Problems
Solved Problems
Post by Sir $wat on 10th November 2008, 11:48 pm
This is my g/f's pc.
Can u plz check this log for her?
Logfile of HijackThis v1.99.1
Scan saved at 3:44:22 PM, on 11/10/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16735)
C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
C:\Program Files\ESET\ESET Smart Security\ekrn.exe
C:\Program Files\ESET\ESET Smart Security\egui.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\Adobe\Reader 8.0\Reader\AcroRd32.exe
C:\Documents and Settings\TG\My Documents\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = [You must be registered and logged in to see this link.]
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O4 - HKLM\..\Run: [egui] "C:\Program Files\ESET\ESET Smart Security\egui.exe" /hide /waitservice
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O11 - Options group: [INTERNATIONAL] International*
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O17 - HKLM\System\CCS\Services\Tcpip\..\{C194A529-38A8-49EE-B762-B350ABB4C6C7}: NameServer = 190.80.16.3 190.80.16.4
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: Eset HTTP Server (EhttpSrv) - ESET - C:\Program Files\ESET\ESET Smart Security\EHttpSrv.exe
O23 - Service: Eset Service (ekrn) - ESET - C:\Program Files\ESET\ESET Smart Security\ekrn.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
Points Points : 34211
Solved Re: Problems
Post by Belahzur on 10th November 2008, 11:50 pm
Hello Sir $wat. Goofy
Log looks clean.
What problems is she having?
Points Points : 245111
Solved Re: Problems
Post by Sir $wat on 11th November 2008, 12:47 am
internet and pc are very slow.
plus she did a scan with adaware and spybot and found some trojans...
but if it is clean, then i guess it's clean...lol
Solved Re: Problems
Post by Belahzur on 11th November 2008, 12:48 am
Hijack This only shows whats up front, not what maybe hiding.
  • Download combofix from here, use the top links - [You must be registered and logged in to see this link.]
  • You will this next prompt that asks if you want to continue the malware scan, select yes
Solved Re: Problems
Post by Sir $wat on 11th November 2008, 12:52 am
ok....
i'll see how fast i can get it back to u...
thanx...
mayb Thursday....
Solved Re: Problems
Post by Belahzur on 18th November 2008, 9:23 am
Hello Sir $wat. Any update on this machine?
Solved Re: Problems
Post by Sir $wat on 22nd November 2008, 2:30 pm
yo close this man...
she said it's ok
Solved Re: Problems
Post by Belahzur on 22nd November 2008, 2:38 pm
Due to request from Sir $wat, this topic is closed.
