MAAgent.exe - Entry point not found
Post by Woody2run on Tue 10 Jun 2014, 6:28 pm
Hi I'm new to the forum I have seen a similar solved thread on here so have followed the info on that.
The procedure entry point?OpenKey@CMAR@@AEPAUKEY_@@PBDHK@Z could not be located in the dynamic link
I downloaded and run a scan with "Hijack This" and have a log but the forum won't let me post it.
Thank you in advance for any help with this problem.
Update:- since posting this on the wrong forum sorry. I have done a little research online and taken the following action :-
Action taken:-
My computer
Boot (C:)
Programs Files
Mark Any - renamed - Mark any 1
Re start
Result :- stopped above warning with no immediate problems noticed on my computer.
Woody2run
Operating System : Windows xp
Re: MAAgent.exe - Entry point not found
Post by Superdave on Tue 10 Jun 2014, 9:11 pm
  • Please close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Delete or Clean.
  • Confirm each time with OK
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
Link 1
Link 2
Tech Staff
Tech Staff
Post by Woody2run on Tue 10 Jun 2014, 11:16 pm
Hi Dave thank you very much for offering to help.
I already scan with MBAM But I will do exactly as you ask which make take some time many thanks.
Colin
Woody2run
Post by Woody2run on Tue 10 Jun 2014, 11:21 pm
Sorry should I return the file I renamed to it's original name before I start the scans?
Woody2run
Post by Superdave on Wed 11 Jun 2014, 4:33 am
Woody2run wrote:Sorry should I return the file I renamed to it's original name before I start the scans?
Yes, please post that log along with the others.
Tech Staff
Tech Staff
Post by Woody2run on Fri 03 Oct 2014, 8:12 am
Hi Dave sorry for the late reply, it's a long story which I'm sure you don't want me to bore you with. Hope you are still able to help me with my computer?
I have done the first scan with Adwcleaner the log as requested follows :-
# AdwCleaner v3.311 - Report created 02/10/2014 at 22:31:00
# Updated 30/09/2014 by Xplode
# Operating System : Microsoft Windows XP Service Pack 3 (32 bits)
# Username : Colin Wood - MEDION06-12-04
# Running from : C:\Documents and Settings\Colin Wood\Desktop\adwcleaner_3.311.exe
# Option : Clean
***** [ Services ] *****
***** [ Files / Folders ] *****
Folder Deleted : C:\Documents and Settings\All Users\Application Data\AVG Secure Search
Folder Deleted : C:\Documents and Settings\All Users\Application Data\SoftSafe
Folder Deleted : C:\Documents and Settings\All Users\Application Data\StarApp
Folder Deleted : C:\Documents and Settings\All Users\Application Data\Systweak
Folder Deleted : C:\Documents and Settings\All Users\Application Data\Viewpoint
Folder Deleted : C:\Documents and Settings\All Users\Application Data\Breowsse2isavee
Folder Deleted : C:\Documents and Settings\All Users\Application Data\BrOwwsae2saevEe
Folder Deleted : C:\Documents and Settings\All Users\Application Data\sAAffe  siave
Folder Deleted : C:\Documents and Settings\All Users\Start Menu\Programs\Breowsse2isavee
Folder Deleted : C:\Documents and Settings\All Users\Start Menu\Programs\BrOwwsae2saevEe
Folder Deleted : C:\Documents and Settings\All Users\Start Menu\Programs\sAAffe  siave
Folder Deleted : C:\Program Files\Advanced System Protector
Folder Deleted : C:\Program Files\AOL Toolbar
Folder Deleted : C:\Program Files\Optimizer Pro
Folder Deleted : C:\Program Files\SafeSaver
Folder Deleted : C:\Program Files\Viewpoint
Folder Deleted : C:\Program Files\WebSearch
Folder Deleted : C:\Documents and Settings\Abbigale\Local Settings\Application Data\AVG Security Toolbar
Folder Deleted : C:\Documents and Settings\Abbigale\Application Data\AVG Secure Search
Folder Deleted : C:\Documents and Settings\Abbigale\Application Data\Viewpoint
Folder Deleted : C:\Documents and Settings\Colin Wood\Application Data\AVG Secure Search
Folder Deleted : C:\Documents and Settings\Colin Wood\Application Data\rightbackup
Folder Deleted : C:\Documents and Settings\Colin Wood\Application Data\Search Protection
Folder Deleted : C:\Documents and Settings\Colin Wood\Application Data\SearchProtect
Folder Deleted : C:\Documents and Settings\Colin Wood\Application Data\Systweak
