c:\documents and settings\Owner\Application Data\LimeWire
2008-12-12 03:43 --------- d-----w c:\program files\Slingo Quest Hawaii
2008-12-12 03:43 --------- d-----w c:\program files\eBay
2008-12-12 01:50 --------- d--h--w c:\program files\InstallShield Installation Information
2008-12-12 00:49 --------- d-----w c:\documents and settings\Owner\Application Data\mIRC
2008-12-12 00:05 --------- d-----w c:\program files\mIRC
2008-12-10 03:13 --------- d-----w c:\documents and settings\All Users\Application Data\Microsoft Help
2008-12-06 02:24 --------- d-----w c:\program files\Common Files\Symantec Shared
2008-12-06 02:23 --------- d-----w c:\documents and settings\All Users\Application Data\Symantec
2008-12-04 02:23 --------- d-----w c:\documents and settings\All Users\Application Data\avg8
2008-12-01 14:12 --------- d-----w c:\program files\Google
2008-12-01 13:58 --------- d-----w c:\program files\Philips
2008-12-01 13:58 --------- d-----w c:\documents and settings\All Users\Application Data\Viewpoint
2008-11-12 22:02 29,808 ----a-w c:\windows\system32\drivers\ssfs0bbc.sys
2008-11-12 22:02 23,152 ----a-w c:\windows\system32\drivers\sshrmd.sys
2008-11-12 22:02 170,608 ----a-w c:\windows\system32\drivers\ssidrv.sys
2008-11-10 06:12 --------- d-----w c:\program files\ICQ6
2008-11-04 23:17 --------- d-----w c:\program files\WinAce
2008-10-24 11:21 455,296 ----a-w c:\windows\system32\drivers\mrxsmb.sys
2008-06-04 21:30 0 ----a-w c:\documents and settings\Owner\Application Data\wklnhst.dat
2007-11-10 04:36 32,768 --sha-w c:\windows\system32\config\systemprofile\Local Settings\Application Data\Microsoft\Feeds Cache\index.dat
"ctfmon.exe"="c:\windows\system32\ctfmon.exe" [2008-04-13 15360]
"Aim6"="c:\program files\AIM6\aim6.exe" [2008-06-06 50528]
"Yahoo! Pager"="c:\program files\Yahoo!\Messenger\YahooMessenger.exe" [2007-08-30 4670704]
"Reminder"="c:\windows\Creator\Remind_XP.exe" [2005-02-25 966656]
"RemoteControl"="c:\program files\CyberLink\PowerDVD\PDVDServ.exe" [2006-11-23 56928]
"{0228e555-4f9c-4e35-a3ec-b109a192b4c2}"="c:\program files\Google\Gmail Notifier\gnotify.exe" [2005-07-15 479232]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-10-07 13574144]
"Recguard"="c:\windows\SMINST\RECGUARD.EXE" [2002-09-14 212992]
SpySubtract.lnk - c:\program files\interMute\SpySubtract\SpySub.exe [2008-12-01 1187840]
"{FA010552-4A27-4cb1-A1BB-3E2D697F1639}"= "c:\program files\interMute\SpySubtract\sshook.dll" [2008-12-01 77824]
"msacm.clmp3enc"= c:\progra~1\CYBERL~1\Power2Go\CLMP3Enc.ACM
"c:\\Program Files\\Yahoo!\\Messenger\\YServer.exe"=
"c:\\Program Files\\mIRC\\mirc.exe"=
"c:\\Program Files\\ICQ6\\ICQ.exe"=
"c:\\Program Files\\EA GAMES\\Battlefield Vietnam\\bfvietnam.exe"=
"c:\\Program Files\\EA GAMES\\Battlefield Vietnam\\bfvietnam_w32ded.exe"=
"c:\\Documents and Settings\\All Users\\Application Data\\NexonUS\\NGM\\NGM.exe"=
"c:\nexon\Combat Arms\CombatArms.exe"= c:\nexon\Combat Arms\CombatArms.exe:*Enabled:CombatArms.exe
"c:\nexon\Combat Arms\Engine.exe"= c:\nexon\Combat Arms\Engine.exe:*Enabled:Engine.exe
"c:\\Nexon\\Combat Arms\\NMService.exe"=
"c:\\Program Files\\Outspark\\Blackshot\\System\\BlackShot.exe"=
R0 ssfs0bbc;ssfs0bbc;c:\windows\system32\DRIVERS\ssfs0bbc.sys [2008-11-12 29808]
R0 SymEFA;Symantec Extended File Attributes;c:\windows\system32\drivers\NIS\1001000.021\SYMEFA.SYS [2008-12-05 309296]
R1 BHDrvx86;Symantec Heuristics Driver;\??\c:\windows\system32\drivers\NIS\1001000.021\BHDrvx86.sys [2008-12-05 255536]
R1 ccHP;Symantec Hash Provider;\??\c:\windows\system32\drivers\NIS\1001000.021\ccHPx86.sys [2008-12-05 362544]
