also a trojan.zlob.g problem
Solved also a trojan.zlob.g problem
Post by jlbeerman2 on 8th December 2008, 6:07 am
My computer has been infected with the trojan.zlob.g virus. It will pop up randomly with a message informing me about malware installed on the computer etc. I hope that someone will be able to help me with this. Below is my hijacklog. Thanks so much
jlbeerman2
Posts Posts : 4
Joined Joined : 2008-12-08
Points Points : 29220
Solved Re: also a trojan.zlob.g problem
Post by Belahzur on 8th December 2008, 1:47 pm
    O4 - HKCU\..\Run: [Smax4] "C:\Documents and Settings\John Beerman.BEERMAN.000\Application Data\Google\kjzna1562565.exe"
Delete this file in bold:
  • Download combofix from here, use the top links - [You must be registered and logged in to see this link.]
  • You will this next prompt that asks if you want to continue the malware scan, select yes
Points Points : 245091
Post by jlbeerman2 on 8th December 2008, 5:19 pm
Thanks, here is my combofix log
jlbeerman2
Posts Posts : 4
Post by Belahzur on 8th December 2008, 5:21 pm
Looks good, what problems remain?
Updating Java:
  • First, unzip it.
  • Then run JavaRa.
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
Post by jlbeerman2 on 8th December 2008, 5:39 pm
The problem seems to have gone away, thanks so much!
jlbeerman2
Posts Posts : 4
Post by Belahzur on 8th December 2008, 5:42 pm
Post by jlbeerman2 on 8th December 2008, 5:44 pm
Thanks so much for all of your help, it is greatly appreciated :-)
jlbeerman2
Posts Posts : 4
Post by Doctor Inferno on 3rd January 2009, 3:59 am
