Need fixes and help removing Stormwatch , PUP
Post by Vista on Sat 07 Mar 2015, 9:06 am
hello,
my son's laptop had free you tube icon, stormwatch and who knows what else. Please advise. I did a malware scan with 141 detections. I can't seem to get the log file after it closed. Please advise.
Valerie
Vista
Senior Surfer
Senior Surfer
Operating System : Windows 8
Re: Need fixes and help removing Stormwatch , PUP
Post by Superdave on Sat 07 Mar 2015, 10:19 am
Link 1
Link 2
Tech Staff
Tech Staff
Post by Vista on Tue 10 Mar 2015, 6:02 am
Scan Date: 3/9/2015
Scan Time: 1:50:29 PM
Logfile: MALWR.txt
Administrator: Yes
Version: 2.00.4.1028
Malware Database: v2015.03.09.05
Rootkit Database: v2015.02.25.01
License: Free
Malware Protection: Disabled
Malicious Website Protection: Disabled
Self-protection: Disabled
OS: Windows 7 Service Pack 1
CPU: x86
File System: NTFS
User: Administrator
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 417344
Time Elapsed: 39 min, 20 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
Modules: 0
Registry Keys: 20
PUP.Optional.SweetIM.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\STATS\{DEDAF650-12B8-48F5-A843-BBA100716106}, Quarantined, [750498ab751552e4776e4ad8b1525ea2],
PUP.Optional.TidyNetwork.A, HKLM\SOFTWARE\MICROSOFT\INTERNET EXPLORER\LOW RIGHTS\ELEVATIONPOLICY\{72A6AB0F-2FA8-4C73-9FCB-1E62A608F001}, Quarantined, [db9e5ee57f0b80b64addef282ed5be42],
PUP.Optional.TidyNetwork.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\TidyNetwork, Quarantined, [94e59ca7a2e8df57e105159c847f827e],
PUP.Optional.TidyNetwork.A, HKLM\SOFTWARE\CLASSES\CLSID\{60510DF3-EF09-3549-D5A8-5612348D219B}, Quarantined, [d3a69ca70b7f8fa7e70c862d679c0af6],
PUP.Optional.TidyNetwork.A, HKLM\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXPLORER\BROWSER HELPER OBJECTS\{60510DF3-EF09-3549-D5A8-5612348D219B}, Quarantined, [d3a69ca70b7f8fa7e70c862d679c0af6],
PUP.Optional.TidyNetwork.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\SETTINGS\{60510DF3-EF09-3549-D5A8-5612348D219B}, Quarantined, [d3a69ca70b7f8fa7e70c862d679c0af6],
PUP.Optional.TidyNetwork.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\STATS\{60510DF3-EF09-3549-D5A8-5612348D219B}, Quarantined, [d3a69ca70b7f8fa7e70c862d679c0af6],
PUP.Optional.TidyNetwork.A, HKLM\SOFTWARE\CLASSES\CLSID\{60510DF3-EF09-3549-D5A8-5612348D219B}\INPROCSERVER32, Quarantined, [d3a69ca70b7f8fa7e70c862d679c0af6],
PUP.Optional.StormWatch.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\StormWatch, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, HKLM\SYSTEM\CURRENTCONTROLSET\SERVICES\SWUpdater, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.TidyNetwork.A, HKLM\SOFTWARE\MICROSOFT\INTERNET EXPLORER\LOW RIGHTS\DRAGDROP\{70BC1CDB-0744-4172-BDA0-B5A487D00C3A}, Quarantined, [20593b088bff350143a87d313ac94eb2],
PUP.Optional.StormWatch.A, HKLM\SOFTWARE\STORMWATCH, Quarantined, [c1b81e257c0e51e53f720fa0877c758b],
PUP.Optional.StormWatchApp.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\StormWatchApp, Quarantined, [a9d0c77c72187bbbeb34d1ecb64dfd03],
PUP.Optional.TidyNetwork.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\TidyNetwork, Quarantined, [b1c81231b1d94ceafe4b4b9e9a6917e9],
PUP.Optional.TNT.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\TNT2, Quarantined, [db9eb98ac4c63303303e218aba49748c],
PUP.Optional.TidyNetwork.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\APPDATALOW\SOFTWARE\TidyNetwork, Quarantined, [205954eff694c274ddcbfaf3fe056c94],
PUP.Optional.UpdateAdmin.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\DOWNLOADADMIN\UpdateAdmin, Quarantined, [e990f44f4d3d3501b650f1bc19ea619f],
PUP.Optional.TidyNetwork.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\INTERNET EXPLORER\LOW RIGHTS\DRAGDROP\{70BC1CDB-0744-4172-BDA0-B5A487D00C3A}, Quarantined, [13665be8a9e167cfc12b08a6ba49bb45],
PUP.Optional.TidyNetwork.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MOZILLAPLUGINS\@tnt2npapi.com/Plugin, Quarantined, [8beed2719cee0c2a6f1614e0cb38837d],
PUP.Optional.TidyNetwork.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\{07D39EE1-9743-4EA5-88A3-44E296565014}, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
Registry Values: 3
PUP.Optional.StormWatch.A, HKLM\SOFTWARE\STORMWATCH|GUID, {0D34B396-6C78-4503-8149-0829BBFE28EC}, Quarantined, [c1b81e257c0e51e53f720fa0877c758b]
PUP.Optional.StormWatch.A, HKLM\SYSTEM\CURRENTCONTROLSET\SERVICES\SWUPDATER|ImagePath, C:\Program Files\StormWatch\SWUpdaterSvc.exe, Quarantined, [6b0eb98ac0cad85e750aa60f7b885da3]
PUP.Optional.UpdateAdmin.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\RUN|UpdateAdmin, C:\Users\Administrator\AppData\Local\UpdateAdmin\UpdateAdmin.exe /RUN, Quarantined, [4633dc678307082ec0bfaff1ea1934cc]
Registry Data: 3
PUP.Optional.Freshy.A, HKLM\SOFTWARE\MICROSOFT\INTERNET EXPLORER\ABOUTURLS|Tabs, [You must be registered and logged in to see this link.] Good: ([You must be registered and logged in to see this link.] Bad: (http://services.freshy.com/general/newhometab.php?hometab=home&partner=11367&guid={07D39EE1-9743-4EA5-88A3-44E296565014}&i=),Replaced,[6a0f46fdcbbf85b1cc8771644eb727d9]