R1 IDSxpx86;IDSxpx86;\??\c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\ipsdefs\20081210.002\IDSxpx86.sys [2008-12-13 274808]
R2 Norton Internet Security;Norton Internet Security;"c:\program files\Norton Internet Security\Engine\16.1.0.33\ccSvcHst.exe" /s "Norton Internet Security" /m "c:\program files\Norton Internet Security\Engine\16.1.0.33\diMaster.dll" /prefetch:1 []
R2 WinDefend;Windows Defender;"c:\program files\Windows Defender\MsMpEng.exe" [2006-11-03 13592]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;\??\c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [2008-12-05 99376]
S3 el575nd5;3Com Megahertz 10/100 LAN CardBus PC Card Driver;c:\windows\system32\DRIVERS\el575nd5.sys [2006-06-30 69692]
S3 XDva207;XDva207;\??\c:\windows\system32\XDva207.sys []
S3 XDva208;XDva208;\??\c:\windows\system32\XDva208.sys []
S4 Viewpoint Manager Service;Viewpoint Manager Service; []
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{5229887d-8f3f-11dc-8e1c-806d6172696f}]
\Shell\AutoRun\command - c:\windows\system32\RunDLL32.EXE Shell32.DLL,ShellExec_RunDLL Info.exe folder.htt 480 480
2008-12-13 c:\windows\Tasks\AdwareAlert Scheduled Scan.job
- c:\program files\AdwareAlert\AdwareAlert.exe []
- c:\program files\AdwareAlert []
2008-12-13 c:\windows\Tasks\GoogleUpdateTaskUser.job
- c:\documents and settings\Owner\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2008-09-02 22:23]
2008-12-13 c:\windows\Tasks\MP Scheduled Scan.job
- c:\program files\Windows Defender\MpCmdRun.exe [2006-11-03 19:20]
2008-12-13 c:\windows\Tasks\Norton Internet Security - Owner - Full System Scan.job
- c:\program files\Norton Internet Security\Engine\16.1.0.33\Navw32.exe [2008-12-05 20:22]
mWindow Title =
c:\windows\Downloaded Program Files\sysreqlab3.dll - O16 -: {1E54D648-B804-468d-BC78-4AFFED8E262E}
c:\windows\Downloaded Program Files\SysReqLab3.osd
c:\windows\Downloaded Program Files\OberonGameHost.dll - O16 -: {D0C0F75C-683A-4390-A791-1ACFD5599AB8}
c:\windows\Downloaded Program Files\OberonGameHost_dbg.inf
FF - ProfilePath - c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\pgi2uebm.default\
FF - plugin: c:\documents and settings\Owner\Local Settings\Application Data\Google\Update\1.2.131.27\npGoogleOneClick6.dll
FF - plugin: c:\program files\Yahoo!\Shared\npYState.dll
Rootkit scan 2008-12-13 15:22:11
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Norton Internet Security]
"ImagePath"="\"c:\program files\Norton Internet Security\Engine\16.1.0.33\ccSvcHst.exe\" /s \"Norton Internet Security\" /m \"c:\program files\Norton Internet Security\Engine\16.1.0.33\diMaster.dll\" /prefetch:1"
- - - - - - - > 'explorer.exe'(2928)
c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2\MSVCR80.dll
c:\program files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
c:\program files\CyberLink\Shared Files\RichVideo.exe
Completion time: 2008-12-13 15:28:02 - machine was rebooted
ComboFix-quarantined-files.txt 2008-12-13 21:27:53
Pre-Run: 119,436,730,368 bytes free
Post-Run: 119,561,261,056 bytes free
229 --- E O F --- 2008-12-12 19:51:59
Endall
Posts Posts : 19
Post by Belahzur on 13th December 2008, 11:08 pm
Press Start > Control Panel > open "Add/remove programs"
Allow the list to load and uninstall these items by selecting each one and pressing the "Remove" button to the right.
SpySubtract
KILLALL::
Driver::
ssfs0bbc
File::
Folder::
Registry::
"{FA010552-4A27-4cb1-A1BB-3E2D697F1639}"=-
[-HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{5229887d-8f3f-11dc-8e1c-806d6172696f}]
This will open combofix.exe again, agree to it's terms and allow it to run, it may want to reboot after it's done. Post the resulting log back here.
