Need help removing malware
Solved Re: Need help removing malware
Post by Belahzur on Wed Nov 26, 2008 8:51 pm
Hmmmm.
I thinking this is either a false alert, or something is still active on your machine.
Lets try this manually.
Put your XP SP2 CD back in and access the i386 yourself.
Find a copy of winlogon.exe and right click > and select Copy
Press Start > Open My computer.
Open the C drive.
Then open the Windows folder.
Then open the system32 folder.
Now right click anywhere and select Paste, select yes to the overwrite warning.
Please re-run combofix again.
Post by kschulz on Wed Nov 26, 2008 9:07 pm
Getting an error on copy. This is immediately after a reboot, before running any programs (other than the startup services).
"Error Copying File or Folder
Cannot copy winlogon: It is being used by another person or program.
Close any programs that might using the file and try again."
kschulz
OS : WinXP
Post by Belahzur on Wed Nov 26, 2008 9:12 pm
Now open a new notepad file.
FCopy::
F:\i386\winlogon.exe | c:\windows\system32\winlogon.exe
F:\i386\termsrv.dll | c:\windows\system32\termsrv.dll
This will open combofix.exe again, agree to it's terms and allow it to run, it may want to reboot after it's done. Post the resulting log back here.
Please run a GMER Rootkit scan:
Download GMER's application from here:
Unzip it and start the GMER.exe
Click the Rootkit tab and click the Scan button.
Once done, click the Copy button.
This will copy the results to your clipboard.
Paste the results in your next reply.
Warning ! Please, do not select the "Show all" checkbox during the scan.
If you're having problems with running GMER.exe, try it in safe mode.
This tools works in safe mode. Other rootkitrevealers don't.
Post by kschulz on Wed Nov 26, 2008 10:47 pm
Ok, I ran Combofix again, feeding it CFscript to copy over the files. The dump is below (still showing infected).
I ran GMER in normal boot mode, but it would eventually exception out and not complete. It ran all the way through in Safe Mode but didn't spit out much in the output:
GMER 1.0.14.14536 - [You must be registered and logged in to see this link.]
Rootkit scan 2008-11-26 17:30:06
---- Devices - GMER 1.0.14 ----
AttachedDevice \FileSystem\Fastfat \Fat InCDrec.SYS (InCD File System Recognizer/Ahead Software AG)
---- EOF - GMER 1.0.14 ----
kschulz
OS : WinXP
ComboFix 08-11-26.03 - Kurt 2008-11-26 16:22:20.4 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.1416 [GMT -5:00]
Running from: c:\documents and settings\Kurt\Desktop\c0mb0-fix.exe
Command switches used :: c:\documents and settings\Kurt\Desktop\CFscript.txt
* Created a new restore point
* Resident AV is active
c:\windows\system32\winlogon.exe . . . is infected!!
