ispynow help
Solved ispynow help
Post by Jarker on 30th November 2008, 8:21 pm
my girlfriend infected her laptop with Ispynow. she had adawar installed but didn't use it so it's not updated. I've tried to install MBAM and hijackthis, but when i click on the icon to install nothing happens. also, I cannot connect to those websites from her laptop. I downloaded them on a flashdrive from mine and copied them to her laptop. I ran avast and it found something which i deleted, but I still cannot install the programs.
Please help,
Thank you
Jarker
Posts Posts : 21
Joined Joined : 2008-11-30
OS OS : winxp
Points Points : 29319
Solved Re: ispynow help
Post by Belahzur on 30th November 2008, 9:11 pm
Lets try this.
Points Points : 245101
Post by Jarker on 30th November 2008, 9:48 pm
thanks for the help. here is the log file:
"Silent Runners.vbs", revision 58, [You must be registered and logged in to see this link.]
Operating System: Windows XP
Output limited to non-default values, except where indicated by "{++}"
Startup items buried in registry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Run\ {++}
"Aim6" = ""C:\Program Files\AIM6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.] ["AOL LLC"]
"DellSupport" = ""C:\Program Files\DellSupport\DSAgnt.exe" /startup" ["Gteko Ltd."]
"SVCHOST.EXE" = "C:\WINDOWS\system32\drivers\svchost.exe" [null data]
"SpybotSD TeaTimer" = "C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe" ["Safer Networking Limited"]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ {++}
"vptray" = "C:\PROGRA~1\SYMANT~1\SYMANT~1\vptray.exe" ["Symantec Corporation"]
"Broadcom Wireless Manager UI" = "C:\WINDOWS\system32\WLTRAY.exe" ["Dell Inc."]
"ATICCC" = ""C:\Program Files\ATI Technologies\ATI.ACE\cli.exe" runtime -Delay" [null data]
"IntelZeroConfig" = ""C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe"" ["Intel Corporation"]
"IntelWireless" = ""C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe" /tf Intel PROSet/Wireless" ["Intel Corporation"]
"SynTPEnh" = "C:\Program Files\Synaptics\SynTP\SynTPEnh.exe" ["Synaptics, Inc."]
"SigmatelSysTrayApp" = "stsystra.exe" ["SigmaTel, Inc."]
"SunJavaUpdateSched" = ""C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe"" ["Sun Microsystems, Inc."]
"LMPDPSRV" = "C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\LMPDPSRV.EXE" ["DeviceGuys"]
"QuickTime Task" = ""C:\Program Files\QuickTime\QTTask.exe" -atboottime" ["Apple Inc."]
"iTunesHelper" = ""C:\Program Files\iTunes\iTunesHelper.exe"" ["Apple Inc."]
"Adobe Reader Speed Launcher" = ""C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"" ["Adobe Systems Incorporated"]
"Adobe Acrobat Speed Launcher" = ""C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe"" ["Adobe Systems Incorporated"]
"(Default)" = "(empty string)" [file not found]
"Acrobat Assistant 8.0" = ""C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe"" ["Adobe Systems Inc."]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\
{00C6482D-C502-44C8-8409-FCE54AD9C208}\(Default) = (no title provided)
-> {HKLM...CLSID} = "SnagIt Toolbar Loader"
\InProcServer32\(Default) = "C:\Program Files\TechSmith\SnagIt 9\SnagItBHO.dll" ["TechSmith Corporation"]
{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}\(Default) = (no title provided)
-> {HKLM...CLSID} = "Adobe PDF Reader Link Helper"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll" ["Adobe Systems Incorporated"]
{18DF081C-E8AD-4283-A596-FA578C2EBDC3}\(Default) = "AcroIEHelperStub"
-> {HKLM...CLSID} = "Adobe PDF Link Helper"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll" ["Adobe Systems Incorporated"]
{53707962-6F74-2D53-2644-206D7942484F}\(Default) = (no title provided)
-> {HKLM...CLSID} = "Spybot-S&D IE Protection"
\InProcServer32\(Default) = "C:\Program Files\Spybot - Search & Destroy\SDHelper.dll" ["Safer Networking Limited"]
{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}\(Default) = (no title provided)
-> {HKLM...CLSID} = "SSVHelper Class"
\InProcServer32\(Default) = "C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll" ["Sun Microsystems, Inc."]
{AE7CD045-E861-484f-8273-0445EE161910}\(Default) = (no title provided)
-> {HKLM...CLSID} = "Adobe PDF Conversion Toolbar Helper"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll" ["Adobe Systems Incorporated"]
{F4971EE7-DAA0-4053-9964-665D8EE6A077}\(Default) = "SmartSelect"
-> {HKLM...CLSID} = "SmartSelect Class"
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\
"{42071714-76d4-11d1-8b24-00a0c9068ff3}" = "Display Panning CPL Extension"
-> {HKLM...CLSID} = "Display Panning CPL Extension"
\InProcServer32\(Default) = "deskpan.dll" [file not found]
"{88895560-9AA2-1069-930E-00AA0030EBC8}" = "HyperTerminal Icon Ext"
-> {HKLM...CLSID} = "HyperTerminal Icon Ext"
\InProcServer32\(Default) = "C:\WINDOWS\system32\hticons.dll" ["Hilgraeve, Inc."]
