Trojan.ZLOG.G - - Final Step - ComboText Too Big To Post
Solved Trojan.ZLOG.G - - Final Step - ComboText Too Big To Post
Post by djohnsonhot on 7th December 2008, 2:34 pm
Hello!
I finished the next step, and the ComboFix.TXT was saved....however, when I try to "post it" back here, I am getting an error message from the Forum program that the file is "too big."
Where should I post (copy and Paste, right?) the ComboFix/txt?
Thanks, Dave
p.s. Thanks for your help..I really appreciate this forum.
djohnsonhot
Posts Posts : 26
Joined Joined : 2008-12-07
Points Points : 29253
Solved Re: Trojan.ZLOG.G - - Final Step - ComboText Too Big To Post
Post by Belahzur on 7th December 2008, 2:43 pm
Split the report up into parts.
First part - Do all the way down to the end of ((((( files created within a month )))))) then second part (((( find3m ))))) all the way down.
Points Points : 245111
Post by djohnsonhot on 7th December 2008, 2:48 pm
OK, will do...that was a quick reply, Belahzur!
djohnsonhot
Posts Posts : 26
Post by Doctor Inferno on 23rd December 2008, 3:36 am
Points Points : 104640
