Please help, coloruservice.exe was preventing shutdown, then a trojan was found
Post by frogzx on Wed Sep 17, 2014 8:54 pm
Greetings. So, last night I was about to go to sleep and began to shut down my laptop, which is running on the latest version of Windows 8 and IIRC is an Asus G750, when I noticed something called Coloruservice was preventing me from shutting down. I cancelled the shutdown because of the paranoid person I am to see what it was and if it was harmful. As I was looking up what it was it popped up that Avast blocked a trojan that was originating from coloruservice.exe in some folder in x86, I immediately proceeded to run a Hardened Boot time scan using Avast free 2014 and supposedly nothing was found. I googled this for hours and couldn't find anything about it being that harmful, but I had never seen it before, and have never run it on my laptop, unless something else causes it to run. Does anyone know what's wrong? What do I do? I have classes in a few and i'm going to be going nuts until I can fix this.
frogzx
Posts Posts : 13
Joined Joined : 2014-09-17
OS OS : Windows 8
Points Points : 8293
Re: Please help, coloruservice.exe was preventing shutdown, then a trojan was found
Post by Superdave on Thu Sep 18, 2014 12:00 am
Please download [You must be registered and logged in to see this link.]by Xplode onto your Desktop.
Please download Malwarebytes Anti-Malware from [You must be registered and logged in to see this link.]
•Temporarily disable your Antivirus and any Antispyware real time protection before performing a scan. Click [You must be registered and logged in to see this link.] link to see a list of security programs that should be disabled and how to disable them.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83181
Post by frogzx on Thu Sep 18, 2014 5:35 am
I finished everything you told me to to a tee, and tried pasting it into a message. However, it says I can't post external links or emails, and apparently the logs contain one of them. Oh, and the last thing, Security Check, I used both links and neither programs were compatible with my OS, it said something along the lines of "INCOMPATIBLE WITH YOUR OS, ABORTING NOW!". My OS is Windows 8.1. I apologize for the time it took me to reply and hope you are still able to help me.
Edit: Looked at another topic and saw you can post them in separate posts, I will do so now.
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by frogzx on Thu Sep 18, 2014 11:17 am
# AdwCleaner v3.310 - Report created 18/09/2014 at 00:12:17
# Updated 12/09/2014 by Xplode
# Operating System : Windows 8.1  (64 bits)
# Username : frogzx - NOAH
# Running from : C:\Users\frogzx\Downloads\adwcleaner_3.310.exe
# Option : Clean
***** [ Services ] *****
***** [ Files / Folders ] *****
Folder Deleted : C:\ProgramData\AVG SafeGuard toolbar
Folder Deleted : C:\ProgramData\AVG Secure Search
Folder Deleted : C:\Program Files (x86)\AVG SafeGuard toolbar
Folder Deleted : C:\Program Files (x86)\Common Files\AVG Secure Search
Folder Deleted : C:\Program Files\AVG SafeGuard toolbar
[!] Folder Deleted : C:\Users\frogzx\AppData\Local\AVG SafeGuard toolbar
Folder Deleted : C:\Users\frogzx\AppData\LocalLow\AVG SafeGuard toolbar
Folder Deleted : C:\Users\frogzx\AppData\Roaming\OpenCandy
Folder Deleted : C:\Users\frogzx\AppData\Roaming\Mozilla\Firefox\Profiles\84a8tq9c.default\Extensions\Avg@toolbar
File Deleted : C:\Users\frogzx\AppData\Roaming\Mozilla\Firefox\Profiles\84a8tq9c.default\searchplugins\avg-secure-search.xml
File Deleted : C:\Program Files (x86)\Mozilla Firefox\browser\searchplugins\safeguard-secure-search.xml
***** [ Scheduled Tasks ] *****
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Deleted : HKLM\SOFTWARE\Classes\AppID\ViProtocol.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AVG SafeGuard toolbar.BrowserWndAPI
Key Deleted : HKLM\SOFTWARE\Classes\AVG SafeGuard toolbar.BrowserWndAPI.1
Key Deleted : HKLM\SOFTWARE\Classes\AVG SafeGuard toolbar.PugiObj
Key Deleted : HKLM\SOFTWARE\Classes\AVG SafeGuard toolbar.PugiObj.1
Key Deleted : HKLM\SOFTWARE\Classes\protocols\handler\viprotocol
Key Deleted : HKLM\SOFTWARE\Classes\S
Key Deleted : HKLM\SOFTWARE\Classes\ScriptHelper.ScriptHelperApi
