Internet browsers and internet refusing to work, think its a hardware problem?
Page 1 of 2 1, 2  Next
Re: Internet browsers and internet refusing to work, think its a hardware problem?
Post by Superdave on 20th June 2016, 6:32 pm
Let's check this computer for malware.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83201
Post by alewiina on 20th June 2016, 9:38 pm
I already have the Malware Bytes program and I'd already run a scan prior to this, but I ran another.  There was no threats at all detected, so it didn't give me a log.
AdW Cleaner log:
# AdwCleaner v5.200 - Logfile created 20/06/2016 at 14:41:26
# Updated 14/06/2016 by ToolsLib
# Database : 2016-06-20.3 [Server]
# Operating system : Windows 7 Home Premium Service Pack 1 (X64)
# Username : user - USER-PC
# Running from : C:\Users\user\Downloads\adwcleaner_5.200.exe
# Option : Clean
# Support : https://toolslib.net/forum
***** [ Services ] *****
***** [ Folders ] *****
[-] Folder Deleted : C:\ProgramData\Partner
[-] Folder Deleted : C:\ProgramData\lavasoft\web companion
[-] Folder Deleted : C:\ProgramData\49a5ffa9
[#] Folder Deleted : C:\ProgramData\Application Data\Partner
[#] Folder Deleted : C:\ProgramData\Application Data\lavasoft\web companion
[#] Folder Deleted : C:\ProgramData\Application Data\49a5ffa9
[-] Folder Deleted : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Plants Vs Zombies
[-] Folder Deleted : C:\Program Files (x86)\Plants Vs Zombies
[-] Folder Deleted : C:\Users\user\AppData\Local\Temp\MPC
[-] Folder Deleted : C:\users\user\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Plants Vs Zombies
[-] Folder Deleted : C:\Users\user\AppData\Local\Google\Chrome\User Data\Default\Extensions\jbolfgndggfhhpbnkgnpjkfhinclbigj
[-] Folder Deleted : C:\uninst
***** [ Files ] *****
[-] File Deleted : C:\windows\SysWOW64\RegistryHelperLM.ocx
[-] File Deleted : C:\Users\user\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_niapdbllcanepiiimjjndipklodoedlc_0.localstorage
[-] File Deleted : C:\Users\user\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_niapdbllcanepiiimjjndipklodoedlc_0.localstorage-journal
***** [ DLLs ] *****
***** [ WMI ] *****
***** [ Shortcuts ] *****
***** [ Scheduled tasks ] *****
[-] Task Deleted : Afefph
[-] Task Deleted : Suqgimcu
***** [ Registry ] *****
[-] Key Deleted : HKCU\Software\ae8bdeb73cb910
[-] Key Deleted : HKLM\SOFTWARE\ae8bdeb73cb910
[-] Key Deleted : HKLM\SOFTWARE\Google\Chrome\Extensions\jbolfgndggfhhpbnkgnpjkfhinclbigj
[-] Key Deleted : HKLM\SOFTWARE\Classes\Prod.cap
[-] Key Deleted : HKCU\Software\Classes\CLSID\{80922EE0-8A76-46AE-95D5-BD3C3FE0708D}
[-] Key Deleted : HKCU\Software\Classes\CLSID\{9C4EFBD5-1ADF-41E6-BE26-AF44326E30E4}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{00B11DA2-75ED-4364-ABA5-9A95B1F5E946}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{1AA60054-57D9-4F99-9A55-D0FBFBE7ECD3}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{6E993643-8FBC-44FE-BC85-D318495C4D96}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{80922EE0-8A76-46AE-95D5-BD3C3FE0708D}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{9C4EFBD5-1ADF-41E6-BE26-AF44326E30E4}
[-] Key Deleted : HKLM\SOFTWARE\Classes\Interface\{10DE7085-6A1E-4D41-A7BF-9AF93E351401}
[-] Key Deleted : HKLM\SOFTWARE\Classes\Interface\{1AD27395-1659-4DFF-A319-2CFA243861A5}
[-] Key Deleted : HKLM\SOFTWARE\Classes\Interface\{E7BC34A1-BA86-11CF-84B1-CBC2DA68BF6C}
[-] Key Deleted : HKCU\Software\Softonic
[-] Key Deleted : HKLM\SOFTWARE\Registry Helper
[-] Key Deleted : HKLM\SOFTWARE\SVH
[-] Key Deleted : HKLM\SOFTWARE\SprgFiles
[-] Key Deleted : HKLM\SOFTWARE\Lavasoft\Web Companion
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\11598763487076930564
[-] Key Deleted : [x64] HKLM\SOFTWARE\Tarma Installer
[-] Value Deleted : HKLM\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules [{341F73AE-705B-4C11-AE5E-5B20DEEDF204}]
[-] Value Deleted : HKLM\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules [{3166C711-BE66-4F9E-8BB2-E52BF6B495A9}]
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\akamaihd.net
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\bestpriceninja.com
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\cdncache-a.akamaihd.net
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\eshopcomp.com
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\nps.pastaleads.com
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\pastaleads.com
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\pstatic.bestpriceninja.com
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\pstatic.eshopcomp.com
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\re-markable.net
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\static.re-markable00.re-markable.net
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\DOMStorage\utop.it
[-] Key Deleted : [x64] HKLM\SOFTWARE\Microsoft\Shared Tools\MsConfig\StartupReg\Registry Helper
[-] Key Deleted : HKLM\SYSTEM\CurrentControlSet\Services\EventLog\Application\Registry Helper Service
***** [ Web browsers ] *****
[-] [C:\Users\user\AppData\Local\Google\Chrome\User Data\Default\Web Data] [Search Provider] Deleted : trovi.search
[-] [C:\Users\user\AppData\Local\Google\Chrome\User Data\Default\Web Data] [Search Provider] Deleted : ask.com
[-] [C:\Users\user\AppData\Local\Google\Chrome\User Data\Default\Web Data] [Search Provider] Deleted : subeta.net
[-] [C:\Users\user\AppData\Local\Google\Chrome\User Data\Default\Secure Preferences] [Extension] Deleted : jbolfgndggfhhpbnkgnpjkfhinclbigj
:: "Tracing" keys deleted
:: Winsock settings cleared
C:\AdwCleaner\AdwCleaner[C1].txt - [5492 bytes] - [20/06/2016 14:41:26]
C:\AdwCleaner\AdwCleaner[R0].txt - [4059 bytes] - [02/03/2014 13:12:17]
C:\AdwCleaner\AdwCleaner[R1].txt - [3391 bytes] - [30/11/2014 23:01:19]
C:\AdwCleaner\AdwCleaner[S1].txt - [5449 bytes] - [20/06/2016 14:35:46]
########## EOF - C:\AdwCleaner\AdwCleaner[C1].txt - [5784 bytes] ##########
JRT log:
Junkware Removal Tool (JRT) by Malwarebytes
Version: 8.0.6 (04.25.2016)
Operating System: Windows 7 Home Premium x64
Ran by user (Administrator) on 20/06/2016 at 15:40:59.14
File System: 24
Successfully deleted: C:\Users\user\Appdata\LocalLow\company (Folder)
Successfully deleted: C:\windows\s.bat (File)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\0BUSMNXI (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\0PS72R2M (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\62AXOPQ5 (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\FFK7W5TF (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\FZG8CKJ5 (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\LIXMVQOA (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\TR0S8YPE (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\UQK86C7N (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\X0ZLX6DM (Temporary Internet Files Folder)
Successfully deleted: C:\Users\user\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\XGESJ1Y9 (Temporary Internet Files Folder)
Successfully deleted: C:\windows\prefetch\DRIVERINSTALL.EXE-586FB42C.pf (File)
Successfully deleted: C:\windows\prefetch\FREEMAKEERRORREPORTER.EXE-7CA8C7FD.pf (File)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\0BUSMNXI (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\0PS72R2M (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\62AXOPQ5 (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\FFK7W5TF (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\FZG8CKJ5 (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\LIXMVQOA (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\TR0S8YPE (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\UQK86C7N (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\X0ZLX6DM (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\XGESJ1Y9 (Temporary Internet Files Folder)
Registry: 2
Successfully deleted: HKLM\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A} (Registry Key)
Successfully deleted: HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A} (Registry Key)
Scan was completed on 20/06/2016 at 15:46:18.87
End of JRT log
alewiina
Posts Posts : 66
Joined Joined : 2011-10-23
OS OS : Windows 7 64 bit
Points Points : 19483
Post by alewiina on 20th June 2016, 9:58 pm
And after all that, it STILL won't work >.<
alewiina
Posts Posts : 66
Post by Superdave on 20th June 2016, 10:03 pm
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Captain
Captain
Posts Posts : 4202
Post by alewiina on 21st June 2016, 1:17 am
So, having issues with this program. It runs just fine for an hour or so, and then this happens:
And its all frozen up and won't go any farther. It did that the first time so I closed it out and restarted it, but it did it again the second time. I'm trying a third time now to see exactly when it happens (staying nearby, last time I was in a different room while it scanned) but I'm going to give up if it happens again
alewiina
Posts Posts : 66
Post by Superdave on 21st June 2016, 2:19 am
Strange. It did the same thing to me. Let's try this one.
Please go to Kaspersky website and perform an online antivirus scan.
1. Read through the requirements and privacy statement and click on Accept button.
2. It will start downloading and installing the scanner and virus definitions. You will be prompted to install an application from Kaspersky. Click Run.
3. When the downloads have finished, click on Settings.
4. Make sure these boxes are checked (ticked). If they are not, please tick them and click on the Save button:
Spyware, Adware, Dialers, and other potentially dangerous programs
Archives
5. Click on My Computer under Scan.
6. Once the scan is complete, it will display the results. Click on View Scan Report.
7. You will see a list of infected items there. Click on Save Report As....
8. Save this report to a convenient place. Change the Files of type to Text file (.txt) before clicking on the Save button.
9. Please post this log in your next reply.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 21st June 2016, 3:17 am
Okay, I got Kaspersky Security Scan running. In settings though, there wasn't any place I could see to check off those boxes (I didn't see those options at all), just "run deep scan" so I clicked that.
There also isnt "my computer" under scan, just "My Kaspersky" :S
alewiina
Posts Posts : 66
Post by alewiina on 21st June 2016, 2:19 pm
Okay this kaspersky scan is not working. It keeps crashing and not finishing scans. What else can I do?
alewiina
Posts Posts : 66
Post by Superdave on 21st June 2016, 7:02 pm
Please download Farbar Service Scanner to the desktop and run it on the computer with the issue.