"{BDA77241-42F6-11d0-85E2-00AA001FE28C}" = "LDVP Shell Extensions"
-> {HKLM...CLSID} = "VpshellEx Class"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Symantec Shared\SSC\vpshell2.dll" ["Symantec Corporation"]
"{5E2121EE-0300-11D4-8D3B-444553540000}" = "Catalyst Context Menu extension"
-> {HKLM...CLSID} = "SimpleShlExt Class"
\InProcServer32\(Default) = "C:\Program Files\ATI Technologies\ATI.ACE\atiacmxx.dll" [empty string]
"{2F603045-309F-11CF-9774-0020AFD0CFF6}" = "Synaptics Control Panel"
-> {HKLM...CLSID} = (no title provided)
\InProcServer32\(Default) = "C:\Program Files\Synaptics\SynTP\SynTPCpl.dll" ["Synaptics, Inc."]
"{0006F045-0000-0000-C000-000000000046}" = "Microsoft Outlook Custom Icon Handler"
-> {HKLM...CLSID} = "Outlook File Icon Extension"
\InProcServer32\(Default) = "C:\Program Files\Microsoft Office\Office10\OLKFSTUB.DLL" [MS]
"{42042206-2D85-11D3-8CFF-005004838597}" = "Microsoft Office HTML Icon Handler"
\InProcServer32\(Default) = "C:\Program Files\Microsoft Office\Office10\msohev.dll" [MS]
"{45994ec6-2fe3-11d4-aace-00c04f9908b1}" = "Lexmark X125"
-> {HKLM...CLSID} = "Lexmark X125"
\InProcServer32\(Default) = "C:\WINDOWS\system32\LMBGShEx.dll" ["DeviceGuys"]
"{B9E1D2CB-CCFF-4AA6-9579-D7A4754030EF}" = "iTunes"
-> {HKLM...CLSID} = "iTunes"
\InProcServer32\(Default) = "C:\Program Files\iTunes\iTunesMiniPlayer.dll" ["Apple Inc."]
"{8FF5E183-ABDE-46EB-B09E-D2AAB95CABE3}" = "SnagIt"
-> {HKLM...CLSID} = "SnagIt"
\InProcServer32\(Default) = "C:\Program Files\TechSmith\SnagIt 9\SnagItIEAddin.dll" ["TechSmith Corporation"]
"{CF74B903-3389-469c-B3B6-0204D204FCBD}" = "SnagIt Shell Extension"
-> {HKLM...CLSID} = "SnagItShellExt Class"
\InProcServer32\(Default) = "C:\Program Files\TechSmith\SnagIt 9\SnagItShellExt.dll" ["TechSmith Corporation"]
"{B41DB860-8EE4-11D2-9906-E49FADC173CA}" = "WinRAR shell extension"
-> {HKLM...CLSID} = "WinRAR"
\InProcServer32\(Default) = "C:\Program Files\WinRAR\rarext.dll" [null data]
"{D25B2CAB-8A9A-4517-A9B2-CB5F68A5A802}" = "Adobe.Acrobat.ContextMenu"
-> {HKLM...CLSID} = "Acrobat Elements Context Menu"
\InProcServer32\(Default) = "C:\Program Files\Adobe\Acrobat 9.0\Acrobat Elements\ContextMenu.dll" ["Adobe Systems Inc."]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\
"WPDShServiceObj" = "{AAA288BA-9A4C-45B0-95D7-94D524869DB5}"
-> {HKLM...CLSID} = "WPDShServiceObj Class"
\InProcServer32\(Default) = "C:\WINDOWS\system32\WPDShServiceObj.dll" [MS]
HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\
<> "BootExecute" = "lsdelete" [null data]
HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\
<> AtiExtEvent\DLLName = "Ati2evxx.dll" ["ATI Technologies Inc."]
<> dimsntfy\DLLName = "C:\WINDOWS\System32\dimsntfy.dll" [MS]
<> NavLogon\DLLName = "C:\WINDOWS\system32\NavLogon.dll" [null data]
HKLM\SOFTWARE\Classes\Folder\shellex\ColumnHandlers\
{F9DB5320-233E-11D1-9F84-707F02C10627}\(Default) = "PDF Column Info"
-> {HKLM...CLSID} = "PDF Shell Extension"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll" ["Adobe Systems, Inc."]
HKLM\SOFTWARE\Classes\*\shellex\ContextMenuHandlers\
Adobe.Acrobat.ContextMenu\(Default) = "{D25B2CAB-8A9A-4517-A9B2-CB5F68A5A802}"
LDVPMenu\(Default) = "{BDA77241-42F6-11d0-85E2-00AA001FE28C}"
SnagItMainShellExt\(Default) = "{CF74B903-3389-469c-B3B6-0204D204FCBD}"
WinRAR\(Default) = "{B41DB860-8EE4-11D2-9906-E49FADC173CA}"
HKLM\SOFTWARE\Classes\Directory\shellex\ContextMenuHandlers\
HKLM\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\
Jarker
Posts Posts : 21
OS OS : winxp
Post by Jarker on 30th November 2008, 9:49 pm
the rest of it:
Group Policies {GPedit.msc branch and setting}:
Note: detected settings may not have any effect.
