Uknown issue causing hardware and software issues
Post by thisdj1 on Thu Dec 25, 2014 5:52 pm
I have recently encountered an issue with my machine. I first noticed it when I was unable to load or play any .mp3 file on my computer or open up windows media player. I ran an MBAM scan and after that was able to run WMP. However, another music playing program I have is unable to find an audio device. I've also discovered that Windows Installer is not working as well. Here are my logs from the AdwCleaner and Security Check.
# AdwCleaner v4.106 - Report created 25/12/2014 at 11:41:08
# Updated 21/12/2014 by Xplode
# Database : 2014-12-21.4 [Live]
# Operating System : Windows 7 Home Premium Service Pack 1 (64 bits)
# Username : Mike - MIKE-PC
# Running from : C:\Users\Mike\Downloads\adwcleaner_4.106.exe
# Option : Clean
***** [ Services ] *****
***** [ Files / Folders ] *****
[!] Folder Deleted : C:\ProgramData\Partner
[!] Folder Deleted : C:\Program Files (x86)\Conduit
[!] Folder Deleted : C:\Program Files (x86)\xVidly
[!] Folder Deleted : C:\Users\Mike\AppData\Local\Conduit
[!] Folder Deleted : C:\Users\Mike\AppData\Local\PackageAware
[!] Folder Deleted : C:\Users\Mike\AppData\LocalLow\Conduit
File Deleted : C:\END
File Deleted : C:\windows\Reimage.ini
File Deleted : C:\Users\Mike\AppData\Local\Temp\Searchqu.ini
File Deleted : C:\Users\Mike\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\xVidly.lnk
File Deleted : C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\Local Storage\hxxps_static.olark.com_0.localstorage-journal
***** [ Scheduled Tasks ] *****
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Deleted : HKLM\SOFTWARE\Classes\AppID\BrowserConnection.dll
Key Deleted : HKLM\SOFTWARE\Classes\AppID\DNSBHO.dll
Key Deleted : HKLM\SOFTWARE\Classes\Toolbar.CT3287307
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{AC662AF2-4601-4A68-84DF-A3FE83F1A5F9}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{D97A8234-F2A2-4AD4-91D5-FECDB2C553AF}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{3F607E46-0D3C-4442-B1DE-DE7FA4768F5C}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{FE0273D1-99DF-4AC0-87D5-1371C6271785}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{93E3D79C-0786-48FF-9329-93BC9F6DC2B3}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{3F607E46-0D3C-4442-B1DE-DE7FA4768F5C}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{FE0273D1-99DF-4AC0-87D5-1371C6271785}
Key Deleted : [x64] HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2410}
Key Deleted : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2410}
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{C7E1DB97-8BAD-4350-A768-7A876A7632EB}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2410}
Key Deleted : HKCU\Software\SearchCore for Browsers
Key Deleted : HKCU\Software\Reimage
Key Deleted : HKCU\Software\AppDataLow\Software\Conduit
Key Deleted : HKCU\Software\AppDataLow\Software\SmartBar
Key Deleted : HKLM\SOFTWARE\Conduit
Key Deleted : HKLM\SOFTWARE\SearchCore for Browsers
Key Deleted : HKLM\SOFTWARE\SearchquMediabarTb
Key Deleted : [x64] HKLM\SOFTWARE\SearchCore for Browsers
Key Deleted : [x64] HKLM\SOFTWARE\Reimage
Data Deleted : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows [AppInit_DLLs] - C:\PROGRA~2\SEARCH~1\SEARCH~1\datamngr.dll
Data Deleted : [x64] HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows [AppInit_DLLs] - C:\PROGRA~2\SEARCH~1\SEARCH~1\x64\IEBHO.dll
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\LowRegistry\DOMStorage\ask.com
***** [ Browsers ] *****
-\\ Internet Explorer v11.0.9600.17496
-\\ Google Chrome v38.0.2125.104
AdwCleaner[R0].txt - [3978 octets] - [25/12/2014 11:39:37]
AdwCleaner[S0].txt - [3369 octets] - [25/12/2014 11:41:08]
########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [3429 octets] ##########
Results of screen317's Security Check version 0.99.93
Windows 7 Service Pack 1 x64 (UAC is enabled)
Internet Explorer 11
Windows Firewall Enabled!