PUP.Optional.Freshy.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\INTERNET EXPLORER\MAIN|Start Page, [You must be registered and logged in to see this link.] Good: ([You must be registered and logged in to see this link.] Bad: (http://services.freshy.com/general/newhometab.php?hometab=home&partner=11367&guid={07D39EE1-9743-4EA5-88A3-44E296565014}&i=),Replaced,[483178cbf397cc6ab59de3f20ff60cf4]
PUP.Optional.Freshy.A, HKU\S-1-5-21-914808374-759592663-328091246-500-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\INTERNET EXPLORER\MAIN|Default_Page_URL, [You must be registered and logged in to see this link.] Good: ([You must be registered and logged in to see this link.] Bad: (http://services.freshy.com/general/newhometab.php?hometab=home&partner=11367&guid={07D39EE1-9743-4EA5-88A3-44E296565014}&i=),Replaced,[4b2e2c17f496fe381a3a44917b8a738d]
Folders: 21
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\StormWatch, Quarantined, [bdbce360b8d23bfb93c8248053b0fe02],
PUP.Optional.UpdateAdmin.A, C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UpdateAdmin, Quarantined, [06733a0993f70d297590dcd1699a17e9],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TidyNetwork, Quarantined, [94e59ca7a2e8df57e105159c847f827e],
PUP.Optional.TidyNetwork.A, C:\Program Files\TidyNetwork, Quarantined, [d3a69ca70b7f8fa7e70c862d679c0af6],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\Common, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\Profiles, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\Profiles\11367, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\2.0.0.1950, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\Profiles, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\Profiles\11367, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\extensions\TidyNetwork@TidyNetwork, Quarantined, [66132f146426f046869990dfbe45bb45],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\extensions\TidyNetwork@TidyNetwork\chrome, Quarantined, [66132f146426f046869990dfbe45bb45],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\extensions\TidyNetwork@TidyNetwork\chrome\content, Quarantined, [66132f146426f046869990dfbe45bb45],
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Local\Weather_Protector_LLC, Quarantined, [1a5fcf7492f8c670b0c0632fce350df3],
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Local\Weather_Protector_LLC\StormWatch.exe_Url_drszjp3ixrql2l5dz2b2jvlplwn11r4l, Quarantined, [1a5fcf7492f8c670b0c0632fce350df3],
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Local\Weather_Protector_LLC\StormWatch.exe_Url_drszjp3ixrql2l5dz2b2jvlplwn11r4l\2.0.0.0, Quarantined, [1a5fcf7492f8c670b0c0632fce350df3],
PUP.Optional.UpdateAdmin.A, C:\Users\Administrator\AppData\Local\UpdateAdmin, Quarantined, [4633dc678307082ec0bfaff1ea1934cc],
Files: 65
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\StormWatch\StormWatch.lnk, Quarantined, [bdbce360b8d23bfb93c8248053b0fe02],
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\StormWatch\Uninstall StormWatch.lnk, Quarantined, [bdbce360b8d23bfb93c8248053b0fe02],
PUP.Optional.UpdateAdmin.A, C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UpdateAdmin\UpdateAdmin.lnk, Quarantined, [06733a0993f70d297590dcd1699a17e9],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TidyNetwork\uninstall.exe, Quarantined, [94e59ca7a2e8df57e105159c847f827e],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TidyNetwork\update.exe, Quarantined, [94e59ca7a2e8df57e105159c847f827e],
PUP.Optional.TidyNetwork.A, C:\Program Files\TidyNetwork\petn.dll, Quarantined, [d3a69ca70b7f8fa7e70c862d679c0af6],
PUP.Optional.TidyNetwork.A, C:\Program Files\TidyNetwork\petn64.dll, Quarantined, [d3a69ca70b7f8fa7e70c862d679c0af6],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch\SWUpdaterSvc.exe.config, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch\ICSharpCode.SharpZipLib.dll, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch\StormWatch.exe, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch\StormWatch.exe.config, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch\StormWatchApp.exe, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch\StormWatchappuninstall.exe, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch\SWUpdaterSvc.exe, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, C:\Program Files\StormWatch\uninstall.exe, Quarantined, [4e2b142f88029a9c334dac096c976d93],
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\StormWatch.lnk, Quarantined, [4d2ccc776327152174e63d8163a022de],
PUP.Optional.TidyNetwork.A, C:\Windows\System32\Tasks\TidyNetwork Update, Quarantined, [4d2c4ff4f79351e5fb0816bd46bd8977],
