System Requirements Lab
Post by Doctor Inferno on 29th December 2007, 5:29 am
What it does
This site provides a One-Click solution that looks at your computer's hardware and system software to determine whether or not your current system can run a product. Each of your computer's components is evaluated to see how well it meets the minimum and recommended requirements for specific products. Recommendations are made on how to update or upgrade each component which does not meet the listed requirements. Sometimes, a simple, free software download is all that is needed. Sometimes you'll find that you need a different video card to fully experience what the game has to offer.
You can test and see if your PC is compatible for the game that you want to run.
http://www.systemrequirementslab.com
-Get your complete report in seconds including suggestions for what to upgrade on your computer.
-Only your system's hardware and system software are evaluated.
-No personally identifiable information is collected.
-Works on Windows 98, 98SE, ME, 2000, XP, 2003, Media Center, Vista.
-Works with Internet Explorer, Firefox & Netscape browsers.
-You will need to give your permission to download a secure ActiveX/Java browser component.
-You can easily uninstall the ActiveX/Java browser component when the analysis is complete.
Last edited by Doctor Inferno on 29th August 2008, 10:57 am; edited 1 time in total (Reason for editing : hide tags removed)
Points Points : 104640
Re: System Requirements Lab
Post by Nazzgull on 29th August 2008, 10:48 am
Hm.. This is interesting for me.
Posts Posts : 2330
Points Points : 40495