WMI entry may not exist for antivirus; attempting automatic update.
Java(TM) 6 Update 14
Java version 32-bit out of Date!
Adobe Reader 9 Adobe Reader out of Date!
Google Chrome 37.0.2062.124 Google Chrome out of date!
Total Fragmentation on Drive C: 3%
thisdj1
Posts Posts : 56
Joined Joined : 2009-01-09
Points Points : 29249
Re: Uknown issue causing hardware and software issues
Post by Superdave on Thu Dec 25, 2014 8:17 pm
Looking over your log it seems you don't have any antivirus software.
Before we continue download and install a free antivirus.
Remember to only install one antivirus!
2) [You must be registered and logged in to see this link.]
3) [You must be registered and logged in to see this link.]
4) [You must be registered and logged in to see this link.] All versions and all languages.
5) [You must be registered and logged in to see this link.] (Uncheck during installation "Install Comodo SafeSurf..", Make Comodo my default search provider" and "Make Comodo Search my homepage" if you choose this one)
It is strongly recommended that you run only one antivirus program at a time. Having more than one antivirus program active in memory uses additional resources and can result in program conflicts and false virus alerts. If you choose to install more than one antivirus program on your computer, then only one of them should be active in memory at a time.
•Temporarily disable your Antivirus and any Antispyware real time protection before performing a scan. Click [You must be registered and logged in to see this link.] link to see a list of security programs that should be disabled and how to disable them.
Update Your Java (JRE)
First [You must be registered and logged in to see this link.]
If your version is out of date install the newest version of the [You must be registered and logged in to see this link.].
Remove any old versions
1. Download [You must be registered and logged in to see this link.] and unzip the file to your Desktop.
3. Once complete exit JavaRA.
Additional Note: [You must be registered and logged in to see this link.] adds a service to improve the initial startup time of Java applets and applications. To disable the JQS service if you don't want to use it, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and reboot your computer.
Update your Adobe Reader. [You must be registered and logged in to see this link.].
Be sure to uncheck the Free McAfee Security Scan so it isn't installed.
Malwarebytes' Anti-Rootkit
Please download [You must be registered and logged in to see this link.] and save it to your desktop.
  • Be sure to print out and follow the instructions provided on that same page for performing a scan.
  • Caution: This is a beta version so also read the disclaimer and [You must be registered and logged in to see this link.] all your data before using.
  • When the scan completes, click on the Cleanup button to remove any threats found and reboot the computer if prompted to do so.
  • Perform another scan with Malwarebytes Anti-Rootkit to verify that no threats remain. If they do, then click Cleanup once more and repeat the process.
  • If there are problems with Internet access, Windows Update, Windows Firewall or other system issues, run the fixdamage tool located in the folder Malwarebytes Anti-Rootkit was run from and reboot your computer.
  • Two files (mbar-log-YYYY-MM-DD, system-log.txt) will be created and saved within that same folder.
  • Copy and paste the contents of these two log files in your next reply.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83171
Post by thisdj1 on Fri Dec 26, 2014 2:54 am
I attempted to install an AV before I created this thread and it will not install as it said it can't start Windows Installer. So I am unable to get it downloaded. Do you want me to proceed with the other steps for now?
thisdj1
Posts Posts : 56
Post by Superdave on Fri Dec 26, 2014 6:50 pm
Yes, go ahead and run the other scans. As for Windows Installer, please do this: Right-click on My Computer and select Manage. Click on Services and look for Windows Installer and tell me if it's started or stopped.
Captain
Captain
Posts Posts : 4202
Post by thisdj1 on Fri Dec 26, 2014 8:38 pm
I had looked before about the issue and it was running but still not working.
thisdj1
Posts Posts : 56
Post by Superdave on Fri Dec 26, 2014 11:20 pm
Ok, let's run the scans that you are able to run.