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\StormWatchApp.lnk, Quarantined, [ea8f043f8a00b77f9614bf708283d32d],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\passport.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\Autorun.inf, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\GameApps.ini, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\GameConsole.exe, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\GameEngine.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\hmac.1.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\iestage2.1.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\IEToolbar.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\IEToolbar64.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\log.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\MinecraftShims64.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\npTNT2.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\passport64.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\progress.1.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\regsvr.1.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\sqlite.1.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\tnt2chrome.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\tnt2chrome64.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\TNT2User.exe, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\TNT2UserPS.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\TNT2UserPS64.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\TntMagicDel.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\UnInjLib.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\UnInjLib64.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\UninstallDlg.1.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\untar.1.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\2.0.0.1950\zipunzip.1.dll, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\Common\GameConsole.exe, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\Profiles\11367\icon.ico, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\Profiles\11367\inst.ini, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Local\TNT2\Profiles\11367\runt.ini, Quarantined, [10691a2992f8a4926af3f87312f14ab6],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\TNT2UserPS.dll, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\TNT2UserPS64.dll, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\2.0.0.1950\IEToolbar.dll, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\2.0.0.1950\IEToolbar64.dll, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\Profiles\11367\passport.dll, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Program Files\TNT2\Profiles\11367\passport64.dll, Quarantined, [c0b900438ffbc076005ebdaec93a6b95],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\extensions\TidyNetwork@TidyNetwork\chrome.manifest, Quarantined, [66132f146426f046869990dfbe45bb45],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\extensions\TidyNetwork@TidyNetwork\chrome\content\overlay.js, Quarantined, [66132f146426f046869990dfbe45bb45],
PUP.Optional.TidyNetwork.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\extensions\TidyNetwork@TidyNetwork\chrome\content\script0.js, Quarantined, [66132f146426f046869990dfbe45bb45],
PUP.Optional.StormWatch.A, C:\Users\Administrator\AppData\Local\Weather_Protector_LLC\StormWatch.exe_Url_drszjp3ixrql2l5dz2b2jvlplwn11r4l\2.0.0.0\user.config, Quarantined, [1a5fcf7492f8c670b0c0632fce350df3],
PUP.Optional.UpdateAdmin.A, C:\Users\Administrator\AppData\Local\UpdateAdmin\UpdateAdmin.exe, Quarantined, [4633dc678307082ec0bfaff1ea1934cc],
PUP.Optional.Freshy.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\prefs.js, Good: (), Bad: (user_pref("browser.startup.homepage", "http://services.freshy.com/general/newhometab.php?hometab=home&partner=11367&guid={07D39EE1-9743-4EA5-88A3-44E296565014}&i=");), Replaced,[6d0c261d701ab185f6fe6bb0b3533cc4]
PUP.Optional.Freshy.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\prefs.js, Good: (), Bad: (user_pref("browser.newtab.url", "http://services.freshy.com/general/newhometab.php?hometab=tab&partner=11367&guid={07D39EE1-9743-4EA5-88A3-44E296565014}&i=");), Replaced,[d0a9350e44469b9b06ef71aa679f03fd]
PUP.Optional.FindWide.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\prefs.js, Good: (), Bad: (user_pref("keyword.URL", "http://search.findwide.com/serp?guid={07D39EE1-9743-4EA5-88A3-44E296565014}&k=");), Replaced,[77022f1488023ef8507d041a947229d7]
PUP.Optional.Freshy.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\user.js, Quarantined, [037668db9ded1323c3c6cd4e0cfaca36],
PUP.Optional.FindWideTB.A, C:\Users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\se9kv7zw.default\user.js, Good: (), Bad: (user_pref("keyword.URL", "http://search.findwide.com/serp?guid={07D39EE1-9743-4EA5-88A3-44E296565014}&k=");), Replaced,[0376142f5e2c6ec8a056c559f610bd43]
Physical Sectors: 0
(end)
Vista
Senior Surfer
Senior Surfer
Post by Vista on Tue 10 Mar 2015, 8:03 am
# AdwCleaner v4.111 - Logfile created 06/03/2015 at 18:48:00
# Updated 18/02/2015 by Xplode
# Database : 2015-03-05.1 [Server]
# Operating system : Windows 7 Ultimate Service Pack 1 (x86)
# Username : Administrator - NEWUSER-PC
# Running from : C:\Users\Administrator\Downloads\adwcleaner_4.111.exe
# Option : Cleaning
***** [ Services ] *****
[#] Service Deleted : vToolbarUpdater18.1.9
Service Deleted : SWUpdater
***** [ Files / Folders ] *****
Folder Deleted : C:\Program Files\StormWatch