((((((((((((((((((((((((( Files Created from 2008-10-26 to 2008-11-26 )))))))))))))))))))))))))))))))
2008-11-25 07:44 . 2008-11-25 07:44 d-------- c:\program files\TortoiseSVN
2008-11-25 07:44 . 2008-11-25 07:44 d-------- c:\program files\Common Files\TortoiseOverlays
2008-11-18 16:09 . 2008-11-18 16:09 d-------- c:\documents and settings\Kurt\Application Data\Vusion
2008-11-09 11:38 . 2008-11-09 11:38 d-------- c:\program files\Common Files\Adobe AIR
2008-10-29 12:49 . 2004-04-13 13:48 233,472 --a------ c:\windows\system32\REX Shared Library.dll
2008-10-29 12:47 . 2008-10-29 12:50 d-------- c:\documents and settings\All Users\Application Data\Cakewalk
2008-11-26 06:19 --------- d-----w c:\program files\Malwarebytes' Anti-Malware
2008-11-26 03:50 --------- d-----w c:\documents and settings\Kurt\Application Data\Avtec,_Inc
2008-11-26 03:50 --------- d-----w c:\documents and settings\Kurt\Application Data\Avtec, Inc
2008-11-26 03:50 --------- d-----w c:\documents and settings\Kurt\Application Data\Apple Computer
2008-11-26 03:50 --------- d-----w c:\documents and settings\Kurt\Application Data\Ahead
2008-11-26 03:50 --------- d-----w c:\documents and settings\Kurt\Application Data\AdobeUM
2008-11-26 03:46 502,272 ----a-w c:\windows\system32\winlogon.exe
2008-11-26 03:46 295,424 ----a-w c:\windows\system32\termsrv.dll
2008-11-26 00:33 5,157,888 ----a-w c:\windows\system32\drivers\vrcore.sys
2008-11-25 13:22 --------- d-----w c:\documents and settings\Kurt\Application Data\TortoiseSVN
2008-11-19 13:18 --------- d-----w c:\program files\Google
2008-11-14 20:44 --------- d-----w c:\program files\Avtec, Inc
2008-11-08 23:07 --------- d-----w c:\documents and settings\Kurt\Application Data\Cakewalk
2008-10-30 11:25 --------- d--h--w c:\program files\InstallShield Installation Information
2008-10-29 18:18 --------- d-----w c:\program files\Cakewalk
2008-10-21 23:32 --------- d-----w c:\program files\Activision
2008-10-18 20:16 --------- d-----w c:\program files\Lexicon
2008-10-10 18:44 --------- d-----w c:\program files\Apple Software Update
2008-10-10 18:40 --------- d-----w c:\program files\iTunes
2008-10-10 18:40 --------- d-----w c:\program files\iPod
2008-10-10 18:40 --------- d-----w c:\documents and settings\All Users\Application Data\{3276BE95_AF08_429F_A64F_CA64CB79BCF6}
2008-10-10 18:39 --------- d-----w c:\program files\Bonjour
2008-10-10 18:38 --------- d-----w c:\program files\QuickTime
2008-10-02 19:57 --------- d-----w c:\program files\Common Files\Aladdin Shared
2008-10-02 19:54 --------- d-----w c:\program files\Common Files\Wise Installation Wizard
2008-08-29 14:18 87,336 ----a-w c:\windows\system32\dns-sd.exe
2008-08-29 13:53 61,440 ----a-w c:\windows\system32\dnssd.dll
2008-08-01 23:38 22,328 ------w c:\documents and settings\Kurt\Application Data\PnkBstrK.sys
2006-10-03 06:43 2,402,550 ----a-w c:\windows\inf\SET328.tmp
2004-08-04 21:00 1,431,144 ----a-w c:\windows\inf\SET39B.tmp
------- Sigcheck -------
2008-11-25 22:46 502272 9b1bd82bd0761b5ba986af66d2809c30 c:\windows\system32\winlogon.exe
2008-11-25 22:46 295424 40ffc19a8d4875e9e19cecdc76ef9201 c:\windows\system32\termsrv.dll
+ 2005-10-21 01:02:28 163,328 ----a-w c:\windows\ERDNT\subs\ERDNT.EXE
- 2008-11-26 17:29:51 17,290 ----a-w c:\windows\system32\tablet.dat
+ 2008-11-26 21:15:20 17,290 ----a-w c:\windows\system32\tablet.dat
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\1TortoiseNormal]
@="{C5994560-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994560-53D9-4125-87C9-F193FC689CB2}]
2008-01-16 17:52 80384 --a------ c:\program files\Common Files\TortoiseOverlays\TortoiseOverlays.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\2TortoiseModified]
@="{C5994561-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994561-53D9-4125-87C9-F193FC689CB2}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\3TortoiseConflict]
@="{C5994562-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994562-53D9-4125-87C9-F193FC689CB2}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\4TortoiseLocked]
@="{C5994563-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994563-53D9-4125-87C9-F193FC689CB2}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\5TortoiseReadOnly]
@="{C5994564-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994564-53D9-4125-87C9-F193FC689CB2}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\6TortoiseDeleted]
@="{C5994565-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994565-53D9-4125-87C9-F193FC689CB2}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\7TortoiseAdded]
@="{C5994566-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994566-53D9-4125-87C9-F193FC689CB2}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\8TortoiseIgnored]
@="{C5994567-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994567-53D9-4125-87C9-F193FC689CB2}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\9TortoiseUnversioned]
@="{C5994568-53D9-4125-87C9-F193FC689CB2}"
[HKEY_CLASSES_ROOT\CLSID\{C5994568-53D9-4125-87C9-F193FC689CB2}]
kschulz
OS : WinXP
Continued....
