Big Problem -trying to get rid of it for 7 days
Post by MJ1 on Sun 08 Feb 2015, 4:27 pm
My windows 8 laptop got really, really slow and would freeze. I have run every single malware program available but it still exists.
I have finally gone into safemode and gotten it to run fine. As soon as I boot into regular mode it practically stops within 3 minutes.
I tried running malwarebytes in regular mode and it froze before it could finish.
So I can only run it in safemode - which is how I am typing to you now.
It has disabled my AVG free anti-virus and won't allow me to Refresh or Reload my System.
Security check - said unsupported system. Aborted
ADW Cleaner - comes up with nothing at all - as I have run it about ten times now over the last week
Can you please help.
Malwarebytes Anti-Malware
Scan Date: 2015-02-07
Scan Time: 9:50:06 PM
Logfile:
Administrator: Yes
Version: 2.00.4.1028
Malware Database: v2015.02.08.02
Rootkit Database: v2015.02.03.01
License: Free
Malware Protection: Disabled
Malicious Website Protection: Disabled
Self-protection: Disabled
OS: Windows 8
CPU: x64
File System: NTFS
User: Sue
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 336659
Time Elapsed: 22 min, 58 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Warn
PUM: Enabled
Processes: 0
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 0
Folders: 0
Files: 0
Physical Sectors: 0
(end)
MJ1
Rookie Surfer
Rookie Surfer
Operating System : Windows 8 64 bit
Re: Big Problem -trying to get rid of it for 7 days
Post by Superdave on Mon 09 Feb 2015, 5:06 am
If you can't run this in Normal Mode, you can run it in Safe Mode.
If your version of Windows defaults to you download folder you will need to copy it to your desktop.
Link 1
Link 2
Link 3
To prevent your anti-virus application interfering with ComboFix we need to disable it. See here for a tutorial regarding how to do so if you are unsure.
Tech Staff
Tech Staff
Post by MJ1 on Mon 09 Feb 2015, 8:20 am
Hello Dave,
I am on windows 8 and have looked up combo fix and it says its not to be used on windows 8 - 64 bit machines. So I would like you to confirm for me that it is OK to use it on a windows 8 machine.
MJ1
Rookie Surfer
Rookie Surfer
Post by Superdave on Mon 09 Feb 2015, 9:49 am
So I would like you to confirm for me that it is OK to use it on a windows 8 machine. .
My bad. I forgot that CF hasn't been updated to run on the newer OS.
What did happen prior to this problem starting? Did you make any changes such as new software or hardware installed? Can you do a System restore? What is the size of the hard drive and how much free space do you have?
Tech Staff
Tech Staff
Post by MJ1 on Mon 09 Feb 2015, 11:00 am
When it started out it yahoo search took over the browser and it would just slow down to a stall as the mouse would just go into a circle and not move anymore.
My windows 7 machine got the virus shortly after and I got rid of it using combo fix.
One program I ran found win32 toolbar widgi D and H and said it got rid of it and the browser seems fine now.
Another program found Spigot (A I believe) and supposedly got rid of it.
There is 387 gigs free on the hard drive.
The only thing that has found anything is gmer:
Disk \Deveice\Harddisk0\DR0 unknown MBR code
Thread C:\Widows\system32\csrss.exe[488: 1412] fffff960008295e8
I see even in safemode the virus(whatever) is still there and won;t let me download any new antivirus for the machine and some antispyware programs just immediately say (scan finished, everything is fine) when I know it hasn't scanned anything.
Also iIt wont let me reload or refresh or anything.
Appreciate your help!
MJ1
Rookie Surfer
Rookie Surfer
Post by MJ1 on Mon 09 Feb 2015, 11:06 am
Gmer just did a third party quick scan and has come up with some things and I just thought I would post it. Not sure if it will be of any help.
GMER 2.1.19357 - [You must be registered and logged in to see this link.]