Note: You need to run the version compatible with your system. If you are not sure which version applies to your system download both of them and try to run them. Only one of them will run on your system, that will be the right version.
Make sure FRST is run under administrator privileges.
Make sure that the Whitelist section is checked.Otherwise, the log will be very long.
You Security programs may prevent the tool from running. If this happens, disable the security program until the scan is completed.
  • Right click to run as administrator (XP users click run after receipt of Windows Security Warning - Open File). When the tool opens click Yes to disclaimer.
  • Press "Scan".
  • It will create a log (FSS.txt) in the same directory the tool is run.
  • Please copy and paste the log to your reply.
  • The first time the tool is run it generates another log (Addition.txt - also located in the same directory as FRST.exe/FRST64.exe). Please also paste that along with the FRST.txt into your reply.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 22nd June 2016, 4:59 am
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 20-06-2016 01
Ran by user (administrator) on USER-PC (21-06-2016 22:48:29)
Running from C:\Users\user\Desktop
Loaded Profiles: UpdatusUser & user (Available Profiles: UpdatusUser & user)
Platform: Windows 7 Home Premium Service Pack 1 (X64) Language: English (United States)
Internet Explorer Version 11 (Default browser not detected!)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
==================== Processes (Whitelisted) =================
(If an entry is included in the fixlist, the process will be closed. The file will not be moved.)
(NVIDIA Corporation) C:\Windows\System32\nvvsvc.exe
(Microsoft Corporation) C:\Windows\System32\wlanext.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\NvXDSync.exe
(Hewlett-Packard Company) C:\Program Files (x86)\Hp\Common\HPSupportSolutionsFrameworkService.exe
(AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\kss.exe
(Google Inc.) C:\Program Files (x86)\Google\Update\1.3.30.3\GoogleCrashHandler.exe
(Google Inc.) C:\Program Files (x86)\Google\Update\1.3.30.3\GoogleCrashHandler64.exe
(AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Software Updater Beta\ksu.exe
(Microsoft Corporation) C:\Program Files\Microsoft LifeCam\MSCamS64.exe
(Safer-Networking Ltd.) C:\Program Files (x86)\Spybot - Search & Destroy 2\SDFSSvc.exe
(Microsoft Corporation) C:\Windows\System32\GWX\GWX.exe
() C:\Program Files (x86)\Intel Driver Update Utility\SUR\SurSvc.exe
(Lenovo.) C:\Windows\System32\TPHDEXLG64.exe
(Microsoft Corp.) C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
(Safer-Networking Ltd.) C:\Program Files (x86)\Spybot - Search & Destroy 2\SDUpdSvc.exe
(Microsoft Corp.) C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVCM.EXE
(CyberLink) C:\Program Files (x86)\Lenovo\YouCam\YCMMirage.exe
(Safer-Networking Ltd.) C:\Program Files (x86)\Spybot - Search & Destroy 2\SDWSCSvc.exe
(Microsoft Corporation) C:\Windows\System32\dllhost.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Updatus\daemonu.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
(Microsoft Corporation) C:\Windows\System32\wbem\WMIADAP.exe
==================== Registry (Whitelisted) ===========================
(If an entry is included in the fixlist, the registry item will be restored to default or removed. The file will not be moved.)
HKLM-x32\...\Run: [] => [X]
Winlogon\Notify\igfxcui: C:\windows\system32\igfxdev.dll (Intel Corporation)
Winlogon\Notify\SDWinLogon-x32: SDWinLogon.dll [X]
HKU\S-1-5-21-2093609111-1690196408-3150272457-1000\...\Run: [FactoryTest] => C:\Windows\Test.bat
HKU\S-1-5-21-2093609111-1690196408-3150272457-1000\...\Run: [Best Buy pc app] => C:\Users\UpdatusUser\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Best Buy\Best Buy pc app.appref-ms
HKU\S-1-5-21-2093609111-1690196408-3150272457-1000\...\Run: [Power2GoExpress] => NA
HKU\S-1-5-21-2093609111-1690196408-3150272457-1000\...\Policies\Explorer: [NoDesktopCleanupWizard] 1
HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\Run: [KSS] => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\kss.exe [1556448 2015-12-15] (AO Kaspersky Lab)
HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\Policies\Explorer: [NoDesktopCleanupWizard] 1
HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\MountPoints2: {6fac2d7a-9e2b-11e0-8048-806e6f6e6963} - F:\Setup.exe
HKU\S-1-5-18\...\Run: [KSS] => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\kss.exe [1556448 2015-12-15] (AO Kaspersky Lab)
Lsa: [Notification Packages] scecli EgisPLPwdFilter
ShellIconOverlayIdentifiers: [00avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => No File
ShellIconOverlayIdentifiers: [VeriFace Enc] -> {771C7324-DA80-49D3-8017-753B0AF60951} => C:\windows\system32\IcnOvrly.dll [2011-06-24] ()
Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Kaspersky Software Updater Beta.lnk [2016-06-20]
ShortcutTarget: Kaspersky Software Updater Beta.lnk -> C:\Program Files (x86)\Kaspersky Lab\Kaspersky Software Updater Beta\ksu.exe (AO Kaspersky Lab)
BootExecute: autocheck autochk * sdnclean64.exe
CHR HKLM\SOFTWARE\Policies\Google: Restriction <======= ATTENTION
==================== Internet (Whitelisted) ====================
(If an item is included in the fixlist, if it is a registry item it will be removed or restored to default.)
Tcpip\Parameters: [DhcpNameServer] 64.59.184.17 64.59.191.229
Tcpip\Parameters: [NameServer] 8.8.8.8,8.8.8.4
Tcpip\..\Interfaces\{532A0296-790E-4757-9817-59680E131AE2}: [DhcpNameServer] 64.59.184.17 64.59.191.229
Tcpip\..\Interfaces\{826BF250-4875-4438-8CA8-FB3611AF2148}: [DhcpNameServer] 64.59.184.17 64.59.191.229
Tcpip\..\Interfaces\{FBB86E63-9DC1-4F0D-8771-C2CEE0BC029E}: [DhcpNameServer] 64.59.184.17 64.59.191.229
Internet Explorer:
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = www.google.com
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = hxxp://www.google.com
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.google.com
HKU\S-1-5-21-2093609111-1690196408-3150272457-1000\Software\Microsoft\Internet Explorer\Main,Start Page = hxxp://www.lenovo.com
HKU\S-1-5-21-2093609111-1690196408-3150272457-1000\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://www.lenovo.com
SearchScopes: HKLM -> DefaultScope {6A1806CD-94D4-4689-BA73-E35EA1EA9990} URL =
SearchScopes: HKLM -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxp://www.bing.com/search?q={searchTerms}&form=LENDF8&pc=MALN&src=IE-SearchBox
BHO: Windows Live ID Sign-in Helper -> {9030D464-4C02-4ABF-8ECC-5164760863C6} -> C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll [2012-07-17] (Microsoft Corp.)
BHO: No Name -> {B164E929-A1B6-4A06-B104-2CD0E90A88FF} -> No File
BHO: Office Document Cache Handler -> {B4F3A835-0E21-4959-BA22-42B3008E02FF} -> C:\Program Files\Microsoft Office\Office14\URLREDIR.DLL [2013-03-06] (Microsoft Corporation)
BHO-x32: Adobe PDF Link Helper -> {18DF081C-E8AD-4283-A596-FA578C2EBDC3} -> C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll [2010-09-22] (Adobe Systems Incorporated)
BHO-x32: DivX Plus Web Player HTML5
Mine didn't have an option to check "KnownDLLs" like yours did, it seems like a slightly different version of the program.
alewiina
Posts Posts : 66
Post by alewiina on 22nd June 2016, 5:01 am
Addition:
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 20-06-2016 01
Ran by user (2016-06-21 22:50:00)
Windows 7 Home Premium Service Pack 1 (X64) (2011-09-07 00:29:34)
Boot Mode: Normal
==================== Accounts: =============================
Administrator (S-1-5-21-2093609111-1690196408-3150272457-500 - Administrator - Disabled)
Guest (S-1-5-21-2093609111-1690196408-3150272457-501 - Limited - Disabled)
HomeGroupUser$ (S-1-5-21-2093609111-1690196408-3150272457-1005 - Limited - Enabled)
UpdatusUser (S-1-5-21-2093609111-1690196408-3150272457-1000 - Limited - Enabled) => C:\Users\UpdatusUser
user (S-1-5-21-2093609111-1690196408-3150272457-1001 - Administrator - Enabled) => C:\Users\user
==================== Security Center ========================
(If an entry is included in the fixlist, it will be removed.)
AS: Windows Defender (Disabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
AS: Spybot - Search and Destroy (Enabled - Out of date) {9BC38DF1-3CCA-732D-A930-C1CA5F20A4B0}
==================== Installed Programs ======================
(Only the adware programs with "Hidden" flag could be added to the fixlist to unhide them. The adware programs should be uninstalled manually.)
µTorrent (HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\uTorrent) (Version: 3.4.7.42330 - BitTorrent Inc.)
Active Protection System (HKLM-x32\...\{F493761C-E465-4B9E-9FC1-A312F161DE0A}) (Version: 1.70.11 - Lenovo)
Add or Remove Adobe Creative Suite 3 Design Premium (HKLM-x32\...\Adobe_c14ac4070fd9614ffe63f4bb533db2c) (Version: 1.0 - Adobe Systems Incorporated)
Adobe Flash Player 11 ActiveX (HKLM-x32\...\Adobe Flash Player ActiveX) (Version: 11.6.602.180 - Adobe Systems Incorporated)
Adobe Flash Player 21 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 21.0.0.213 - Adobe Systems Incorporated)
Adobe Photoshop CS3 (HKLM-x32\...\Adobe_719d6f144d0c086a0dfa7ff76bb9ac1) (Version: 10.0 - Adobe Systems Incorporated)
Adobe Reader 9.4.0 (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-A94000000001}) (Version: 9.4.0 - Adobe Systems Incorporated)
Adobe Shockwave Player 12.1 (HKLM-x32\...\Adobe Shockwave Player) (Version: 12.1.8.158 - Adobe Systems, Inc.)
