MAJOR VIRUS PROBLEMS..... HELP
Solved MAJOR VIRUS PROBLEMS..... HELP
Post by beppeboy on 14th November 2008, 5:14 am
Hi - having only just thanked you guys for helping me fix my mates laptop i have fallen foul of some bad asse virus that seems to ave taken over my desktop ... opened up a file off p2p and got some page pop up saying something about black box flight recorder of something ... the screen went blue and rebooted ... came back with no antivirus (the icon has been removed from the tray and if i try to open it from programs it says exe is not valid win32 application... so itry to run ccleaner ... that does not work ... i happen to have avast on a key as i just put on laptop ... i instal avast .. same message not valid win 32 app .. infact any program gets that response cant open any antivirus or anything ... tried to open hijack this and it wouldnt let me ... please help :cry:
beppeboy
Posts Posts : 20
Joined Joined : 2008-11-10
OS OS : windows xp
Points Points : 29500
Solved Re: MAJOR VIRUS PROBLEMS..... HELP
Post by beppeboy on 14th November 2008, 12:29 pm
anybody ? any help would be gratefully received
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Doctor Inferno on 14th November 2008, 1:08 pm
Please [You must be registered and logged in to see this link.] and post a Hijack This log.
Belahzur will help you later.
Post by Belahzur on 14th November 2008, 1:09 pm
Hello beppeboy. Please be patient, I have college during the day.
Can you post a new Hijack This log please?
[edit] Cross posted. LOL Banner
Points Points : 245091
Post by beppeboy on 14th November 2008, 1:35 pm
Hi Sorry if i seem impatient but i am stressed out . . . i cant post a hijack this as it will not let me open hijack this .. or any other program .. it will not let me open windows in safe mode .. there is just a long scroll of writing and it goes blue screen and crashes .. its stopping me at every angle !
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Belahzur on 14th November 2008, 1:38 pm
Can you boot to safe mode?
I'm gonna take a guess here, but if you can get into safe mode, do this.
Search for this file.
C:\WINDOWS\system32\drivers\TDSS****.sys <-- the *'s are random letters, but the file begins with TDSS. If it's there, delete it.
Can you run Hijack This now?
Post by beppeboy on 14th November 2008, 2:07 pm
hiya .. that files not there .. stlil cant open in safe mode ... said something bout
multi(0) system 32 not valid win32 application when tried safe mode then rebooted ... still all antivirus and c cleaner and hijack all come up with same message .exe is not avalid win32 application .
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Belahzur on 14th November 2008, 2:15 pm
Is this machine using Norton?
This isn't an exe, so it may be able to run.
Post by beppeboy on 14th November 2008, 2:48 pm
yes norton 2007 was on the pc ... heres the log .. thanks .again for helping ....
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Belahzur on 14th November 2008, 3:08 pm
Was? It's not anymore?
Silent runners says it's still there.
Over the past two days, two machines have failed to start, and that was Norton doing that.
Please uninstall Norton via add/remove programs.
Press Start > Control panel > Add/remove programs
Remove anything with Norton/Symantec in the name.
Post by beppeboy on 14th November 2008, 4:17 pm
i dont think its to do with norton as i said when i opened the suspect file a window opened which looked like it was installing something ... said black box flight recorder or something i can boot up the pc as normal but no programs work ... it removed norton from the sytem tray but i think its still there .. i will remove it now
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Belahzur on 14th November 2008, 4:32 pm
    "ccApp"=-
    "osCheck"=-
    "Symantec PIF AlertEng"=-
Delete these two folders:
C:\Program Files\Common Files\Symantec Shared
C:\Program Files\Norton Internet Security
  • Now open another new notepad file.
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile]
    @="Application"
    "EditFlags"=hex:38,07,00,00
    "TileInfo"="prop:FileDescription;Company;FileVersion"
    "InfoTip"="prop:FileDescription;Company;FileVersion;Create;Size"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\DefaultIcon]
    @="%1"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shell]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shell\open]
    "EditFlags"=hex:00,00,00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shell\open\command]
    @="\"%1\" %*"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shell\runas]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shell\runas\command]
    @="\"%1\" %*"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shellex]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shellex\DropHandler]
    @="{86C86720-42A0-1069-A2E8-08002B30309D}"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shellex\PropertySheetHandlers]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shellex\PropertySheetHandlers\PifProps]
    @="{86F19A00-42A0-1069-A2E9-08002B30309D}"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shellex\PropertySheetHandlers\ShimLayer Property Page]
    @="{513D916F-2A8E-4F51-AEAB-0CBC76FB1AF8}"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\exefile\shellex\PropertySheetHandlers\{B41DB860-8EE4-11D2-9906-E49FADC173CA}]
Can you run exe files now?
Post by beppeboy on 14th November 2008, 5:11 pm
ok it says the specified file is not a regisry script - you can only import binary registry files"
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Belahzur on 14th November 2008, 5:14 pm
You have to include Windows Registry Editor Version 5.00 at the top of the script. Make sure that is there otherwise the script will fail.
Post by beppeboy on 14th November 2008, 6:01 pm
ok done as you asked .. still wont open any progs exe .. still wont run in safe mode
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Belahzur on 14th November 2008, 6:42 pm
Okay.
Could be rundll32.exe is missing.
Find this file:
C:\WINDOWS\system32\rundll32.exe <-- can you see it in the system32 folder?
Post by beppeboy on 15th November 2008, 5:59 pm
it went completely last night so im about to reinstal windows as it wont even boot up any more .. id like to try keep the stuff on the d drive do you think it will be uninfected of will i have to lose everything Sad tearing
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Belahzur on 15th November 2008, 6:29 pm
It isn't all that bad. Once you reformat, believe me, you'll find space on your hardrive you never knew you had. LOL Banner
And yes, it should be clean once you've formatted.
Post by beppeboy on 15th November 2008, 7:53 pm
thank you for all your great advice i will be very careful from now on and will certainly follow the advice given regarding prevention -
thanks again Thank You!
beppeboy
Posts Posts : 20
OS OS : windows xp
Post by Doctor Inferno on 25th November 2008, 2:18 am
Since this issue appears resolved, this topic is closed.