Folder Deleted : C:\Users\Administrator\AppData\Local\StormWatch
Folder Deleted : C:\Users\Administrator\AppData\Local\Pro_PC_Cleaner
Folder Deleted : C:\Users\Administrator\Documents\ProPCCleaner
***** [ Scheduled tasks ] *****
Task Deleted : ProPCCleaner_Start
Task Deleted : ProPCCleaner_Popup
Task Deleted : YTDownloaderUpd
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{1DABCDA7-56B8-489F-94D5-3BED51D6ED95}
Key Deleted : HKCU\Software\StormWatchApp
Key Deleted : HKCU\Software\ProPCCleanerLanguage
Key Deleted : HKCU\Software\ProPCCleanerConfig
Key Deleted : HKLM\SOFTWARE\SearchModule
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Search module
***** [ Web browsers ] *****
-\\ Internet Explorer v11.0.9600.17631
-\\ Mozilla Firefox v36.0.1 (x86 en-US)
[se9kv7zw.default\prefs.js] - Line Deleted : user_pref("plugin.state.npconduitfirefoxplugin", 0);
AdwCleaner[R0].txt - [997 bytes] - [04/01/2015 13:58:51]
AdwCleaner[R1].txt - [1746 bytes] - [06/03/2015 17:10:05]
AdwCleaner[S0].txt - [1071 bytes] - [04/01/2015 14:01:32]
AdwCleaner[S1].txt - [1718 bytes] - [06/03/2015 18:48:00]
########## EOF - C:\AdwCleaner\AdwCleaner[S1].txt - [1777 bytes] ##########
# AdwCleaner v4.112 - Logfile created 09/03/2015 at 15:17:55
# Updated 09/03/2015 by Xplode
# Running from : C:\Users\Administrator\Downloads\AdwCleaner.exe
# Option : Cleaning
Folder Deleted : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Pro PC Cleaner
Folder Deleted : C:\Program Files\Pro PC Cleaner
Folder Deleted : C:\Users\Administrator\AppData\Roaming\Pro PC Cleaner
File Deleted : C:\Users\Public\Desktop\Pro PC Cleaner.lnk
Key Deleted : HKCU\Software\Pro PC Cleaner
Key Deleted : HKLM\SOFTWARE\Pro PC Cleaner
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C3060724-6AC7-4BEF-B516-4F6B1D90887D}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\4270603C7CA6FEB45B61F4B6D10988D7
Key Deleted : HKLM\SOFTWARE\Classes\Installer\Features\4270603C7CA6FEB45B61F4B6D10988D7
Key Deleted : HKLM\SOFTWARE\Classes\Installer\Products\4270603C7CA6FEB45B61F4B6D10988D7
-\\ Mozilla Firefox v35.0.1 (x86 en-US)
AdwCleaner[R0].txt - [997 bytes] - [04/01/2015 14:58:51]
AdwCleaner[R1].txt - [4079 bytes] - [06/03/2015 18:10:05]
AdwCleaner[S0].txt - [1071 bytes] - [04/01/2015 15:01:32]
AdwCleaner[S1].txt - [4113 bytes] - [06/03/2015 19:48:00]
########## EOF - C:\AdwCleaner\AdwCleaner[S1].txt - [4172 bytes] ##########
Vista
Senior Surfer
Senior Surfer
Post by Vista on Tue 10 Mar 2015, 8:12 am
Should I uninstall the free you tube on the desk top. Scan is below
Version: 6.4.3 (03.01.2015:1)
OS: Windows 7 Ultimate x86
Ran by Administrator on Mon 03/09/2015 at 17:06:28.29
~~~ Services
~~~ Registry Values
~~~ Registry Keys
~~~ Files
~~~ Folders
Successfully deleted: [Folder] "C:\Users\Administrator\Local Settings\Application Data\free youtube downloader"
Successfully deleted: [Folder] "C:\Program Files\free youtube downloader"
~~~ FireFox
Successfully deleted: [File] C:\user.js
~~~ Event Viewer Logs were cleared
Scan was completed on Mon 03/09/2015 at 17:09:18.25
End of JRT log
Vista
Senior Surfer
Senior Surfer
Post by Vista on Tue 10 Mar 2015, 8:22 am
The security check by 317 goes to start up and says unsupported operating system..Abort!
What can I do to fix that.. thanks.
Vista
Senior Surfer
Senior Surfer
Post by Superdave on Tue 10 Mar 2015, 12:48 pm
Yes, the program has been removed already. The security Check sometimes does that. What AV are you using and is it up to date?
Malwarebytes' Anti-Rootkit
Please download Malwarebytes' Anti-Rootkit and save it to your desktop.
  • Be sure to print out and follow the instructions provided on that same page for performing a scan.
  • Caution: This is a beta version so also read the disclaimer and back up all your data before using.
  • When the scan completes, click on the Cleanup button to remove any threats found and reboot the computer if prompted to do so.
  • Perform another scan with Malwarebytes Anti-Rootkit to verify that no threats remain. If they do, then click Cleanup once more and repeat the process.
  • If there are problems with Internet access, Windows Update, Windows Firewall or other system issues, run the fixdamage tool located in the folder Malwarebytes Anti-Rootkit was run from and reboot your computer.
  • Two files (mbar-log-YYYY-MM-DD, system-log.txt) will be created and saved within that same folder.
  • Copy and paste the contents of these two log files in your next reply.
Tech Staff
Tech Staff
Post by Vista on Thu 12 Mar 2015, 2:05 am
Can not find the mbar-log-YYYY-MM-DD, does not have it in the file. Is it under a file folder name? Following is the system log:
Malwarebytes Anti-Rootkit BETA 1.09.1.1004
(c) Malwarebytes Corporation 2011-2012
OS version: 6.1.7601 Windows 7 Service Pack 1 x86
Account is Administrative
Internet Explorer version: 11.0.9600.17633
File system is: NTFS
Disk drives: C:\ DRIVE_FIXED
CPU speed: 2.194000 GHz
Memory total: 2105921536, free: 1071624192
Downloaded database version: v2015.03.10.06
Downloaded database version: v2015.02.25.01
Downloaded database version: v2015.03.09.01
Initializing...