Key Deleted : HKLM\SOFTWARE\Classes\ScriptHelper.ScriptHelperApi.1
Key Deleted : HKLM\SOFTWARE\Classes\ViProtocol.ViProtocolOLE
Key Deleted : HKLM\SOFTWARE\Classes\ViProtocol.ViProtocolOLE.1
Value Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [vProt]
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@avg.com/AVG SiteSafety plugin,version=11.0.0.1,application/x-avg-sitesafety-plugin
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{1FDFF5A2-7BB1-48E1-8081-7236812B12B2}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{933B95E2-E7B7-4AD9-B952-7AC336682AE3}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{95B7759C-8C7F-4BF1-B163-73684A933233}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{B658800C-F66E-4EF3-AB85-6C0C227862A9}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{DE9028D0-5FFA-4E69-94E3-89EE8741F468}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{03E2A1F3-4402-4121-8B35-733216D61217}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{9E3B11F6-4179-4603-A71B-A55F4BCB0BEC}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{74FB6AFD-DD77-4CEB-83BD-AB2B63E63C93}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{9C049BA6-EA47-4AC3-AED6-A66D8DC9E1D8}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{C2AC8A0E-E48E-484B-A71C-C7A937FAAB94}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{C6FDD0C3-266A-4DC3-B459-28C697C44CDC}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39}
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{95B7759C-8C7F-4BF1-B163-73684A933233}
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{95B7759C-8C7F-4BF1-B163-73684A933233}]
Key Deleted : [x64] HKLM\SOFTWARE\Classes\CLSID\{95B7759C-8C7F-4BF1-B163-73684A933233}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\CLSID\{DE9028D0-5FFA-4E69-94E3-89EE8741F468}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\CLSID\{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{03E2A1F3-4402-4121-8B35-733216D61217}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{9E3B11F6-4179-4603-A71B-A55F4BCB0BEC}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
Value Deleted : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{95B7759C-8C7F-4BF1-B163-73684A933233}]
Key Deleted : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39}
Key Deleted : HKCU\Software\AVG SafeGuard toolbar
Key Deleted : HKLM\SOFTWARE\AVG SafeGuard toolbar
Key Deleted : HKLM\SOFTWARE\AVG Security Toolbar
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG SafeGuard toolbar
***** [ Browsers ] *****
-\\ Internet Explorer v11.0.9600.17278
-\\ Mozilla Firefox v30.0 (en-US)
[ File : C:\Users\frogzx\AppData\Roaming\Mozilla\Firefox\Profiles\84a8tq9c.default\prefs.js ]
Line Deleted : user_pref("browser.search.defaultenginename", "AVG Secure Search");
Line Deleted : user_pref("browser.search.selectedEngine", "AVG Secure Search");
-\\ Google Chrome v37.0.2062.120
AdwCleaner[R0].txt - [1054 octets] - [05/03/2014 06:58:00]
AdwCleaner[R1].txt - [855 octets] - [05/03/2014 07:03:54]
AdwCleaner[R2].txt - [1879 octets] - [27/07/2014 05:03:11]
AdwCleaner[R3].txt - [6001 octets] - [18/09/2014 00:10:21]
AdwCleaner[S0].txt - [1087 octets] - [05/03/2014 07:01:01]
AdwCleaner[S1].txt - [915 octets] - [05/03/2014 07:04:58]
AdwCleaner[S2].txt - [1843 octets] - [27/07/2014 05:11:52]
AdwCleaner[S3].txt - [5746 octets] - [18/09/2014 00:12:17]
########## EOF - C:\AdwCleaner\AdwCleaner[S3].txt - [5806 octets] ##########
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by frogzx on Thu Sep 18, 2014 11:18 am
(Was the websites link, can't put it here because of the 7 day restriction)
Scan Date: 9/18/2014
Scan Time: 12:26:28 AM
Logfile:
Administrator: Yes
Version: 2.00.2.1012
Malware Database: v2014.09.18.01
Rootkit Database: v2014.09.15.01
License: Free
Malware Protection: Disabled
Malicious Website Protection: Disabled
Self-protection: Disabled
OS: Windows 8.1
CPU: x64
File System: NTFS
User: frogzx
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 429196
Time Elapsed: 46 min, 21 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Enabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 0
Folders: 0
Files: 0
Physical Sectors: 0
(end)