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\
"shutdownwithoutlogon" = (REG_DWORD) dword:0x00000001
{Computer Configuration|Windows Settings|Security Settings|Local Policies|Security Options|
Shutdown: Allow system to be shut down without having to log on}
"undockwithoutlogon" = (REG_DWORD) dword:0x00000001
Devices: Allow undock without having to log on}
Active Desktop and Wallpaper:
Active Desktop may be disabled at this entry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellState
Displayed if Active Desktop enabled and wallpaper not set by Group Policy:
HKCU\Software\Microsoft\Internet Explorer\Desktop\General\
"Wallpaper" = "C:\WINDOWS\system32\config\systemprofile\Local Settings\Application Data\Microsoft\Wallpaper1.bmp"
Displayed if Active Desktop disabled and wallpaper not set by Group Policy:
HKCU\Control Panel\Desktop\
"Wallpaper" = "C:\Documents and Settings\C\Application Data\Mozilla\Firefox\Desktop Background.bmp"
Enabled Screen Saver:
"SCRNSAVE.EXE" = "C:\WINDOWS\system32\ssstars.scr" [MS]
Windows Portable Device AutoPlay Handlers
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers\Handlers\
iTunesBurnCDOnArrival\
"Provider" = "iTunes"
"InvokeProgID" = "iTunes.BurnCD"
"InvokeVerb" = "burn"
HKLM\SOFTWARE\Classes\iTunes.BurnCD\shell\burn\command\(Default) = ""C:\Program Files\iTunes\iTunes.exe" /AutoPlayBurn "%L"" ["Apple Inc."]
iTunesImportSongsOnArrival\
"InvokeProgID" = "iTunes.ImportSongsOnCD"
"InvokeVerb" = "import"
HKLM\SOFTWARE\Classes\iTunes.ImportSongsOnCD\shell\import\command\(Default) = ""C:\Program Files\iTunes\iTunes.exe" /AutoPlayImportSongs "%L"" ["Apple Inc."]
iTunesPlaySongsOnArrival\
"InvokeProgID" = "iTunes.PlaySongsOnCD"
"InvokeVerb" = "play"
HKLM\SOFTWARE\Classes\iTunes.PlaySongsOnCD\shell\play\command\(Default) = ""C:\Program Files\iTunes\iTunes.exe" /playCD "%L"" ["Apple Inc."]
iTunesShowSongsOnArrival\
"InvokeProgID" = "iTunes.ShowSongsOnCD"
"InvokeVerb" = "showsongs"
HKLM\SOFTWARE\Classes\iTunes.ShowSongsOnCD\shell\showsongs\command\(Default) = ""C:\Program Files\iTunes\iTunes.exe" /AutoPlayShowSongs "%L"" ["Apple Inc."]
MSWPDShellNamespaceHandler\
"Provider" = "@%SystemRoot%\System32\WPDShextRes.dll,-501"
"CLSID" = "{A55803CC-4D53-404c-8557-FD63DBA95D24}"
"InitCmdLine" = " "
-> {HKLM...CLSID} = "WPDShextAutoplay"
\LocalServer32\(Default) = "C:\WINDOWS\system32\WPDShextAutoplay.exe" [MS]
Startup items in "C" & "All Users" startup folders:
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
"Lexmark X125 Settings Utility" -> shortcut to: "C:\Program Files\Lexmark X125\LEX125SU.exe" ["Lexmark International"]
"Microsoft Office" -> shortcut to: "C:\Program Files\Microsoft Office\Office10\OSA.EXE -b -l" [MS]
"SnagIt 9" -> shortcut to: "C:\Program Files\TechSmith\SnagIt 9\SnagIt32.exe" ["TechSmith Corporation"]
Enabled Scheduled Tasks:
"AppleSoftwareUpdate" -> launches: "C:\Program Files\Apple Software Update\SoftwareUpdate.exe -task" ["Apple Inc."]
Winsock2 Service Provider DLLs:
Namespace Service Providers
HKLM\SYSTEM\CurrentControlSet\Services\Winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\ {++}
000000000001\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
000000000002\LibraryPath = "%SystemRoot%\System32\winrnr.dll" [MS]
000000000003\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
Transport Service Providers
HKLM\SYSTEM\CurrentControlSet\Services\Winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\ {++}
0000000000##\PackedCatalogItem (contains) DLL [Company Name], (at) ## range:
%SystemRoot%\system32\mswsock.dll [MS], 01 - 03, 06 - 17
%SystemRoot%\system32\rsvpsp.dll [MS], 04 - 05
Toolbars, Explorer Bars, Extensions:
Toolbars
HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\
"{32099AAC-C132-4136-9E9A-4E364A424E17}"
-> {HKLM...CLSID} = "DAEMON Tools Toolbar"
\InProcServer32\(Default) = "C:\Program Files\DAEMON Tools Toolbar\DTToolbar.dll" [null data]
"{47833539-D0C5-4125-9FA8-0819E2EAAC93}"
-> {HKLM...CLSID} = "Adobe PDF"
HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar\
"{8FF5E183-ABDE-46EB-B09E-D2AAB95CABE3}" = (no title provided)
"{32099AAC-C132-4136-9E9A-4E364A424E17}" = (no title provided)
"{47833539-D0C5-4125-9FA8-0819E2EAAC93}" = (no title provided)
Extensions (Tools menu items, main toolbar menu buttons)
HKLM\SOFTWARE\Microsoft\Internet Explorer\Extensions\
{08B0E5C0-4FCB-11CF-AAA5-00401C608501}\
"MenuText" = "Sun Java Console"
"CLSIDExtension" = "{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC}"
-> {HKCU...CLSID} = "Java Plug-in 1.6.0_03"
-> {HKLM...CLSID} = "Java Plug-in 1.6.0_03"
\InProcServer32\(Default) = "C:\Program Files\Java\jre1.6.0_03\bin\npjpi160_03.dll" ["Sun Microsystems, Inc."]