Folder Deleted : C:\Documents and Settings\Colin Wood\Application Data\Viewpoint
Folder Deleted : C:\Documents and Settings\Colin Wood\My Documents\Optimizer Pro
Folder Deleted : C:\Documents and Settings\Guest\Local Settings\Application Data\AVG Security Toolbar
Folder Deleted : C:\Documents and Settings\Kelly\Local Settings\Application Data\AVG Security Toolbar
Folder Deleted : C:\Documents and Settings\Kelly\Application Data\AVG Secure Search
Folder Deleted : C:\Documents and Settings\Kelly\Application Data\Viewpoint
Folder Deleted : C:\Program Files\Mozilla Firefox\Extensions\ffxtlbr@babylon.com
File Deleted : C:\Documents and Settings\Abbigale\Application Data\Mozilla\Firefox\Profiles\eprs3f6v.default\Extensions\{c0c9a2c7-2e5c-4447-bc53-97718bc91e1b}.xpi
File Deleted : C:\END
File Deleted : C:\WINDOWS\system32\roboot.exe
File Deleted : C:\Documents and Settings\Colin Wood\Application Data\Mozilla\Firefox\Profiles\uicjh6ra.default\.autoreg
***** [ Scheduled Tasks ] *****
***** [ Shortcuts ] *****
***** [ Registry ] *****
Value Deleted : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [Avg@toolbar]
Key Deleted : HKLM\SOFTWARE\Classes\AppID\secman.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\WMHelper.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AxMetaStream.MetaStreamCtl
Key Deleted : HKLM\SOFTWARE\Classes\AxMetaStream.MetaStreamCtl.1
Key Deleted : HKLM\SOFTWARE\Classes\AxMetaStream.MetaStreamCtlSecondary
Key Deleted : HKLM\SOFTWARE\Classes\AxMetaStream.MetaStreamCtlSecondary.1
Key Deleted : HKLM\SOFTWARE\Classes\S
Key Deleted : HKLM\SOFTWARE\Classes\secman.OutlookSecurityManager
Key Deleted : HKLM\SOFTWARE\Classes\secman.OutlookSecurityManager.1
Key Deleted : HKLM\SOFTWARE\Microsoft\Active Setup\Installed Components\{03F998B2-0E00-11D3-A498-00104B6EB52E}
Key Deleted : HKLM\SOFTWARE\Microsoft\Active Setup\Installed Components\{1B00725B-C455-4DE6-BFB6-AD540AD427CD}
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@viewpoint.com/VMP
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SP_0bdf5975
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SP_48c708f2
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SP_b0285714
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{4D076AB4-7562-427A-B5D2-BD96E19DEE56}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{A7DDCBDE-5C86-415C-8A37-763AE183E7E4}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{1B00725B-C455-4DE6-BFB6-AD540AD427CD}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{826D7151-8D99-434B-8540-082B8C2AE556}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{BC9FD17D-30F6-4464-9E53-596A90AFF023}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{CC5AD34C-6F10-4CB3-B74A-C2DD4D5060A3}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{DE9028D0-5FFA-4E69-94E3-89EE8741F468}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{03E2A1F3-4402-4121-8B35-733216D61217}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8FFE}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{813A22E0-3E2B-4188-9BDA-ECA9878B8D48}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{9E3B11F6-4179-4603-A71B-A55F4BCB0BEC}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{BCFF5F55-6F44-11D2-86F8-00104B265ED5}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{11549FE4-7C5A-4C17-9FC3-56FC5162A994}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{4F7D1B07-6203-41F0-947B-A29CC9ECD9B0}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{9C049BA6-EA47-4AC3-AED6-A66D8DC9E1D8}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{9DBB28C1-1925-11D3-A498-00104B6EB52E}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{95B7759C-8C7F-4BF1-B163-73684A933233}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{95B7759C-8C7F-4BF1-B163-73684A933233}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{95B7759C-8C7F-4BF1-B163-73684A933233}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{C6FDD0C3-266A-4DC3-B459-28C697C44CDC}
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{95B7759C-8C7F-4BF1-B163-73684A933233}