Post by Endall on 14th December 2008, 12:17 am
log part 1:
ComboFix 08-12-12.05 - Owner 2008-12-13 18:05:40.2 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.895.489 [GMT -6:00]
Running from: c:\documents and settings\Owner\Desktop\InHere\ComboFix.exe
Command switches used :: c:\documents and settings\Owner\Desktop\InHere\CFScript.txt
FILE ::
c:\documents and settings\Owner\Application Data\InterMute\SpySubtract\tmp\3
c:\documents and settings\Owner\Application Data\InterMute\SpySubtract\tmp\3.ldb
c:\program files\interMute\SpySubtract\CWShredder.exe
c:\program files\interMute\SpySubtract\CWSInstall.exe
c:\program files\interMute\SpySubtract\en-us.dll
c:\program files\interMute\SpySubtract\Help\en-us.chm
c:\program files\interMute\SpySubtract\IMReport.exe
c:\program files\interMute\SpySubtract\Install.log
c:\program files\interMute\SpySubtract\readme.txt
c:\program files\interMute\SpySubtract\Sounds\Pinball\cl2.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\cl3.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\cl4.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\cld.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\sc1.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\sc11.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\sc2.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\sc3.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\sc4.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\sc5.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\sc6.wav
c:\program files\interMute\SpySubtract\Sounds\Pinball\scd.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\cl2.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\cl3.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\cl4.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\cld.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc1.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc10.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc11.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc12.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc3.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc4.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc6.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc7.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\sc8.wav
c:\program files\interMute\SpySubtract\Sounds\Tomcat\scd.wav
c:\program files\interMute\SpySubtract\SpUninst.exe
c:\program files\interMute\SpySubtract\SpySubtract.log
c:\program files\interMute\SpySubtract\spyware.dat
c:\program files\interMute\SpySubtract\ssengine.dll
c:\program files\interMute\SpySubtract\Themes\Default\bg_common.bmp
c:\program files\interMute\SpySubtract\Themes\Default\bg_main.bmp
c:\program files\interMute\SpySubtract\Themes\Default\bg_messagedlg.bmp
c:\program files\interMute\SpySubtract\Themes\Default\btn_activate.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_add.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_allow.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_bigdelete.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_bighelp.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_bigupdates.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_buy.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_cancel.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_clean.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_cleanprivacy.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_clear.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_config.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_cws.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_dbupdate.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_deny.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_details.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_feedback.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_help.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_home.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_ok.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_options.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_remove.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_restore.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_save.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_scan.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_selecttoggle.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_start.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_stop.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_updates.ico
c:\program files\interMute\SpySubtract\Themes\Default\btn_viewlog.ico
c:\program files\interMute\SpySubtract\Themes\Default\copyright.bmp
c:\program files\interMute\SpySubtract\Themes\Default\DetailsTemplate.htm
c:\program files\interMute\SpySubtract\Themes\Default\icon_check_blank.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_check_finished.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_check_off.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_check_on.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_check_working.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_config_adv_scanners.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_config_cleaning.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_config_general.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_config_scanner.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_config_scanners.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_config_scheduling.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_config_sounds.