{B7FE5D70-9AA2-40F1-9C6B-12A255F085E1}\
"ButtonText" = "PartyPoker.com"
"MenuText" = "PartyPoker.com"
"Exec" = "C:\Program Files\PartyGaming\PartyPoker\RunApp.exe" [empty string]
{DFB852A3-47F8-48C4-A200-58CAB36FD2A2}\
"MenuText" = "Spybot - Search && Destroy Configuration"
"CLSIDExtension" = "{53707962-6F74-2D53-2644-206D7942484F}"
{E2E2DD38-D088-4134-82B7-F2BA38496583}\
"MenuText" = "@xpsp3res.dll,-20001"
"Exec" = "%windir%\Network Diagnostic\xpnetdiag.exe" [MS]
{FB5F1910-F110-11D2-BB9E-00C04F795683}\
"ButtonText" = "Messenger"
"MenuText" = "Windows Messenger"
"Exec" = "C:\Program Files\Messenger\msmsgs.exe" [MS]
Running Services (Display Name, Service Name, Path {Service DLL}):
Apple Mobile Device, Apple Mobile Device, ""C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe"" ["Apple, Inc."]
Ati HotKey Poller, Ati HotKey Poller, "C:\WINDOWS\system32\Ati2evxx.exe" ["ATI Technologies Inc."]
DefWatch, DefWatch, ""C:\Program Files\Symantec_Client_Security\Symantec AntiVirus\DefWatch.exe"" ["Symantec Corporation"]
Dell Wireless WLAN Tray Service, wltrysvc, "C:\WINDOWS\System32\WLTRYSVC.EXE C:\WINDOWS\System32\bcmwltry.exe" [null data]
Intel(R) PROSet/Wireless Event Log, EvtEng, "C:\Program Files\Intel\Wireless\Bin\EvtEng.exe" ["Intel Corporation"]
Intel(R) PROSet/Wireless Registry Service, RegSrvc, "C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe" ["Intel Corporation"]
Intel(R) PROSet/Wireless Service, S24EventMonitor, "C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe" ["Intel Corporation "]
Intel(R) PROSet/Wireless SSO Service, WLANKEEPER, "C:\Program Files\Intel\Wireless\Bin\WLKeeper.exe" ["Intel(R) Corporation"]
iPod Service, iPod Service, ""C:\Program Files\iPod\bin\iPodService.exe"" ["Apple Inc."]
Lavasoft Ad-Aware Service, aawservice, ""C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe"" ["Lavasoft"]
Symantec AntiVirus Client, Norton AntiVirus Server, ""C:\Program Files\Symantec_Client_Security\Symantec AntiVirus\Rtvscan.exe"" ["Symantec Corporation"]
Print Monitors:
HKLM\SYSTEM\CurrentControlSet\Control\Print\Monitors\
Adobe PDF Port Monitor\Driver = "AdobePDF.dll" ["Adobe Systems Inc"]
Lexmark X125 Language Monitor\Driver = "LMPDPMON.DLL" ["DeviceGuys"]
---------- (launch time: 2008-11-30 16:43:51)
<>: Suspicious data at a malware launch point.
+ This report excludes default entries except where indicated.
+ To see *everywhere* the script checks and *everything* it finds,
launch it from a command prompt or a shortcut with the -all parameter.
+ To search all directories of local fixed drives for DESKTOP.INI
DLL launch points, use the -supp parameter or answer "No" at the
first message box and "Yes" at the second message box.
---------- (total run time: 40 seconds, including 18 seconds for message boxes)
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 30th November 2008, 9:51 pm
I notice that you have Spybot's TeaTimer running. While this is normally a wonderful tool to protect against hijackers, it can also interfere with HijackThis fixes. So please disable TeaTimer by doing the following:
1) Run Spybot-S&D
2) Go to the Mode menu, and make sure "Advanced Mode" is selected
3) On the left hand side, choose Tools -> Resident
4) Uncheck "Resident TeaTimer" and OK any prompts
You can reenable TeaTimer once your system is clean.
Please make sure Teatimer is disable before we do this, otherwise this fix will fail.
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
    "SVCHOST.EXE"=-
Delete this file in bold:
C:\WINDOWS\system32\drivers\svchost.exe <== delete only in the drivers folder.
Please try running CF again. Smile
Post by Jarker on 30th November 2008, 10:15 pm
I cannot delete svchost.exe, it says it is in use.
what did you mean by running CF again?
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 30th November 2008, 10:41 pm
Mistake, forgot I hadn't posted that just yet.
  • Download combofix from here, use the top links - [You must be registered and logged in to see this link.]
  • You will this next prompt that asks if you want to continue the malware scan, select yes
Post by Jarker on 30th November 2008, 10:42 pm
should I run the fix even though i cannot delete the svchost.exe
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 30th November 2008, 10:43 pm
Yes, combofix will delete it for us.
