GeekPolice is a website which provides free Computer Technical Support & Virus/Spyware Removal to our members.
Take 30 seconds to register below and unlock the limitations of this website to discover new computer knowledge!
How to remove Perfect Defender 2009 [Removal Guide]
Post by Doctor Inferno on Tue 02 Dec 2008, 11:33 pm
This guide will give you easy instructions on how to remove Perfect Defender 2009.
Perfect Defender 2009 Screenshots:
Symptoms in HijackThis Logs:
O4 - HKLM\..\Run: [Perfect Defender 2009] "C:\Program Files\Perfect Defender 2009\pdfndr.exe"
1. Please download Malwarebytes' Anti-Malware.
2. Install Malwarebytes' Anti-Malware by double clicking on mbam-setup.exe
4. Malwarebytes' Anti-Malware will automatically update itself after the install, you can press the OK button to close that box and you will now be at the main program as shown below.
If you are having problems with the updater, you can use this link to manually update MBAM with the latest database
Spoiler:
Download the Full database to your Desktop or to your usual Download Folder and install it by double clicking the file. Make sure that MBAM is closed before installing the update.
5. Close ALL open Windows, Programs, File or Folders.
6. Make sure you are on the Scanner tab. Select Perform quick scan then click the Scan button as shown above.
8. When the scan is finished a message box will appear, click Ok to continue.
9. Click Show Results.
11. Click on Remove seletced
12. When removing the files, Malwarebytes' Anti-Malware may require you to restart the computer in order to do a complete removal. If it displays a message stating that it needs to restart, please allow it to do so.
13. After that you can close the Malwarebytes' Anti-Malware window, your computer is now cleaned.
If you are still experiencing problems or difficulties following this guide or require any assistance removing this malware, please post your questions in our Malware Removal forums for free help.
You have to be logged in to post questions. Registration is free. By registering you are privileged to other virus removal resources.
Last edited by Doctor Inferno on Thu 03 Sep 2009, 7:34 am; edited 4 times in total
The GeekPolice
The GeekPolice
Re: How to remove Perfect Defender 2009 [Removal Guide]
Post by Jerry Parnell on Wed 03 Dec 2008, 8:39 pm
Haha! The ripped off of Comodo's Icon that they use for there Internet Security Suite!
Jerry Parnell
Advanced Surfer
Advanced Surfer
Operating System: Windows Vista Home Basic
Post by konahaku on Sat 06 Dec 2008, 4:12 am
The first link is 404'd. >:
konahaku
Operating System: Windows XP
Post by Doctor Inferno on Sat 06 Dec 2008, 4:44 am
Sorry, fixed.
The GeekPolice
The GeekPolice
