CPU using 100% on start up and intermittently
Post by Magnern on Fri 13 Nov 2015, 9:13 am
Moved from operating systems
Post by Magnern on Wed 11 Nov 2015, 8:11 am
HP ProBook 6475b labtop
Win7 Pro
8GB ram
AMD A6-4400M APU w/radeon HD graphics
Online Armor Firewall (free)
Microsoft Security Essentials
When the desktop loads something in the background is eating 100% of the CPU and there is nothing in the task manager that is showing up using that much. If I add up the usage of the programs listed it is like maybe 10%. So there must be something hiding.
If someone could advise me on how to start looking for it that would be great! Thank you for reading!
-Magnern
Magnern
Operating System : Windows 7 Professional 64-bit
Re: CPU using 100% on start up and intermittently
Post by Superdave on Fri 13 Nov 2015, 12:50 pm
Link 1
Link 2
Tech Staff
Tech Staff
Post by Magnern on Mon 16 Nov 2015, 10:21 am
Thank you for replying! I will run the scans tomorrow while I am at school and get back to you.
Just and FYI the computer force-updated itself and a lot of the problem has been alleviated but I still have a lot of issues on start up. I am still sure there is something lurking and will post the logs tomorrow.
Magnern
Post by Magnern on Sat 21 Nov 2015, 5:25 am
Junkware Removal Tool (JRT) by Malwarebytes
Version: 8.0.0 (11.12.2015)
Operating System: Windows 7 Professional x64
Ran by V (Administrator) on Thu 11/19/2015 at 15:47:48.07
File System: 1
Successfully deleted: C:\Users\V\AppData\Roaming\Mozilla\Firefox\Profiles\kkfusthh.default\user.js (File)
Registry: 2
Successfully deleted: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{2fa28606-de77-4029-af96-b231e3b8f827} (Registry Key)
Successfully deleted: HKLM\Software\Microsoft\Internet Explorer\SearchScopes\{2fa28606-de77-4029-af96-b231e3b8f827} (Registry Key)
Scan was completed on Thu 11/19/2015 at 16:05:51.82
End of JRT log
Scan Date: 11/10/2015
Scan Time: 2:31 PM
Logfile: Malwarebytes log.txt
Administrator: Yes
Version: 2.2.0.1024
Malware Database: v2015.11.10.07
Rootkit Database: v2015.11.04.02
License: Free
Malware Protection: Disabled
Malicious Website Protection: Disabled
Self-protection: Disabled
OS: Windows 7 Service Pack 1
CPU: x64
File System: NTFS
User: V
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 337025
Time Elapsed: 20 min, 41 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
Modules: 0
Registry Keys: 4
PUP.Optional.InstallCore, HKLM\SOFTWARE\WOW6432NODE\InstallCore, Quarantined, [035c205c0e7dc07661025620ec174cb4],
PUP.Optional.Astromenda, HKU\S-1-5-21-639823073-3137791329-2892488224-1001\SOFTWARE\astromenda, Quarantined, [16498bf19dee9f97058b29320cf7936d],
PUP.Optional.InstallCore, HKU\S-1-5-21-639823073-3137791329-2892488224-1001\SOFTWARE\InstallCore, Quarantined, [3d222e4e96f57db9d78b690d50b332ce],
PUP.Optional.Astromenda, HKLM\SOFTWARE\WOW6432NODE\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\Astromenda, Quarantined, [98c7b8c4e0ab78be29005ef16c963ac6],
Registry Values: 0
Registry Data: 0
Folders: 2
PUP.Optional.Astromenda, C:\Program Files (x86)\Astromenda, Quarantined, [98c7b8c4e0ab78be29005ef16c963ac6],
PUP.Optional.Astromenda, C:\Program Files (x86)\Astromenda\bh, Quarantined, [98c7b8c4e0ab78be29005ef16c963ac6],
Files: 5
PUP.Optional.Astromenda, C:\Users\V\AppData\Roaming\Mozilla\Firefox\Profiles\kkfusthh.default\searchplugins\Astromenda.xml, Quarantined, [bba44f2db9d2c6703477f899ff03b14f],
PUP.Optional.Astromenda, C:\Program Files (x86)\Astromenda\FavIcon.ico, Quarantined, [98c7b8c4e0ab78be29005ef16c963ac6],
PUP.Optional.Astromenda, C:\Program Files (x86)\Astromenda\Sqlite3.dll, Quarantined, [98c7b8c4e0ab78be29005ef16c963ac6],
PUP.Optional.Astromenda, C:\Program Files (x86)\Astromenda\uninst.dat, Quarantined, [98c7b8c4e0ab78be29005ef16c963ac6],
PUP.Optional.Astromenda, C:\Program Files (x86)\Astromenda\uninstall.exe, Quarantined, [98c7b8c4e0ab78be29005ef16c963ac6],
Physical Sectors: 0
(end)
