Help me for my laptop!
Post by ervinako on 11th August 2014, 11:11 am
Everytime i open browser my browser go to efactor.com or amazon.com and it pop up something but it didn't open. Can anyone help me, Is my laptop has virus?  Annoyed or Unimpress
ervinako
Posts Posts : 21
Joined Joined : 2010-03-27
OS OS : Xp
Points Points : 24666
Re: Help me for my laptop!
Post by Superdave on 11th August 2014, 7:34 pm
Please download [You must be registered and logged in to see this link.]by Xplode onto your Desktop.
Please download Malwarebytes Anti-Malware from [You must be registered and logged in to see this link.]
•Temporarily disable your Antivirus and any Antispyware real time protection before performing a scan. Click [You must be registered and logged in to see this link.] link to see a list of security programs that should be disabled and how to disable them.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83221
