spyware.ispynow problems
Solved Re: spyware.ispynow problems
Post by greenraisin on 3rd December 2008, 3:37 pm
IS AVG just an antivirus or is it a spyware also? Is it a good one?
Should I use all of those recommended spyware programs or just one?
I only use Firefox...
What do you know about COMODO?
Doesn't Windows provide a Firewall? Is that no good?
What about the Norton programs? Lots of popularity, but not sure if they're any good.
greenraisin
Posts Posts : 31
Joined Joined : 2008-12-03
OS OS : windows xp
Points Points : 29260
Post by Belahzur on 3rd December 2008, 3:42 pm
AVG is an anti-virus only.
Just use one or two of the programs recommended.
Comodo Firewall - I kow lots who use it and I recommend you use it too.
Windows comes with a firewall, but it's not as strong as something like Comodo
Norton - Yes, hugely popular, but can really slow down the system.
Updating Java:
  • First, unzip it.
  • Then run JavaRa.
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
  • It will make a log file of what it's removed, but I don't need to see it.
Your clean now, you go can and be free. Big Grin
Points Points : 245079
Post by greenraisin on 3rd December 2008, 4:36 pm
If I use COMODO or one of the other Firewalls, should I disable the WIndows Firewall?
greenraisin
Posts Posts : 31
OS OS : windows xp
Post by Belahzur on 3rd December 2008, 4:36 pm
Yes, but Comodo should do that for you.
Post by greenraisin on 3rd December 2008, 4:38 pm
Thank you so much! You've been a tremendous help!
greenraisin
Posts Posts : 31
OS OS : windows xp
Post by Belahzur on 3rd December 2008, 4:39 pm
Glad I could help. Right On!
Post by greenraisin on 3rd December 2008, 5:08 pm
Do you know anything about cyberdefenderfree?
greenraisin
Posts Posts : 31
OS OS : windows xp
Post by Doctor Inferno on 11th December 2008, 9:06 am
Points Points : 104610