# AdwCleaner v5.021 - Logfile created 19/11/2015 at 15:41:59
# Updated 14/11/2015 by Xplode
# Database : 2015-11-19.3 [Server]
# Operating system : Windows 7 Professional Service Pack 1 (x64)
# Username : V - V-HP
# Running from : C:\Users\V\Downloads\adwcleaner_5.021.exe
# Option : Scan
# Support : [You must be registered and logged in to see this link.]
***** [ Services ] *****
***** [ Folders ] *****
***** [ Files ] *****
File Found : C:\Users\V\AppData\Roaming\Mozilla\Firefox\Profiles\kkfusthh.default\user.js
***** [ DLL ] *****
***** [ Shortcuts ] *****
***** [ Scheduled tasks ] *****
***** [ Registry ] *****
Key Found : HKLM\SOFTWARE\Classes\AppID\{9CB2CD61-FFA0-406C-9D2D-8FDE6F4A4D8A}
Key Found : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{2fa28606-de77-4029-af96-b231e3b8f827}
Key Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{2fa28606-de77-4029-af96-b231e3b8f827}
***** [ Web browsers ] *****
[C:\Users\V\AppData\Local\Google\Chrome\User Data\Default\Web data] [Search Provider] Found : aol.com
[C:\Users\V\AppData\Local\Google\Chrome\User Data\Default\Web data] [Search Provider] Found : ask.com
[C:\Users\V\AppData\Local\Google\Chrome\User Data\Default\Web data] [Search Provider] Found : Astromenda.com
########## EOF - C:\AdwCleaner\AdwCleaner[S2].txt - [1279 bytes] ##########
Magnern
Post by Superdave on Sat 21 Nov 2015, 5:44 am
Please run AdwCleaner again and hit the delete button after the scan. I would also like to see the MBAM log.
Tech Staff
Tech Staff
Post by Magnern on Tue 24 Nov 2015, 9:52 am
2015/11/23 14:57:09 -0600
mbam-log-2015-11-23 (14-56-52).xml
yes
V-HP
10.166.32.36
x64
V
NTFS
threat
completed
339137
0
0
0
0
0
0
0
0
enabled
enabled
enabled
enabled
disabled
disabled
enabled
enabled
enabled
Results of screen317's Security Check version 1.009
Windows 7 Service Pack 1 x64 (UAC is enabled)
Internet Explorer 11
Windows Firewall Disabled!
Antivirus up to date!
Java 8 Update 31
Java version 32-bit out of Date!
Adobe Flash Player 19.0.0.245
Mozilla Firefox (42.0)
Microsoft Security Essentials MSMpEng.exe
Tall Emu Online Armor OAcat.exe
Tall Emu Online Armor oasrv.exe
Tall Emu Online Armor oaui.exe
Tall Emu Online Armor OAhlp.exe
Total Fragmentation on Drive C: 2%
# AdwCleaner v5.022 - Logfile created 23/11/2015 at 16:38:24
# Updated 22/11/2015 by Xplode
# Database : 2015-11-22.2 [Server]
# Running from : C:\Users\V\Downloads\adwcleaner_5.022.exe
# Option : Cleaning
***** [ DLLs ] *****
[-] Key Deleted : HKLM\SOFTWARE\Classes\AppID\{9CB2CD61-FFA0-406C-9D2D-8FDE6F4A4D8A}
[-] [C:\Users\V\AppData\Local\Google\Chrome\User Data\Default\Web Data] [Search Provider] Deleted : aol.com
[-] [C:\Users\V\AppData\Local\Google\Chrome\User Data\Default\Web Data] [Search Provider] Deleted : ask.com
[-] [C:\Users\V\AppData\Local\Google\Chrome\User Data\Default\Web Data] [Search Provider] Deleted : Astromenda.com
:: "Tracing" keys removed
:: Winsock settings cleared
########## EOF - C:\AdwCleaner\AdwCleaner[C1].txt - [1090 bytes] ##########
Magnern
Post by Magnern on Tue 24 Nov 2015, 9:53 am
I hope I got it right >_<
Magnern
Post by Superdave on Tue 24 Nov 2015, 10:17 am
You really should turn on your Windows Firewall.
The MBAM log is incorrect. Please follow the instructions and run it again.
Update Your Java (JRE)
First Verify your Java Version
If your version is out of date install the newest version of the Sun Java Runtime Environment.
Remove any old versions
1. Download JavaRa and unzip the file to your Desktop.
3. Once complete exit JavaRA.
Additional Note: The Java Quick Starter (JQS.exe) adds a service to improve the initial startup time of Java applets and applications. To disable the JQS service if you don't want to use it, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and reboot your computer.
Tech Staff
Tech Staff
Post by Magnern on Wed 25 Nov 2015, 8:17 am
Superdave wrote:[color=green]You really should turn on your Windows Firewall.
I'm using online armor from tall emu as a firewall. I was under the impression that this was superior to windows firewall.
Ok I will re-do the MBAM log
Magnern
Post by Superdave on Wed 25 Nov 2015, 9:45 am
I don't see any evidence that Emu is installed as your firewall. You should check it.
Tech Staff
Tech Staff
Post by Magnern on Sat 05 Dec 2015, 1:48 pm
Superdave wrote:I don't see any evidence that Emu is installed as your firewall. You should check it.
How can I get you evidence? The icon is in the lower right in the task bar and shows online armor as active. Program guard, firewall, web shield and anti-keylogger appear to be active
I hope this is the MBAM log you want.
Scan Date: 12/4/2015
Scan Time: 6:54 PM
Logfile:
Administrator: Yes
Version: 2.2.0.1024
Malware Database: v2015.12.04.06
Rootkit Database: v2015.11.26.01
License: Free
CPU: x64
File System: NTFS
User: V
Result: Completed
Objects Scanned: 343828
Time Elapsed: 1 hr, 2 min, 47 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 0
Folders: 0
Files: 0
Physical Sectors: 0
(end)
Magnern
Post by Superdave on Sun 06 Dec 2015, 5:20 am
Java 8 Update 31
If EMU was active it should have shown up here. Go to Control Panel and make sure the security is on.
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by Sponsored content Today at 1:09 pm