3rd party scan 2015-02-08 17:03:16
Windows 6.2.9200 x64 \Device\Harddisk0\DR0 -> \Device\00000036 HGST_HTS545050A7E380 rev.GG2OACA0 465.76GB
Running: o2tejppe.exe; Driver: C:\Users\Sue\AppData\Local\Temp\pxloypoc.sys
---- Modules - GMER 2.1 ----
Module \SystemRoot\System32\drivers\iaStorA.sys (Intel Rapid Storage Technology driver - x64/Intel Corporation SIGNED)(2012-07-31 19:22:00) fffff88002006000-fffff880022d0000 (2924544 bytes)
Module \SystemRoot\system32\DRIVERS\avgloga.sys (AVG Logging Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-07-18 21:53:26) fffff88002eda000-fffff88002f29000 (323584 bytes)
Module \SystemRoot\system32\DRIVERS\avgmfx64.sys (AVG Resident Shield Minifilter Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-10-06 03:41:40) fffff88002f29000-fffff88002f4b000 (139264 bytes)
Module \SystemRoot\system32\DRIVERS\avgidsha.sys (AVG Application Activity Monitor Helper Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-11-19 04:42:04) fffff88002b9d000-fffff88002bd1000 (212992 bytes)
Module \SystemRoot\system32\DRIVERS\avgrkx64.sys (AVG Anti-Rootkit Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-06-19 03:03:20) fffff8800126c000-fffff88001276000 (40960 bytes)
Module \SystemRoot\system32\DRIVERS\avgwfpa.sys (AVG Firewall driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-09-25 03:03:42) fffff88006edf000-fffff88006f26000 (290816 bytes)
Module \SystemRoot\system32\DRIVERS\SynTP.sys (Synaptics Touchpad Driver/Synaptics Incorporated SIGNED)(2012-08-29 03:33:50) fffff88007400000-fffff88007473000 (471040 bytes)
Module \SystemRoot\System32\Drivers\dump_diskdump.sys fffff88007ac1000-fffff88007ace000 (53248 bytes)
Module \SystemRoot\System32\Drivers\dump_amd_sata.sys fffff88007ace000-fffff88007aeb000 (118784 bytes)
Module \SystemRoot\System32\Drivers\dump_dumpfve.sys fffff88007491000-fffff880074a5000 (81920 bytes)
---- Processes - GMER 2.1 ----
Process C:\Windows\system32\svchost.exe [944] (Bonjour Namespace Provider/Apple Inc. SIGNED)(2011-08-31 06:05:32) 0000000072fb0000
Library C:\Program Files\Bonjour\mdnsNSP.dll (Bonjour Namespace Provider/Apple Inc. SIGNED)(2011-08-31 06:05:32) 0000000072fb0000
Process C:\Windows\Explorer.EXE [1436] (Hewlett-Packard Company DeskBand/Hewlett-Packard Company SIGNED)(2012-08-11 00:55:26) 0000000180000000
Library C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPSFMessenger\HPSFTaskbar.dll (Hewlett-Packard Company DeskBand/Hewlett-Packard Company SIGNED)(2012-08-11 00:55:26) 0000000180000000
Library C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamext.dll (Malwarebytes Anti-Malware/Malwarebytes Corporation SIGNED)(2015-02-05 03:10:07) 000007fe2ad10000
Library C:\Program Files (x86)\Spybot - Search & Destroy 2\SDECon64.dll (Windows Explorer context menu integration/Safer-Networking Ltd. SIGNED)(2015-02-03 03:19:05) 0000000110000000
Library C:\Program Files (x86)\Glary Utilities 5\x64\ContextHandler.dll (Context Menu Handler/Glarysoft Ltd SIGNED)(2015-01-19 05:10:22) 000007fe2d5b0000
Library C:\Program Files (x86)\Common Files\CyberLink\ShellExtComponent\CLVDShellExt.dll (Cyberlink Shell Extension dynamic link library/Cyberlink)(2013-05-01 19:54:34) 000007fe2b650000
Library C:\Windows\system32\BSAppShlExt.dll (TODO: <(2012-08-02 19:37:02) 000007fe2aca0000
Library C:\Windows\system32\BsSDK.dll (Bluetooth Application/IVT Corporation)(2012-07-11 01:11:00) 0000000065500000
Library C:\Windows\system32\BsCommon.dll (Bluetooth Application/IVT Corporation)(2012-07-12 21:55:30) 0000000065200000
Library C:\Windows\system32\BsLangInDepRes.dll (Bluetooth Application/IVT Corporation)(2012-07-12 21:47:24) 000000000e200000
Library C:\Windows\system32\BsExtendFunc.dll(2012-07-27 21:51:16) 000007fe29e70000
Library C:\Windows\system32\BsTrace.dll(2012-07-11 01:09:22) 0000000065600000
Library C:\Windows\SYSTEM32\Bs2Res.dll (Bluetooth Application/IVT Corporation)(2012-07-11 01:09:24) 0000000008c50000
Library C:\Program Files (x86)\AVG\AVG2015\avgsea.dll (AVG Shell Extension/AVG Technologies CZ, s.r.o. SIGNED)(2015-01-07 04:48:46) 000007fe29de0000