Age of Conan: Unchained (HKLM-x32\...\Age of Conan_is1) (Version: - Funcom)
AHV content for Acrobat and Flash (x32 Version: 1 - Adobe Systems Incorporated) Hidden
Apple Application Support (32-bit) (HKLM-x32\...\{AFA1153A-F547-409B-B837-3A0D6C5A3FEC}) (Version: 3.1.3 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{D7B824DE-DA32-4772-9E5E-39C5158136A7}) (Version: 3.1.3 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{C4123106-B685-48E6-B9BD-E4F911841EB4}) (Version: 8.1.1.3 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}) (Version: 2.1.3.127 - Apple Inc.)
Audacity 2.1.2 (HKLM-x32\...\Audacity®_is1) (Version: 2.1.2 - Audacity Team)
Awakening: Moonfell Wood (HKLM-x32\...\BFG-Awakening - Moonfell Wood) (Version: - )
Awakening: The Goblin Kingdom (HKLM-x32\...\BFG-Awakening - The Goblin Kingdom) (Version: - )
Battle.net (HKLM-x32\...\Battle.net) (Version: - Blizzard Entertainment)
Best Buy pc app (HKU\S-1-5-21-2093609111-1690196408-3150272457-1000\...\48e4cff94f039634) (Version: 3.2.420.5 - Best Buy)
Best Buy pc app (Version: 3.2.0.0 - Best Buy) Hidden
Best Buy pc app (x32 Version: 3.2.0.0 - Best Buy) Hidden
Big Fish Games: Game Manager (HKLM-x32\...\BFGC) (Version: 3.0.1.60 - )
Bubble Town (HKLM-x32\...\BFG-Bubble Town) (Version: - )
Christmas Wonderland 2 (HKLM-x32\...\BFG-Christmas Wonderland 2) (Version: - )
Curse Client (HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\101a9f93b8f0bb6f) (Version: 5.1.1.844 - Curse)
CyberLink YouCam (HKLM-x32\...\InstallShield_{01FB4998-33C4-4431-85ED-079E3EEFE75D}) (Version: 3.1.3623 - CyberLink Corp.)
D3DX10 (x32 Version: 15.4.2368.0902 - Microsoft) Hidden
DC Universe Online Live (HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\SOE-DC Universe Online Live) (Version: - Sony Online Entertainment)
DivX Setup (HKLM-x32\...\DivX Setup) (Version: 2.6.1.9 - DivX, LLC)
EgisTec ES603 WDM Driver (HKLM-x32\...\InstallShield_{AE4167B0-F589-4D2A-BF05-E181D543C49F}) (Version: 3.0.10.4 - Egis Technology Inc.)
Energy Management (HKLM-x32\...\InstallShield_{D0956C11-0F60-43FE-99AD-524E833471BB}) (Version: 6.0.2.1 - Lenovo)
Energy Management (x32 Version: 6.0.2.1 - Lenovo) Hidden
ES603 WDM Driver (x32 Version: 3.0.10.4 - Egis Technology Inc.) Hidden
Fishdom 2 (HKLM-x32\...\BFG-Fishdom 2) (Version: - )
Fishdom: Frosty Splash (HKLM-x32\...\BFG-Fishdom - Frosty Splash) (Version: - )
FonePaw Android Data Recovery 1.2.0 (HKLM-x32\...\{10E7BD57-C5FE-484f-A3F2-A1755286C0A7}_is1) (Version: 1.2.0 - FonePaw)
Freemake Video Converter version 4.1.3 (HKLM-x32\...\Freemake Video Converter_is1) (Version: 4.1.3 - Ellora Assets Corporation)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 51.0.2704.103 - Google Inc.)
Google Earth (HKLM-x32\...\{817750FA-EC6A-485D-9901-0683AE6FFDF1}) (Version: 7.1.5.1557 - Google)
Google Update Helper (x32 Version: 1.3.25.11 - Google Inc.) Hidden
Google Update Helper (x32 Version: 1.3.30.3 - Google Inc.) Hidden
Guild Wars 2 (HKLM-x32\...\Guild Wars 2) (Version: - NCsoft Corporation, Ltd.)
Hearthstone (HKLM-x32\...\Hearthstone) (Version: - Blizzard Entertainment)
Heroes of the Storm (HKLM-x32\...\Heroes of the Storm) (Version: - Blizzard Entertainment)
HP Officejet Pro 8610 Basic Device Software (HKLM\...\{39DA3F40-0B9E-4002-8E01-108FEC9EFE43}) (Version: 32.3.198.49673 - Hewlett-Packard Co.)
HP Officejet Pro 8610 Help (HKLM-x32\...\{F9569D00-4576-46C8-B6C7-207A4FD39745}) (Version: 32.0.0 - Hewlett Packard)
HP Support Solutions Framework (HKLM-x32\...\{44157EB3-D8D0-4BB1-B0F5-AD2C38814ED1}) (Version: 11.51.0027 - Hewlett-Packard Company)
HP Update (HKLM-x32\...\{912D30CF-F39E-4B31-AD9A-123C6B794EE2}) (Version: 5.005.002.002 - Hewlett-Packard)
I.R.I.S. OCR (HKLM-x32\...\{CA6BCA2F-EDEB-408F-850B-31404BE16A61}) (Version: 12.3.4.0 - HP)
IceChat 7.70 (Build 20101031) (HKLM-x32\...\IceChat_is1) (Version: 7.70 - IceChat Networks)
Intel(R) Control Center (HKLM-x32\...\{F8A9085D-4C7A-41a9-8A77-C8998A96C421}) (Version: 1.2.1.1007 - Intel Corporation)
Intel(R) Driver Update Utility 2.5 (x32 Version: 2.5.0.22 - Intel) Hidden
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 7.0.0.1144 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 9.17.10.4229 - Intel Corporation)
Intel(R) Product Improvement Program (x32 Version: 2.1.27.3 - Intel) Hidden
Intel(R) Rapid Storage Technology (HKLM-x32\...\{3E29EE6C-963A-4aae-86C1-DC237C4A49FC}) (Version: 10.1.5.1001 - Intel Corporation)
Intel® Driver Update Utility (HKLM-x32\...\{aa1dec3b-dc4b-4db0-8c18-9157457eff1f}) (Version: 2.5.0.22 - Intel)
iTunes (HKLM\...\{93F2A022-6C37-48B8-B241-FFABD9F60C30}) (Version: 12.1.2.27 - Apple Inc.)
Java(TM) 6 Update 26 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F83216026FF}) (Version: 6.0.260 - Oracle)
Kaspersky Security Scan (HKLM-x32\...\InstallWIX_{D1282694-0693-41A8-ABC1-6D1FFC1F65C5}) (Version: 16.0.0.1344 - Kaspersky Lab)
Kaspersky Security Scan (x32 Version: 16.0.0.1344 - Kaspersky Lab) Hidden
Kaspersky Software Updater Beta (HKLM-x32\...\InstallWIX_{94C8D443-1D07-4E6D-A9EB-FDBA45A839D8}) (Version: 1.5.2.228 - Kaspersky Lab)
Kaspersky Software Updater Beta (x32 Version: 1.5.2.228 - Kaspersky Lab) Hidden
LAME v3.99.3 (for Windows) (HKLM-x32\...\LAME_is1) (Version: - )
League of Legends (HKLM-x32\...\{92606477-9366-4D3B-8AE3-6BE4B29727AB}) (Version: 1.3 - Riot Games)
Lenovo EasyCamera (HKLM-x32\...\{ADE16A9D-FBDC-4ECC-B6BD-9C31E51D0333}) (Version: 1.11.0209.1 - Lenovo EasyCamera)
Lenovo EE Boot Optimizer (HKLM\...\Lenovo EE Boot Optimizer) (Version: 0.0.1.6 - Lenovo)
Lenovo OneKey Recovery (HKLM-x32\...\InstallShield_{46F4D124-20E5-4D12-BE52-EC177A7A4B42}) (Version: 7.0.1628 - CyberLink Corp.)
Lenovo OneKey Recovery (Version: 7.0.1628 - CyberLink Corp.) Hidden
Lenovo Security Suite (HKLM-x32\...\InstallShield_{0034859F-8E01-4C1D-BE77-F891C4786FBC}) (Version: 2.0.11.0 - Lenovo)
Lenovo Security Suite (x32 Version: 2.0.11.0 - Lenovo) Hidden
Lenovo_Wireless_Driver (HKLM-x32\...\{28ABE740-47F3-441B-9437-852F6A64EFF8}) (Version: 1.02.01 - Lenovo)
Luxor Bundle Pack (HKLM-x32\...\BFG-Luxor Bundle Pack) (Version: - )
Mahjongg: Ancient Mayas (HKLM-x32\...\BFG-Mahjongg - Ancient Mayas) (Version: - )
Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32\...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
Microsoft .NET Framework 4.6.1 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft IntelliPoint 8.2 (HKLM\...\Microsoft IntelliPoint 8.2) (Version: 8.20.468.0 - Microsoft Corporation)
Microsoft LifeCam (HKLM\...\{6965A8D2-465D-4F98-9FAA-0E9E2348F329}) (Version: 3.22.270.0 - Microsoft Corporation)
Microsoft Office Home and Student 2010 (HKLM-x32\...\Office14.SingleImage) (Version: 14.0.7015.1000 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.41212.0 - Microsoft Corporation)
Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32\...\{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053 (HKLM-x32\...\{770657D0-A123-3C07-8E44-1C83EC895118}) (Version: 8.0.50727.4053 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}) (Version: 8.0.61001 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022 (HKLM-x32\...\{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}) (Version: 9.0.21022 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 (HKLM-x32\...\{9BE518E6-ECC6-35A9-88E4-87755C07200F}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 (HKLM\...\{1D8E6291-B0D5-35EC-8441-6616F567A0F7}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 (HKLM-x32\...\{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 (HKLM-x32\...\{ca67548a-5ebe-413a-b50c-4b9ceb6d66c6}) (Version: 11.0.61030.0 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 (HKLM-x32\...\{33d1fd90-4274-48a1-9bc1-97e33d9c2d6f}) (Version: 11.0.61030.0 - Microsoft Corporation)
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
Microsoft WSE 3.0 Runtime (HKLM-x32\...\{E3E71D07-CD27-46CB-8448-16D4FB29AA13}) (Version: 3.0.5305.0 - Microsoft Corp.)
