-=[:Please Help! Virus/Trojan seems to be rehealing after removal:]=-
Solved Re: -=[:Please Help! Virus/Trojan seems to be rehealing after removal:]=-
Post by MilanoMint on 10th December 2008, 5:14 am
Hi Belahzur~
It's fixed now!~ Thank you soooooooo much!!!~ I can finally get some good night's sleep tonight. hehehe!~ Much much appreciated!!! <33 Thank You!
You are seriously awesome!!! Big Grin
MilanoMint
Posts Posts : 27
Joined Joined : 2008-12-08
OS OS : Windows XP Media Center 2002
Points Points : 29373
Post by Belahzur on 10th December 2008, 2:31 pm
Glad I could help. Smile
Updating Java:
  • First, unzip it.
  • Then run JavaRa.
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
Points Points : 245121
Post by MilanoMint on 10th December 2008, 7:02 pm
OKiee dokiee will do that tonight Smile Thanks again!!!~
MilanoMint
Posts Posts : 27
Post by Belahzur on 10th December 2008, 8:06 pm
Post by MilanoMint on 12th December 2008, 4:42 am
Thanks, got all that done Smile
MilanoMint
Posts Posts : 27
Post by Doctor Inferno on 15th January 2009, 8:26 am
Points Points : 104650