------------ Kernel report ------------
03/10/2015 17:19:55
------------ Loaded modules -----------
\SystemRoot\system32\ntkrnlpa.exe
\SystemRoot\system32\halmacpi.dll
\SystemRoot\system32\kdcom.dll
\SystemRoot\system32\mcupdate_GenuineIntel.dll
\SystemRoot\system32\PSHED.dll
\SystemRoot\system32\BOOTVID.dll
\SystemRoot\system32\CLFS.SYS
\SystemRoot\system32\CI.dll
\SystemRoot\system32\drivers\Wdf01000.sys
\SystemRoot\system32\drivers\WDFLDR.SYS
\SystemRoot\system32\drivers\ACPI.sys
\SystemRoot\system32\drivers\WMILIB.SYS
\SystemRoot\system32\drivers\msisadrv.sys
\SystemRoot\system32\drivers\pci.sys
\SystemRoot\system32\drivers\vdrvroot.sys
\SystemRoot\System32\drivers\partmgr.sys
\SystemRoot\system32\DRIVERS\compbatt.sys
\SystemRoot\system32\DRIVERS\BATTC.SYS
\SystemRoot\system32\drivers\volmgr.sys
\SystemRoot\System32\drivers\volmgrx.sys
\SystemRoot\System32\drivers\mountmgr.sys
\SystemRoot\system32\drivers\vmbus.sys
\SystemRoot\system32\drivers\winhv.sys
\SystemRoot\system32\drivers\atapi.sys
\SystemRoot\system32\drivers\ataport.SYS
\SystemRoot\system32\drivers\msahci.sys
\SystemRoot\system32\drivers\PCIIDEX.SYS
\SystemRoot\system32\drivers\amdxata.sys
\SystemRoot\system32\drivers\fltmgr.sys
\SystemRoot\system32\drivers\fileinfo.sys
\SystemRoot\system32\DRIVERS\MpFilter.sys
\SystemRoot\System32\Drivers\Ntfs.sys
\SystemRoot\System32\Drivers\msrpc.sys
\SystemRoot\System32\Drivers\ksecdd.sys
\SystemRoot\System32\Drivers\cng.sys
\SystemRoot\System32\drivers\pcw.sys
\SystemRoot\System32\Drivers\Fs_Rec.sys
\SystemRoot\system32\drivers\ndis.sys
\SystemRoot\system32\drivers\NETIO.SYS
\SystemRoot\System32\Drivers\ksecpkg.sys
\SystemRoot\System32\drivers\tcpip.sys
\SystemRoot\System32\drivers\fwpkclnt.sys
\SystemRoot\system32\drivers\vmstorfl.sys
\SystemRoot\system32\drivers\volsnap.sys
\SystemRoot\System32\Drivers\spldr.sys
\SystemRoot\System32\drivers\rdyboost.sys
\SystemRoot\System32\Drivers\mup.sys
\SystemRoot\System32\drivers\hwpolicy.sys
\SystemRoot\System32\DRIVERS\fvevol.sys
\SystemRoot\system32\DRIVERS\disk.sys
\SystemRoot\system32\DRIVERS\CLASSPNP.SYS
\SystemRoot\System32\Drivers\aswVmm.sys
\SystemRoot\System32\Drivers\aswRvrt.sys
\SystemRoot\system32\drivers\cdrom.sys
\SystemRoot\system32\drivers\aswSnx.sys
\SystemRoot\system32\drivers\aswSP.sys
\SystemRoot\System32\Drivers\Null.SYS
\SystemRoot\System32\Drivers\Beep.SYS
\??\C:\Windows\system32\drivers\avgtpx86.sys
\SystemRoot\System32\Drivers\aswKbd.SYS
\SystemRoot\System32\drivers\vga.sys
\SystemRoot\System32\drivers\VIDEOPRT.SYS
\SystemRoot\System32\drivers\watchdog.sys
\SystemRoot\System32\DRIVERS\RDPCDD.sys
\SystemRoot\system32\drivers\rdpencdd.sys
\SystemRoot\system32\drivers\rdprefmp.sys
\SystemRoot\System32\Drivers\Msfs.SYS
\SystemRoot\System32\Drivers\Npfs.SYS
\SystemRoot\system32\DRIVERS\tdx.sys
\SystemRoot\system32\DRIVERS\TDI.SYS
\SystemRoot\system32\drivers\afd.sys
\SystemRoot\system32\drivers\aswRdr2.sys
\SystemRoot\System32\DRIVERS\netbt.sys
\SystemRoot\system32\DRIVERS\wfplwf.sys
\SystemRoot\system32\DRIVERS\pacer.sys
\SystemRoot\system32\DRIVERS\vwififlt.sys
\SystemRoot\system32\DRIVERS\netbios.sys
\SystemRoot\system32\DRIVERS\wanarp.sys
\SystemRoot\system32\drivers\termdd.sys
\SystemRoot\system32\DRIVERS\rdbss.sys
\SystemRoot\system32\drivers\nsiproxy.sys
\SystemRoot\system32\drivers\mssmbios.sys
\SystemRoot\System32\drivers\discache.sys
\SystemRoot\system32\drivers\csc.sys
\SystemRoot\System32\Drivers\dfsc.sys
\SystemRoot\system32\DRIVERS\blbdrive.sys
