systray, wrong icons displayed, double icons in control panel
Solved systray, wrong icons displayed, double icons in control panel
Post by Voods on Sun Dec 07, 2008 8:21 pm
I'm having problems with my systray, like many im sure. Icons seem to disappear amd re-appear frequently. Systray does appear to be installed in the registry. In the customize notifacations area, wrong icons are dispayed for the programs.
Also when I load Malware AntiBytes from the desktop, it tries to install I-tunes twice, before the program loads.
I also have double icons of everything in the control panel.
The systray and icon problems started after I scanned and cleaned my computer of viruses and malware. I have used
CC Cleaner
Super Anti-Spyware
Malware Anti-Bytes
And Symantec Corporate edition
Any help would be most appreciated.
Regards
Voods
Posts Posts : 229
Joined Joined : 2008-12-07
Protection Protection : Eset Smart Security 4
Points Points : 31454
Solved Re: systray, wrong icons displayed, double icons in control panel
Post by Belahzur on Sun Dec 07, 2008 9:33 pm
I will look into this as soon as I get time, I have moved this to the Software forum since this is no longer a malware issue.
Points Points : 245069
Post by Lance(HAOH) on Tue Dec 30, 2008 3:13 pm
Lance(HAOH)
Posts Posts : 138
Joined Joined : 2008-12-12
OS OS : Windows XP Professional, Windows 7 Enterprise, Windows 8 Professional WMC, Ubuntu Linux
Protection Protection : Avast 8
Points Points : 30180
Post by Voods on Sun Feb 01, 2009 8:34 pm
Thanks fore those. I went for the Cd repair option. and the taskbar repair tool.
My only problem now is with the Symantec not showing in the notifacation are and the double icons in control panel.
These are no biggy though.
Regards
Dave
Voods
Posts Posts : 229