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_msg_bad.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_msg_error.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_msg_good.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_msg_info.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_msg_question.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_msg_uncertain.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_msg_verybad.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_msg_warning.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_cookie.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_folder.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_none.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_process.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_regykey.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_regyval.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_shortcutlink.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_suspect.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_scanner_winfile.bmp
c:\program files\interMute\SpySubtract\Themes\Default\icon_threat_3.bmp
c:\program files\interMute\SpySubtract\Themes\Default\ProductLogo.bmp
c:\program files\interMute\SpySubtract\Themes\Default\splash.bmp
c:\program files\interMute\SpySubtract\Themes\Default\SplashBASIC.bmp
c:\program files\interMute\SpySubtract\Themes\Default\SplashPRO.bmp
c:\program files\interMute\SpySubtract\Themes\Default\theme.ini
c:\program files\interMute\SpySubtract\usrwl.dat
c:\program files\interMute\SpySubtract\WebRegister.exe
-------\Legacy_SSFS0BBC
-------\Legacy_VIEWPOINT_MANAGER_SERVICE
-------\Service_ssfs0bbc
-------\Service_Viewpoint Manager Service
Endall
Posts Posts : 19
Post by Endall on 14th December 2008, 12:18 am
and part 2:
((((((((((((((((((((((((( Files Created from 2008-11-14 to 2008-12-14 )))))))))))))))))))))))))))))))
2008-12-13 18:04 . 2008-12-13 18:13 d-------- C:\ComboFix
2008-12-13 18:02 . 2008-12-13 18:02 d--hs---- C:\RECYCLER
2008-12-13 16:36 . 2008-12-13 16:36 d-------- c:\documents and settings\Owner\Application Data\Malwarebytes
2008-12-13 15:16 . 2008-12-13 15:16 drahs---- C:\cmdcons
2008-12-13 15:14 . 2008-12-13 18:10 d-------- C:\Qoobox
2008-12-13 14:54 . 2008-12-13 14:55 d-------- C:\Avenger
2008-12-12 21:11 . 939,053,056 C:\hiberfil.sys
2008-12-03 19:49 . 2008-12-11 19:52 d--h----- C:\Config.Msi
2008-10-23 12:36 286,720 ----a-w c:\windows\system32\gdi32.dll
2008-10-16 20:38 826,368 ----a-w c:\windows\system32\wininet.dll
2008-10-16 20:13 202,776 ----a-w c:\windows\system32\wuweb.dll
2008-10-16 20:13 1,809,944 ----a-w c:\windows\system32\wuaueng.dll
2008-10-16 20:12 561,688 ----a-w c:\windows\system32\wuapi.dll
2008-10-16 20:12 323,608 ----a-w c:\windows\system32\wucltui.dll
2008-10-16 20:09 92,696 ----a-w c:\windows\system32\cdm.dll
2008-10-16 20:09 51,224 ----a-w c:\windows\system32\wuauclt.exe
2008-10-16 20:09 43,544 ----a-w c:\windows\system32\wups2.dll
2008-10-16 20:08 34,328 ----a-w c:\windows\system32\wups.dll
2008-10-16 20:06 268,648 ----a-w c:\windows\system32\mucltui.dll
2008-10-16 20:06 208,744 ----a-w c:\windows\system32\muweb.dll
2008-10-03 10:02 247,326 ----a-w c:\windows\system32\strmdll.dll
2008-10-02 16:07 453,152 ----a-w c:\windows\system32\NVUNINST.EXE
2008-09-30 22:43 1,286,152 ----a-w c:\windows\system32\msxml4.dll
2008-09-15 12:12 1,846,400 ----a-w c:\windows\system32\win32k.sys
+ 2008-12-14 00:12:01 16,384 ----atw c:\windows\Temp\Perflib_Perfdata_224.dat
2008-12-14 c:\windows\Tasks\MP Scheduled Scan.job
mWindow Title =
Rootkit scan 2008-12-13 18:10:22
Completion time: 2008-12-13 18:15:47 - machine was rebooted
ComboFix-quarantined-files.txt 2008-12-14 00:15:42
ComboFix2.txt 2008-12-13 21:28:04
Pre-Run: 119,532,777,472 bytes free
Post-Run: 119,496,990,720 bytes free
353 --- E O F --- 2008-12-12 19:51:59
Endall
Posts Posts : 19
Post by Endall on 14th December 2008, 12:20 am
as you can see by the log, I missed the part about removing SpySubtract first... seems that it was taken care of anyway.
Endall
Posts Posts : 19
Post by Belahzur on 14th December 2008, 12:33 am
Tis okay, CF removed it's folder along with it's files, so that is gone.
Post by Endall on 14th December 2008, 12:39 am
much better thanks!!! I haven't noticed anything like what was going on. It's so nice to end up on the page for the link you clicked in a google search and not bounced to who-knows-where.
I am so happy I found this site. You have been the MOST help I've ever gotten for any such problem!
I don't know how to thank you for the help. I know I'm gonna keep a book mark for the site and will direct others I may come accross with similar problems here.
Now, one more question... What's a decent anti-virus/malare package to run? I was using AVG Free at the time I became infected, so my confidence is a bit low with it now. I'm currently running a trial version of Norton. Should I just spend the money and stick with it or is there something better out there?
Endall
Posts Posts : 19
Post by Belahzur on 14th December 2008, 12:43 am
In my opinion - Norton drags the system down because it's a large program, I would stick with AVG, much smaller and lighter on the system.
Post by Endall on 14th December 2008, 1:16 am
heh, I've got firefox too.. it was also affected by the bug...
so far, all seems well!
I really do appreciate the help.
Endall
Posts Posts : 19
Post by Jerry Parnell on 14th December 2008, 1:16 am
Wow Bel! Very nice fix, fastest for this rootkit so far! Right On!
Jerry Parnell
Posts Posts : 670
Post by Doctor Inferno on 17th January 2009, 10:26 am
Points Points : 104640
