making a system repair disc
Post by suzonka on Thu Nov 06, 2014 12:46 am
I have a computer without any way to recover it ,no disc came with it , I noticed it has a program to make a system repair disc, with a DVD or a CD R/W type . it also has a choice to restore to last know good behavior, should I make a system repair disc or just turn on the last good know recovery? HP DC5800 desk top, windows 7 IE 11 Whoa!
suzonka
Posts Posts : 199
Joined Joined : 2008-08-30
OS OS : windows 10
Points Points : 31643
Re: making a system repair disc
Post by Superdave on Thu Nov 06, 2014 2:28 am
Make a repair disk and keep it somewhere safe.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83161
repair disc
Post by suzonka on Thu Nov 06, 2014 4:31 am
@Superdave wrote:Make a repair disk and keep it somewhere safe.
Thank you will a regular CD 700 MB Have enough space to perform this
suzonka
Posts Posts : 199
OS OS : windows 10
Post by Superdave on Thu Nov 06, 2014 8:13 pm
If there's not enough room, you will receive a warning that the disk is too small.
Captain
Captain
Posts Posts : 4202
Post by driver_ian on Thu Nov 06, 2014 8:34 pm
As an alternative you could use Acronis True Image.
The trial version will give you time enough to create a 'set' of discs that can be used to restore a system from.. If 700MB Cd's are used it will ask for multiple discs if required so make sure you have several available before you start.
driver_ian
Posts Posts : 30
Joined Joined : 2012-02-24
OS OS : Windows 7 Ultimate
Protection Protection : Avast Free, MBAM, Windows Firewall
Points Points : 17781
REPAR DISC
Post by suzonka on Thu Nov 06, 2014 9:09 pm
@Superdave wrote:If there's not enough room, you will receive a warning that the disk is too small.
THANK Hooray! YOU FOR YOUR HELP
suzonka
Posts Posts : 199
OS OS : windows 10
disc space needed
Post by suzonka on Thu Nov 06, 2014 9:11 pm
@driver_ian wrote:As an alternative you could use Acronis True Image.
thank you I had read that it only take about 200 MB
suzonka
Posts Posts : 199
OS OS : windows 10
Post by driver_ian on Thu Nov 06, 2014 9:23 pm
The size of the recovery disc will depend on the size of the original hard drive and the amount of data on that drive,,
driver_ian
Posts Posts : 30