Movie Maker (x32 Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Nitro PDF Reader 2 (HKLM\...\{536CE037-9381-4A3F-9B70-4E0523730123}) (Version: 2.0.0.29 - Nitro PDF Software)
NVIDIA Graphics Driver 267.53 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 267.53 - NVIDIA Corporation)
Origin (HKLM-x32\...\Origin) (Version: 8.5.0.4554 - Electronic Arts, Inc.)
Pando Media Booster (HKLM-x32\...\{980A182F-E0A2-4A40-94C1-AE0C1235902E}) (Version: 2.3.6.0 - Pando Networks Inc.)
PDF Settings (x32 Version: 1.0 - Adobe Systems Incorporated) Hidden
PhotoPad Image Editor (HKLM-x32\...\PhotoPad) (Version: - NCH Software)
Plants vs. Zombies (HKLM-x32\...\BFG-Plants vs Zombies) (Version: - )
Port Locker (HKLM-x32\...\InstallShield_{A6FEE06D-C7E1-48CB-A9DF-1E317CF83CA4}) (Version: 1.0.5.24 - Egis Technology Inc.)
Port Locker (Version: 1.0.5.24 - Egis Technology Inc.) Hidden
Port Locker (x32 Version: 1.0.5.24 - Egis Technology Inc.) Hidden
Power2Go (HKLM-x32\...\{40BF1E83-20EB-11D8-97C5-0009C5020658}) (Version: 5.6.0.7303 - CyberLink Corp.)
QuickTime (HKLM-x32\...\{7BE15435-2D3E-4B58-867F-9C75BED0208C}) (Version: 7.71.80.42 - Apple Inc.)
Ranch Rush 2 - Sara's Island Experiment (HKLM-x32\...\BFG-Ranch Rush 2 - Sara's Island Experiment) (Version: - )
Realtek Ethernet Controller Driver For Windows 7 (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.21.531.2010 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.6282 - Realtek Semiconductor Corp.)
Realtek USB 2.0 Reader Driver (HKLM-x32\...\{62BBB2F0-E220-4821-A564-730807D2C34D}) (Version: 6.1.7600.10008 - Realtek Semiconductor Corp.)
Remo Recover 4.0 (HKLM\...\{A573D759-F894-448D-A420-3A9C31879F88}_is1) (Version: 4.0.0.34 - Remo Software)
Remo Recover for Android (HKLM\...\{3BF6B4CF-E6A1-45B3-9BC5-67213D146CB6}_is1) (Version: 2.0.0.9 - Remo Software)
Roll (HKLM-x32\...\RollerCoaster Tycoon Setup) (Version: - )
RollerCoaster Tycoon 2 Triple Thrill Pack (HKLM-x32\...\{4C5D15D2-5351-4F05-A96E-56C20554F977}) (Version: 1.00.000 - )
RollerCoaster Tycoon: Deluxe (HKLM-x32\...\Steam App 285310) (Version: - Chris Sawyer Productions)
Samsung USB Driver for Mobile Phones (HKLM\...\{D0795B21-0CDA-4a92-AB9E-6E92D8111E44}) (Version: 1.5.59.0 - Samsung Electronics Co., Ltd.)
Scrivener (HKLM-x32\...\Scrivener 1030) (Version: 1030 - Literature and Latte)
Service Pack 2 for Microsoft Office 2010 (KB2687455) 32-Bit Edition (HKLM-x32\...\{90140000-003D-0000-0000-0000000FF1CE}_Office14.SingleImage_{DE28B448-32E8-4E8F-84F0-A52B21A49B5B}) (Version: - Microsoft)
Skype™ 7.17 (HKLM-x32\...\{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.17.105 - Skype Technologies S.A.)
Smart Switch (HKLM-x32\...\InstallShield_{74FA5314-85C8-4E2A-907D-D9ECCCB770A7}) (Version: 4.1.16021.15 - Samsung Electronics Co., Ltd.)
Smart Switch (x32 Version: 4.1.16021.15 - Samsung Electronics Co., Ltd.) Hidden
SPORE™ (HKLM-x32\...\{9DF0196F-B6B8-4C3A-8790-DE42AA530101}) (Version: 1.00.0000 - Electronic Arts)
Spybot - Search & Destroy (HKLM-x32\...\{B4092C6D-E886-4CB2-BA68-FE5A99D31DE7}_is1) (Version: 2.0.12 - Safer-Networking Ltd.)
SpyHunter (HKLM\...\{6B6C4C46-1B7E-4A41-9E70-ACFBB22B1D81}) (Version: 4.12.13.4202 - Enigma Software Group USA, LLC)
Steam (HKLM-x32\...\Steam) (Version: 2.10.91.91 - Valve Corporation)
SUPERAntiSpyware (HKLM\...\{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}) (Version: 6.0.1212 - SUPERAntiSpyware.com)
swMSM (x32 Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
Synaptics Pointing Device Driver (HKLM\...\SynTPDeinstKey) (Version: 15.2.7.0 - Synaptics Incorporated)
System Requirements Lab for Intel (HKLM-x32\...\{CD41B576-4787-4D5C-95EE-24A4ABD89CD3}) (Version: 4.4.24.0 - Husdawg, LLC)
The Sims™ 3 (HKLM-x32\...\{C05D8CDB-417D-4335-A38C-A0659EDFD6B8}) (Version: 1.33.2 - Electronic Arts)
The Sims™ 3 Pets (HKLM-x32\...\{C12631C6-804D-4B32-B0DD-8A496462F106}) (Version: 10.0.96 - Electronic Arts)
VC80CRTRedist - 8.0.50727.6195 (x32 Version: 1.2.0 - DivX, Inc) Hidden
Ventrilo Client for Windows x64 (HKLM\...\{EEB3F6BB-318D-4CE5-989F-8191FCBFB578}) (Version: 3.0.8.0 - Flagship Industries, Inc.)
VeriFace (HKLM-x32\...\VeriFace) (Version: 4.0.0.1224 - Lenovo)
Vesuvia (HKLM-x32\...\BFG-Vesuvia) (Version: - )
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.2 - VideoLAN)
Windows Driver Package - Lenovo (ACPIVPC) System (12/02/2010 6.1.0.1) (HKLM\...\EA12B1FB53CE4E387C31A85236C41EF559B5E392) (Version: 12/02/2010 6.1.0.1 - Lenovo)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
Windows Live Sync (HKLM-x32\...\{B10914FD-8812-47A4-85A1-50FCDE7F1F33}) (Version: 14.0.8117.416 - Microsoft Corporation)
Wondershare Dr.Fone for Android(Build 4.8.2.142) (HKLM-x32\...\{1DB91A95-C548-4BA5-9D4C-18C7DEAAC39F}_is1) (Version: 4.8.2.142 - Wondershare Software Co.,Ltd.)
World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment)
World of Warcraft Beta (HKLM-x32\...\World of Warcraft Beta) (Version: - Blizzard Entertainment)
Yahoo! Messenger (HKLM-x32\...\Yahoo! Messenger) (Version: - Yahoo! Inc.)
==================== Custom CLSID (Whitelisted): ==========================
(If an entry is included in the fixlist, it will be removed from the registry. The file will not be moved unless listed separately.)
==================== Scheduled Tasks (Whitelisted) =============
Task: {00CC0248-2925-4228-AA60-3DF4CB5CDD28} - System32\Tasks\MirageAgent => C:\Program Files (x86)\Lenovo\YouCam\YCMMirage.exe [2010-12-24] (CyberLink)
Task: {04678332-60E8-484C-9BE6-42C9299AF1C6} - System32\Tasks\Intel\Intel Telemetry 2 (x86) => C:\Program Files (x86)\Intel\Telemetry 2.0\lrio.exe [2016-03-17] (Intel Corporation)
Task: {2F681684-196B-44D9-ADD1-521AC51B54CC} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-29] (Google Inc.)
Task: {57AD3173-724D-42C2-A627-35038491DC8F} - System32\Tasks\SUPERAntiSpyware Scheduled Task 02cda89e-9f84-4b9b-9126-1adbc4273e3c => C:\Program Files\SUPERAntiSpyware\SASTask.exe [2013-11-07] (SUPERAdBlocker.com)
Task: {5B59329B-69EB-42A2-84C9-D9D6F421C30B} - System32\Tasks\Safer-Networking\Spybot - Search and Destroy\Scan the system => C:\Program Files (x86)\Spybot - Search & Destroy 2\SDScan.exe [2012-11-13] (Safer-Networking Ltd.)
Task: {7A547C45-F188-4570-ADCA-C256F18C9F42} - System32\Tasks\Microsoft_Hardware_Launch_IPoint_exe => c:\Program Files\Microsoft IntelliPoint\IPoint.exe [2011-08-01] (Microsoft Corporation)
Task: {879014D7-3E23-49FE-B3BA-F8EC9EF270B9} - System32\Tasks\USER_ESRV_SVC_WILLAMETTE => Wscript.exe //B //NoLogo "C:\Program Files\Intel\SUR\WILLAMETTE\ESRV\task.vbs"
Task: {8A2E0877-A02F-4931-BED4-6F1BE7CA897A} - System32\Tasks\{4A6849FC-1822-48EB-A87D-91CEF5E31253} => Firefox.exe hxxp://ui.skype.com/ui/0/5.5.59.124/en/abandoninstall?source=lightinstaller&page=tsProblems&LastError=12002&installinfo=google-toolbar:notoffered;notincluded,google-chrome:notoffered;disabled
Task: {9D0D2A3B-81BC-4204-9576-B6A36108956B} - System32\Tasks\AVAST Software\Avast settings backup => C:\Program Files\Common Files\AV\avast! Antivirus\backup.exe [2016-06-04] (AVAST Software)
Task: {A1A24DA2-57F0-4060-9B95-3279EA824E8D} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-29] (Google Inc.)
Task: {A28C1CE1-A63B-49D4-A3C0-CF8D5A6E253E} - System32\Tasks\Safer-Networking\Spybot - Search and Destroy\Check for updates => C:\Program Files (x86)\Spybot - Search & Destroy 2\SDUpdate.exe [2012-11-13] (Safer-Networking Ltd.)
Task: {A6015E8C-988B-4F70-8553-33FBE5B41205} - System32\Tasks\Adobe Flash Player Updater => C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2016-05-08] (Adobe Systems Incorporated)
Task: {AB5F0394-95B9-48D0-A9FF-66195DF822F7} - System32\Tasks\Safer-Networking\Spybot - Search and Destroy\Refresh immunization => C:\Program Files (x86)\Spybot - Search & Destroy 2\SDImmunize.exe [2012-11-13] (Safer-Networking Ltd.)