"MsnMsgr"="c:\program files\Windows Live\Messenger\MsnMsgr.Exe" [2007-10-18 5724184]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2006-10-18 204288]
"ctfmon.exe"="c:\windows\system32\ctfmon.exe" [2004-08-04 15360]
"Google Update"="c:\documents and settings\Kurt\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" [2008-09-04 133104]
"Console Monitor"="c:\program files\Avtec" [X]
"hpWirelessAssistant"="c:\program files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe" [2006-10-18 472800]
"SunJavaUpdateSched"="c:\program files\Java\jre1.6.0_07\bin\jusched.exe" [2008-06-10 144784]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2006-09-27 7585792]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2006-09-27 86016]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2007-01-12 827392]
"QPService"="c:\program files\HP\QuickPlay\QPService.exe" [2006-07-19 102400]
"ISUSPM Startup"="c:\program files\Common Files\InstallShield\UpdateService\isuspm.exe" [2005-08-11 249856]
"ISUSScheduler"="c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2005-08-11 81920]
"QlbCtrl"="c:\program files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe" [2007-09-06 202032]
"Cpqset"="c:\program files\Hewlett-Packard\Default Settings\cpqset.exe" [2006-07-13 40960]
"RecGuard"="c:\windows\SMINST\RecGuard.exe" [2005-10-11 1187840]
"Reminder"="c:\windows\CREATOR\Remind_XP.exe" [2006-02-09 643072]
"Acrobat Assistant 8.0"="c:\program files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe" [2008-01-11 623992]
"Vrmon"="c:\program files\PCSecurityShield\ShieldAntivirus\vrmonnt.exe" [2005-06-27 249916]
"VrSchedule"="c:\program files\PCSecurityShield\ShieldAntivirus\Vrres.exe" [2004-03-11 266304]
"InCD"="c:\program files\Ahead\InCD\InCD.exe" [2004-11-26 1349120]
"MediaFace Integration"="c:\program files\Fellowes\MediaFACE 5.0\SetHook.exe" [2005-10-27 53248]
"openvpn-gui"="c:\program files\OpenVPN\bin\openvpn-gui.exe" [2005-08-18 99328]
"PCSuiteTrayApplication"="c:\program files\Nokia\Nokia PC Suite 6\LaunchApplication.exe" [2007-06-18 271360]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-03-05 185896]
"HP Software Update"="c:\program files\Hp\HP Software Update\HPWuSchd2.exe" [2007-05-08 54840]
"CanonSolutionMenu"="c:\program files\Canon\SolutionMenu\CNSLMAIN.exe" [2007-05-14 644696]
"CanonMyPrinter"="c:\program files\Canon\MyPrinter\BJMyPrt.exe" [2007-04-03 1603152]
"SSBkgdUpdate"="c:\program files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" [2006-10-25 210472]
"OpwareSE4"="c:\program files\ScanSoft\OmniPageSE4\OpwareSE4.exe" [2007-02-04 79400]
"IJNetworkScanUtility"="c:\program files\Canon\Canon IJ Network Scan Utility\CNMNSUT.EXE" [2007-05-21 124512]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2008-09-06 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-10-01 289576]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2008-06-12 34672]
"nwiz"="nwiz.exe" [2006-09-27 c:\windows\system32\nwiz.exe]
"MsmqIntCert"="mqrt.dll" [2004-08-04 c:\windows\system32\mqrt.dll]