Post by Jarker on 30th November 2008, 10:50 pm
the fix will not open just like the other installers. i double click and nothing happen
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 30th November 2008, 10:53 pm
There maybe something deeper going on.
Link: [You must be registered and logged in to see this link.].
2. Copy all the text contained in the code box below to your Clipboard by highlighting it and pressing (Ctrl+C):
Files to delete:
  • Don't tick the box below.
5. Please copy/paste the content of c:\avenger.txt into your reply.
Post by Jarker on 30th November 2008, 11:28 pm
ok i ran it and it said it worked
Platform: Windows XP
Rootkit scan active.
Hidden driver "TDSSserv.sys" found!
ImagePath: \systemroot\system32\drivers\TDSSpaxt.sys
Start Type: 1 (System)
Rootkit scan completed.
File "C:\WINDOWS\system32\drivers\svchost.exe" deleted successfully.
Completed script processing.
Finished! Terminate.
now do I run the fix?
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 30th November 2008, 11:30 pm
No, the rootkit is still running and active, we need to kill it first.
Drivers to disable:
TDSSserv.sys
Drivers to delete:
TDSSserv.sys
Files to delete:
C:\windows\system32\drivers\TDSSpaxt.sys
5. Please copy/paste the content of c:\avenger.txt into your reply along with a fresh HJT log.
Post by Jarker on 30th November 2008, 11:45 pm
ok ran it all and it let me install hijackthis. good work so far Smile
here is the avenger.txt:
Start Type: 4 (Disabled)
Driver "TDSSserv.sys" disabled successfully.
Driver "TDSSserv.sys" deleted successfully.
File "C:\windows\system32\drivers\TDSSpaxt.sys" deleted successfully.
Jarker
Posts Posts : 21
OS OS : winxp
hijack log:
Scan saved at 6:43:07 PM, on 11/30/2008
MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
C:\WINDOWS\stsystra.exe
C:\WINDOWS\system32\LMPDPUI.EXE
C:\Program Files\TechSmith\SnagIt 9\TSCHelp.exe
C:\Program Files\TechSmith\SnagIt 9\SnagPriv.exe
C:\Program Files\Intel\Wireless\Bin\Dot1XCfg.exe
C:\Program Files\TechSmith\SnagIt 9\snagiteditor.exe
O2 - BHO: SnagIt Toolbar Loader - {00C6482D-C502-44C8-8409-FCE54AD9C208} - C:\Program Files\TechSmith\SnagIt 9\SnagItBHO.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O2 - BHO: SmartSelect - {F4971EE7-DAA0-4053-9964-665D8EE6A077} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O3 - Toolbar: SnagIt - {8FF5E183-ABDE-46EB-B09E-D2AAB95CABE3} - C:\Program Files\TechSmith\SnagIt 9\SnagItIEAddin.dll
O3 - Toolbar: DAEMON Tools Toolbar - {32099AAC-C132-4136-9E9A-4E364A424E17} - C:\Program Files\DAEMON Tools Toolbar\DTToolbar.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O4 - HKLM\..\Run: [vptray] C:\PROGRA~1\SYMANT~1\SYMANT~1\vptray.exe
O4 - HKLM\..\Run: [Broadcom Wireless Manager UI] C:\WINDOWS\system32\WLTRAY.exe
O4 - HKLM\..\Run: [ATICCC] "C:\Program Files\ATI Technologies\ATI.ACE\cli.exe" runtime -Delay
O4 - HKLM\..\Run: [IntelZeroConfig] "C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe"
O4 - HKLM\..\Run: [IntelWireless] "C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe" /tf Intel PROSet/Wireless
O4 - HKLM\..\Run: [SigmatelSysTrayApp] stsystra.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe"
O4 - HKLM\..\Run: [LMPDPSRV] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\LMPDPSRV.EXE
O4 - HKLM\..\Run: [Adobe Acrobat Speed Launcher] "C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 8.0] "C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe"
O4 - HKCU\..\Run: [Aim6] "C:\Program Files\AIM6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.]