Captain
Captain
Posts Posts : 4202
Post by thisdj1 on Sun Dec 28, 2014 3:22 pm
Well, I did as much as I could. The Windows Installer issue has prevented me from updating my Java and Adobe. The MBAR found no threats and I also ran the fixdamage as Windows Updates have been having issues. It keeps trying to install 6 updates but after restart it wants to install the same 6. So, I'm assuming it too has something to do with the installer issue. Here are the logs.
Version: 6.4.1 (12.28.2014:1)
OS: Windows 7 Home Premium x64
Ran by Mike on Sun 12/28/2014 at 8:30:24.48
~~~ Services
~~~ Registry Values
~~~ Registry Keys
Successfully deleted: [Registry Key - Orphan] HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}
Successfully deleted: [Registry Key - Orphan] HKEY_CLASSES_ROOT\CLSID\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}
Successfully deleted: [Registry Key - Orphan] HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}
Successfully deleted: [Registry Key - Orphan] HKEY_CLASSES_ROOT\CLSID\{5C255C8A-E604-49b4-9D64-90988571CECB}
Successfully deleted: [Registry Key - Orphan] HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{9030D464-4C02-4ABF-8ECC-5164760863C6}
Successfully deleted: [Registry Key - Orphan] HKEY_CLASSES_ROOT\CLSID\{9030D464-4C02-4ABF-8ECC-5164760863C6}
Successfully deleted: [Registry Key - Orphan] HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}
Successfully deleted: [Registry Key - Orphan] HKEY_CLASSES_ROOT\CLSID\{DBC80044-A445-435b-BC74-9C25C1C588A9}
Successfully deleted: [Registry Key - Orphan] HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}
Successfully deleted: [Registry Key - Orphan] HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}
Successfully deleted: [Registry Key - Orphan] HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{9030D464-4C02-4ABF-8ECC-5164760863C6}
Successfully deleted: [Registry Key - Orphan] HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}
~~~ Files
~~~ Folders
Successfully deleted: [Folder] "C:\Users\Mike\appdata\local\cre"
Failed to delete: [Folder] "C:\ai_recyclebin"
Successfully deleted: [Folder] "C:\windows\syswow64\ai_recyclebin"
~~~ Event Viewer Logs were cleared
Scan was completed on Sun 12/28/2014 at 8:34:33.20
End of JRT log
Malwarebytes Anti-Rootkit BETA 1.08.2.1001
Database version: v2014.12.28.07
Windows 7 Service Pack 1 x64 NTFS
Internet Explorer 11.0.9600.17501
Mike :: MIKE-PC [administrator]
12/28/2014 8:59:37 AM
mbar-log-2014-12-28 (08-59-37).txt
Scan type: Quick scan
Scan options enabled: Anti-Rootkit | Drivers | MBR | Physical Sectors | Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken
Scan options disabled:
Objects scanned: 370780
Time elapsed: 17 minute(s),
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 0
Physical Sectors Detected: 0
(end)
(c) Malwarebytes Corporation 2011-2012
OS version: 6.1.7601 Windows 7 Service Pack 1 x64
Account is Administrative
Internet Explorer version: 11.0.9600.17501
Java version: 1.6.0_14
File system is: NTFS
Disk drives: C:\ DRIVE_FIXED
CPU speed: 2.194000 GHz
Memory total: 4123926528, free: 2752204800
Downloaded database version: v2014.12.28.07
Downloaded database version: v2014.12.23.02
Downloaded database version: v2014.12.06.01
Initializing...