"High Definition Audio Property Page Shortcut"="CHDAudPropShortcut.exe" [2006-06-02 c:\windows\system32\CHDAudPropShortcut.exe]
"Nokia.PCSync"="c:\program files\Nokia\Nokia PC Suite 6\PcSync2.exe" [2007-06-19 1241088]
c:\documents and settings\Kurt\Start Menu\Programs\Startup\
Adobe Gamma.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2005-03-16 113664]
Bluetooth.lnk - c:\program files\WIDCOMM\Bluetooth Software\BTTray.exe [2006-05-12 581693]
Qshelf.lnk - c:\program files\Microsoft Reference\Bookshelf 98\qshelf98.exe [2006-12-10 123904]
TabUserW.exe.lnk - c:\windows\system32\WTablet\TabUserW.exe [2006-12-23 77824]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
2008-08-26 05:37 352256 c:\program files\SUPERAntiSpyware\SASWINLO.DLL
"AntiVirusDisableNotify"=dword:00000001
"c:\\WINDOWS\\system32\\mqsvc.exe"=
"c:\\Program Files\\Windows Live\\Messenger\\livecall.exe"=
"c:\\WINDOWS\\system32\\PnkBstrA.exe"=
"c:\\WINDOWS\\system32\\PnkBstrB.exe"=
"c:\\Program Files\\Activision\\Call of Duty 4 - Modern Warfare\\iw3mp.exe"=
"d:\\My Projects\\Avtec\\Visual Studio 2005\\Newport\\Avtec SVN Repository\\FrontEndApps\\bin\\Debug\\BusinessService.exe"=
"c:\\Program Files\\Nokia\\Nokia Software Updater\\nsu_ui_client.exe"=
"c:\\Program Files\\Common Files\\Nokia\\Service Layer\\A\\nsl_host_process.exe"=
"c:\\Program Files\\Avtec, Inc\\Scout\\BusinessService.exe"=
"c:\\Program Files\\Avtec, Inc\\VPGate\\Endpoints\\NXU2.exe"=
"c:\\Documents and Settings\\Kurt\\Application Data\\Vusion\\WARPVideoStreamer.exe"=
"8000:UDP"= 8000:UDP:Express Talk RTP Incoming Audio (UDP)
"8001:UDP"= 8001:UDP:Express Talk RTP Incoming Audio (UDP)
"8002:UDP"= 8002:UDP:Express Talk RTP Incoming Audio (UDP)
"8003:UDP"= 8003:UDP:Express Talk RTP Incoming Audio (UDP)
"8004:UDP"= 8004:UDP:Express Talk RTP Incoming Audio (UDP)
"8005:UDP"= 8005:UDP:Express Talk RTP Incoming Audio (UDP)
"8006:UDP"= 8006:UDP:Express Talk RTP Incoming Audio (UDP)
"8007:UDP"= 8007:UDP:Express Talk RTP Incoming Audio (UDP)
"8008:UDP"= 8008:UDP:Express Talk RTP Incoming Audio (UDP)
"8009:UDP"= 8009:UDP:Express Talk RTP Incoming Audio (UDP)
"5070:UDP"= 5070:UDP:Express Talk Sip Incoming Calls (UDP)
"5060:UDP"= 5060:UDP:Axon Sip Incoming Calls (UDP)
"81:TCP"= 81:TCP:Axon Web Server
"1947:TCP"= 1947:TCP:HASP SRM
"1947:UDP"= 1947:UDP:HASP SRM
R0 ntcdrdrv;ntcdrdrv;c:\windows\system32\DRIVERS\ntcdrdrv.sys [2007-04-20 13184]
R2 aksfridge;HASP Fridge;c:\windows\system32\DRIVERS\aksfridge.sys [2008-10-02 350720]
R2 hasplms;HASP License Manager;c:\windows\system32\hasplms.exe -run []
R2 TwDrvService;MT7 Serial Search Service;c:\program files\MicroTouch\MT7\TwService.exe /Service [2007-02-22 36864]
R2 XobniService;XobniService;"c:\program files\Xobni\XobniService.exe" [2008-05-05 33280]
R3 5U870CAP_VID_1262&PID_25FD;HP Pavilion Webcam ;c:\windows\system32\Drivers\5U870CAP.sys [2006-06-06 61952]
R3 L6DP;L6DP;c:\windows\system32\Drivers\l6dp.sys [2003-06-27 29312]