O4 - HKCU\..\Run: [DellSupport] "C:\Program Files\DellSupport\DSAgnt.exe" /startup
O4 - Global Startup: Lexmark X125 Settings Utility.lnk = C:\Program Files\Lexmark X125\LEX125SU.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: SnagIt 9.lnk = C:\Program Files\TechSmith\SnagIt 9\SnagIt32.exe
O8 - Extra context menu item: Append Link Target to Existing PDF - [You must be registered and logged in to see this link.] Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Append to Existing PDF - [You must be registered and logged in to see this link.] Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert Link Target to Adobe PDF - [You must be registered and logged in to see this link.] Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert to Adobe PDF - [You must be registered and logged in to see this link.] Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECapture.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra button: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe
O9 - Extra 'Tools' menuitem: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe
O20 - AppInit_DLLs: acaptuser32.dll
O23 - Service: Lavasoft Ad-Aware Service (aawservice) - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Ares Chatroom server (AresChatServer) - Ares Development Group - C:\Program Files\Ares\chatServer.exe
O23 - Service: DefWatch - Symantec Corporation - C:\Program Files\Symantec_Client_Security\Symantec AntiVirus\DefWatch.exe
O23 - Service: DSBrokerService - Unknown owner - C:\Program Files\DellSupport\brkrsvc.exe
O23 - Service: Intel(R) PROSet/Wireless Event Log (EvtEng) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Symantec AntiVirus Client (Norton AntiVirus Server) - Symantec Corporation - C:\Program Files\Symantec_Client_Security\Symantec AntiVirus\Rtvscan.exe
O23 - Service: Intel(R) PROSet/Wireless Registry Service (RegSrvc) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
O23 - Service: Intel(R) PROSet/Wireless Service (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
O23 - Service: Intel(R) PROSet/Wireless SSO Service (WLANKEEPER) - Intel(R) Corporation - C:\Program Files\Intel\Wireless\Bin\WLKeeper.exe
O23 - Service: Dell Wireless WLAN Tray Service (wltrysvc) - Unknown owner - C:\WINDOWS\System32\WLTRYSVC.EXE
End of file - 9249 bytes
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 30th November 2008, 11:46 pm
The rootkit is gone now, please try combofix. Smile
Post by Jarker on 1st December 2008, 12:12 am
combo fix ran. here is the log
ComboFix 08-11-30.01 - C 2008-11-30 18:50:29.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.504 [GMT -5:00]
Running from: c:\documents and settings\C\Desktop\ComboFix.exe
* Created a new restore point
c:\windows\system32\TDSScfum.dll
c:\windows\system32\TDSSfxmp.dll
c:\windows\system32\TDSSosvd.dat
c:\windows\system32\TDSStkdv.log
Infected copy of c:\windows\system32\winlogon.exe was found and disinfected
Restored copy from - c:\windows\system32\dllcache\winlogon.exe
-------\Legacy_TDSSSERV.SYS
((((((((((((((((((((((((( Files Created from 2008-10-28 to 2008-11-30 )))))))))))))))))))))))))))))))
2008-11-30 18:42 . 2008-11-30 18:42 d-------- c:\program files\Trend Micro
2008-11-30 14:08 . 2007-09-01 17:13 d-------- c:\documents and settings\Administrator\Application Data\Intel
2008-11-30 14:08 . 2008-11-30 14:08 d-------- c:\documents and settings\Administrator
2008-11-30 14:03 . 2008-11-30 14:03 d-------- C:\spoolerlogs
2008-11-30 13:43 . 2008-11-30 17:13 d-------- c:\program files\Spybot - Search & Destroy
2008-11-30 13:43 . 2008-11-30 17:13 d-------- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
2008-11-29 23:30 . 2008-11-29 23:30 59,904 --a------ c:\windows\system32\drivers\TDSSpqlt.sys
2008-11-29 23:30 . 2008-11-29 23:30 27,136 --a------ c:\windows\system32\TDSSoiqt.dll
2008-11-14 12:58 . 2008-11-14 12:58 d-------- c:\documents and settings\All Users\Application Data\FLEXnet
2008-11-14 12:55 . 2008-11-14 12:55 d-------- c:\program files\Common Files\Macrovision Shared
2008-11-14 12:55 . 2008-04-07 05:38 45,392 -ra------ c:\windows\system32\AdobePDF.dll
2008-11-14 12:55 . 2008-04-07 05:38 22,872 -ra------ c:\windows\system32\AdobePDFUI.dll
2008-11-14 12:45 . 2008-11-14 12:45 d-------- c:\program files\DAEMON Tools Toolbar
2008-11-14 12:45 . 2008-11-14 12:45 d-------- c:\program files\DAEMON Tools Lite
2008-11-14 12:30 . 2008-11-14 12:30 717,296 --a------ c:\windows\system32\drivers\sptd.sys
2008-11-14 12:29 . 2008-11-14 12:29 d-------- c:\documents and settings\C\Application Data\DAEMON Tools
2008-11-12 10:29 . 2008-09-04 12:15 1,106,944 -----c--- c:\windows\system32\dllcache\msxml3.dll
2008-11-12 10:29 . 2008-10-24 06:21 455,296 -----c--- c:\windows\system32\dllcache\mrxsmb.sys
2008-10-24 08:18 . 2008-10-15 11:34 337,408 -----c--- c:\windows\system32\dllcache\netapi32.dll
2008-10-14 13:53 . 2008-08-14 05:11 2,189,184 -----c--- c:\windows\system32\dllcache\ntoskrnl.exe
2008-10-14 13:53 . 2008-08-14 05:09 2,145,280 -----c--- c:\windows\system32\dllcache\ntkrnlmp.exe
2008-10-14 13:53 . 2008-08-14 04:33 2,023,936 -----c--- c:\windows\system32\dllcache\ntkrpamp.exe