Library C:\Program Files (x86)\AVG\AVG2015\avgsysa.dll (AVG SYS Library/AVG Technologies CZ, s.r.o. SIGNED)(2015-01-07 04:43:30) 000007fe29b30000
Library C:\Program Files (x86)\AVG\AVG2015\avgcmla.dll (AVG CML Library/AVG Technologies CZ, s.r.o. SIGNED)(2015-01-07 04:50:46) 000007fe29aa0000
Library C:\Program Files (x86)\AVG\AVG2015\avgntopenssla.dll (AVG NT OpenSSL Library/AVG Technologies CZ, s.r.o. SIGNED)(2015-01-07 04:50:20) 000007fe29960000
Library C:\Program Files (x86)\AVG\AVG2015\avgloga.dll (AVG Logging Library/AVG Technologies CZ, s.r.o. SIGNED)(2015-01-07 04:52:34) 000007fe298f0000
Process C:\Program Files (x86)\Mozilla Firefox\firefox.exe [1664] (Firefox/Mozilla Corporation SIGNED)(2015-02-05 05:41:14) 0000000000bd0000
Process C:\Users\Sue\Desktop\Downloads\o2tejppe.exe [1156](2015-02-08 23:51:55) 0000000000400000
---- Services - GMER 2.1 ----
Service .NET CLR Data
Service .NET CLR Networking
Service .NET CLR Networking 4.0.0.0
Service .NET Data Provider for Oracle
Service .NET Data Provider for SqlServer
Service .NET Memory Cache 4.0
Service .NETFramework
Service C:\EEK\bin\a2ddax64.sys (Emsisoft Direct Disk Access Support Driver/Emsisoft GmbH SIGNED)(2015-02-08 00:49:15) [SYSTEM] A2DDA
Service C:\Program Files\ATI Technologies\ATI.ACE\Fuel\Fuel.Service.exe (AMD Fuel Service/Advanced Micro Devices, Inc.)(2012-08-08 17:36:06) [AUTO] AMD FUEL Service
Service C:\Windows\system32\DRIVERS\appexDrv.sys (AppEx Accelerator LWF/WFP Driver L.E./AppEx Networks Corporation SIGNED)(2013-05-01 19:28:43) [AUTO] APXACC
Service ASP.NET
Service ASP.NET_2.0.50727
Service ASP.NET_4.0.30319
Service ASP.NET_64_2.0.50727
Service Atierecord
Service Avg
Service C:\Windows\system32\DRIVERS\avgdiska.sys (AVG File Vault Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-06-19 03:03:34) [SYSTEM] Avgdiska
Service C:\Windows\system32\DRIVERS\avgidsdrivera.sys (AVG IDS Application Activity Monitor Driver./AVG Technologies CZ, s.r.o. SIGNED)(2014-12-09 04:24:26) [SYSTEM] AVGIDSDriver
Service C:\Windows\system32\DRIVERS\avgidsha.sys (AVG Application Activity Monitor Helper Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-11-19 04:42:04) [BOOT] AVGIDSHA
Service C:\Windows\system32\DRIVERS\avgldx64.sys (AVG AVI Loader Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-08-29 03:47:24) [SYSTEM] Avgldx64
Service C:\Windows\system32\DRIVERS\avgloga.sys (AVG Logging Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-07-18 21:53:26) [BOOT] Avgloga
Service C:\Windows\system32\DRIVERS\avgmfx64.sys (AVG Resident Shield Minifilter Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-10-06 03:41:40) [BOOT] Avgmfx64
Service C:\Windows\system32\DRIVERS\avgrkx64.sys (AVG Anti-Rootkit Driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-06-19 03:03:20) [BOOT] Avgrkx64
Service C:\Windows\system32\DRIVERS\avgwfpa.sys (AVG Firewall driver/AVG Technologies CZ, s.r.o. SIGNED)(2014-09-25 03:03:42) [SYSTEM] Avgwfpa
Service BootDefrag
Service Btcsrusb
Service C:\EEK\bin\cleanhlp64.sys (Emsisoft Cleaning Helper Driver/Emsisoft GmbH SIGNED)(2015-02-08 00:49:15) [MANUAL] cleanhlp
Service CngHwAssist
Service CscService
Service C:\Windows\system32\Drivers\ESETCleanersDriver.sys (ESET Cleaners Driver/ESET SIGNED)(2015-02-05 04:00:17) [MANUAL] ESETCleanersDriver
Service C:\Windows\System32\drivers\GUBootStartup.sys (The driver for the Startup Manager tool/Glarysoft Ltd SIGNED)(2015-01-30 05:30:42) [SYSTEM] GUBootStartup
Service C:\Program Files\HitmanPro\hmpsched.exe (HitmanPro Scheduler/SurfRight B.V. SIGNED)(2015-02-07 20:34:25) [AUTO] HitmanProScheduler
Service C:\Windows\System32\drivers\iaStorA.sys (Intel Rapid Storage Technology driver - x64/Intel Corporation SIGNED)(2012-07-31 19:22:00) [BOOT] iaStorA
Service InetInfo
Service C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan\kss.exe (Kaspersky Lab ZAO SIGNED)(2014-12-13 23:49:42) [AUTO] kss
Service mfebopk
Service MSDTC Bridge 3.0.0.0
Service MSDTC Bridge 4.0.0.0
Service PeerDistSvc
