problem
Solved problem
Post by xdyeo on Sun Sep 14, 2008 2:24 am
I have this problem. When I download mangas or comics, it will be a window player file. How to I change it to those kind of compress zipped folder so I can read it. I file I downloaded is a RAR file. Btw I tried opening it with MS word but it cant work so someone teach me how to change it to a zipped folder.
xdyeo
Posts Posts : 62
Joined Joined : 2008-04-09
Points Points : 31661
Solved Re: problem
Post by Doctor Inferno on Sun Sep 14, 2008 3:49 am
Try this:
Right click the file >> select Open With >> select WinRAR.
Solved Re: problem
Post by xdyeo on Sun Sep 14, 2008 5:38 am
I dont have a WinRar so how do I get it?
xdyeo
Posts Posts : 62
Solved Re: problem
Post by Belahzur on Sun Sep 14, 2008 12:01 pm
Download 7zip from here:
http://www.7-zip.org/
Once downloaded, install it. It won't take more than a minute.
Now that it's installed, right click the rar file > 7zip > extract here.
Points Points : 245049
Solved Re: problem
Post by xdyeo on Sun Sep 14, 2008 1:38 pm
I instill it but it doen't have extract here. I has compress and email or compress to 7-zip.vz and email or compress tp 7-zip.zip and email
xdyeo
Posts Posts : 62
Solved Re: problem
Post by Belahzur on Sun Sep 14, 2008 2:16 pm
Right click the rar > Open with > Browser button > Follow this path:
C:\Program Files\7zip\7zfm.exe
Double click it and it will add to the list of items, select to open with that.
Solved Re: problem
Post by xdyeo on Wed Sep 17, 2008 10:52 am
Thx a lot and i can read my mangas.
xdyeo
Posts Posts : 62