------------ Kernel report ------------
12/28/2014 08:59:25
------------ Loaded modules -----------
\SystemRoot\system32\ntoskrnl.exe
\SystemRoot\system32\hal.dll
\SystemRoot\system32\kdcom.dll
\SystemRoot\system32\mcupdate_GenuineIntel.dll
\SystemRoot\system32\PSHED.dll
\SystemRoot\system32\CLFS.SYS
\SystemRoot\system32\CI.dll
\SystemRoot\system32\drivers\Wdf01000.sys
\SystemRoot\system32\drivers\WDFLDR.SYS
\SystemRoot\system32\drivers\ACPI.sys
\SystemRoot\system32\drivers\WMILIB.SYS
\SystemRoot\system32\drivers\msisadrv.sys
\SystemRoot\system32\drivers\pci.sys
\SystemRoot\system32\drivers\vdrvroot.sys
\SystemRoot\system32\DRIVERS\LPCFilter.sys
\SystemRoot\System32\drivers\partmgr.sys
\SystemRoot\system32\DRIVERS\compbatt.sys
\SystemRoot\system32\DRIVERS\BATTC.SYS
\SystemRoot\system32\drivers\volmgr.sys
\SystemRoot\System32\drivers\volmgrx.sys
\SystemRoot\System32\drivers\mountmgr.sys
\SystemRoot\system32\drivers\pciide.sys
\SystemRoot\system32\drivers\PCIIDEX.SYS
\SystemRoot\system32\DRIVERS\iaStor.sys
\SystemRoot\system32\drivers\atapi.sys
\SystemRoot\system32\drivers\ataport.SYS
\SystemRoot\system32\drivers\msahci.sys
\SystemRoot\system32\drivers\amdxata.sys
\SystemRoot\system32\drivers\fltmgr.sys
\SystemRoot\system32\drivers\fileinfo.sys
\SystemRoot\System32\Drivers\PxHlpa64.sys
\SystemRoot\System32\Drivers\Ntfs.sys
\SystemRoot\System32\Drivers\msrpc.sys
\SystemRoot\System32\Drivers\ksecdd.sys
\SystemRoot\System32\Drivers\cng.sys
\SystemRoot\System32\drivers\pcw.sys
\SystemRoot\System32\Drivers\Fs_Rec.sys
\SystemRoot\system32\drivers\ndis.sys
\SystemRoot\system32\drivers\NETIO.SYS
\SystemRoot\System32\Drivers\ksecpkg.sys
\SystemRoot\System32\drivers\tcpip.sys
\SystemRoot\System32\drivers\fwpkclnt.sys
\SystemRoot\system32\drivers\volsnap.sys
\SystemRoot\system32\DRIVERS\TVALZ_O.SYS
\SystemRoot\system32\DRIVERS\tos_sps64.sys
\SystemRoot\System32\Drivers\spldr.sys
\SystemRoot\System32\drivers\rdyboost.sys
\SystemRoot\System32\Drivers\mup.sys
\SystemRoot\System32\drivers\hwpolicy.sys
\SystemRoot\System32\DRIVERS\fvevol.sys
\SystemRoot\system32\DRIVERS\disk.sys
\SystemRoot\system32\DRIVERS\CLASSPNP.SYS
\SystemRoot\system32\DRIVERS\cdrom.sys
\SystemRoot\System32\Drivers\Null.SYS
\SystemRoot\System32\Drivers\Beep.SYS
\SystemRoot\System32\drivers\vga.sys
\SystemRoot\System32\drivers\VIDEOPRT.SYS
\SystemRoot\System32\drivers\watchdog.sys
\SystemRoot\System32\DRIVERS\RDPCDD.sys
\SystemRoot\system32\drivers\rdpencdd.sys
\SystemRoot\system32\drivers\rdprefmp.sys
\SystemRoot\System32\Drivers\Msfs.SYS
\SystemRoot\System32\Drivers\Npfs.SYS
\SystemRoot\system32\DRIVERS\tdx.sys
\SystemRoot\system32\DRIVERS\TDI.SYS
\SystemRoot\system32\drivers\afd.sys
\SystemRoot\System32\DRIVERS\netbt.sys
\SystemRoot\system32\DRIVERS\wfplwf.sys
\SystemRoot\system32\DRIVERS\pacer.sys
\SystemRoot\system32\DRIVERS\vwififlt.sys
\SystemRoot\system32\DRIVERS\netbios.sys