Service C:\Windows\System32\DRIVERS\PSKMAD.sys (Panda Kernel Memory Access Driver (x86)/Panda Security, S.L. SIGNED)(2015-02-08 01:19:40) [MANUAL] PSKMAD
Service RDMANDK
Service RDPUDD
Service C:\Windows\system32\DRIVERS\RtsP2Stor.sys (Realtek Pcie CardReader Driver for 2K/XP/Vista/Win7/Win8/Realtek Semiconductor Corp. SIGNED)(2013-05-01 19:29:41) [MANUAL] RSP2STOR
Service C:\Windows\System32\drivers\rtbth.sys (Ralink Bluetooth Adapter/Ralink Technology, Corp. SIGNED)(2013-12-02 16:42:14) [MANUAL] rtbth
Service ServiceModelEndpoint 3.0.0.0
Service ServiceModelOperation 3.0.0.0
Service ServiceModelService 3.0.0.0
Service C:\Windows\System32\drivers\Smb_driver_AMDASF.sys (Synaptics SMBus Driver/Synaptics Incorporated SIGNED)(2012-08-11 02:32:30) [MANUAL] SmbDrv
Service C:\Windows\System32\drivers\Smb_driver_Intel.sys (Synaptics SMBus Driver/Synaptics Incorporated SIGNED)(2012-08-11 02:32:30) [MANUAL] SmbDrvI
Service SMSvcHost 3.0.0.0
Service SMSvcHost 4.0.0.0
Service C:\Program Files (x86)\IObit\Start Menu 8\StartMenuServices.exe (StartMenu8 Services/IObit SIGNED)(2015-02-06 05:12:51) [AUTO] StartMenuService
Service C:\Windows\system32\DRIVERS\stwrt64.sys (IDT PC Audio/IDT, Inc.)(2014-07-23 01:42:18) [MANUAL] STHDA
Service C:\Windows\system32\DRIVERS\SynTP.sys (Synaptics Touchpad Driver/Synaptics Incorporated SIGNED)(2012-08-29 03:33:50) [MANUAL] SynTP
Service Windows Workflow Foundation 3.0.0.0
Service Windows Workflow Foundation 4.0.0.0
Service workerdd
Service WSearchIdxPi
---- EOF - GMER 2.1 ----
MJ1
Rookie Surfer
Rookie Surfer
Post by Superdave on Mon 09 Feb 2015, 12:50 pm
Malwarebytes' Anti-Rootkit
Please download Malwarebytes' Anti-Rootkit and save it to your desktop.
  • Be sure to print out and follow the instructions provided on that same page for performing a scan.
  • Caution: This is a beta version so also read the disclaimer and back up all your data before using.
  • When the scan completes, click on the Cleanup button to remove any threats found and reboot the computer if prompted to do so.
  • Perform another scan with Malwarebytes Anti-Rootkit to verify that no threats remain. If they do, then click Cleanup once more and repeat the process.
  • If there are problems with Internet access, Windows Update, Windows Firewall or other system issues, run the fixdamage tool located in the folder Malwarebytes Anti-Rootkit was run from and reboot your computer.
  • Two files (mbar-log-YYYY-MM-DD, system-log.txt) will be created and saved within that same folder.
  • Copy and paste the contents of these two log files in your next reply.
Tech Staff
Tech Staff
Post by MJ1 on Mon 09 Feb 2015, 2:39 pm
OK - the end result said No problems found - Nothing to clean up.
I did run the fix
and here are the txt files
Malwarebytes Anti-Rootkit BETA 1.08.3.1004
Database version:
main: v2015.02.09.01
rootkit: v2015.02.03.01
Windows 8 x64 NTFS (Safe Mode/Networking)
Internet Explorer 10.0.9200.17183
Sue :: MOMS [administrator]
2015-02-08 8:00:40 PM
mbar-log-2015-02-08 (20-00-40).txt
Scan type: Quick scan
Scan options enabled: Anti-Rootkit | Drivers | MBR | Physical Sectors | Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken
Scan options disabled:
Objects scanned: 335264
Time elapsed: 22 minute(s), 42 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 0
Physical Sectors Detected: 0
(end)
(c) Malwarebytes Corporation 2011-2012
OS version: 6.2.9200 Windows 8 x64
System is currently in a safe mode
Account is Administrative
Internet Explorer version: 10.0.9200.17183
File system is: NTFS
Disk drives: C:\ DRIVE_FIXED, D:\ DRIVE_FIXED
CPU speed: 1.896000 GHz
Memory total: 3726909440, free: 2270793728
Downloaded database version: v2015.02.04.14
Downloaded database version: v2015.02.03.01
Downloaded database version: v2014.12.06.01
Initializing...
This version of Malwarebytes Anti-Rootkit requires you to completely exit the Malwarebytes Anti-Malware application to continue.
Memory total: 3726909440, free: 2205351936
Downloaded database version: v2015.02.05.01
Initializing...
