Problems with laptop
Post by katjari on Tue 29 Dec 2015, 9:22 am
Hello! I've been having some problems with laptop lately. Yesterday, it wouldn't load youtube videos, "the blue screen of death" would appear, saying the device driver got stuck in an infinite loop, this indicates problem with the device itself or the device driver programming. Some people suggested updating drivers, so I downloaded from Dell web page driver r228489 for Dell Inspiron and it worked fine, but today I couldn't load Mozilla saying it was removed or deleted, although I didn't do any of that. Eventually I managed to load Mozilla, but it's acting really weird. Thank you in advance for your help.
katjari
Operating System : windows xp home
Re: Problems with laptop
Post by Superdave on Wed 30 Dec 2015, 2:51 am
Link 1
Link 2
Tech Staff
Tech Staff
Post by katjari on Wed 30 Dec 2015, 11:30 am
Here are the logs:
# AdwCleaner v5.026 - Logfile created 29/12/2015 at 23:50:00
# Updated 21/12/2015 by Xplode
# Database : 2015-12-29.1 [Server]
# Operating system : Windows 7 Home Premium Service Pack 1 (x64)
# Username : SandraKatja - SANDRAKATJA-PC
# Running from : C:\Users\SandraKatja\Downloads\adwcleaner_5.026.exe
# Option : Cleaning
# Support : [You must be registered and logged in to see this link.]
***** [ Services ] *****
[-] Service Deleted : vToolbarUpdater40.2.4
***** [ Folders ] *****
[-] Folder Deleted : C:\Program Files (x86)\Common Files\AVG Secure Search
[-] Folder Deleted : C:\Program Files\Common Files\AVG Secure Search
[-] Folder Deleted : C:\ProgramData\AVG Secure Search
[-] Folder Deleted : C:\ProgramData\AVG Security Toolbar
***** [ Files ] *****
[-] File Deleted : C:\Users\SandraKatja\AppData\Roaming\Mozilla\Firefox\Profiles\8oc92gcr.default-1437511943371\Extensions\Avg@toolbar.xpi
[-] File Deleted : C:\Users\SandraKatja\AppData\Roaming\Mozilla\Firefox\Profiles\8oc92gcr.default-1437511943371\searchplugins\avg-secure-search.xml
***** [ DLLs ] *****
***** [ Shortcuts ] *****
***** [ Scheduled tasks ] *****
***** [ Registry ] *****
[-] Key Deleted : HKLM\SOFTWARE\Classes\S
[-] Key Deleted : HKLM\SOFTWARE\Classes\ScriptHelper.ScriptHelperApi
[-] Key Deleted : HKLM\SOFTWARE\Classes\ScriptHelper.ScriptHelperApi.1
[-] Value Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [vProt]
[-] Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@avg.com/AVG SiteSafety plugin,version=11.0.0.1,application/x-avg-sitesafety-plugin
[-] Key Deleted : HKLM\SOFTWARE\Google\Chrome\NativeMessagingHosts\avgsh
[-] Key Deleted : HKCU\Software\Classes\CLSID\{1BBF13E0-551E-42DD-91F4-1A547443FFDA}
[-] Key Deleted : HKCU\Software\Classes\CLSID\{3A1209A4-8568-40F0-9B5E-4A06A2A06417}
[-] Key Deleted : HKCU\Software\Classes\CLSID\{31264A33-A653-46C4-AF49-1232C59A7DA5}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{933B95E2-E7B7-4AD9-B952-7AC336682AE3}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{95B7759C-8C7F-4BF1-B163-73684A933233}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{B2BC04DF-EFBD-409A-95CA-36874E5AB92A}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{CA3A5461-96B5-46DD-9341-5350D3C94615}
[-] Key Deleted : HKLM\SOFTWARE\Classes\Interface\{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
[-] Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{C2AC8A0E-E48E-484B-A71C-C7A937FAAB94}
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{95B7759C-8C7F-4BF1-B163-73684A933233}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{95B7759C-8C7F-4BF1-B163-73684A933233}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{B2BC04DF-EFBD-409A-95CA-36874E5AB92A}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{95B7759C-8C7F-4BF1-B163-73684A933233}
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{B2BC04DF-EFBD-409A-95CA-36874E5AB92A}
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B2BC04DF-EFBD-409A-95CA-36874E5AB92A}
[-] Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
[-] Key Deleted : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B2BC04DF-EFBD-409A-95CA-36874E5AB92A}
[-] Key Deleted : HKCU\Software\Conduit
[-] Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{95B7759C-8C7F-4BF1-B163-73684A933233}
***** [ Web browsers ] *****
:: "Tracing" keys removed
:: Winsock settings cleared
########## EOF - C:\AdwCleaner\AdwCleaner[C2].txt - [3652 bytes] ##########
Scan Date: 29.12.2015.
