RAW problem
Solved RAW problem
Post by Nazzgull on 5th December 2008, 4:08 pm
I downloaded some game. Now, got first problem. Can't open it.. Some stupid RAW extension. I tried with Daemon Tools and nothing, got this
Windows cannot read from this disk.The disk might be corrupted, or it could be using a format that is not compatible with windows.
Help ?
Points Points : 40475
Solved Re: RAW problem
Post by Doctor Inferno on 6th December 2008, 10:50 am
What speed did you burn at? You should try burning at about speed 4x.
Post by Nazzgull on 6th December 2008, 11:07 am
It was on 2x or 4x , i can't remember. Problem is that RAW format, impossible to open
Post by Lance(HAOH) on 30th December 2008, 3:28 pm
Then,your downloaded game could have been a corrupted file you or you could read this: http://en.wikipedia.org/wiki/RAW_image_format
Lance(HAOH)
Posts Posts : 138
Joined Joined : 2008-12-12
OS OS : Windows XP Professional, Windows 7 Enterprise, Windows 8 Professional WMC, Ubuntu Linux
Protection Protection : Avast 8
Points Points : 30200
Post by Nazzgull on 30th December 2008, 3:44 pm
It's solved now Smile