2008-10-14 13:53 . 2008-09-15 07:12 1,846,400 -----c--- c:\windows\system32\dllcache\win32k.sys
2008-10-14 13:53 . 2008-09-08 05:41 333,824 -----c--- c:\windows\system32\dllcache\srv.sys
2008-10-14 13:52 . 2008-08-14 04:33 2,066,048 -----c--- c:\windows\system32\dllcache\ntkrnlpa.exe
2008-11-30 20:00 --------- d-----w c:\documents and settings\All Users\Application Data\Viewpoint
2008-11-14 17:55 --------- d-----w c:\program files\Common Files\Adobe
2008-11-14 17:26 --------- d-----w c:\documents and settings\C\Application Data\uTorrent
2008-11-04 15:49 --------- d-----w c:\program files\Lavasoft
2008-11-04 15:48 --------- d-----w c:\program files\Common Files\Wise Installation Wizard
2008-11-04 15:46 --------- d-----w c:\documents and settings\All Users\Application Data\Lavasoft
2008-10-26 22:46 --------- d-----w c:\program files\Microsoft Silverlight
2008-10-24 11:21 455,296 ----a-w c:\windows\system32\drivers\mrxsmb.sys
2008-10-21 13:18 --------- d-----w c:\program files\Apple Software Update
2008-10-05 15:15 17,536 ----a-w c:\documents and settings\C\Application Data\GDIPFONTCACHEV1.DAT
2002-01-18 11:52 3,932 ------w c:\documents and settings\C\Application Data\LMLayout.dat
"Aim6"="c:\program files\AIM6\aim6.exe" [2007-04-27 50736]
"vptray"="c:\progra~1\SYMANT~1\SYMANT~1\vptray.exe" [2002-07-30 77824]
"Broadcom Wireless Manager UI"="c:\windows\system32\WLTRAY.exe" [2007-03-16 1392640]
"ATICCC"="c:\program files\ATI Technologies\ATI.ACE\cli.exe" [2006-01-02 45056]
"IntelZeroConfig"="c:\program files\Intel\Wireless\bin\ZCfgSvc.exe" [2007-07-25 823296]
"IntelWireless"="c:\program files\Intel\Wireless\Bin\ifrmewrk.exe" [2007-07-25 974848]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2006-03-08 761947]
"SunJavaUpdateSched"="c:\program files\Java\jre1.6.0_03\bin\jusched.exe" [2007-09-25 132496]
"LMPDPSRV"="c:\windows\System32\spool\DRIVERS\W32X86\3\LMPDPSRV.EXE" [2002-07-11 45056]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2007-06-29 286720]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2007-09-26 267064]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-10-15 39792]
"Adobe Acrobat Speed Launcher"="c:\program files\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe" [2008-06-12 37232]
"Acrobat Assistant 8.0"="c:\program files\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe" [2008-06-11 640376]
"SigmatelSysTrayApp"="stsystra.exe" [2006-03-24 c:\windows\stsystra.exe]
Lexmark X125 Settings Utility.lnk - c:\program files\Lexmark X125\LEX125SU.exe [2007-09-26 1810432]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office10\OSA.EXE [2001-02-13 83360]
SnagIt 9.lnk - c:\program files\TechSmith\SnagIt 9\SnagIt32.exe [2008-05-15 6822728]
"AppInit_DLLs"=acaptuser32.dll
"c:\\Program Files\\Ares\\Ares.exe"=
"c:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\LMpdpsrv.exe"=
"c:\\Documents and Settings\\C\\Desktop\\utorrent.exe"=
S0 snuz;snuz;c:\windows\system32\drivers\ukoltlf.sys []
S1 lusbaudio;Logitech USB Microphone;c:\windows\system32\drivers\OVSound2.sys [2007-09-14 25216]
S3 aswArKrn;aswArKrn;\??\c:\docume~1\C\LOCALS~1\Temp\aswArKrn.sys []
S3 QCEmerald;Logitech QuickCam Web;c:\windows\system32\DRIVERS\OVCE.sys [2007-09-14 31872]
2008-10-20 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 11:34]
WebBrowser-{8FF5E180-ABDE-46EB-B09E-D2AAB95CABE3} - (no file)
FireFox -: Profile - c:\documents and settings\C\Application Data\Mozilla\Firefox\Profiles\4knowa66.default\
FireFox -: prefs.js - STARTUP.HOMEPAGE - [You must be registered and logged in to see this link.]
FF -: plugin - c:\program files\iTunes\Mozilla Plugins\npitunes.dll
FF -: plugin - c:\program files\Microsoft Silverlight\2.0.31005.0\npctrl.dll
FF -: plugin - c:\program files\Mozilla Firefox\plugins\NPTURNMED.dll
Rootkit scan 2008-11-30 18:53:09
- - - - - - - > 'winlogon.exe'(860)
c:\windows\System32\BCMLogon.dll
c:\windows\system32\ati2evxx.exe
c:\program files\Intel\Wireless\Bin\S24EvMon.exe
c:\windows\system32\WLTRYSVC.EXE
c:\windows\system32\BCMWLTRY.EXE
c:\program files\Lavasoft\Ad-Aware\aawservice.exe
c:\program files\Symantec_Client_Security\Symantec AntiVirus\DefWatch.exe
c:\program files\Intel\Wireless\Bin\EvtEng.exe
c:\program files\Symantec_Client_Security\Symantec AntiVirus\Rtvscan.exe
c:\program files\Intel\Wireless\Bin\RegSrvc.exe
c:\program files\Intel\Wireless\Bin\WLKEEPER.exe
c:\windows\system32\LMPDPUI.exe
c:\program files\AIM6\aolsoftware.exe
c:\program files\Intel\Wireless\Bin\Dot1XCfg.exe
c:\program files\TechSmith\SnagIt 9\TscHelp.exe
c:\program files\TechSmith\SnagIt 9\SnagPriv.exe
c:\program files\TechSmith\SnagIt 9\SnagItEditor.exe
Completion time: 2008-11-30 18:56:10 - machine was rebooted
ComboFix-quarantined-files.txt 2008-11-30 23:56:04
Pre-Run: 65,095,024,640 bytes free
Post-Run: 65,085,968,384 bytes free
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Media Center Edition" /noexecute=optin /fastdetect
170 --- E O F --- 2008-11-14 17:42:02
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 1st December 2008, 12:15 am
Driver::
snuz
aswArKrn
File::
Folder::
This will open combofix.exe again, agree to it's terms and allow it to run, it may want to reboot after it's done. Post the resulting log back here.