R3 tap0801;TAP-Win32 Adapter V8;c:\windows\system32\DRIVERS\tap0801.sys [2006-10-01 26624]
R3 TwBus;MicroTouch Serial Bus Enumerator;c:\windows\system32\DRIVERS\TwBus.sys [2007-02-22 12240]
S3 akshhl;Aladdin HASP HL Key;c:\windows\system32\DRIVERS\akshhl.sys [2008-10-02 46336]
S3 Avtec VPGate;Avtec VPGate;c:\program files\Avtec, Inc\VPGate\VPGate.exe [2007-08-07 371200]
S3 AxonService;Axon Service;"c:\program files\NCH Swift Sound\Axon\axon.exe" -service [2008-07-10 438276]
S3 BusinessService.exe;Avtec Business Layer;c:\program files\Avtec, Inc\Scout\BusinessService.exe [2008-10-28 327680]
S3 CEUSBAUD;Lexicon USB MIDI Driver1;c:\windows\system32\Drivers\CEUSBAUD.sys [2003-11-01 17920]
S3 ConsoleMgrSvc.exe;Avtec Console Manager;c:\program files\Avtec, Inc\Scout\ConsoleMgrSvc.exe [2007-04-25 233472]
S3 ControlService.exe;Avtec Control Layer;c:\program files\Avtec, Inc\Scout\ControlService.exe [2008-10-28 225280]
S3 CPSSvc.exe;Avtec Centralized Project Storage;c:\program files\Avtec, Inc\CPS\CPSSvc.exe [2007-04-02 172032]
S3 FarStoneFireWallDrive;FarStoneFireWallDrive;c:\windows\system32\Drivers\FarDrive.sys [2004-05-19 142169]
S3 L6POD;L6 PODxt Service;c:\windows\system32\Drivers\L6POD.sys [2003-06-27 114048]
S3 MediaWkstnSvc.exe;Avtec Media Workstation 1900-316-42xx;c:\program files\Avtec, Inc\Scout\MediaWkstnSvc.exe [2007-04-25 126976]
S3 MSS;MSS Simulator;d:\my projects\Avtec\Visual Studio 2005\Newport\Avtec SVN Repository\FrontEndApps\bin\Debug\mss.exe [2007-03-15 69632]
S3 NPF;NetGroup Packet Filter Driver;c:\windows\system32\drivers\npf.sys [2007-11-06 34064]
S3 PDEXLOCK;Photodex Hardware Lock Driver;c:\windows\system32\Drivers\PDEXLOCK.sys [2006-12-14 12288]
S3 TASCAM_US122144;TASCAM USB 2.0 Audio Device driver;c:\windows\system32\Drivers\tascusb2.sys [2008-05-10 360448]
S3 TASCAM_US144_MIDI;TASCAM US-144 WDM MIDI Device;c:\windows\system32\drivers\tscusb2m.sys [2008-05-10 18944]
S3 TASCAM_US144_WDM;TASCAM US-144 WDM;c:\windows\system32\drivers\tscusb2a.sys [2008-05-10 33792]
S3 TwTouch;MicroTouch touch screen;c:\windows\system32\DRIVERS\TwTouch.sys [2007-02-22 84945]
S4 msvsmon80;Visual Studio 2005 Remote Debugger;"c:\program files\Microsoft Visual Studio 8\Common7\IDE\Remote Debugger\x86\msvsmon.exe" /service msvsmon80 [2005-09-23 2799808]
2008-11-25 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 11:34]
2008-11-26 c:\windows\Tasks\GoogleUpdateTaskUser.job
- c:\documents and settings\Kurt\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2008-09-04 20:40]
Rootkit scan 2008-11-26 16:31:18
Cpqset = c:\program files\Hewlett-Packard\Default Settings\cpqset.exe????????????L?@? ???Pd??????g?@?????L?@
- - - - - - - > 'winlogon.exe'(1320)
Completion time: 2008-11-26 16:33:25
ComboFix-quarantined-files.txt 2008-11-26 21:32:48
ComboFix2.txt 2008-11-26 20:30:23
ComboFix3.txt 2008-11-26 19:39:01
Pre-Run: 11,513,860,096 bytes free
Post-Run: 11,497,275,392 bytes free
252 --- E O F --- 2007-07-21 13:12:46
kschulz
OS : WinXP
Post by Belahzur on Wed Nov 26, 2008 11:03 pm
Does the machine seem okay?