Task: {D1DF7F43-CD5C-45B1-ABC8-2BA9DEC3BF70} - System32\Tasks\SUPERAntiSpyware Scheduled Task fa5a1b0c-59fe-4e30-b857-512244b911c4 => C:\Program Files\SUPERAntiSpyware\SASTask.exe [2013-11-07] (SUPERAdBlocker.com)
Task: {F596C311-F899-43E3-9EF5-93435E0499E7} - System32\Tasks\{FA386C4B-C066-4A36-AAC1-BACA8135B761} => Firefox.exe hxxp://www.skype.com/go/downloading?source=lightinstaller&ver=5.5.59.124&LastError=12002
(If an entry is included in the fixlist, the task (.job) file will be moved. The file which is running by the task will not be moved.)
Task: C:\windows\Tasks\Adobe Flash Player Updater.job => C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
Task: C:\windows\Tasks\GoogleUpdateTaskMachineCore.job => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
Task: C:\windows\Tasks\GoogleUpdateTaskMachineUA.job => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
Task: C:\windows\Tasks\SUPERAntiSpyware Scheduled Task 02cda89e-9f84-4b9b-9126-1adbc4273e3c.job => C:\Program Files\SUPERAntiSpyware\SASTask.exe C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
Task: C:\windows\Tasks\SUPERAntiSpyware Scheduled Task fa5a1b0c-59fe-4e30-b857-512244b911c4.job => C:\Program Files\SUPERAntiSpyware\SASTask.exe C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
==================== Shortcuts =============================
(The entries could be listed to be restored or removed.)
ShortcutWithArgument: C:\Users\user\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\StartMenu\Google Chrome.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) -> "
==================== Loaded Modules (Whitelisted) ==============
2010-10-22 08:38 - 2010-10-22 08:38 - 01407344 _____ () C:\Program Files (x86)\EgisTec Port Locker\x64\LIBEAY32.dll
2011-06-24 01:00 - 2011-06-24 01:00 - 01508192 _____ () C:\windows\system32\IcnOvrly.dll
2011-06-24 01:00 - 2011-06-24 01:00 - 00628064 _____ () C:\windows\system32\SimpleExt.dll
2016-03-09 20:43 - 2016-03-09 20:43 - 00118424 _____ () C:\Program Files (x86)\Intel Driver Update Utility\SUR\SurSvc.exe
2015-12-15 13:38 - 2015-12-15 13:38 - 00326112 _____ () C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\dblite.dll
2015-10-27 16:44 - 2015-10-27 16:44 - 00404952 _____ () C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\ipm_service.dll
2015-12-15 13:45 - 2015-12-15 13:45 - 45077376 _____ () C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\libcef.dll
2013-03-31 00:43 - 2012-11-13 14:06 - 00108960 _____ () C:\Program Files (x86)\Spybot - Search & Destroy 2\snlThirdParty150.bpl
2013-03-31 00:43 - 2012-11-13 14:06 - 00416160 _____ () C:\Program Files (x86)\Spybot - Search & Destroy 2\DEC150.bpl
2013-03-31 00:43 - 2012-11-13 14:06 - 00158624 _____ () C:\Program Files (x86)\Spybot - Search & Destroy 2\snlFileFormats150.bpl
2013-03-31 00:43 - 2012-08-23 09:38 - 00574840 _____ () C:\Program Files (x86)\Spybot - Search & Destroy 2\sqlite3.dll
2013-03-31 00:43 - 2012-11-13 14:06 - 00528288 _____ () C:\Program Files (x86)\Spybot - Search & Destroy 2\JSDialogPack150.bpl
2015-12-15 13:45 - 2015-12-15 13:45 - 01650560 _____ () C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\libglesv2.dll
2015-12-15 13:45 - 2015-12-15 13:45 - 00082304 _____ () C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\libegl.dll
==================== Alternate Data Streams (Whitelisted) =========
(If an entry is included in the fixlist, only the ADS will be removed.)
AlternateDataStreams: C:\ProgramData\Temp:1095ECE1 [494]
AlternateDataStreams: C:\ProgramData\Temp:1F7A10DD [452]
AlternateDataStreams: C:\ProgramData\Temp:2AE74FF9 [496]
AlternateDataStreams: C:\ProgramData\Temp:598E8EA1 [440]
AlternateDataStreams: C:\ProgramData\Temp:661DC753 [498]
AlternateDataStreams: C:\ProgramData\Temp:76466F4C [462]
AlternateDataStreams: C:\ProgramData\Temp:8684F6F0 [436]
AlternateDataStreams: C:\ProgramData\Temp:B1FBBD09 [410]
AlternateDataStreams: C:\ProgramData\Temp:B36361EE [448]
AlternateDataStreams: C:\ProgramData\Temp:BD13A410 [400]
AlternateDataStreams: C:\ProgramData\Temp:CBAF0C30 [444]
==================== Safe Mode (Whitelisted) ===================
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" will be restored.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MCODS => ""=""
==================== Association (Whitelisted) ===============
(If an entry is included in the fixlist, the registry item will be restored to default or removed.)
==================== Internet Explorer trusted/restricted ===============
(If an entry is included in the fixlist, it will be removed from the registry.)
IE trusted site: HKU\.DEFAULT\...\clonewarsadventures.com -> clonewarsadventures.com
IE trusted site: HKU\.DEFAULT\...\freerealms.com -> freerealms.com
IE trusted site: HKU\.DEFAULT\...\soe.com -> soe.com
IE trusted site: HKU\.DEFAULT\...\sony.com -> sony.com
IE trusted site: HKU\S-1-5-19\...\clonewarsadventures.com -> clonewarsadventures.com
IE trusted site: HKU\S-1-5-19\...\freerealms.com -> freerealms.com
IE trusted site: HKU\S-1-5-19\...\soe.com -> soe.com
IE trusted site: HKU\S-1-5-19\...\sony.com -> sony.com
IE trusted site: HKU\S-1-5-20\...\clonewarsadventures.com -> clonewarsadventures.com
IE trusted site: HKU\S-1-5-20\...\freerealms.com -> freerealms.com
IE trusted site: HKU\S-1-5-20\...\soe.com -> soe.com
IE trusted site: HKU\S-1-5-20\...\sony.com -> sony.com
IE trusted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\clonewarsadventures.com -> clonewarsadventures.com
IE trusted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\freerealms.com -> freerealms.com
IE trusted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\soe.com -> soe.com
IE trusted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\sony.com -> sony.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\007guard.com -> install.007guard.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\008i.com -> 008i.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\008k.com -> www.008k.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\00hq.com -> www.00hq.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\010402.com -> 010402.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\032439.com -> 80gw6ry3i3x3qbrkwhxhw.032439.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\0scan.com -> www.0scan.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\1-2005-search.com -> www.1-2005-search.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\1-domains-registrations.com -> www.1-domains-registrations.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\1000gratisproben.com -> www.1000gratisproben.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\1001namen.com -> www.1001namen.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\100888290cs.com -> mir.100888290cs.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\100sexlinks.com -> www.100sexlinks.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\10sek.com -> www.10sek.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\12-26.net -> user1.12-26.net
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\12-27.net -> user1.12-27.net
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\123fporn.info -> www.123fporn.info
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\123haustiereundmehr.com -> www.123haustiereundmehr.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\123moviedownload.com -> www.123moviedownload.com
IE restricted site: HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\...\123simsen.com -> www.123simsen.com
There are 7777 more sites.
==================== Hosts content: ===============================
(If needed Hosts: directive could be included in the fixlist to reset Hosts.)
2015-07-28 10:57 - 2016-06-18 13:55 - 00000022 _RASH C:\windows\system32\Drivers\etc\hosts
127.0.0.1 localhost
==================== Other Areas ============================
(Currently there is no automatic fix for this section.)
HKU\S-1-5-21-2093609111-1690196408-3150272457-1001\Control Panel\Desktop\\Wallpaper -> C:\Users\user\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
DNS Servers: 64.59.184.17 - 64.59.191.229
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
Windows Firewall is enabled.
