How should I adjust my power settng on my lap top
Post by suzonka on Fri 03 Jul 2015, 10:18 am
on my dell E6400 the bottom gets warm to the touch after I have been using it a while,, should I change my settings in power to hibernate after 20 minutes, or stand by .
suzonka
Rookie Surfer
Rookie Surfer
Operating System : windows 10
Re: How should I adjust my power settng on my lap top
Post by Superdave on Fri 03 Jul 2015, 12:51 pm
It's normal for the bottom to get warm after usage. You can buy ventilating pads to set the laptop upon to eliminate this problem.
Tech Staff
Tech Staff
