autorun.inf problem
autorun.inf problem
Post by bongring on 23rd October 2008, 9:46 am
how to delete autorun.inf folder, with nothing in it. sophos can't do anything about it.
bongring
Posts Posts : 95
Joined Joined : 2008-10-20
OS OS : windows xp sp3
Points Points : 29830
Re: autorun.inf problem
Post by Belahzur on 23rd October 2008, 9:53 am
Hello and welcome. Big Grin
Wrong section for malware problems though.
Did the autorun.inf folder get created using Flash_Disinfector.exe?
Points Points : 245111
Post by Doctor Inferno on 23rd October 2008, 10:03 am
Moderated Message:Hello and welcome.
Moved from Welcome New Members and please edit your title to a more specific title. Thank you.
Points Points : 104640
Post by Belahzur on 23rd October 2008, 10:06 am
I suspect it's part of a flash drive infection anyway.
Please download the current version of HijackThis from [You must be registered and logged in to see this link.].
  • Download this file - [You must be registered and logged in to see this link.]
  • You will this next prompt that asks if you want to continue the malware scan, select yes
Please post both logs, I'll check them when I get home.
Post by Belahzur on 1st November 2008, 5:12 pm
Due to lack of feedback, this topic is closed.