Post by kschulz on Wed Nov 26, 2008 11:35 pm
Yes, since the first ComboFix run it seems to be working normally, which is hard for me to believe as bad as it seemed. We'll see how it goes for awhile - hopefully it's scoured clean by now.
Belahzur, thanks so much for your help. You saved me a huge amount of time and aggravation. Really appreciate the help!
kschulz
OS : WinXP
Post by Belahzur on Wed Nov 26, 2008 11:38 pm
Hello again.
I think I made a mistake before.
Put your XP SP2 CD back in the machine in normal mode.
Press Start > Run. When the run command opens, type this in the open field.
cmd
Press enter.
Then when the command prompt opens, type this in:
expand f:\i386\winlogon.ex_ c:\windows\system32\winlogon.exe
Press enter.
Now type this in:
expand f:\i386\termsrv.dl_ c:\windows\system32\termsrv.dll
Press enter.
Please re-run combofix again, I think it might not display the infected alert anymore.
Post by kschulz on Thu Nov 27, 2008 12:12 am
"Can't open input file: f:\i386\winlogon.ex_."
Looking at the i386 folder on the CD, it doesn't look there are any compressed files. I do see the winlogon.exe and termsrv.dll files there.
If it's any help, there is the winlogon.exe in my C:\Windows\System32 folder, dated yesterday, 11/25/2008 10:46pm which is about the time I first noticed problems and suspected malware. There is also a winlogon.old file there dated 8/4/2004 4:00pm of the exact same size. Same with termsrv.dll.
kschulz
OS : WinXP
Post by Belahzur on Thu Nov 27, 2008 12:18 am
That's maybe where the alert is coming from.
Delete the .old files.
The real dll and exe are the proper size, we are both running XP SP2 so your files are the same as mine, so I think they aren't infected.
Post by kschulz on Thu Nov 27, 2008 12:56 am
I deleted the .old files and ComboFix is still reporting winlogon.exe as infected. Everything seems to be running fine though - I think you're right that it's probably a false positive. Maybe just the file date change is why it's getting tagged.
kschulz
OS : WinXP
Post by Belahzur on Thu Nov 27, 2008 1:01 am
Okay, let me know if anything changes.
Post by kschulz on Thu Nov 27, 2008 1:11 am
Belahzur, thanks again. I really appreciate your time and patience with this. Hopefully I won't be back to bug you.
You've been a tremendous help! My Buddy
kschulz
OS : WinXP
Post by kschulz on Thu Nov 27, 2008 4:07 pm
A final bit of info - I noticed the following in the ComboFix log dumps:
Thinking that SAS is interfering with ComboFix accessing the winlogo.exe file, causing it to be tagged as infected - but it's a false positive. A few quick searches on the net reveals this is a common issue even with other anti-virus programs.
So I feel confident we're good. Solved?
kschulz
OS : WinXP
Post by Belahzur on Thu Nov 27, 2008 4:10 pm
I think your right, SAS has hooked itself into winlogon, probably to protect it.
But combofix detects this as malware.
If everything is still good for you, then yes.
I will add solved tags to the topic and leave it open for a few days incase you have any questions.
Post by Doctor Inferno on Thu Dec 04, 2008 4:05 am