Post by Jarker on 1st December 2008, 12:30 am
done and done. Log below:
ComboFix 08-11-30.01 - C 2008-11-30 19:23:01.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.529 [GMT -5:00]
Command switches used :: c:\documents and settings\C\Desktop\CFscript.txt
FILE ::
-------\Legacy_ASWARKRN
-------\Service_aswArKrn
-------\Service_snuz
((((((((((((((((((((((((( Files Created from 2008-11-01 to 2008-12-01 )))))))))))))))))))))))))))))))
2008-11-30 19:13 . 2008-11-30 19:13 d-------- c:\documents and settings\C\Application Data\Malwarebytes
2008-11-30 19:12 . 2008-11-30 19:12 d-------- c:\program files\Malwarebytes' Anti-Malware
2008-11-30 19:12 . 2008-11-30 19:12 d-------- c:\documents and settings\All Users\Application Data\Malwarebytes
2008-11-30 19:12 . 2008-10-22 16:10 38,496 --a------ c:\windows\system32\drivers\mbamswissarmy.sys
2008-11-30 19:12 . 2008-10-22 16:10 15,504 --a------ c:\windows\system32\drivers\mbam.sys
2008-11-30 23:51 507,904 ----a-w c:\windows\system32\winlogon.exe
2008-11-30 04:30 295,424 ----a-w c:\windows\system32\termsrv.dll
2008-10-16 19:13 202,776 ----a-w c:\windows\system32\wuweb.dll
2008-10-16 19:13 1,809,944 ----a-w c:\windows\system32\wuaueng.dll
2008-10-16 19:12 561,688 ----a-w c:\windows\system32\wuapi.dll
2008-10-16 19:12 323,608 ----a-w c:\windows\system32\wucltui.dll
2008-10-16 19:09 92,696 ----a-w c:\windows\system32\cdm.dll
2008-10-16 19:09 51,224 ----a-w c:\windows\system32\wuauclt.exe
2008-10-16 19:09 43,544 ----a-w c:\windows\system32\wups2.dll
2008-10-16 19:08 34,328 ----a-w c:\windows\system32\wups.dll
2008-10-16 19:06 268,648 ----a-w c:\windows\system32\mucltui.dll
2008-10-16 19:06 208,744 ----a-w c:\windows\system32\muweb.dll
2008-09-15 12:12 1,846,400 ----a-w c:\windows\system32\win32k.sys
2008-09-10 01:14 1,307,648 ----a-w c:\windows\system32\msxml6.dll
2008-09-04 17:15 1,106,944 ----a-w c:\windows\system32\msxml3.dll
+ 2008-04-14 00:12:02 106,496 -c--a-w c:\windows\system32\dllcache\odbccp32.dll
+ 2008-04-14 00:12:08 18,944 -c--a-w c:\windows\system32\dllcache\version.dll
+ 2008-04-14 00:12:08 214,528 -c--a-w c:\windows\system32\dllcache\wbemcomn.dll
Rootkit scan 2008-11-30 19:25:56
Completion time: 2008-11-30 19:28:59 - machine was rebooted [C]
ComboFix-quarantined-files.txt 2008-12-01 00:28:49
ComboFix2.txt 2008-11-30 23:56:11
Pre-Run: 65,075,847,168 bytes free
Post-Run: 65,060,311,040 bytes free
169 --- E O F --- 2008-11-14 17:42:02
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 1st December 2008, 12:35 am
Log looks good.
What problems remain?
Post by Jarker on 1st December 2008, 12:39 am
great. I don't see any problems at this moment if you think the log is clean.
Thank you very much. you do great work here
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 1st December 2008, 12:41 am
Glad to hear it. Smile
Before I can let you go, we need to get you secured.
Updating Java:
  • Select the first option where it says "Java SE Runtime Environment (JRE) 6 Update 10".
  • Then from your desktop double-click on jre-6u10-windows-i586-p.exe that you downloaded to install the newest version.
  • First, unzip it.
  • Then run JavaRa.
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
Post by Jarker on 1st December 2008, 1:10 am
here's the log:
JavaRa 1.11 Removal Log.
Report follows after line.
The JavaRa removal process was started on Sun Nov 30 20:08:49 2008
Found and removed: C:\Program Files\Java\jre1.6.0_03
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_03\
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBB}
Finished reporting.
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 1st December 2008, 1:12 am
Delete this folders in bold:
C:\avenger
C:\Qoobox
Post by Jarker on 1st December 2008, 1:23 am
thank you again. Great work. I really appreciate it
Jarker
Posts Posts : 21
OS OS : winxp
Post by Doctor Inferno on 7th December 2008, 12:23 pm
Points Points : 104630