Scan Time: 23:59
Logfile: malvarebytes log.txt
Administrator: Yes
Version: 2.2.0.1024
Malware Database: v2015.12.29.06
Rootkit Database: v2015.12.26.01
License: Trial
Malware Protection: Enabled
Malicious Website Protection: Enabled
Self-protection: Disabled
OS: Windows 7 Service Pack 1
CPU: x64
File System: NTFS
User: SandraKatja
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 410157
Time Elapsed: 44 min, 16 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 0
Folders: 0
Files: 0
Physical Sectors: 0
(end)
Junkware Removal Tool (JRT) by Malwarebytes
Version: 8.0.1 (11.24.2015)
Operating System: Windows 7 Home Premium x64
Ran by SandraKatja (Administrator) on sri 30.12.2015. at 1:00:52,97
File System: 3
Successfully deleted: C:\Windows\SysWOW64\REN2432.tmp (File)
Successfully deleted: C:\Windows\SysWOW64\REN8AD2.tmp (File)
Successfully deleted: C:\Windows\SysWOW64\REN8AD3.tmp (File)
Registry: 3
Successfully deleted: HKCU\Software\Microsoft\Internet Explorer\Main\\Start Page (Registry Value)
Successfully deleted: HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AF69DE43-7D58-4638-B6FA-CE66B5AD205D} (Registry Key)
Successfully deleted: HKLM\Software\Microsoft\Internet Explorer\Main\\Start Page (Registry Value)
Scan was completed on sri 30.12.2015. at 1:04:38,63
End of JRT log
Results of screen317's Security Check version 1.009
Windows 7 Service Pack 1 x64 (UAC is enabled)
Internet Explorer 11
Windows Firewall Enabled!
Windows Firewall Disabled!
AVG AntiVirus Free Edition
Antivirus up to date! (On Access scanning disabled!)
AVG Web TuneUp
CCleaner
Java 8 Update 66
Java version 32-bit out of Date!
Adobe Flash Player 20.0.0.235
Adobe Reader XI
Mozilla Firefox (43.0.3)
Total Fragmentation on Drive C: 5%
Thank you for your help.
katjari
Post by Superdave on Wed 30 Dec 2015, 1:55 pm
Update Your Java (JRE)
First Verify your Java Version
If your version is out of date install the newest version of the Sun Java Runtime Environment.
Remove any old versions
1. Download JavaRa and unzip the file to your Desktop.
3. Once complete exit JavaRA.
Additional Note: The Java Quick Starter (JQS.exe) adds a service to improve the initial startup time of Java applets and applications. To disable the JQS service if you don't want to use it, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and reboot your computer.
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by katjari on Sun 03 Jan 2016, 1:41 am
Hi, I wish you a happy new year and thank you for your help. A removed old versions of Java with JavaRa and here is the ESET log file:
all ok
# product=EOS
# version=8
# EOSSerial=130c6992a9872a4a8b056c87029c10ba
# end=init
# utc_time=2016-01-01 09:39:59
# local_time=2016-01-01 10:39:59 (+0100, Central European Standard Time)
# country="Croatia"
# osver=6.1.7601 NT Service Pack 1
all ok
# product=EOS
# version=8
# end=init
# utc_time=2016-01-01 09:44:57
# local_time=2016-01-01 10:44:57 (+0100, Central European Standard Time)
# country="Croatia"
Update Init
Update Download
Update Finalize
Updated modules version: 27453
# product=EOS
# version=8
# end=updated
# utc_time=2016-01-01 09:50:13
# local_time=2016-01-01 10:50:13 (+0100, Central European Standard Time)
# country="Croatia"
# product=EOS
# version=8
# OnlineScanner.ocx=1.0.0.7777
# api_version=3.1.1
# engine=27453
# end=stopped
# remove_checked=false
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2016-01-02 12:09:48
# local_time=2016-01-02 01:09:48 (+0100, Central European Standard Time)
# country="Croatia"
# lang=1033
# compatibility_mode_1='AVG AntiVirus Free Edition'
# compatibility_mode=1057 16777213 100 100 444131 3045636 0 0
# compatibility_mode_1=''
# compatibility_mode=5893 16776574 100 94 14518621 203323238 0 0
# scanned=253195
# found=0
# cleaned=0
# scan_time=8375
all ok
# product=EOS
# version=8
# end=init
# utc_time=2016-01-02 11:09:48
# local_time=2016-01-02 12:09:48 (+0100, Central European Standard Time)
# country="Croatia"
Update Init
Update Download
Update Finalize
Updated modules version: 27459
# product=EOS
# version=8
# end=updated
# utc_time=2016-01-02 11:10:39
# local_time=2016-01-02 12:10:39 (+0100, Central European Standard Time)
# country="Croatia"
# product=EOS
# version=8
# api_version=3.1.1
# engine=27459
# end=finished
# remove_checked=true
# utc_time=2016-01-02 02:00:05
# local_time=2016-01-02 03:00:05 (+0100, Central European Standard Time)
# country="Croatia"
# lang=1033
# compatibility_mode=1057 16777213 100 100 497548 3095453 0 0
# compatibility_mode=5893 16776574 100 94 14568438 203373055 0 0
# scanned=294953
# found=0
# cleaned=0
# scan_time=10165
katjari
Post by Superdave on Sun 03 Jan 2016, 4:39 am
Happy New Year. How's your computer working now?
Tech Staff
Tech Staff
Post by katjari on Tue 05 Jan 2016, 8:47 am
It's working really well, thank you so much for your help
katjari
Post by Superdave on Wed 06 Jan 2016, 2:28 am
This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
This is a very crucial step so make sure you don't skip it.
Download DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
Double-click Delfix.exe to start the tool.
Make sure the following items are checked:
  • Activate UAC (optional; some users prefer to keep it off)
  • Remove disinfection tools
  • Create Registry backup
  • Purge System Restore Points
  • Re-set system settings
Now click "Run" and wait patiently.
Once finished a logfile will be created. You don't have to attach it to your next reply.
Safe Surfing!
Tech Staff
Tech Staff
Post by Sponsored content Today at 7:46 am