\SystemRoot\system32\DRIVERS\tunnel.sys
\SystemRoot\system32\DRIVERS\igdkmd32.sys
\SystemRoot\System32\drivers\dxgkrnl.sys
\SystemRoot\System32\drivers\dxgmms1.sys
\SystemRoot\system32\DRIVERS\usbuhci.sys
\SystemRoot\system32\DRIVERS\USBPORT.SYS
\SystemRoot\system32\DRIVERS\usbehci.sys
\SystemRoot\system32\drivers\HDAudBus.sys
\SystemRoot\system32\DRIVERS\bcmwl6.sys
\SystemRoot\system32\DRIVERS\vwifibus.sys
\SystemRoot\system32\DRIVERS\yk62x86.sys
\SystemRoot\system32\drivers\i8042prt.sys
\SystemRoot\system32\drivers\mouclass.sys
\SystemRoot\system32\drivers\kbdclass.sys
\SystemRoot\system32\DRIVERS\GEARAspiWDM.sys
\SystemRoot\system32\DRIVERS\CmBatt.sys
\SystemRoot\system32\drivers\wmiacpi.sys
\SystemRoot\system32\DRIVERS\intelppm.sys
\SystemRoot\system32\drivers\CompositeBus.sys
\SystemRoot\system32\DRIVERS\AgileVpn.sys
\SystemRoot\system32\DRIVERS\rasl2tp.sys
\SystemRoot\system32\DRIVERS\ndistapi.sys
\SystemRoot\system32\DRIVERS\ndiswan.sys
\SystemRoot\system32\DRIVERS\raspppoe.sys
\SystemRoot\system32\DRIVERS\raspptp.sys
\SystemRoot\system32\DRIVERS\rassstp.sys
\SystemRoot\system32\DRIVERS\rdpbus.sys
\SystemRoot\system32\drivers\swenum.sys
\SystemRoot\system32\drivers\ks.sys
\SystemRoot\system32\drivers\umbus.sys
\SystemRoot\system32\DRIVERS\usbhub.sys
\SystemRoot\System32\Drivers\NDProxy.SYS
\SystemRoot\system32\drivers\HdAudio.sys
\SystemRoot\system32\drivers\portcls.sys
\SystemRoot\system32\drivers\drmk.sys
\SystemRoot\System32\win32k.sys
\SystemRoot\System32\drivers\Dxapi.sys
\SystemRoot\System32\Drivers\crashdmp.sys
\SystemRoot\System32\Drivers\dump_dumpata.sys
\SystemRoot\System32\Drivers\dump_msahci.sys
\SystemRoot\System32\Drivers\dump_dumpfve.sys
\SystemRoot\system32\DRIVERS\USBSTOR.SYS
\SystemRoot\system32\DRIVERS\USBD.SYS
\SystemRoot\system32\DRIVERS\monitor.sys
\SystemRoot\System32\TSDDD.dll
\SystemRoot\System32\cdd.dll
\SystemRoot\system32\DRIVERS\usbccgp.sys
\SystemRoot\System32\Drivers\usbvideo.sys
\SystemRoot\system32\drivers\luafv.sys
\SystemRoot\system32\drivers\aswMonFlt.sys
\SystemRoot\System32\ATMFD.DLL
\SystemRoot\system32\drivers\aswStm.sys
\SystemRoot\system32\DRIVERS\lltdio.sys
\SystemRoot\system32\DRIVERS\nwifi.sys
\SystemRoot\system32\DRIVERS\ndisuio.sys
\SystemRoot\system32\DRIVERS\rspndr.sys
\SystemRoot\system32\drivers\HTTP.sys
\SystemRoot\system32\DRIVERS\bowser.sys
\SystemRoot\System32\drivers\mpsdrv.sys
\SystemRoot\system32\DRIVERS\mrxsmb.sys
\SystemRoot\system32\DRIVERS\mrxsmb10.sys
\SystemRoot\system32\DRIVERS\mrxsmb20.sys
\SystemRoot\system32\drivers\aswHwid.sys
\SystemRoot\system32\DRIVERS\NisDrvWFP.sys
\SystemRoot\system32\drivers\peauth.sys
\SystemRoot\System32\Drivers\secdrv.SYS
\SystemRoot\System32\DRIVERS\srvnet.sys
\SystemRoot\System32\drivers\tcpipreg.sys
\SystemRoot\System32\DRIVERS\srv2.sys
\SystemRoot\System32\DRIVERS\srv.sys
\SystemRoot\system32\drivers\WudfPf.sys
\SystemRoot\system32\DRIVERS\WUDFRd.sys
\??\C:\Windows\system32\drivers\mbamchameleon.sys
\??\C:\Windows\system32\drivers\MBAMSwissArmy.sys
\Windows\System32\ntdll.dll
\Windows\System32\smss.exe
\Windows\System32\apisetschema.dll
\Windows\System32\autochk.exe
\Windows\System32\iertutil.dll
\Windows\System32\lpk.dll
\Windows\System32\comdlg32.dll
\Windows\System32\ws2_32.dll
\Windows\System32\oleaut32.dll
\Windows\System32\Wldap32.dll
\Windows\System32\user32.dll
\Windows\System32\normaliz.dll
\Windows\System32\ole32.dll
\Windows\System32\imm32.dll
\Windows\System32\sechost.dll
