"No Signal" to monitor
Post by lizstaley on 30th July 2014, 3:50 pm
Full (but shortened) story- my hard drive in my Windows8 Gateway PC did a slow decline all last week and finally bit the dust on Monday. Wouldn't turn on. Took it to GeekSquad and they confirmed that the hard drive was dead. I bought a new hard drive and ordered recovery disks from Gateway.
Installed the hard drive yesterday, disks arrived today and everything was going just fine with the system restore. It was installing software when my monitor shut itself off and then when I turned it back on the monitor displays "No Signal" before turning off again. I grabbed a different monitor, same thing.
This has happened before with this PC, and restarting has always fixed the problem. Except in this case. I cannot get it to register either monitor. Did my video card fry too?
lizstaley
Joined Joined : 2014-07-30
OS OS : Windows 8
Points Points : 8653
Re: "No Signal" to monitor
Post by Superdave on 30th July 2014, 7:12 pm
This has happened before with this PC, and restarting has always fixed the problem. Except in this case. I cannot get it to register either monitor. Did my video card fry too? .
This usually means that the computer has shut down. First thing to do is check the cables. If the cables are good and the computer is turned on it probably means there's something wrong with the video card.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83231