\SystemRoot\system32\DRIVERS\wanarp.sys
\SystemRoot\system32\drivers\termdd.sys
\SystemRoot\system32\DRIVERS\rdbss.sys
\SystemRoot\system32\drivers\nsiproxy.sys
\SystemRoot\system32\drivers\mssmbios.sys
\SystemRoot\System32\drivers\discache.sys
\SystemRoot\System32\Drivers\dfsc.sys
\SystemRoot\system32\DRIVERS\blbdrive.sys
\SystemRoot\system32\DRIVERS\tunnel.sys
\SystemRoot\system32\DRIVERS\igdkmd64.sys
\SystemRoot\System32\drivers\dxgkrnl.sys
\SystemRoot\System32\drivers\dxgmms1.sys
\SystemRoot\system32\DRIVERS\usbuhci.sys
\SystemRoot\system32\DRIVERS\USBPORT.SYS
\SystemRoot\system32\DRIVERS\usbehci.sys
\SystemRoot\system32\drivers\HDAudBus.sys
\SystemRoot\system32\DRIVERS\Rt64win7.sys
\SystemRoot\system32\DRIVERS\CmBatt.sys
\SystemRoot\system32\drivers\i8042prt.sys
\SystemRoot\system32\drivers\kbdclass.sys
\SystemRoot\system32\DRIVERS\SynTP.sys
\SystemRoot\system32\DRIVERS\USBD.SYS
\SystemRoot\system32\drivers\mouclass.sys
\SystemRoot\system32\DRIVERS\tdcmdpst.sys
\SystemRoot\system32\DRIVERS\intelppm.sys
\SystemRoot\system32\drivers\CompositeBus.sys
\SystemRoot\system32\DRIVERS\AgileVpn.sys
\SystemRoot\system32\DRIVERS\rasl2tp.sys
\SystemRoot\system32\DRIVERS\ndistapi.sys
\SystemRoot\system32\DRIVERS\ndiswan.sys
\SystemRoot\system32\DRIVERS\raspppoe.sys
\SystemRoot\system32\DRIVERS\raspptp.sys
\SystemRoot\system32\DRIVERS\rassstp.sys
\SystemRoot\system32\drivers\swenum.sys
\SystemRoot\system32\drivers\ks.sys
\SystemRoot\system32\drivers\umbus.sys
\SystemRoot\system32\DRIVERS\usbhub.sys
\SystemRoot\System32\Drivers\NDProxy.SYS
\SystemRoot\system32\drivers\HdAudio.sys
\SystemRoot\system32\drivers\portcls.sys
\SystemRoot\system32\drivers\drmk.sys
\SystemRoot\system32\drivers\ksthunk.sys
\SystemRoot\System32\Drivers\crashdmp.sys
\SystemRoot\System32\Drivers\dump_iaStor.sys
\SystemRoot\System32\Drivers\dump_dumpfve.sys
\SystemRoot\system32\DRIVERS\RTL8187B.sys
\SystemRoot\System32\drivers\vwifibus.sys
\SystemRoot\System32\win32k.sys
\SystemRoot\System32\drivers\Dxapi.sys
\SystemRoot\system32\DRIVERS\monitor.sys
\SystemRoot\System32\TSDDD.dll
\SystemRoot\System32\cdd.dll
\SystemRoot\system32\drivers\luafv.sys
\SystemRoot\system32\drivers\WudfPf.sys
\SystemRoot\system32\DRIVERS\lltdio.sys
\SystemRoot\system32\DRIVERS\nwifi.sys
\SystemRoot\system32\DRIVERS\ndisuio.sys
\SystemRoot\system32\DRIVERS\rspndr.sys
\SystemRoot\system32\drivers\HTTP.sys
\SystemRoot\system32\DRIVERS\bowser.sys
\SystemRoot\System32\drivers\mpsdrv.sys
\SystemRoot\system32\DRIVERS\mrxsmb.sys
\SystemRoot\system32\DRIVERS\mrxsmb10.sys
\SystemRoot\system32\DRIVERS\mrxsmb20.sys
\SystemRoot\system32\drivers\peauth.sys
\SystemRoot\System32\Drivers\secdrv.SYS
\SystemRoot\System32\DRIVERS\srvnet.sys
\SystemRoot\System32\drivers\tcpipreg.sys
\SystemRoot\System32\DRIVERS\srv2.sys
\SystemRoot\System32\DRIVERS\srv.sys
\??\C:\windows\system32\drivers\mbamchameleon.sys