\Windows\System32\psapi.dll
\Windows\System32\rpcrt4.dll
\Windows\System32\nsi.dll
\Windows\System32\shlwapi.dll
\Windows\System32\difxapi.dll
\Windows\System32\imagehlp.dll
\Windows\System32\urlmon.dll
\Windows\System32\gdi32.dll
\Windows\System32\setupapi.dll
\Windows\System32\kernel32.dll
\Windows\System32\msctf.dll
\Windows\System32\advapi32.dll
\Windows\System32\clbcatq.dll
\Windows\System32\msvcrt.dll
\Windows\System32\shell32.dll
\Windows\System32\usp10.dll
\Windows\System32\wininet.dll
\Windows\System32\api-ms-win-downlevel-version-l1-1-0.dll
\Windows\System32\crypt32.dll
\Windows\System32\comctl32.dll
\Windows\System32\devobj.dll
\Windows\System32\api-ms-win-downlevel-advapi32-l1-1-0.dll
\Windows\System32\api-ms-win-downlevel-normaliz-l1-1-0.dll
\Windows\System32\userenv.dll
\Windows\System32\api-ms-win-downlevel-ole32-l1-1-0.dll
\Windows\System32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
\Windows\System32\cfgmgr32.dll
\Windows\System32\api-ms-win-downlevel-user32-l1-1-0.dll
\Windows\System32\wintrust.dll
\Windows\System32\KernelBase.dll
\Windows\System32\profapi.dll
\Windows\System32\msasn1.dll
----------- End -----------
Done!
Scan started
Database versions:
main: v2015.03.10.06
rootkit: v2015.02.25.01
<<<2>>>
Physical Sector Size: 512
Drive: 0, DevicePointer: 0xffffffff86850560, DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\Disk\
--------- Disk Stack ------
DevicePointer: 0xffffffff86850240, DeviceName: Unknown, DriverName: \Driver\partmgr\
DevicePointer: 0xffffffff8633d908, DeviceName: \Device\Ide\IdeDeviceP0T0L0-0\, DriverName: \Driver\atapi\
------------ End ----------
Alternate DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\Disk\
Upper DeviceData: 0x0, 0x0, 0x0
Lower DeviceData: 0x0, 0x0, 0x0
<<<3>>>
Volume: C:
File system type: NTFS
SectorSize = 512, ClusterSize = 4096, MFTRecordSize = 1024, MFTIndexSize = 4096 bytes
<<<2>>>
<<<3>>>
Volume: C:
Scanning drivers directory: C:\WINDOWS\SYSTEM32\drivers...
Done!
Drive 0
This is a System drive
Scanning MBR on drive 0...
Inspecting partition table:
MBR Signature: 55AA
Disk Signature: 1A0BF02E
Partition information:
Partition 0 type is Primary (0x7)
Partition is ACTIVE.
Partition starts at LBA: 206848 Numsec = 976564224
Partition file system is NTFS
Partition is bootable
Partition 1 type is Empty (0x0)
Partition is NOT ACTIVE.
Partition starts at LBA: 0 Numsec = 0
Partition 2 type is Empty (0x0)
Partition 3 type is Empty (0x0)
Disk Size: 500107862016 bytes
Sector size: 512 bytes
Done!
Physical Sector Size: 0
Drive: 1, DevicePointer: 0xffffffff871d8418, DeviceName: \Device\Harddisk1\DR1\, DriverName: \Driver\Disk\
DevicePointer: 0xffffffff871e3d10, DeviceName: Unknown, DriverName: \Driver\partmgr\
DevicePointer: 0xffffffff87214ca8, DeviceName: \Device\00000076\, DriverName: \Driver\USBSTOR\
Vista
Senior Surfer
Senior Surfer
Post by Vista on Thu 12 Mar 2015, 3:08 am
Just cleaned with MBAR for the 2nd time and it is all clean! Runs great except the start up is soooo slow... about 4 minutes before getting to user icon.
Please advise.
Vista
Senior Surfer
Senior Surfer
Post by Superdave on Thu 12 Mar 2015, 5:32 am
StartupLite
Download StartupLite by MalwareBytes to your Desktop.
Doubleclick StartupLite.exe to launch the program.
Ensure the Disable box is checked.
Click Continue.
A pop up message will tell you the unecessary startup items in your list have been disabled and ask you to restart your computer.
Re-start your computer.