------------ Kernel report ------------
02/04/2015 22:05:30
------------ Loaded modules -----------
\SystemRoot\system32\ntoskrnl.exe
\SystemRoot\system32\hal.dll
\SystemRoot\system32\kd.dll
\SystemRoot\system32\mcupdate_AuthenticAMD.dll
\SystemRoot\System32\drivers\CLFS.SYS
\SystemRoot\System32\drivers\tm.sys
\SystemRoot\system32\PSHED.dll
\SystemRoot\system32\BOOTVID.dll
\SystemRoot\system32\CI.dll
\SystemRoot\System32\drivers\msrpc.sys
\SystemRoot\system32\drivers\Wdf01000.sys
\SystemRoot\system32\drivers\WDFLDR.SYS
\SystemRoot\System32\Drivers\acpiex.sys
\SystemRoot\System32\Drivers\WppRecorder.sys
\SystemRoot\System32\drivers\ACPI.sys
\SystemRoot\System32\drivers\WMILIB.SYS
\SystemRoot\System32\Drivers\cng.sys
\SystemRoot\system32\DRIVERS\avgboota.sys
\SystemRoot\System32\drivers\msisadrv.sys
\SystemRoot\System32\drivers\pci.sys
\SystemRoot\System32\drivers\isapnp.sys
\SystemRoot\System32\drivers\vdrvroot.sys
\SystemRoot\system32\drivers\pdc.sys
\SystemRoot\System32\drivers\partmgr.sys
\SystemRoot\System32\drivers\spaceport.sys
\SystemRoot\System32\drivers\volmgr.sys
\SystemRoot\System32\drivers\volmgrx.sys
\SystemRoot\System32\drivers\vmbus.sys
\SystemRoot\System32\drivers\vmbkmcl.sys
\SystemRoot\System32\drivers\winhv.sys
\SystemRoot\System32\drivers\nvraid.sys
\SystemRoot\System32\drivers\CLASSPNP.SYS
\SystemRoot\System32\drivers\pciide.sys
\SystemRoot\System32\drivers\PCIIDEX.SYS
\SystemRoot\System32\drivers\intelide.sys
\SystemRoot\System32\drivers\viaide.sys
\SystemRoot\System32\drivers\bxvbda.sys
\SystemRoot\System32\drivers\evbda.sys
\SystemRoot\System32\drivers\sdbus.sys
\SystemRoot\System32\drivers\pcmcia.sys
\SystemRoot\System32\drivers\mountmgr.sys
\SystemRoot\System32\drivers\iaStorV.sys
\SystemRoot\System32\drivers\nvstor.sys
\SystemRoot\System32\drivers\storport.sys
\SystemRoot\System32\drivers\lsi_sas.sys
\SystemRoot\System32\drivers\lsi_sas2.sys
\SystemRoot\System32\drivers\lsi_sss.sys
\SystemRoot\System32\drivers\3ware.sys
\SystemRoot\System32\drivers\mvumis.sys
\SystemRoot\System32\drivers\vstxraid.sys
\SystemRoot\System32\drivers\lsi_scsi.sys
\SystemRoot\System32\drivers\megasas.sys
\SystemRoot\System32\drivers\MegaSR.sys
\SystemRoot\System32\drivers\amdsata.sys
\SystemRoot\System32\drivers\amdxata.sys
\SystemRoot\System32\drivers\amdsbs.sys
\SystemRoot\System32\drivers\adp94xx.sys
\SystemRoot\System32\drivers\adpahci.sys
\SystemRoot\System32\drivers\adpu320.sys
\SystemRoot\System32\drivers\arc.sys
\SystemRoot\System32\drivers\arcsas.sys
\SystemRoot\System32\drivers\iirsp.sys
\SystemRoot\System32\drivers\nfrd960.sys
\SystemRoot\System32\drivers\vsmraid.sys
\SystemRoot\System32\drivers\SiSRaid2.sys
\SystemRoot\System32\drivers\sisraid4.sys
\SystemRoot\System32\drivers\atapi.sys
\SystemRoot\System32\drivers\ataport.SYS
\SystemRoot\System32\drivers\storahci.sys
\SystemRoot\System32\drivers\stexstor.sys
\SystemRoot\System32\drivers\amd_sata.sys
\SystemRoot\System32\drivers\amd_xata.sys
\SystemRoot\System32\drivers\HpSAMD.sys
\SystemRoot\System32\drivers\EhStorTcgDrv.sys
\SystemRoot\System32\drivers\EhStorClass.sys
\SystemRoot\system32\drivers\fltmgr.sys
\SystemRoot\System32\drivers\fileinfo.sys
\SystemRoot\System32\Drivers\Ntfs.sys
\SystemRoot\System32\Drivers\ksecdd.sys
\SystemRoot\System32\drivers\storvsc.sys
\SystemRoot\System32\drivers\usbhub.sys
\SystemRoot\System32\drivers\USBD.SYS
\SystemRoot\System32\drivers\usbehci.sys
\SystemRoot\System32\drivers\USBPORT.SYS
\SystemRoot\System32\drivers\ucx01000.sys
\SystemRoot\System32\drivers\UsbHub3.sys
\SystemRoot\System32\drivers\pcw.sys
\SystemRoot\System32\Drivers\Fs_Rec.sys
\SystemRoot\system32\drivers\ndis.sys
\SystemRoot\system32\drivers\NETIO.SYS
\SystemRoot\System32\Drivers\ksecpkg.sys
