Erratic and unreliable system
Post by demoncurrie on Wed 02 Dec 2015, 5:30 am
Hi, I need your help again. My PC has become unreliable:
- crashing intermittently
- operating very slowly
- Failing to boot sometimes.
- recently my McAfee firewall protection got re-set to OFF.
When it crashes, it sometimes goes to a dump screen (with "System service Exception" info posted). Sometimes, it just goes blank.
Failure to boot can get partially through the boot sequence, and then just hang.
I have run Windows Update, Ccleaner, Spybot, Malwarebytes, and McAfee. But the problem persists. Could it be a hardware fault? Or is it malware?
demoncurrie
Rookie Surfer
Rookie Surfer
Operating System : Windows XP Home
Re: Erratic and unreliable system
Post by Superdave on Wed 02 Dec 2015, 10:53 am
It sounds like a hardware problem but let's run some scans to make sure it's clean then we'll go from there.
Link 1
Link 2
Tech Staff
Tech Staff
Post by demoncurrie on Wed 02 Dec 2015, 8:18 pm
Thanks.
The ADW results:
# AdwCleaner v5.023 - Logfile created 02/12/2015 at 00:54:17
# Updated 30/11/2015 by Xplode
# Database : 2015-11-30.1 [Server]
# Operating system : Windows 7 Professional Service Pack 1 (x64)
# Username : User - WIN7
# Running from : C:\Users\User\Desktop\adwcleaner_5.023.exe
# Option : Cleaning
# Support : [You must be registered and logged in to see this link.]
***** [ Services ] *****
***** [ Folders ] *****
[-] Folder Deleted : C:\Program Files (x86)\Yahoo!\Companion
[-] Folder Deleted : C:\ProgramData\Yahoo! Companion
[-] Folder Deleted : C:\Users\User\AppData\Roaming\Yahoo!\Companion
***** [ Files ] *****
***** [ DLLs ] *****
***** [ Shortcuts ] *****
***** [ Scheduled tasks ] *****
***** [ Registry ] *****
[-] Key Deleted : HKLM\SOFTWARE\Classes\AppID\YMERemote.DLL
[-] Key Deleted : HKLM\SOFTWARE\Classes\YBrowserToolbar.YBrowserToolbar.1
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{81017EA9-9AA8-4A6A-9734-7AF40E7D593F}
[-] Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{FDAD4DA1-61A2-4FD8-9C17-86F7AC245081}
[-] Key Deleted : HKLM\SOFTWARE\Classes\Interface\{8233093C-178B-484B-979E-3C6B5B147DBC}
[-] Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{B722ED8B-0B38-408E-BB89-260C73BCF3D4}
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{FDAD4DA1-61A2-4FD8-9C17-86F7AC245081}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{FDAD4DA1-61A2-4FD8-9C17-86F7AC245081}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
[-] Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{FDAD4DA1-61A2-4FD8-9C17-86F7AC245081}
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
[-] Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
[-] Value Deleted : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
[-] Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{8233093C-178B-484B-979E-3C6B5B147DBC}
[-] Key Deleted : HKCU\Software\Yahoo\Companion
[-] Key Deleted : HKCU\Software\Yahoo\YFriendsBar
[-] Key Deleted : HKCU\Software\AppDataLow\Software\Yahoo\Companion
[-] Key Deleted : HKLM\SOFTWARE\Yahoo\Companion
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Yahoo! Toolbar
[-] Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Yahoo! Companion
***** [ Web browsers ] *****
[-] [C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\Web Data] [Search Provider] Deleted : uk.ask.com
[-] [C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\Secure Preferences] [Extension] Deleted : bmkckgpgekmanipelfidlhmkfcjicion
:: "Tracing" keys removed
:: Winsock settings cleared
########## EOF - C:\AdwCleaner\AdwCleaner[C1].txt - [3786 bytes] ##########
The malware bytes results:
Scan Date: 02/12/2015
Scan Time: 01:14
Logfile: malwarebytes results.txt
Administrator: Yes
Version: 2.2.0.1024
Malware Database: v2015.12.01.07
Rootkit Database: v2015.11.26.01
License: Free
Malware Protection: Disabled
Malicious Website Protection: Disabled
Self-protection: Disabled
OS: Windows 7 Service Pack 1
CPU: x64
File System: NTFS
User: User
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 332497
Time Elapsed: 13 min, 15 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0.
