recovery cd help?
Solved recovery cd help?
Post by amir20001 on Sun Aug 31, 2008 1:18 am
i'm not sur if this is the right section to put this in
but can any help me make a recovery cd for vista home premium
thank you
amir20001
Posts Posts : 83
Joined Joined : 2008-08-08
Points Points : 30801
Solved Re: recovery cd help?
Post by Doctor Inferno on Sun Aug 31, 2008 1:26 am
Do you mean you want to know how to make a recovery CD?
If so, what is the brand of the laptop you are using?
Here is an example if you are using a HP computer
Click Start >> All Programs. If you have an HP Pavilion click Hewlett-Packard and then HP PC Recovery CD Creator. If not, try clicking PC Help & Tools, then HP CD Recovery CD-DVD Creator to start the program.
Post by amir20001 on Sun Aug 31, 2008 1:35 am
ya that is what i mean, i am using a toshiba satellite l300d
amir20001
Posts Posts : 83
Post by Doctor Inferno on Sun Aug 31, 2008 2:05 am
Open the program "Recovery Disc Creator" and create your recovery disc.
Post by amir20001 on Sun Aug 31, 2008 2:16 am
thank you are there any free anti vrius or spyware u suggest
amir20001
Posts Posts : 83
Post by Doctor Inferno on Sun Aug 31, 2008 9:21 am
For a free antivirus I would suggest Avast Home Edition. I recommended it because it actually disinfects viruses instead of deleting them. Grab it here.
For a free antispyware you can use SUPERAntiSpyware Free Edition. Grab it here.
SUPERAntiSpyware Free Edition doesn't have a real time protection, so if you want an anti-spyware with a real-time protection you can use Spybot, download from here
Both are reputable anti spywares and you can choose between the 2.