\SystemRoot\System32\drivers\tcpip.sys
\SystemRoot\System32\drivers\fwpkclnt.sys
\SystemRoot\system32\DRIVERS\wfplwfs.sys
\SystemRoot\system32\DRIVERS\vmstorfl.sys
\SystemRoot\System32\DRIVERS\fvevol.sys
\SystemRoot\System32\drivers\gagp30kx.sys
\SystemRoot\System32\drivers\uagp35.sys
\SystemRoot\System32\drivers\agp440.sys
\SystemRoot\System32\drivers\nv_agp.sys
\SystemRoot\System32\drivers\uliagpkx.sys
\SystemRoot\system32\DRIVERS\usbfilter.sys
\SystemRoot\system32\DRIVERS\hpdskflt.sys
\SystemRoot\System32\drivers\wd.sys
\SystemRoot\System32\drivers\volsnap.sys
\SystemRoot\System32\drivers\USBXHCI.SYS
\SystemRoot\System32\drivers\USBSTOR.SYS
\SystemRoot\System32\drivers\uaspstor.sys
\SystemRoot\System32\drivers\sdstor.sys
\SystemRoot\System32\drivers\sbp2port.sys
\SystemRoot\System32\drivers\rdyboost.sys
\SystemRoot\System32\Drivers\mup.sys
\SystemRoot\System32\drivers\disk.sys
\SystemRoot\System32\Drivers\crashdmp.sys
\SystemRoot\System32\Drivers\Null.SYS
\SystemRoot\System32\Drivers\Beep.SYS
\SystemRoot\System32\drivers\BasicRender.sys
\SystemRoot\System32\drivers\dxgkrnl.sys
\SystemRoot\System32\drivers\watchdog.sys
\SystemRoot\System32\drivers\dxgmms1.sys
\SystemRoot\System32\drivers\BasicDisplay.sys
\SystemRoot\System32\Drivers\Npfs.SYS
\SystemRoot\System32\Drivers\Msfs.SYS
\SystemRoot\system32\DRIVERS\tdx.sys
\SystemRoot\system32\DRIVERS\TDI.SYS
\SystemRoot\System32\DRIVERS\netbt.sys
\SystemRoot\system32\drivers\afd.sys
\SystemRoot\system32\DRIVERS\pacer.sys
\SystemRoot\system32\DRIVERS\vwififlt.sys
\SystemRoot\system32\DRIVERS\netbios.sys
\SystemRoot\system32\DRIVERS\rdbss.sys
\SystemRoot\system32\drivers\nsiproxy.sys
\SystemRoot\System32\drivers\npsvctrig.sys
\SystemRoot\System32\drivers\mssmbios.sys
\SystemRoot\System32\Drivers\dfsc.sys
\SystemRoot\system32\DRIVERS\ndistapi.sys
\SystemRoot\system32\DRIVERS\ndiswan.sys
\SystemRoot\system32\DRIVERS\rassstp.sys
\SystemRoot\system32\DRIVERS\AgileVpn.sys
\SystemRoot\system32\DRIVERS\tunnel.sys
\SystemRoot\System32\drivers\CompositeBus.sys
\SystemRoot\system32\DRIVERS\kdnic.sys
\SystemRoot\System32\drivers\umbus.sys
\SystemRoot\System32\drivers\WirelessButtonDriver64.sys
\SystemRoot\System32\drivers\HIDCLASS.SYS
\SystemRoot\System32\drivers\HIDPARSE.SYS
\SystemRoot\System32\drivers\HDAudBus.sys
\SystemRoot\system32\DRIVERS\netr28x.sys
\SystemRoot\System32\drivers\vwifibus.sys
\SystemRoot\System32\drivers\cdrom.sys
\SystemRoot\System32\drivers\usbohci.sys
\SystemRoot\System32\drivers\usbccgp.sys
\SystemRoot\System32\drivers\i8042prt.sys
\SystemRoot\System32\drivers\kbdclass.sys
\SystemRoot\System32\drivers\mouclass.sys
\SystemRoot\system32\DRIVERS\Rt630x64.sys
\SystemRoot\system32\DRIVERS\Accelerometer.sys
\SystemRoot\System32\drivers\wmiacpi.sys
\SystemRoot\system32\DRIVERS\raspptp.sys
\SystemRoot\system32\DRIVERS\rasl2tp.sys
\SystemRoot\system32\DRIVERS\raspppoe.sys
\SystemRoot\System32\drivers\swenum.sys
\SystemRoot\System32\drivers\ks.sys
\SystemRoot\System32\drivers\rdpbus.sys
\SystemRoot\System32\Drivers\NDProxy.SYS
\SystemRoot\System32\Drivers\fastfat.SYS
\SystemRoot\System32\win32k.sys
\SystemRoot\System32\TSDDD.dll
\SystemRoot\System32\cdd.dll
\SystemRoot\System32\ATMFD.DLL
\SystemRoot\system32\DRIVERS\nwifi.sys
\SystemRoot\system32\DRIVERS\ndisuio.sys
\SystemRoot\system32\DRIVERS\bowser.sys
\SystemRoot\System32\drivers\mpsdrv.sys
\SystemRoot\system32\DRIVERS\mrxsmb.sys
\SystemRoot\system32\DRIVERS\mrxsmb10.sys
\SystemRoot\system32\DRIVERS\mrxsmb20.sys
\SystemRoot\system32\DRIVERS\vwifimp.sys
\SystemRoot\System32\drivers\condrv.sys
\??\C:\Windows\system32\drivers\mbamchameleon.sys
\??\C:\Windows\system32\drivers\MBAMSwissArmy.sys
----------- End -----------
Done!
