Need help on upgrade!
Solved Need help on upgrade!
Post by iloveyouguys on Tue Dec 09, 2008 3:11 am
Hoping you guys can help me on this.
After you guys helped me get rid of a virus, I updated the xp windows sp1 to sp2.
Now I get this message when I try to connect my ipod, "ipodservice module has encountered a problem and needs to close."
searching the web, i realized that my device manager is empty.
Can you guys help me with this?
Thanks!
iloveyouguys
Posts Posts : 7
Joined Joined : 2008-12-07
OS OS : windows xp professional service pack 1
Points Points : 29190
Solved Re: Need help on upgrade!
Post by Doctor Inferno on Tue Dec 09, 2008 1:44 pm
To open the Device Manager, Click Start >> right click My Computer >> Properties Hardware tab >> Device manager.
Expand the Removable Media menu near the bottom. It will only be visible if it is plugged in.
Back up all your songs etc.
Uninstall itunes and download the latest version here:
http://www.apple.com/itunes/download/
Post by iloveyouguys on Tue Dec 09, 2008 3:53 pm
Thanks, Doctor Inferno for your help.
I'm not sure when you mean to expand. The device manager is completely empty. It's completely white. Nothing is there. Not the computer, disk drives, etc. There is nothing to select.
iloveyouguys
Posts Posts : 7
Post by iloveyouguys on Wed Dec 10, 2008 4:16 am
Don't worry, Inferno.
Found the resolution to the problem. I guess when I upgraded, Symantec and Microsoft had incompatibility issues.
I found the fix here: http://support.microsoft.com/kb/893249
iloveyouguys
Posts Posts : 7
Post by Doctor Inferno on Wed Dec 10, 2008 4:31 am
Thanks for letting us know. I will now add a solved tag. Wink
