Please Help (Trojan Problem)
Page 2 of 2 Previous  1, 2
Solved Re: Please Help (Trojan Problem)
Post by Doctor Inferno on 24th November 2008, 5:04 am
Yes, copy Windows Registry Editor Version 5.00. Everything in the code box.
Post by outlawz28 on 24th November 2008, 5:13 am
ntn happened do i need to restart?
outlawz28
Posts Posts : 84
Joined Joined : 2008-11-19
OS OS : Windows Vista Home Premium
Points Points : 29699
Post by Doctor Inferno on 24th November 2008, 5:20 am
You can try.
Post by Belahzur on 24th November 2008, 3:15 pm
It could be just a cache problem.
  • Close ATF-Cleaner.exe.
Points Points : 245091
Post by outlawz28 on 25th November 2008, 11:45 pm
no luck i dont seem to see what the problem could be could it have something to do with the virus protection or windows firewall?
outlawz28
Posts Posts : 84
Post by Doctor Inferno on 26th November 2008, 7:24 am
I don't have a proper solution for you, but there might be a work-around for this problem. Open explorer, in the Menu bar >> Views >> Icons. Once the view has been changed switch back to thumbnails view (small, medium, large)
As for the wallpaper settings, I'm still trying to find out what to do since you can't change views for it like in explorer, but it's worth a try.
Currently the only way I can figure to change your wallpaper is to upload it to a image host like tinypic.com and right click the image >> set as desktop background.
Post by outlawz28 on 1st December 2008, 9:21 pm
Hey I cant go onto certain sites now such as [You must be registered and logged in to see this link.] Could some files have been deleted or damaged because of the trojan?
outlawz28
Posts Posts : 84
Post by Doctor Inferno on 11th December 2008, 9:06 am