Scan started
Database versions:
main: v2015.02.05.01
<<<2>>>
Physical Sector Size: 512
Drive: 0, DevicePointer: 0xfffffa80052df060, DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\disk\
--------- Disk Stack ------
DevicePointer: 0xfffffa80052dfb10, DeviceName: Unknown, DriverName: \Driver\partmgr\
DevicePointer: 0xfffffa80052b5950, DeviceName: Unknown, DriverName: \Driver\hpdskflt\
DevicePointer: 0xfffffa80050f3040, DeviceName: Unknown, DriverName: \Driver\amd_xata\
DevicePointer: 0xfffffa80051132d0, DeviceName: \Device\00000036\, DriverName: \Driver\amd_sata\
------------ End ----------
Alternate DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\disk\
Upper DeviceData: 0x0, 0x0, 0x0
Lower DeviceData: 0x0, 0x0, 0x0
<<<3>>>
Volume: C:
File system type: NTFS
SectorSize = 512, ClusterSize = 4096, MFTRecordSize = 1024, MFTIndexSize = 4096 bytes
<<<2>>>
<<<3>>>
Volume: C:
Scanning drivers directory: C:\WINDOWS\SYSTEM32\drivers...
File "C:\Windows\System32\Drivers\vwifibus.sys" is compressed (flags = 1)
File "C:\WINDOWS\SYSTEM32\drivers\vwifibus.sys" is compressed (flags = 1)
Done!
Drive 0
This is a System drive
Scanning MBR on drive 0...
Inspecting partition table:
This drive is a GPT Drive.
MBR Signature: 55AA
Disk Signature: 2D3A2CF0
GPT Protective MBR Partition information:
Partition 0 type is EFI-GPT (0xee)
Partition is NOT ACTIVE.
Partition starts at LBA: 1 Numsec = 976773167
Partition 1 type is Empty (0x0)
Partition starts at LBA: 0 Numsec = 0
Partition 2 type is Empty (0x0)
Partition 3 type is Empty (0x0)
GPT Partition information:
GPT Header Signature 4546492050415254
GPT Header Revision 65536 Size 92 CRC 983076807
GPT Header CurrentLba = 1 BackupLba 976773167
GPT Header FirstUsableLba 34 LastUsableLba 976773134
GPT Header Guid 5cfd64c-e4c0-43f0-852b-226c5d1ca779
GPT Header Contains 128 partition entries starting at LBA 2
GPT Header Partition entry size = 128
Backup GPT header Signature 4546492050415254
Backup GPT header Revision 65536 Size 92 CRC 983076807
Backup GPT header CurrentLba = 976773167 BackupLba 1
Backup GPT header FirstUsableLba 34 LastUsableLba 976773134
Backup GPT header Guid 5cfd64c-e4c0-43f0-852b-226c5d1ca779
Backup GPT header Contains 128 partition entries starting at LBA 976773135
Backup GPT header Partition entry size = 128
Partition 0 Type de94bba4-6d1-4d40-a16a-bfd5179d6ac
Partition ID 61f6fd05-97d3-4fea-8653-76829fdcb51d
FirstLBA 2048 Last LBA 821247
Attributes 1
Partition Name Basic data partition
Partition 1 Type c12a7328-f81f-11d2-ba4b-0a0c93ec93b
Partition ID d05879ac-393e-438b-8584-ef9f87276894
FirstLBA 821248 Last LBA 1353727
Attributes 0
Partition Name EFI system partition
GPT Partition 1 is bootable
Partition 2 Type e3c9e316-b5c-4db8-817d-f92df0215ae
Partition ID 2a19bd57-c2ce-4814-83d-c270e076c811
FirstLBA 1353728 Last LBA 1615871
Attributes 0
Partition Name Microsoft reserved partition
Partition 3 Type ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
Partition ID 207250e8-2c5e-497a-a160-5975fe90eec9
FirstLBA 1615872 Last LBA 924479487
Attributes 0
Partition 4 Type de94bba4-6d1-4d40-a16a-bfd5179d6ac
Partition ID a2b99c1d-d492-4386-a86-a1dfb8f5f4d2
FirstLBA 924479488 Last LBA 925401087
Attributes 1
Partition Name
Partition 5 Type ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
Partition ID f7e509cb-d612-4558-a116-1839788b440
FirstLBA 925401088 Last LBA 976773119
Attributes 1
Disk Size: 500107862016 bytes
Sector size: 512 bytes
Done!