\??\C:\windows\system32\drivers\MBAMSwissArmy.sys
\Windows\System32\ntdll.dll
\Windows\System32\smss.exe
\Windows\System32\apisetschema.dll
\Windows\System32\autochk.exe
\Windows\System32\iertutil.dll
\Windows\System32\oleaut32.dll
\Windows\System32\msvcrt.dll
\Windows\System32\urlmon.dll
\Windows\System32\Wldap32.dll
\Windows\System32\gdi32.dll
\Windows\System32\shlwapi.dll
\Windows\System32\difxapi.dll
\Windows\System32\ws2_32.dll
\Windows\System32\lpk.dll
\Windows\System32\clbcatq.dll
\Windows\System32\kernel32.dll
\Windows\System32\ole32.dll
\Windows\System32\rpcrt4.dll
\Windows\System32\nsi.dll
\Windows\System32\comdlg32.dll
\Windows\System32\psapi.dll
\Windows\System32\sechost.dll
\Windows\System32\normaliz.dll
\Windows\System32\advapi32.dll
\Windows\System32\imm32.dll
\Windows\System32\msctf.dll
\Windows\System32\wininet.dll
\Windows\System32\imagehlp.dll
\Windows\System32\shell32.dll
\Windows\System32\user32.dll
\Windows\System32\usp10.dll
\Windows\System32\setupapi.dll
\Windows\System32\api-ms-win-downlevel-normaliz-l1-1-0.dll
\Windows\System32\cfgmgr32.dll
\Windows\System32\api-ms-win-downlevel-version-l1-1-0.dll
\Windows\System32\api-ms-win-downlevel-advapi32-l1-1-0.dll
\Windows\System32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
\Windows\System32\devobj.dll
\Windows\System32\comctl32.dll
\Windows\System32\wintrust.dll
\Windows\System32\api-ms-win-downlevel-user32-l1-1-0.dll
\Windows\System32\crypt32.dll
\Windows\System32\KernelBase.dll
\Windows\System32\api-ms-win-downlevel-ole32-l1-1-0.dll
\Windows\System32\userenv.dll
\Windows\System32\msasn1.dll
\Windows\System32\profapi.dll
----------- End -----------
Done!
<<<1>>>
Upper Device Name: \Device\Harddisk0\DR0
Upper Device Object: 0xfffffa8004c41060
Upper Device Driver Name: \Driver\Disk\
Lower Device Name: \Device\Ide\IAAStorageDevice-1\
Lower Device Object: 0xfffffa8004749050
Lower Device Driver Name: \Driver\iaStor\
<<<2>>>
Physical Sector Size: 512
Drive: 0, DevicePointer: 0xfffffa8004c41060, DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\Disk\
--------- Disk Stack ------
DevicePointer: 0xfffffa8004c41ab0, DeviceName: Unknown, DriverName: \Driver\partmgr\
DevicePointer: 0xfffffa8004749050, DeviceName: \Device\Ide\IAAStorageDevice-1\, DriverName: \Driver\iaStor\
------------ End ----------
Alternate DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\Disk\
Upper DeviceData: 0x0, 0x0, 0x0
Lower DeviceData: 0x0, 0x0, 0x0
<<<3>>>
Volume: C:
File system type: NTFS
SectorSize = 512, ClusterSize = 4096, MFTRecordSize = 1024, MFTIndexSize = 4096 bytes
<<<2>>>
<<<3>>>
Volume: C:
Scanning drivers directory: C:\WINDOWS\SYSTEM32\drivers...
Done!
Drive 0
This is a System drive
Scanning MBR on drive 0...
Inspecting partition table:
MBR Signature: 55AA
Disk Signature: CE865B76
Partition information:
Partition 0 type is Other (0x27)
Partition is ACTIVE.