==================== MSCONFIG/TASK MANAGER disabled items ==
MSCONFIG\Services: !SASCORE => 2
MSCONFIG\Services: AdobeFlashPlayerUpdateSvc => 3
MSCONFIG\Services: Apple Mobile Device Service => 2
MSCONFIG\Services: AVP => 2
MSCONFIG\Services: Bonjour Service => 2
MSCONFIG\Services: CSObjectsSrv => 2
MSCONFIG\Services: FLEXnet Licensing Service => 3
MSCONFIG\Services: Freemake Improver => 2
MSCONFIG\Services: iPod Service => 3
MSCONFIG\Services: McComponentHostService => 3
MSCONFIG\Services: MozillaMaintenance => 3
MSCONFIG\Services: NitroReaderDriverReadSpool2 => 2
MSCONFIG\Services: SkypeUpdate => 2
MSCONFIG\Services: ss_conn_service => 2
MSCONFIG\Services: Steam Client Service => 3
MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^Adobe Acrobat Speed Launcher.lnk => C:\windows\pss\Adobe Acrobat Speed Launcher.lnk.CommonStartup
MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^Adobe Acrobat Synchronizer.lnk => C:\windows\pss\Adobe Acrobat Synchronizer.lnk.CommonStartup
MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^McAfee Security Scan Plus.lnk => C:\windows\pss\McAfee Security Scan Plus.lnk.CommonStartup
MSCONFIG\startupfolder: C:^Users^user^AppData^Roaming^Microsoft^Windows^Start Menu^Programs^Startup^CurseClientStartup.ccip => C:\windows\pss\CurseClientStartup.ccip.Startup
MSCONFIG\startupreg: Acrobat Assistant 8.0 => "C:\Program Files (x86)\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe"
MSCONFIG\startupreg: Adobe Reader Speed Launcher => "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
MSCONFIG\startupreg: APSDaemon => "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
MSCONFIG\startupreg: ares => "C:\Program Files (x86)\Ares\Ares.exe" -h
MSCONFIG\startupreg: AVP => "C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE\avp.exe"
MSCONFIG\startupreg: DivXUpdate => "C:\Program Files (x86)\DivX\DivX Update\DivXUpdate.exe" /CHECKNOW
MSCONFIG\startupreg: EA Core => "C:\Program Files (x86)\Electronic Arts\EADM\Core.exe" -silent
MSCONFIG\startupreg: Energy Management => C:\Program Files (x86)\Lenovo\Energy Management\Energy Management.exe
MSCONFIG\startupreg: EnergyUtility => C:\Program Files (x86)\Lenovo\Energy Management\Utility.exe
MSCONFIG\startupreg: HotKeysCmds => "C:\windows\system32\hkcmd.exe"
MSCONFIG\startupreg: HP Officejet Pro 8610 (NET) => "C:\Program Files\HP\HP Officejet Pro 8610\Bin\ScanToPCActivationApp.exe" -deviceID "CN4BEEX1T9:NW" -scfn "HP Officejet Pro 8610 (NET)" -AutoStart 1
MSCONFIG\startupreg: HP Software Update => C:\Program Files (x86)\Hp\HP Software Update\HPWuSchd2.exe
MSCONFIG\startupreg: IgfxTray => "C:\windows\system32\igfxtray.exe"
MSCONFIG\startupreg: IntelliPoint => "c:\Program Files\Microsoft IntelliPoint\ipoint.exe"
MSCONFIG\startupreg: iTunesHelper => "C:\Program Files\iTunes\iTunesHelper.exe"
MSCONFIG\startupreg: Lenovo EE Boot Optimizer => C:\Program Files (x86)\Lenovo\Boot Optimizer\PopWnd.exe
MSCONFIG\startupreg: LifeCam => "C:\Program Files (x86)\Microsoft LifeCam\LifeExp.exe"
MSCONFIG\startupreg: Logitech Download Assistant => C:\Windows\system32\rundll32.exe C:\Windows\System32\LogiLDA.dll,LogiFetch
MSCONFIG\startupreg: Messenger (Yahoo!) => "C:\Program Files (x86)\Yahoo!\Messenger\YahooMessenger.exe" -quiet
MSCONFIG\startupreg: msnmsgr => "C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe" /background
MSCONFIG\startupreg: Pando Media Booster => C:\Program Files (x86)\Pando Networks\Media Booster\PMB.exe
MSCONFIG\startupreg: Persistence => "C:\windows\system32\igfxpers.exe"
MSCONFIG\startupreg: QuickTime Task => "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
MSCONFIG\startupreg: RtHDVCpl => C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe -s
MSCONFIG\startupreg: SDTray => "C:\Program Files (x86)\Spybot - Search & Destroy 2\SDTray.exe"
MSCONFIG\startupreg: Sidebar => C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
MSCONFIG\startupreg: Spybot-S&D Cleaning => "C:\Program Files (x86)\Spybot - Search & Destroy 2\SDCleaner.exe" /autoclean
MSCONFIG\startupreg: Steam => "C:\Program Files (x86)\Steam\steam.exe" -silent
MSCONFIG\startupreg: SUPERAntiSpyware => C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
MSCONFIG\startupreg: SynTPEnh => %ProgramFiles%\Synaptics\SynTP\SynTPEnh.exe
MSCONFIG\startupreg: TpShocks => C:\Windows\System32\TpShocks.exe
MSCONFIG\startupreg: Wondershare Helper Compact.exe => "C:\Program Files (x86)\Common Files\Wondershare\Wondershare Helper Compact\WSHelperSetup.exe"
==================== FirewallRules (Whitelisted) ===============
FirewallRules: [{5697A711-FE3C-4AA0-9ABD-95BC31F4A341}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Updatus\daemonu.exe
FirewallRules: [{102E729B-AE2F-424C-AFA7-CBB1C5739DE7}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Updatus\daemonu.exe
FirewallRules: [{93809413-65AF-44F5-ABC9-739829DEF6C7}] => (Allow) C:\Program Files (x86)\Windows Live\Sync\WindowsLiveSync.exe
FirewallRules: [{A750D7D5-2643-48C0-90C6-0131088BD260}] => (Allow) C:\Program Files (x86)\Pando Networks\Media Booster\PMB.exe
FirewallRules: [{08DD6BB7-B34F-4666-AB67-AAD29C101F9E}] => (Allow) C:\Program Files (x86)\Pando Networks\Media Booster\PMB.exe
FirewallRules: [{3ACABB95-8142-4D11-BC2A-B4DCAD2B6A37}] => (Allow) C:\Program Files (x86)\Pando Networks\Media Booster\PMB.exe
FirewallRules: [{281E5893-3998-4CE9-BA5C-17E61D14842F}] => (Allow) C:\Program Files (x86)\Pando Networks\Media Booster\PMB.exe
FirewallRules: [{48D2D9FA-B50E-45E3-A914-D702AA0FA0ED}] => (Allow) C:\Program Files (x86)\Pando Networks\Media Booster\PMB.exe
FirewallRules: [{57EB2A45-60C7-47A5-A7F4-BC846DFF1439}] => (Allow) C:\Program Files\Ventrilo\Ventrilo.exe
FirewallRules: [{B860A997-AC96-4B03-81EC-463F9D0AF29C}] => (Allow) C:\Program Files\Ventrilo\Ventrilo.exe
FirewallRules: [{439263EF-1DE3-4778-BAD5-83ED20FC7E75}] => (Allow) C:\Program Files (x86)\Skype\Phone\Skype.exe
FirewallRules: [{B5010F1D-2C10-497F-8CE6-A7AE53B58240}] => (Allow) C:\Program Files (x86)\Microsoft LifeCam\LifeCam.exe
FirewallRules: [{E1251581-A7C2-4385-85B0-F84304CB5455}] => (Allow) C:\Program Files (x86)\Microsoft LifeCam\LifeCam.exe
FirewallRules: [{06452E61-F735-4728-B9D5-1E435409A27F}] => (Allow) C:\Program Files (x86)\Microsoft LifeCam\LifeEnC2.exe
FirewallRules: [{7E25C3BE-8345-4F62-8E11-6B2BA910BD76}] => (Allow) C:\Program Files (x86)\Microsoft LifeCam\LifeEnC2.exe
FirewallRules: [{C8ADA2A2-7CD0-44CF-A945-BC1838292495}] => (Allow) C:\Program Files (x86)\Microsoft LifeCam\LifeExp.exe
FirewallRules: [{E0B72BE9-4D5D-4B24-9A63-88884D6F0083}] => (Allow) C:\Program Files (x86)\Microsoft LifeCam\LifeExp.exe
FirewallRules: [{30C18444-4D3A-4C85-9C3C-A9853C427111}] => (Allow) C:\Program Files (x86)\Microsoft LifeCam\LifeTray.exe
FirewallRules: [{AFE0E456-1352-4779-8B0D-61E3FCB6507C}] => (Allow) C:\Program Files (x86)\Microsoft LifeCam\LifeTray.exe
FirewallRules: [{BBEF51F2-F118-4709-A9CF-4EC44D6A98E6}] => (Allow) C:\Program Files (x86)\Yahoo!\Messenger\YahooMessenger.exe
FirewallRules: [{85BCD279-60E3-4114-A0CB-1A79814CAEEC}] => (Allow) C:\Program Files (x86)\Yahoo!\Messenger\YahooMessenger.exe
FirewallRules: [{4958212C-38B4-44B7-ADBC-3F55494430BE}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2380\Agent.exe
FirewallRules: [{E9D542A4-5E10-48D9-AA2F-B640541DE167}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2380\Agent.exe
FirewallRules: [{CABB8DBB-3FE1-4661-9437-6E59B331193E}] => (Allow) C:\Users\user\AppData\Roaming\uTorrent\uTorrent.exe
FirewallRules: [{C1B20C2A-EF08-466F-9AC9-5093E42F124D}] => (Allow) C:\Users\user\AppData\Roaming\uTorrent\uTorrent.exe
FirewallRules: [{57974F8B-CAF4-4BBD-8EAA-DE10EC9D4D62}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2689\Agent.exe
FirewallRules: [{44919729-13E1-49AB-A66B-6909C7007DB2}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2689\Agent.exe
FirewallRules: [{821C1390-C63A-4FAF-9B68-A025F65D074D}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2689\Agent.exe
FirewallRules: [{1399CB20-AB04-44A4-A92D-675371D69D72}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2689\Agent.exe
FirewallRules: [{0306780D-F348-41EC-91A7-99A74AA630ED}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2717\Agent.exe
FirewallRules: [{BAE5C91B-3EDA-4BDE-933F-0284143E712A}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2717\Agent.exe
FirewallRules: [{DC3C779F-47F8-474F-B647-F70A7C3A03E1}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.beta.2737\Agent.exe
FirewallRules: [{6B541489-96F3-426F-986A-47C993CD0DED}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.beta.2737\Agent.exe
FirewallRules: [{57C0D768-1D9F-4C70-AB1C-E5E599B85A2F}] => (Allow) C:\Program Files (x86)\Battle.net\Battle.net.exe
FirewallRules: [{1B5D4A9C-7990-405A-A4F0-9D3A065DB3D9}] => (Allow) C:\Program Files (x86)\Battle.net\Battle.net.exe
FirewallRules: [{6F59EFC6-02D4-43C0-88D3-257C619C295A}] => (Allow) C:\Program Files (x86)\Hearthstone\Hearthstone.exe
FirewallRules: [{A3A0C3D0-3E8D-4153-BCC3-4DA0C5F783E8}] => (Allow) C:\Program Files (x86)\Hearthstone\Hearthstone.exe
FirewallRules: [{03C786E2-4A57-4003-96A3-67C64FE2A84E}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.beta.2753\Agent.exe
FirewallRules: [{1FD28A22-D2FB-43DB-A72D-B1566BABD2FD}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.beta.2753\Agent.exe
FirewallRules: [{B66110BD-A977-454E-B9F9-EF60567A11EB}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2787\Agent.exe
FirewallRules: [{E41A224E-BA55-4402-8BB5-128A88D103DB}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2787\Agent.exe
FirewallRules: [{82DBD8B2-D488-45F1-8204-F2409B3EAB3E}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2816\Agent.exe
FirewallRules: [{74A1B620-2EF9-460F-AF0F-9B0F3C9F307E}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2816\Agent.exe
FirewallRules: [{CDDCAEDD-FA6C-499D-B8C0-C054360C457F}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe
FirewallRules: [{0B9EBF73-6F0E-486B-B608-F3142BBF1DBB}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe
FirewallRules: [{75B17ABE-8472-4EA0-B8FA-9EF9B74F8B7C}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3023\Agent.exe
FirewallRules: [{84E7020E-6762-4CB7-AD94-A463CE57CF18}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3023\Agent.exe