Scan finished
Removal queue found; removal started
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\MBR-0-i.mbam...
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\MBR-0-r.mbam...
Removal finished
Memory total: 3726909440, free: 2804391936
Downloaded database version: v2015.02.09.01
Initializing...
02/08/2015 20:00:28
Done!
Scan started
Database versions:
<<<2>>>
Drive: 0, DevicePointer: 0xfffffa80052db060, DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\disk\
DevicePointer: 0xfffffa80052dbaa0, DeviceName: Unknown, DriverName: \Driver\partmgr\
DevicePointer: 0xfffffa80052afb10, DeviceName: Unknown, DriverName: \Driver\hpdskflt\
DevicePointer: 0xfffffa80050ee040, DeviceName: Unknown, DriverName: \Driver\amd_xata\
DevicePointer: 0xfffffa80050f2060, DeviceName: \Device\00000036\, DriverName: \Driver\amd_sata\
<<<3>>>
Volume: C:
<<<2>>>
<<<3>>>
Volume: C:
Done!
Drive 0
MBR Signature: 55AA
Attributes 1
Attributes 0
Attributes 0
Attributes 0
Attributes 1
Partition Name
Attributes 1
Done!
Scan finished
Removal finished
MJ1
Rookie Surfer
Rookie Surfer
Post by Superdave on Tue 10 Feb 2015, 6:30 am
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by MJ1 on Tue 10 Feb 2015, 10:05 am
I had previously run this (last week) and I believe it did find Spigot and deleted it.
This time it came out clean.
all ok
all ok
# product=EOS
# version=8
# OnlineScanner.ocx=1.0.0.7623
# api_version=3.0.2
# EOSSerial=20fabb0905dc944ba050b048e1688591
# engine=22335
# end=finished
# remove_checked=false
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=true
# antistealth_checked=true
# utc_time=2015-02-06 09:15:58
# local_time=2015-02-06 02:15:58 (-0700, Mountain Standard Time)
# country="Canada"
# lang=1033
# osver=6.2.9200 NT
# compatibility_mode_1='AVG AntiVirus Free Edition 2015'
# compatibility_mode=1055 16777214 100 100 0 109397742 0 0
# compatibility_mode_1=''
# compatibility_mode=5893 16776574 100 94 6516996 82633869 0 0
# scanned=221172
# found=0
# cleaned=0
# scan_time=6584
all ok
# product=EOS
# version=8
# api_version=3.0.2
# engine=22386
# end=finished
# utc_time=2015-02-09 10:47:17
# local_time=2015-02-09 03:47:17 (-0700, Mountain Standard Time)
# country="Canada"
# lang=1033
# osver=6.2.9200 NT
# compatibility_mode=1055 16777214 100 100 0 109705621 0 0
# compatibility_mode=5893 16776574 100 94 6824875 82941748 0 0
# scanned=222226
# found=0
# cleaned=0
# scan_time=5291
I have previously run several online scanners, etc and they can't seem to find this bug. I'm hoping you will come up with some type of magic bullet.
MJ1
Rookie Surfer
Rookie Surfer
Post by Superdave on Tue 10 Feb 2015, 10:20 am
Has anything changed since we started cleaning?
Tech Staff
Tech Staff
Post by MJ1 on Wed 11 Feb 2015, 5:36 pm
I went on to regular start up and it seemed a bit better but would not let me run any antivirus.
The disk is showing 100% usage  (it has 300 gigs free) and I read that AVG can do that - so have tried to take it off and 6 dll's are saying they are being used by another program and won't delete.
It still won't let me do any kind of refresh. Its still quite bad
I
MJ1
Rookie Surfer
Rookie Surfer
Post by MJ1 on Wed 11 Feb 2015, 6:45 pm
I don't have time to work on it the next few days, so lets just leave it as I may just send it out to get Windows 8 reloaded.
I'll come back in a few days if I need more help.. THanks
MJ1
Rookie Surfer
Rookie Surfer
Post by Superdave on Thu 12 Feb 2015, 2:18 am
Windows 8 and 8.1 comes with its own AV called Windows Defender. You would be well advised to uninstall AVG. If you have problems, you can use the AVG removal tool below.
AVG Antivirus - AVG Anti-virus Removal Tool
Tech Staff
Tech Staff
Post by Sponsored content Today at 12:58 pm
