I need help
I need help
Post by Coolhorn on Fri Nov 21, 2008 9:18 am
Hello i have a irritating problem with my computer.
Every time i use my computer to surf the net or play warcraft 3 ,after about 15 to 20 minutes the screen hangs, goes blank and comes up with a message that reads
Out of Range: H-frequency 28khz
V-frequency 38hz
and i cannot do anything to my computer except switch off the power button. what is wrong and how do i solve this problem?
Coolhorn
Posts Posts : 8
Joined Joined : 2008-11-21
Points Points : 29390
Re: I need help
Post by Digitalocksmith on Fri Nov 21, 2008 6:50 pm
There are a number of things i need you to check and answer for me.
(1) Have you got the latest drivers for your graphics card?
If so, did you properly remove the old video drivers before installing new?
Have you changed any hardware.......graphics cards?
(2) Are your resolution and refresh rates set correctly? you can try setting it to 60 to test the game.
(3) did you make sure to install DirectX 9c or better?
(4) Do you need updated drivers for your motherboard i.e. if VIA?
(5) Are you using a minimum of XP SP2 operating system?
Regards
Digitalocksmith
Posts Posts : 625
Joined Joined : 2007-12-22
Points Points : 48941
Re: I need help
Post by Coolhorn on Sat Nov 22, 2008 3:23 am
er my graphic card is asus i think...
and i dunno about drivers.....
Coolhorn
Posts Posts : 8
Re: I need help
Post by Coolhorn on Sat Nov 22, 2008 3:25 am
i am sorry can i try to find out more and come back later?
Coolhorn
Posts Posts : 8
Re: I need help
Post by Coolhorn on Sat Nov 22, 2008 10:55 am
er... i have found out that my graphic card is ASUS Extreme 3000X... any idea where i can get updates?
Coolhorn
Posts Posts : 8
Re: I need help
Post by Digitalocksmith on Sat Nov 22, 2008 4:33 pm
Down this freeware app to identify your internal hardware specifics.
http://www.majorgeeks.com/Belarc_Advisor_d1385.html
Need more accurate info as i dont recognize this model off hand......is it AGP, PCI? V3000 or V3000ZX
Once you have the details from the above app, have a search on the Asus Website for any driver updates.
Whats your situation with the other questions i asked?
Regards
Digitalocksmith
Posts Posts : 625
Re: I need help
Post by Coolhorn on Mon Nov 24, 2008 9:26 am
i have already downloaded uniblue driver scanner and updated all my out to date drivers in accordance, but the problem still exists. Must i bring it to a hardware shop????????? Sad tearing Sad tearing Sad tearing Sad tearing Sad tearing Sad tearing Sad tearing
Coolhorn
Posts Posts : 8
Re: I need help
Post by Coolhorn on Wed Nov 26, 2008 6:07 am
hello, it turns out im missing on alot of microsoft updates
would that be the problem????
Coolhorn
Posts Posts : 8
Re: I need help
Post by dropleague on Wed Nov 26, 2008 11:20 am
perhaps there are some corrupted files in the system? maybe try reformating or something?
dropleague
Posts Posts : 94
Joined Joined : 2008-07-07
Protection Protection : Avast
Points Points : 30756
Re: I need help
Post by Coolhorn on Wed Nov 26, 2008 11:23 am
hello... er i reformated my computer already....Sad tearing
Coolhorn
Posts Posts : 8
Re: I need help
Post by Doctor Inferno on Wed Nov 26, 2008 9:53 pm
Try changing your monitor's resolution to a lower one. Have you tried the suggestions by Digitalocksmith in his first post?
Re: I need help
Post by Coolhorn on Thu Nov 27, 2008 5:07 am
i have not changed any new hardware recently...
According to a software that i have downloaded, Uniblue Driver Scanner , my drivers are all updated.
I am quite sure i already have DirectX 9c, and i am using windows XP SP2
Coolhorn
Posts Posts : 8