FirewallRules: [{8FF33333-396B-4573-A377-AF19BE963D25}] => (Allow) C:\Users\user\AppData\Roaming\uTorrent\uTorrent.exe
FirewallRules: [{AFC7AE33-301D-4B6A-B5CD-43164F807885}] => (Allow) C:\Users\user\AppData\Roaming\uTorrent\uTorrent.exe
FirewallRules: [{DE347D8A-9CC7-4DCE-8479-534830500E72}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3147\Agent.exe
FirewallRules: [{B58FCF7B-BBB5-43CF-B426-ED8B6304EB01}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3147\Agent.exe
FirewallRules: [{65750839-B2C4-433E-A42E-0F411AF54862}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3182\Agent.exe
FirewallRules: [{89C8161D-0DE6-40BB-98DE-79C5F093633C}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3182\Agent.exe
FirewallRules: [{C049A757-C703-4C86-A01B-7ED6AB21907F}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3235\Agent.exe
FirewallRules: [{F142C492-E901-4675-BE4D-359E96DE687D}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3235\Agent.exe
FirewallRules: [{9B87D791-4005-4244-AFB0-AB5DB4412250}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3286\Agent.exe
FirewallRules: [{5D86F130-FE12-475A-9992-615150FC7163}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3286\Agent.exe
FirewallRules: [{A3F1A20C-BC6E-4BCB-91F9-CE242BC2AE55}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3334\Agent.exe
FirewallRules: [{5A7B2E34-2B16-4FC1-A040-8D76B0916F81}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3334\Agent.exe
FirewallRules: [{B363380A-942A-48B6-A78B-AEB71C53ACDA}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3346\Agent.exe
FirewallRules: [{96D4F0D6-002F-4D63-BAF7-C7EAF8C3B2E8}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3346\Agent.exe
FirewallRules: [{E0A69586-77EE-442A-AD3E-466B07FBA2D3}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3372\Agent.exe
FirewallRules: [{78B5B2A4-B624-4EE2-8E59-DD77AF17A4E8}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3372\Agent.exe
FirewallRules: [{F5C09939-322C-41E9-8BCA-E05778E292FA}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3427\Agent.exe
FirewallRules: [{E32BDB99-E88D-4132-BE4A-5ECA922279DE}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3427\Agent.exe
FirewallRules: [{CD217347-86A7-465B-A51D-6C5327655086}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe
FirewallRules: [{BBBC0209-043D-4B76-A3DB-183D5563AE64}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe
FirewallRules: [{B0A28D6F-3662-4A4F-8F2E-11FE7F36E943}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe
FirewallRules: [{A1FB7A6D-6FB7-4699-805C-7B33A2359D79}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe
FirewallRules: [{DDF6B2E1-E46D-4F5D-BFB9-A08CEE823EEE}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe
FirewallRules: [{D9A0AB90-EBC7-4C16-A665-6F096B881132}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe
FirewallRules: [{9C4015F0-B32D-4303-AA99-F62135B41F28}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe
FirewallRules: [{DAC132DB-719F-471F-B5A2-025AE7BDFC74}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe
FirewallRules: [{E53C5284-7F45-4FE7-8CC9-4D98FF9C065A}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe
FirewallRules: [{3957DAFE-0729-439E-BBF5-55BA3258ED0B}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe
FirewallRules: [{0BEC2A67-1451-43DF-8C39-51C4CDEF6F98}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe
FirewallRules: [{F9F7830E-9080-44A8-A0DB-DD73135F3936}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe
FirewallRules: [{C0589572-D639-45B8-9ECF-ED503E1AB50D}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe
FirewallRules: [{9D3E107C-D986-487C-9FA1-7870A777110F}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe
FirewallRules: [{880727A6-817A-419D-BA72-84F2C4E38856}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe
FirewallRules: [{0B6233BF-2F4C-4F9F-AF9A-AC58A5320FAF}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe
FirewallRules: [{E96CB382-57AB-45AC-892F-B980B172646C}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3668\Agent.exe
FirewallRules: [{37062186-7962-47B0-969A-5B595262D1A2}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3668\Agent.exe
FirewallRules: [{88B999A6-8E35-4877-83B5-F69C48CBA684}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe
FirewallRules: [{9ED1C16E-3393-46A5-8DD1-B044592C28BE}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe
FirewallRules: [{228EBE8E-9061-455A-AEB5-5DA4E1B26000}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe
FirewallRules: [{FC98372C-692A-45C2-ABFE-10C934772F5C}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe
FirewallRules: [{6C5FCAD5-C25C-444B-B0C1-BCA16912212E}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3715\Agent.exe
FirewallRules: [{9C641869-008E-44DA-AFDD-1B654FF274EE}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3715\Agent.exe
FirewallRules: [{C63BEBCF-2596-4D69-8C85-4FC0C36A4A0C}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3715\Agent.exe
FirewallRules: [{6ABAA2EC-0175-4760-9756-9E39D57A7457}] => (Allow) C:\ProgramData\Battle.net\Agent\Agent.3715\Agent.exe
FirewallRules: [{261A4E3C-7F37-48AC-8FE3-49424D651F26}] => (Allow) C:\Program Files\HP\HP Officejet Pro 8610\bin\FaxApplications.exe
FirewallRules: [{58304E03-10C5-48BE-B11F-75A7D8B3AC25}] => (Allow) C:\Program Files\HP\HP Officejet Pro 8610\bin\DigitalWizards.exe
FirewallRules: [{C4088A17-0E48-4B6F-BB0A-AA7A9C51CEC7}] => (Allow) C:\Program Files\HP\HP Officejet Pro 8610\bin\SendAFax.exe
FirewallRules: [{6B648C96-B5E4-4E6D-960B-69ECC8FD9E97}] => (Allow) C:\Program Files\HP\HP Officejet Pro 8610\Bin\DeviceSetup.exe
FirewallRules: [{5B8C992B-C663-4886-8173-2105ECDEC718}] => (Allow) LPort=5357
FirewallRules: [{A626BD9E-B311-4984-AC24-75CA33EF64B6}] => (Allow) C:\Program Files\HP\HP Officejet Pro 8610\Bin\HPNetworkCommunicatorCom.exe
FirewallRules: [{AEF763A9-FCA5-46FA-A1CE-9E344A223FFB}] => (Allow) C:\Program Files (x86)\Bonjour\mDNSResponder.exe
FirewallRules: [{4D41A687-95BA-493F-B5D5-07CEAC730C6E}] => (Allow) C:\Program Files (x86)\Bonjour\mDNSResponder.exe
FirewallRules: [{E78FB013-13F3-4F17-A2D5-207242E96467}] => (Allow) C:\Program Files\iTunes\iTunes.exe
FirewallRules: [TCP Query User{763FCB84-9D3C-4609-8938-DC45A8617A53}C:\program files (x86)\ares\ares.exe] => (Allow) C:\program files (x86)\ares\ares.exe
FirewallRules: [UDP Query User{97A119BB-B40D-4687-9174-926A012241DB}C:\program files (x86)\ares\ares.exe] => (Allow) C:\program files (x86)\ares\ares.exe
FirewallRules: [{5D011A4B-7A5A-42C6-B400-F3ED0B5C159E}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{0907931D-66F7-40E4-AF0F-807AA7E6F62C}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{3A2BFE9E-0659-492E-970F-ECB17E2EFA29}] => (Allow) C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
FirewallRules: [{1BB9E020-2623-40BE-BC74-C45FE2C5799A}] => (Allow) C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
FirewallRules: [{C6198C95-CA87-40A3-88D8-CDAD067698EE}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\RollerCoaster Tycoon Deluxe\RCT.EXE
FirewallRules: [{8A48D1B6-4ABF-4A7D-94BB-A456EA476CB4}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\RollerCoaster Tycoon Deluxe\RCT.EXE
FirewallRules: [TCP Query User{5DB9B922-EA6B-4259-9795-785F83787FF3}C:\program files (x86)\amsn\bin\wish.exe] => (Allow) C:\program files (x86)\amsn\bin\wish.exe
FirewallRules: [UDP Query User{7CB73A2F-9D25-4A98-9D78-05C4A59ADF0E}C:\program files (x86)\amsn\bin\wish.exe] => (Allow) C:\program files (x86)\amsn\bin\wish.exe
FirewallRules: [{0D98918E-9C3F-42C7-8B45-6E46773FCD21}] => (Allow) C:\Program Files (x86)\Windows Live\Contacts\wlcomm.exe
FirewallRules: [{701817B2-BA2C-4CA4-AECE-D22BB57BD595}] => (Allow) LPort=2869
FirewallRules: [{8F9D9F19-36AA-4007-8D08-04B16A07FD6B}] => (Allow) LPort=1900
FirewallRules: [{51DF1EF6-1ECF-494F-AB29-63BA7446551E}] => (Allow) C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe
FirewallRules: [TCP Query User{CDBB6AB1-CBD3-428E-8FB3-0D216DF9F47D}C:\program files (x86)\heroes of the storm\versions\base39951\heroesofthestorm_x64.exe] => (Allow) C:\program files (x86)\heroes of the storm\versions\base39951\heroesofthestorm_x64.exe
FirewallRules: [UDP Query User{1F816787-3FF5-4C17-B1AA-D9243A18ADD8}C:\program files (x86)\heroes of the storm\versions\base39951\heroesofthestorm_x64.exe] => (Allow) C:\program files (x86)\heroes of the storm\versions\base39951\heroesofthestorm_x64.exe
FirewallRules: [{B366D998-4776-4F14-A824-88FD9F44DC65}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
StandardProfile\AuthorizedApplications: [C:\Program Files (x86)\Spybot - Search & Destroy 2\SDTray.exe] => Enabled:Spybot-S&D 2 Tray Icon
StandardProfile\AuthorizedApplications: [C:\Program Files (x86)\Spybot - Search & Destroy 2\SDFSSvc.exe] => Enabled:Spybot-S&D 2 Scanner Service
StandardProfile\AuthorizedApplications: [C:\Program Files (x86)\Spybot - Search & Destroy 2\SDUpdate.exe] => Enabled:Spybot-S&D 2 Updater
StandardProfile\AuthorizedApplications: [C:\Program Files (x86)\Spybot - Search & Destroy 2\SDUpdSvc.exe] => Enabled:Spybot-S&D 2 Background update service
==================== Restore Points =========================
20-06-2016 15:41:03 JRT Pre-Junkware Removal
==================== Faulty Device Manager Devices =============
==================== Event log errors: =========================
Application errors:
Error: (06/21/2016 10:41:07 PM) (Source: WinMgmt) (EventID: 10) (User: )
Description: //./root/CIMV2SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 990x80041003
Error: (06/21/2016 10:36:57 PM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (06/21/2016 10:06:53 PM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (06/21/2016 10:01:07 PM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (06/21/2016 08:21:37 AM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (06/21/2016 08:12:36 AM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (06/20/2016 09:08:55 PM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (06/20/2016 09:03:42 PM) (Source: MsiInstaller) (EventID: 11719) (User: user-PC)
Description: Application: Kaspersky Internet Security -- Error 1719. Windows Installer service could not be accessed. Contact Technical Support to verify that it is properly registered and enabled.
