Wireless Networks window will randomly freeze until restart.
Post by PanzerschreckLeopard on Thu Sep 11, 2014 1:16 pm
So my laptop has this weird and extremely rage-inducing habit: routinely, it will disconnect from the net...but the real problem is, sometimes the window for wireless networks will freeze when I try to use it. And it will absolutely not un-freeze without restarting the whole computer. I have tried using task manager to end and restart explorer.exe, but it will just freeze again when I try to bring the networks window back up.
The weirdest part is, it really only does this at school; at home, disconnections rarely if ever result in the freeze. Some days, I can go the whole time at school with just a single freeze at the most; sometimes, like this morning, I'll be restarting 5 or 6 times every hour. Malwarebytes can never find anything, defragging the comp doesn't help...what do I do?
OS : Windows XP
Re: Wireless Networks window will randomly freeze until restart.
Post by Superdave on Thu Sep 11, 2014 6:17 pm
You will have to run the Speedtest at school.
Here's the site to test your ISP speed.
Captain
Captain
OS : Windows 8.1 and a dual-boot with XP Home SP3
Post by PanzerschreckLeopard on Fri Sep 12, 2014 11:52 am
13ms Ping, 0.96 Mbps Download, 1.00 mbps upload.
OS : Windows XP
Post by Superdave on Fri Sep 12, 2014 6:11 pm
Wow, that network is really slow. I believe that is your problem.
Captain
Captain
Post by PanzerschreckLeopard on Fri Sep 12, 2014 11:02 pm
But how would that cause it to freeze? As noted above, I can end explorer.exe and restart it, and the process will work fine only if I don't go to any network related window, because it'll freeze again if I do.It disconnects all the time at home, and rarely if ever freezes like that.
Also, half the time I go to shut down or stand-by, it will say there are updates to install, even if I chose to do that earlier in the day...I thought there were no more updates for XP?
OS : Windows XP
Post by Superdave on Sat Sep 13, 2014 1:40 am
Oh yes, there are still updates. Do they ever download?
Captain
Captain
Post by PanzerschreckLeopard on Sun Sep 14, 2014 2:17 am
Not sure. Half the time it gets stuck on "shutting down..." so the only way to turn off is to hold the power button.
OS : Windows XP
Post by Superdave on Sun Sep 14, 2014 6:45 pm
Please download and run MS Fix-it from here.
Captain
Captain
Post by PanzerschreckLeopard on Mon Sep 15, 2014 11:50 am
Done. The only thing with an option to fix was the speakers.
OS : Windows XP
Post by Superdave on Mon Sep 15, 2014 6:58 pm
It will repair a number of Windows errors. Click on "Visit our solution center" and click on Windows.
Captain
Captain
