ispynow help
Solved Re: ispynow help
Post by Kynetix on Mon Dec 01, 2008 1:58 pm
JavaRa 1.11 Removal Log.
Report follows after line.
The JavaRa removal process was started on Mon Dec 01 07:55:50 2008
Found and removed: C:\Program Files\Java\j2re1.4.2_03
Found and removed: C:\Program Files\Java\jre1.5.0_04
Found and removed: C:\Program Files\Java\jre1.6.0_01
Found and removed: C:\Program Files\Java\jre1.6.0_02
Found and removed: C:\Program Files\Java\jre1.6.0_03
Found and removed: C:\Program Files\Java\jre1.6.0_05
Found and removed: C:\Program Files\Java\jre1.6.0_07
Found and removed: C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.4
Found and removed: Software\JavaSoft\Java2D\1.5.0_05
Found and removed: Software\JavaSoft\Java2D\1.5.0_06
Found and removed: Software\JavaSoft\Java2D\1.5.0_09
Found and removed: Software\JavaSoft\Java2D\1.5.0_10
Found and removed: Software\JavaSoft\Java2D\1.5.0_11
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\JavaPlugin.150_05
Found and removed: SOFTWARE\Classes\JavaPlugin.150_06
Found and removed: SOFTWARE\Classes\JavaPlugin.150_09
Found and removed: SOFTWARE\Classes\JavaPlugin.150_10
Found and removed: SOFTWARE\Classes\JavaWebStart.isInstalled.1.5.0.0
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\Installer\Features\8A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Classes\Installer\Features\8A0F842331866D117AB7000B0D610002
Found and removed: SOFTWARE\Classes\Installer\Features\8A0F842331866D117AB7000B0D610003
Found and removed: SOFTWARE\Classes\Installer\Features\8A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F842331866D117AB7000B0D610002
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F842331866D117AB7000B0D610003
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Classes\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Classes\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610002
Found and removed: SOFTWARE\Classes\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610003
Found and removed: SOFTWARE\Classes\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Classes\JavaPlugin.160_01
Found and removed: SOFTWARE\Classes\JavaPlugin.160_02
Found and removed: SOFTWARE\Classes\JavaPlugin.160_03
Found and removed: SOFTWARE\Classes\JavaPlugin.160_05
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.6.0_01
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.6.0_02
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.6.0_03
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.6.0_05
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6.0_01
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6.0_02
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6.0_03
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6.0_05
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610002
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610003
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D610001
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D610002
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D610003
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D610005
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D610002
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D610003
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D610005
Kynetix
Posts Posts : 21
Joined Joined : 2008-12-01
Points Points : 29270
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0160010}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0160020}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0160030}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0160050}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F841731866D117AB7000B0D410203
Found and removed: SOFTWARE\Classes\JavaPlugin.142_03
Found and removed: Software\Classes\JavaPlugin.160_01
Found and removed: Software\Classes\JavaPlugin.160_02
Found and removed: Software\Classes\JavaPlugin.160_03
Found and removed: Software\Classes\JavaPlugin.160_05
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_01\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_02\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_03\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_05\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_01\bin\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_02\bin\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_03\bin\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_05\bin\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\C:\Program Files\Common Files\Java\Update\Base Images\jre1.6.0.b105\patch-jre1.6.0_01.b06\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\C:\Program Files\Common Files\Java\Update\Base Images\jre1.6.0.b105\patch-jre1.6.0_03.b05\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\C:\Program Files\Common Files\Java\Update\Base Images\jre1.6.0.b105\patch-jre1.6.0_05.b13\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls\C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\core1.zip
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls\C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\core2.zip
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls\C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\core3.zip
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.6.0_01
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.6.0_02
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.6.0_03
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.6.0_05
Found and removed: Software\JavaSoft\Java2D\1.6.0_01
Found and removed: Software\JavaSoft\Java2D\1.6.0_02
Found and removed: Software\JavaSoft\Java2D\1.6.0_03
Found and removed: Software\JavaSoft\Java2D\1.6.0_05
Found and removed: Software\JavaSoft\Java Runtime Environment\1.6.0_01
Found and removed: Software\JavaSoft\Java Runtime Environment\1.6.0_02
Found and removed: Software\JavaSoft\Java Runtime Environment\1.6.0_03
Found and removed: Software\JavaSoft\Java Runtime Environment\1.6.0_05
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBA}
The JavaRa removal process was started on Mon Dec 01 07:56:29 2008
Finished reporting.
Kynetix
Posts Posts : 21
Post by Belahzur on Mon Dec 01, 2008 2:00 pm
Delete these two folders in bold:
C:\qoobox
C:\avenger
Points Points : 245069
Post by Kynetix on Mon Dec 01, 2008 3:32 pm
Thank you for the recommendations!
I've downloaded/installed/read-through Ad-Aware SE, as well as Kerio.
Would it be beneficial to download and install all the other programs you suggested as well, or would that be unnecessary?
Kynetix
Posts Posts : 21
Post by Belahzur on Mon Dec 01, 2008 3:34 pm
Probably unnecessary, you have a Firewall and adaware installed. Smile
Everything should be good.
Post by Kynetix on Mon Dec 01, 2008 3:37 pm
Aha, gotcha~
I'd like to thank you again for all your help. I really appreciate the time and effort you took into helping me fix my computer.
All the best, Belahzur!
Kynetix
Posts Posts : 21
Post by Doctor Inferno on Mon Dec 08, 2008 10:42 am
Everyone else, please start a new topic for your questions.
Points Points : 104600