Error: (06/20/2016 09:00:44 PM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (06/20/2016 04:19:20 PM) (Source: WinMgmt) (EventID: 10) (User: )
System errors:
Error: (06/21/2016 10:43:53 PM) (Source: BROWSER) (EventID: 8032) (User: )
Description: The browser service has failed to retrieve the backup list too many times on transport \Device\NetBT_Tcpip_{FBB86E63-9DC1-4F0D-8771-C2CEE0BC029E}.
The backup browser is stopping.
Error: (06/21/2016 10:38:15 PM) (Source: Service Control Manager) (EventID: 7001) (User: )
Description: The Computer Browser service depends on the Server service which failed to start because of the following error:
%%1068 = The dependency service or group failed to start.
Error: (06/21/2016 10:36:07 PM) (Source: Service Control Manager) (EventID: 7001) (User: )
Error: (06/21/2016 10:36:05 PM) (Source: Service Control Manager) (EventID: 7001) (User: )
CodeIntegrity:
Date: 2016-02-16 00:30:37.003
Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume2\Program Files\Sound+\SoundP.dll because the set of per-page image hashes could not be found on the system.
Date: 2016-02-16 00:30:36.907
Date: 2016-02-16 00:28:16.879
Date: 2016-02-16 00:28:16.778
Date: 2016-02-16 00:25:07.804
Date: 2016-02-16 00:25:07.712
Date: 2016-02-16 00:22:31.560
Date: 2016-02-16 00:22:31.467
Date: 2016-02-16 00:22:19.403
Date: 2016-02-16 00:22:19.301
==================== Memory info ===========================
Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
Percentage of memory in use: 26%
Total physical RAM: 6058.17 MB
Available physical RAM: 4459.51 MB
Total Virtual: 12114.53 MB
Available Virtual: 10494.26 MB
==================== Drives ================================
Drive c: () (Fixed) (Total:654.69 GB) (Free:107.52 GB) NTFS
Drive d: (LENOVO) (Fixed) (Total:29 GB) (Free:26.62 GB) NTFS
==================== MBR & Partition Table ==================
Disk: 0 (MBR Code: Windows 7 or 8) (Size: 698.6 GB) (Disk ID: 35DDCDB7)
Partition 1: (Active) - (Size=200 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=654.7 GB) - (Type=07 NTFS)
Partition 3: (Not Active) - (Size=29 GB) - (Type=OF Extended)
Partition 4: (Not Active) - (Size=14.7 GB) - (Type=12)
==================== End of Addition.txt ============================
alewiina
Posts Posts : 66
Joined Joined : 2011-10-23
OS OS : Windows 7 64 bit
Points Points : 19483
Re: Internet browsers and internet refusing to work, think its a hardware problem?
Post by Superdave on 22nd June 2016, 10:11 pm
You should turn on Windows Defender. It is free protection. Search and Destroy is obsolete and should be removed.
Internet Explorer's security is based upon a set of zones. Each zone has different security in terms of what scripts and applications can be run from a site that is in that zone. There is a security zone called the Trusted Zone. This zone has the lowest security and allows scripts and applications from sites in this zone to run without your knowledge. It is therefore a popular setting for malware sites to use so that future infections can be easily done on your computer without your knowledge as these sites will be in the Trusted Zone. Therefore, I recommend that nothing be allowed in the trusted zone. If you agree, please do the following.
In Internet Explores select Tools, Internet Options, Security Tab and select Trusted Zones and select Sites. You can remove each trusted zone there.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83201
Post by alewiina on 22nd June 2016, 11:58 pm
Okay, Windows Defender wouldn't let me turn it back on but I figured out how, so its back on now. I also uninstalled Spybot S&D.
I also changed those things in IE.
Now what? Smile
alewiina
Posts Posts : 66
Post by Superdave on 23rd June 2016, 12:22 am
I wonder if it has anything to do with this message on FBR: Internet Explorer Version 11 (Default browser not detected!)
Captain
Captain
Posts Posts : 4202
Post by alewiina on 23rd June 2016, 12:53 am
Hm. I don't know. Firefox was my default but I uninstalled that after teh problems started
alewiina
Posts Posts : 66
Post by alewiina on 23rd June 2016, 1:01 am
Are there any options left? I'm feeling so frustrated at this point. I don't want to lose this computer ;_;
alewiina
Posts Posts : 66
Post by Superdave on 23rd June 2016, 1:12 am
Do you still have that yellow warning icon in Device Manager? Is it still yellow when you boot in Safe Mode?
Captain
Captain
Posts Posts : 4202
Post by alewiina on 23rd June 2016, 1:36 am
No yellow warnings. Everything looks fine in device manager.
alewiina
Posts Posts : 66
Post by Superdave on 23rd June 2016, 1:48 am
I'm stumped. We cleared the host files and the Trusted zones. One log shows that it is connected but I don't understand why it won't work in Normal Mode. It could have something to do with that problem of something sticking up into the computer.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 24th June 2016, 3:52 am
Could wiping the computer/resetting it to defaults help? Could a driver or something not showing up be affecting it?
alewiina
Posts Posts : 66
Post by alewiina on 24th June 2016, 4:54 am
So, I've just made an incredibly weird discovery. Internet works in Chrome (in normal mode!!) if I Run as Administrator. I don't get it.
And services needing the internet don't work still, like Yahoo Messenger. I guess because its not run as admin?
Any ideas why that would be, and what could fix it?
alewiina
Posts Posts : 66
Post by Superdave on 24th June 2016, 6:47 pm
I noticed that in the FBR scan.
Any ideas why that would be, and what could fix it?.
I've run out of ideas. The problem may be with the accounts. You should try to get that sorted out.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 24th June 2016, 9:18 pm
Well, I only have one account, and its set as administrator
alewiina
Posts Posts : 66
Post by Superdave on 24th June 2016, 10:23 pm
According to this there is more than one account.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 26th June 2016, 3:53 am
I don't understand why it would say that, there's literally just my account. This is a screenshot from the account page:
alewiina
Posts Posts : 66
Post by Superdave on 26th June 2016, 6:02 pm
It says the adm. account is disabled. Can you verify if this account is working?
Captain
Captain
Posts Posts : 4202
Post by alewiina on 26th June 2016, 7:19 pm
The Dani account is the account I see or ever use. I thought that was the admin account? Its the one I've been using this whole time
alewiina
Posts Posts : 66
Post by alewiina on 26th June 2016, 7:20 pm
*the only account
alewiina
Posts Posts : 66
Post by Superdave on 26th June 2016, 10:57 pm
Ok, it shows the adm account is disabled. Could try creating a new guest account to see if it disabled or enabled. You can alway delete the guest account later.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 26th June 2016, 11:33 pm
How do I create another guest account? Or do you mean just another account in general? Set as standard, or admin?
alewiina
Posts Posts : 66
Post by Superdave on 27th June 2016, 12:34 am
Set it as standard.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 27th June 2016, 2:50 am
Okay, and sorry but I'm not sure what I'm checking by doing this? Am I just looking to see if another account shows up?
alewiina
Posts Posts : 66
Post by alewiina on 27th June 2016, 5:25 am
Okay so I managed to find and reactivate the disabled Administrator account. But now I have no idea what to do. When I go into manage accounts on the Admin account, there's nothing about internet settings on my other account. I would just use the admin account but all my docs/pics/other stuff is on the Dani account...
alewiina
Posts Posts : 66
Post by Superdave on 27th June 2016, 6:47 pm
Ok, the Dani account is the Adm. account and it is now enabled. I just thought that this was the reason why your internet was not working. I've run out of ideas.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 28th June 2016, 3:40 am
Alright. At this point I'm saving everything onto an external hard drive in preparation to wipe the damn laptop and hope that fixes any messed up settings. Do you think I should do that?
Also how exactly do I restore to factory settings? Its been a while since I wiped anything.
alewiina
Posts Posts : 66
Post by Superdave on 28th June 2016, 6:28 pm
Do you have the Windows 7 disk(s)? If not, do you have recovery disks? If not, you must have the Recovery on a separate drive on your computer. Look for the D drive. Before you do anything else you should get that problem you had with something sticking up inside the bottom of the laptop looked at.
Captain
Captain
Posts Posts : 4202
Post by alewiina on 28th June 2016, 8:19 pm
There's no longer anything there.  I removed the piece that was sticking up and there was no damage underneath, thankfully.
I don't have the discs, I was never given any when I bought my laptop.
alewiina
Posts Posts : 66
Post by Superdave on 28th June 2016, 10:49 pm
In that case the Recovery must be on your hard drive in a separate partition probably D:
Captain
Captain
Posts Posts : 4202
Post by alewiina on 29th June 2016, 3:33 am
So, I can't find a recovery partition.  My D: drive doesn't have one.  When I attempt the "Repair Your Computer" on the F8 boot screen, there doesn't seem to be any kind of option for me to restore to factory settings.  The "recover an image" part keeps asking for a backup disc or to find an image from the server, but I don't know what that means.  When I wiped my desktop a while back it had a partition
Edit: Nevermind, Lenovo has a built in recovery program thing. Trying it now.
alewiina
Posts Posts : 66
Post by alewiina on 29th June 2016, 6:25 am
So, I successfully restored the laptop to factory state, and everything seems to be working again. I have no idea what was wrong. o_O
alewiina
Posts Posts : 66
Post by Superdave on 29th June 2016, 6:32 pm
I'm glad everything worked out for you.
Captain
Captain
Posts Posts : 4202
Page 1 of 2 1, 2  Next