Partition starts at LBA: 2048 Numsec = 3072000
Partition file system is NTFS
Partition is bootable
Partition 1 type is Primary (0x7)
Partition is NOT ACTIVE.
Partition starts at LBA: 3074048 Numsec = 603224064
Partition 2 type is HIDDEN (0x17)
Partition starts at LBA: 606298112 Numsec = 18843648
Partition is not bootable
Hidden partition VBR is not infected.
Partition 3 type is Empty (0x0)
Partition starts at LBA: 0 Numsec = 0
Disk Size: 320072933376 bytes
Sector size: 512 bytes
Done!
Scan finished
Removal queue found; removal started
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\MBR-0-i.mbam...
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\VBR-0-0-2048-i.mbam...
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\VBR-0-2-606298112-i.mbam...
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\MBR-0-r.mbam...
Removal finished
thisdj1
Posts Posts : 56
Post by Superdave on Sun Dec 28, 2014 6:54 pm
Please tell me the size of the hard drive and how much free space you have left?
Please run the SFC below and tell me what happens.
To Run the SFC /SCANNOW Command in Windows 7
1. Open an [You must be registered and logged in to see this link.]
2. To Scan and Repair System Files
NOTE: Scans the integrity of all protected system files and repairs the system files if needed.
A) In the elevated command prompt, type sfc /scannow and press Enter. (see screenshot below)
NOTE: This may take some time to finish.
B) Go to step 4.
3. To Only Verify if the System Files are Corrupted
NOTE: Scans and only verifies the integrity of all proteced system files only.
A) In the elevated command prompt, type sfc /verifyonly and press Enter.
4. When the scan is complete, hopefully you will see all is ok like the screenshot below.
NOTE: If not, then you can attempt to run a [You must be registered and logged in to see this link.] using a restore point dated before the bad file occured to fix it. You may need to repeat doing a System Restore until you find a older restore point that may work.
5. When done, close the elevated command prompt.
Captain
Captain
Posts Posts : 4202
Post by thisdj1 on Mon Dec 29, 2014 1:20 am
Here is the result from the scan. I was not able to open the log as it wouldn't let me. I have 210 of 287 GB free on my hard drive. Thanks!
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\windows\system32>sfc/scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection found corrupt files and successfully repaired
them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
example C:\Windows\Logs\CBS\CBS.log
thisdj1
Posts Posts : 56
Post by Superdave on Mon Dec 29, 2014 1:28 am
Can you install an AV now?
Captain
Captain
Posts Posts : 4202
Post by thisdj1 on Mon Dec 29, 2014 3:24 am
No, it still cannot access the Windows Installer. I also double checked and turned on the Windows Installer. It was set to automatic but wasn't started so I started it. However, the error still showed up. I've also lost my sound while trying to play anything off of the internet. I'm also unable to open IE or download a new version of it. I've always used Chrome but thought I'd see if I had the same issue with IE but when I open the browser it opens briefly then closes automatically. I downloaded Firefox and I can't get Flash to download in order to watch any videos on that browser as well.
thisdj1
Posts Posts : 56
Post by Superdave on Mon Dec 29, 2014 7:30 pm
Have you tried a System Restore to before the time this problem started?
Captain
Captain
Posts Posts : 4202
Post by thisdj1 on Mon Dec 29, 2014 8:19 pm
Yeah, that was the first thing that I did, to no avail.
thisdj1
Posts Posts : 56
Post by Superdave on Mon Dec 29, 2014 10:15 pm
Do you have the Windows 7 OS disk or is there a Recovery Console on your computer?
Captain
Captain
Posts Posts : 4202
Post by thisdj1 on Tue Dec 30, 2014 12:08 am
I don't have the disc. Is it standard to have the hard restore already installed?
thisdj1
Posts Posts : 56
Post by Superdave on Tue Dec 30, 2014 2:10 am
If you didn't receive a disk, then the Recovery Console is installed in a separate partition of your hard drive. It's usually called the D drive. Take a look.[You must be registered and logged in to see this link.] how to run the repair.
Captain
Captain
Posts Posts : 4202