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by frogzx on Thu Sep 18, 2014 11:20 am
Version: 6.1.5 (09.16.2014:1)
OS: Windows 8.1 x64
Ran by frogzx on Thu 09/18/2014 at  1:20:30.38
~~~ Services
~~~ Registry Values
Successfully repaired: [Registry Value] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\\Start Page
Successfully repaired: [Registry Value] HKEY_USERS\.DEFAULT\Software\Microsoft\Internet Explorer\Main\\Start Page
Successfully repaired: [Registry Value] HKEY_USERS\S-1-5-18\Software\Microsoft\Internet Explorer\Main\\Start Page
Successfully repaired: [Registry Value] HKEY_USERS\S-1-5-19\Software\Microsoft\Internet Explorer\Main\\Start Page
Successfully repaired: [Registry Value] HKEY_USERS\S-1-5-20\Software\Microsoft\Internet Explorer\Main\\Start Page
Successfully repaired: [Registry Value] HKEY_USERS\S-1-5-21-2402987494-1766145203-3524339115-1002\Software\Microsoft\Internet Explorer\Main\\Start Page
~~~ Registry Keys
~~~ Files
~~~ Folders
Successfully deleted: [Folder] "C:\Windows\syswow64\ai_recyclebin"
~~~ FireFox
Successfully deleted the following from C:\Users\frogzx\AppData\Roaming\mozilla\firefox\profiles\84a8tq9c.default\prefs.js
user_pref("browser.startup .homepage", "hxxps ://mysearch.avg .com ?cid={CFB09662-DE3A-4ABD-BE95-26C24190C68B}&mid=1d9431c8c81047d2a1ebf543228a8ab0-8bdf601c0ad72aed861483c58f7159e
~~~ Event Viewer Logs were cleared
Scan was completed on Thu 09/18/2014 at  1:24:54.17
End of JRT log
Put spaces between some of the links so it would allow posting.
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by frogzx on Thu Sep 18, 2014 11:27 am
Is SysWOW64 a virus? I say that the JRT removed something in it's folder and I heard i remember hearing that it's a virus. Same with Coloruservice. I just want everything cleared..
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by Superdave on Thu Sep 18, 2014 7:14 pm
You may have to remove those links before posting the log.
Not usually.
What Anti-virus are you using?
Malwarebytes' Anti-Rootkit
Please download [You must be registered and logged in to see this link.] and save it to your desktop.
  • Be sure to print out and follow the instructions provided on that same page for performing a scan.
  • Caution: This is a beta version so also read the disclaimer and [You must be registered and logged in to see this link.] all your data before using.
  • When the scan completes, click on the Cleanup button to remove any threats found and reboot the computer if prompted to do so.
  • Perform another scan with Malwarebytes Anti-Rootkit to verify that no threats remain. If they do, then click Cleanup once more and repeat the process.
  • If there are problems with Internet access, Windows Update, Windows Firewall or other system issues, run the fixdamage tool located in the folder Malwarebytes Anti-Rootkit was run from and reboot your computer.
  • Two files (mbar-log-YYYY-MM-DD, system-log.txt) will be created and saved within that same folder.
  • Copy and paste the contents of these two log files in your next reply.
Captain
Captain
Posts Posts : 4202
Post by frogzx on Thu Sep 18, 2014 7:47 pm
I am using Avast free 2014, do you recommend something different? I don't really know what the good antivirus's are, or what other checkups I should routinely use. I will download and use the Anti-Rootkit now and post the information momentarily
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by frogzx on Thu Sep 18, 2014 8:36 pm
Malwarebytes Anti-Rootkit BETA 1.07.0.1012
Database version: v2014.09.18.08
Windows 8.1 x64 NTFS
Internet Explorer 11.0.9600.17278
frogzx :: NOAH [administrator]
9/18/2014 3:47:53 PM
mbar-log-2014-09-18 (15-47-53).txt
Scan type: Quick scan
Scan options enabled: Anti-Rootkit | Drivers | MBR | Physical Sectors | Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken
Scan options disabled:
Objects scanned: 431651
Time elapsed: 43 minute(s), 33 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 0
Physical Sectors Detected: 0
(end)
This is after running it once, I am running it again after this post just to make sure, will post if there are any irregularities.
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by frogzx on Thu Sep 18, 2014 9:19 pm
And here are the second scan results.