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by Vista on Sat 14 Mar 2015, 6:52 am
# product=EOS
# version=8
# iexplore.exe=11.00.9600.16428 (winblue_gdr.131013-1700)
# OnlineScanner.ocx=1.0.0.7623
# api_version=3.0.2
# EOSSerial=beb89874d5a56245a36a4f8b645e5fde
# engine=22863
# end=finished
# remove_checked=true
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2015-03-11 08:46:18
# local_time=2015-03-11 04:46:18 (-0500, Eastern Daylight Time)
# country="United States"
# lang=1033
# osver=6.1.7601 NT Service Pack 1
# compatibility_mode_1='avast! Antivirus'
# compatibility_mode=783 16777213 100 97 0 189605668 0 0
# compatibility_mode_1='Microsoft Security Essentials'
# compatibility_mode=5895 16777213 100 100 1287612 120179982 0 0
# scanned=158006
# found=11
# cleaned=11
# scan_time=5133
sh=9EC383123A7416205085DCD71F5B2CCB8C78FD3F ft=1 fh=6a7410a6c9e8ed34 vn="a variant of MSIL/Rebrand.LittleRegClean.B potentially unwanted application (deleted - quarantined)" ac=C fn="C:\AdwCleaner\Quarantine\C\Program Files\Pro PC Cleaner\Helper.dll.vir"
sh=D49B60A12414C5F9FD39D4FAEE9ABB6CD5B3B3EA ft=1 fh=e6dd68f64917ffa5 vn="a variant of MSIL/Rebrand.LittleRegClean.B potentially unwanted application (deleted - quarantined)" ac=C fn="C:\AdwCleaner\Quarantine\C\Program Files\Pro PC Cleaner\ProPCCleaner.exe.vir"
sh=497D8A9697F271DAD0E1A63B0F7C56FD3B570F8C ft=1 fh=2949a26673d8f2ad vn="a variant of MSIL/Rebrand.LittleRegClean.B potentially unwanted application (deleted - quarantined)" ac=C fn="C:\AdwCleaner\Quarantine\C\Program Files\Pro PC Cleaner\Uninst000.CA.dll.vir"
sh=9EC383123A7416205085DCD71F5B2CCB8C78FD3F ft=1 fh=6a7410a6c9e8ed34 vn="a variant of MSIL/Rebrand.LittleRegClean.B potentially unwanted application (deleted - quarantined)" ac=C fn="C:\AdwCleaner\Quarantine\C\Users\Administrator\AppData\Roaming\Pro PC Cleaner\Pro PC Cleaner 2.5.5\install\D90887D\Helper.dll.vir"
sh=D49B60A12414C5F9FD39D4FAEE9ABB6CD5B3B3EA ft=1 fh=e6dd68f64917ffa5 vn="a variant of MSIL/Rebrand.LittleRegClean.B potentially unwanted application (deleted - quarantined)" ac=C fn="C:\AdwCleaner\Quarantine\C\Users\Administrator\AppData\Roaming\Pro PC Cleaner\Pro PC Cleaner 2.5.5\install\D90887D\ProPCCleaner.exe.vir"
sh=497D8A9697F271DAD0E1A63B0F7C56FD3B570F8C ft=1 fh=2949a26673d8f2ad vn="a variant of MSIL/Rebrand.LittleRegClean.B potentially unwanted application (deleted - quarantined)" ac=C fn="C:\AdwCleaner\Quarantine\C\Users\Administrator\AppData\Roaming\Pro PC Cleaner\Pro PC Cleaner 2.5.5\install\D90887D\Uninst000.CA.dll.vir"
sh=48C87BF89A2FB7974AC4B81E7956F439B64D99A6 ft=1 fh=6defbe7c4fedab3d vn="a variant of Win32/SBWatchman.D potentially unwanted application (deleted - quarantined)" ac=C fn="C:\Program Files\Common Files\System\SysMenu.dll"
sh=E4A3439C3370184AA795A710341CFE423D9444B0 ft=1 fh=dc14b1b2a5b02ce5 vn="a variant of Win32/Toolbar.SearchSuite.Y potentially unwanted application (deleted - quarantined)" ac=C fn="C:\Users\New User\Downloads\iMeshV11.exe"
sh=737798535E7A693ADC760EA4132D12D387D34356 ft=1 fh=96fbfd2a42e1df7c vn="a variant of Win32/Toolbar.Perion.H potentially unwanted application (deleted - quarantined)" ac=C fn="C:\Windows\System32\mjcm\dnkt.exe"
sh=C33FEDF1A60F25DC90A4754446535DF6924A9FDF ft=1 fh=017cd515e52a74e6 vn="a variant of Win32/Toolbar.Perion.H potentially unwanted application (deleted - quarantined)" ac=C fn="C:\Windows\System32\mjcm\5108\nsib.dll"
sh=181241E6431887DC27F4E2B92159F77D82831893 ft=1 fh=80d13d017bfcdcc5 vn="a variant of Win32/Toolbar.Perion.H potentially unwanted application (deleted - quarantined)" ac=C fn="C:\Windows\System32\mjcm\5113\nsib.dll"
Vista
Senior Surfer
Senior Surfer
Post by Superdave on Sun 15 Mar 2015, 3:35 am
How's your computer running now? Any other issues?
Tech Staff
Tech Staff
Post by Vista on Sun 15 Mar 2015, 8:31 am
Seems to be working great! Thanks so much!
Vista
Senior Surfer
Senior Surfer
Post by Superdave on Sun 15 Mar 2015, 9:41 am
Ok, let's clean up.
This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
This is a very crucial step so make sure you don't skip it.
Download DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
Double-click Delfix.exe to start the tool.
Make sure the following items are checked:
  • Activate UAC (optional; some users prefer to keep it off)
  • Remove disinfection tools
  • Create Registry backup
  • Purge System Restore Points
  • Re-set system settings
Now click "Run" and wait patiently.
Once finished a logfile will be created. You don't have to attach it to your next reply.
Safe Surfing!
Tech Staff
Tech Staff
Post by Sponsored content Today at 11:32 pm
