GeekPolice is a website which provides free Computer Technical Support & Virus/Spyware Removal to our members.
Take 30 seconds to register below and unlock the limitations of this website to discover new computer knowledge!
How to Remove RapidAntivirus [Removal Guide]
Post by Doctor Inferno on Fri 10 Oct 2008, 8:26 pm
This guide will give you easy instructions on how to remove RapidAntivirus for free.
What is RapidAntivirus? (Information)
RapidAntivirus is a fake security software which uses fraudulent strategies by displaying false or exaggerated security issues on your computer rather than any legitimate ones to coerce you into purchasing their software.
RapidAntivirus Screenshot:
Symptoms in a HijackThis log:
    O4 - Startup: Rapid Antivirus.lnk = C:\Program Files\Rapid Antivirus\Rapid Antivirus.exe
1. Please download Malwarebytes' Anti-Malware.
2. Install Malwarebytes' Anti-Malware by double clicking on Download_mbam-setup.exe
4. Malwarebytes' Anti-Malware will automatically update itself after the install, you can press the OK button to close that box and you will now be at the main program as shown below.
If you are having problems with the updater, you can use this link to manually update MBAM with the latest database
Spoiler:
  • Malwarebytes' Anti-Malwares' latest database
Download the Full database to your Desktop or to your usual Download Folder and install it by double clicking the file. Make sure that MBAM is closed before installing the update.
5. Close ALL open Windows, Programs, File or Folders.
6. Make sure you are on the Scanner tab. Select Perform quick scan then click the Scan button as shown above.
8. When the scan is finished a message box will appear, click Ok to continue.
9. Click Show Results.
11. Click on Remove seletced
12. When removing the files, Malwarebytes' Anti-Malware may require you to restart the computer in order to do a complete removal. If it displays a message stating that it needs to restart, please allow it to do so.
13. After that you can close the Malwarebytes' Anti-Malware window, your computer is now cleaned.
If you are still experiencing problems or difficulties following this guide or require any assistance removing this software, please post your questions in our Virus, Spyware & Malware Removal forums for free help.
You have to be logged in to post questions. Registration is free. By registering you are privileged to other virus removal resources in future.
The GeekPolice
The GeekPolice