9/18/2014 4:33:15 PM
mbar-log-2014-09-18 (16-33-15).txt
Objects scanned: 431585
Time elapsed: 43 minute(s), 48 second(s)
Folders Detected: 0
Files Detected: 0
(end)
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by Superdave on Fri Sep 19, 2014 12:09 am
No, I just wanted to know.Many people don't use an AV.
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Captain
Captain
Posts Posts : 4202
Post by frogzx on Fri Sep 19, 2014 2:13 am
C:\Users\frogzx\Desktop\ELX 1.6.3 Qt\ELX.exe a variant of Win32/Packed.NoobyProtect.G potentially unwanted application deleted - quarantined
C:\Users\frogzx\Desktop\ELX 1.6.3 Qt\io\elx.dll a variant of Win32/Packed.NoobyProtect.L potentially unwanted application deleted - quarantined
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by frogzx on Fri Sep 19, 2014 2:15 am
Not sure if you wanted the second log or not so here
all ok
# product=EOS
# version=8
# OnlineScanner.ocx=1.0.0.7623
# api_version=3.0.2
# EOSSerial=0c7a1dfa9bacb543bdf3d9aba5cac48b
# engine=20223
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2014-09-19 02:12:09
# local_time=2014-09-18 10:12:09 (-0500, Eastern Daylight Time)
# country="United States"
# lang=1033
# osver=6.2.9200 NT
# compatibility_mode_1='avast! Antivirus'
# compatibility_mode=783 16777213 100 95 0 11512220 0 0
# compatibility_mode_1=''
# compatibility_mode=5893 16776574 100 94 7665755 14551050 0 0
# scanned=371976
# found=2
# cleaned=2
# scan_time=5603
sh=A014D70A905A2882515EA91DD087EE548FDCC09D ft=1 fh=01d5d590ae488c14 vn="a variant of Win32/Packed.NoobyProtect.G potentially unwanted application (deleted - quarantined)" ac=C fn="C:\Users\frogzx\Desktop\ELX 1.6.3 Qt\ELX.exe"
sh=424C23178108D0F0027279DCB960858B06CFA4B2 ft=1 fh=729b3e55565d5847 vn="a variant of Win32/Packed.NoobyProtect.L potentially unwanted application (deleted - quarantined)" ac=C fn="C:\Users\frogzx\Desktop\ELX 1.6.3 Qt\io\elx.dll"
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by Superdave on Fri Sep 19, 2014 6:59 pm
Ok, how's your computer working now? Any other issues?
Captain
Captain
Posts Posts : 4202
Post by frogzx on Fri Sep 19, 2014 7:19 pm
[You must be registered and logged in to see this link.] wrote:Ok, how's your computer working now? Any other issues?
Not at all, it's running much faster now, even faster than it did before the virus! I just hope it wasnt a virus that can hide from all this stuff.
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by Superdave on Fri Sep 19, 2014 7:25 pm
I just hope it wasnt a virus that can hide from all this stuff..
Not very likely. Let's do some clean up.
This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
This is a very crucial step so make sure you don't skip it.
Download [You must be registered and logged in to see this link.] to your desktop. Delfix will delete all the used tools and logfiles.
Double-click Delfix.exe to start the tool.
Make sure the following items are checked:
  • Activate UAC (optional; some users prefer to keep it off)
  • Remove disinfection tools
  • Create Registry backup
  • Purge System Restore Points
  • Re-set system settings
Now click "Run" and wait patiently.
Once finished a logfile will be created. You don't have to attach it to your next reply.
I suggest using [You must be registered and logged in to see this link.]. WOT is a free Internet security addon for your browser. It will keep you safe from online scams, identity theft, spyware, spam, viruses and unreliable shopping sites. WOT warns you before you interact with a risky website. It's easy and it's free.
Check out [You must be registered and logged in to see this link.] for tips and free tools to help keep you safe in the future.
Also see [You must be registered and logged in to see this link.] for free cleaning/maintenance tools to help keep your computer running smoothly.
Safe Surfing!
Captain
Captain
Posts Posts : 4202
Post by frogzx on Fri Sep 19, 2014 7:35 pm
Everything ran smoothly, i'm going to run an Avast scan just to make sure I got everything. Thank you so much for your help, I greatly appreciate it!
frogzx
Posts Posts : 13
OS OS : Windows 8
Post by Superdave on Fri Sep 19, 2014 7:41 pm
You're welcome. I will lock this thread. If you need it re-opened, please send me a pm.
Captain
Captain
Posts Posts : 4202