The JUNKWARE results:
Junkware Removal Tool (JRT) by Malwarebytes
Version: 8.0.1 (11.24.2015)
Operating System: Windows 7 Professional x64
Ran by User (Administrator) on 02/12/2015 at 8:57:10.48
File System: 1
Successfully deleted: C:\Windows\wininit.ini (File)
Registry: 1
Successfully deleted: HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{5D13E62F-F64C-440B-88A3-B69CC3013B33} (Registry Key)
Scan was completed on 02/12/2015 at 9:02:08.03
End of JRT log
The SECURITYCHECK results:
Results of screen317's Security Check version 1.009
Windows 7 Service Pack 1 x64 (UAC is enabled)
Internet Explorer 11
Windows Firewall Enabled!
Microsoft Security Essentials
McAfee Anti-Virus and Anti-Spyware
(On Access scanning disabled!)
Error obtaining update status for antivirus!
MVPS Hosts File
Spybot - Search & Destroy
Java 7 Update 51
Java 8 Update 31
Java version 32-bit out of Date!
Google Chrome (46.0.2490.80)
Google Chrome (46.0.2490.86)
Microsoft Security Essentials MSMpEng.exe
Microsoft Security Essentials msseces.exe
Spybot Teatimer.exe is disabled!
Total Fragmentation on Drive C: 2%
NB I had re-enabled my Firewall and Realtime scanning, prior to SECURITY CHECK. So are the McAfee results in securitycheck Nnot surprising?
demoncurrie
Rookie Surfer
Rookie Surfer
Post by Superdave on Thu 03 Dec 2015, 9:54 am
Spybot is obsolete. You can uninstall it.
The log shows that you have McAfee disabled. If you paid for this program you should enable the on-access scanning and uninstall MSE. If it's outdated and you no longer intend to pay for another year, you should uninstall McAfee.
Update Your Java (JRE)
First Verify your Java Version
If your version is out of date install the newest version of the Sun Java Runtime Environment.
Remove any old versions
1. Download JavaRa and unzip the file to your Desktop.
3. Once complete exit JavaRA.
Additional Note: The Java Quick Starter (JQS.exe) adds a service to improve the initial startup time of Java applets and applications. To disable the JQS service if you don't want to use it, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and reboot your computer.
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by demoncurrie on Wed 09 Dec 2015, 10:41 pm
Apologies. I had thought I had posted a reply to this last post.
I enabled McAfee more fully, and updated JRE.
ESET ran and found zero problems. I couldn't see a log.
At this point, the system started randomly crashing too frequently to be able to access and use my PC. So I put it into a repairer to check h/w etc. They sorted it, allegedly by running DSKCHK, SFC and RAMCHK. They also installed and presumably ran SEATOOLS. The system now is working ok, although the keyboard appears to have difficulty to keep up with my (amateur speed) typing. I can appreciate that this interferes with the logical flow of your investigations.
So, three questions:
- Chrome was reported as not supporting Java NPAPI - should I not use Chrome?
- Do we stop and re-start if problems re-appers?
- if we stop how do I uninstall tidy up "your" downloaded programmes?
demoncurrie
Rookie Surfer
Rookie Surfer
Post by Superdave on Thu 10 Dec 2015, 3:56 am
Does it give the option of supporting Java? Does it affect the function of Chrome?
Yes.
if we stop how do I uninstall tidy up "your" downloaded programmes?.
This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
This is a very crucial step so make sure you don't skip it.
Download DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
Double-click Delfix.exe to start the tool.
Make sure the following items are checked:
  • Activate UAC (optional; some users prefer to keep it off)
  • Remove disinfection tools
  • Create Registry backup
  • Purge System Restore Points
  • Re-set system settings
Now click "Run" and wait patiently.
Once finished a logfile will be created. You don't have to attach it to your next reply.
Safe Surfing!
Tech Staff
Tech Staff
Post by demoncurrie on Fri 11 Dec 2015, 3:38 am
OK, thanks, have followed up on these links. Please close this issue.
demoncurrie
Rookie Surfer
Rookie Surfer
Post by Sponsored content Today at 4:12 pm