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{9CB96984-43C3-4D44-90EF-01466EFCF7BB}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9CB96984-43C3-4D44-90EF-01466EFCF7BB}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{95B7759C-8C7F-4BF1-B163-73684A933233}]
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39}]
Value Deleted : HKLM\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List [C:\Program Files\Common Files\Nokia\Service Layer\A\nsl_host_process.exe]
Key Deleted : HKCU\Software\Myfree Codec
Key Deleted : HKCU\Software\StartSearch
Key Deleted : HKCU\Software\systweak
Key Deleted : HKCU\Software\YahooPartnerToolbar
Key Deleted : HKCU\Software\AppDataLow\{1146AC44-2F03-4431-B4FD-889BC837521F}
Key Deleted : HKLM\SOFTWARE\{1146AC44-2F03-4431-B4FD-889BC837521F}
Key Deleted : HKLM\SOFTWARE\{3A7D3E19-1B79-4E4E-BD96-5467DA2C4EF0}
Key Deleted : HKLM\SOFTWARE\{6791A2F3-FC80-475C-A002-C014AF797E9C}
Key Deleted : HKLM\SOFTWARE\AVG SafeGuard toolbar
Key Deleted : HKLM\SOFTWARE\AVG Secure Search
Key Deleted : HKLM\SOFTWARE\MetaStream
Key Deleted : HKLM\SOFTWARE\Myfree Codec
Key Deleted : HKLM\SOFTWARE\SP Global
Key Deleted : HKLM\SOFTWARE\SProtector
Key Deleted : HKLM\SOFTWARE\systweak
Key Deleted : HKLM\SOFTWARE\Viewpoint
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Uninstall\Search Protection
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ViewpointMediaPlayer
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-00B0-0409-0000-0000000FF1CE}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Search Protection
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{C3F3165C-74D3-6FDB-3274-14FDA8698CFA}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{C670DCAE-E392-AA32-6F42-143C7FC4BDFD}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\ViewpointMediaPlayer
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\SP_48c708f2
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{90120000-00B0-0409-0000-0000000FF1CE}
Data Deleted : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows [AppInit_DLLs] - c:\progra~1\searchprotect\searchprotect\bin\spvc32loader.dll
Data Deleted : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows [AppInit_DLLs] - c:\progra~1\websea~1\sprote~1.dll
Data Deleted : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows [AppInit_DLLs] - c:\progra~1\browse~1\sprote~1.dll
***** [ Browsers ] *****
-\\ Internet Explorer v8.0.6001.18702
-\\ Mozilla Firefox v32.0 (x86 en-GB)
[ File : C:\Documents and Settings\Abbigale\Application Data\Mozilla\Firefox\Profiles\eprs3f6v.default\prefs.js ]
Line Deleted : user_pref("aol_toolbar.default.homepage.check", false);
Line Deleted : user_pref("aol_toolbar.default.search.check", false);
Line Deleted : user_pref("avg.install.installDirPath", "C:\\Documents and Settings\\All Users\\Application Data\\AVG Secure Search\\10.2.0.3");
Line Deleted : user_pref("avg.install.userSPSettings", "AVG Secure Search");
Line Deleted : user_pref("browser.search.defaultenginename", "AVG Secure Search");
Line Deleted : user_pref("keyword.URL", "hxxp://isearch.avg.com/search?cid=%7B12e8b071-830c-4f2d-98b1-3b0758333a09%7D&mid=4356ba926660bfda1dc0d5ced54ac557-982eff693cbd4d01c67f59932588776bef5e9037&ds=AVG&v=10.2.0.3&l[...]
Line Deleted : user_pref("plugin.blocklisted.npviewpoint", true);
Line Deleted : user_pref("sweetim.toolbar.previous.browser.search.defaultenginename", "");
Line Deleted : user_pref("sweetim.toolbar.previous.browser.search.selectedEngine", "");
Line Deleted : user_pref("sweetim.toolbar.previous.browser.startup.homepage", "");
Line Deleted : user_pref("sweetim.toolbar.previous.keyword.URL", "");
Line Deleted : user_pref("sweetim.toolbar.scripts.1.domain-blacklist", "");
Line Deleted : user_pref("sweetim.toolbar.searchguard.UserRejectedGuard_DS", "");
Line Deleted : user_pref("sweetim.toolbar.searchguard.UserRejectedGuard_HP", "");
Line Deleted : user_pref("sweetim.toolbar.searchguard.enable", "");
[ File : C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\ixjvhotr.default\prefs.js ]
[ File : C:\Documents and Settings\Colin Wood\Application Data\Mozilla\Firefox\Profiles\ib9vp1uo.default-1401381511875\prefs.js ]
[ File : C:\Documents and Settings\Colin Wood\Application Data\Mozilla\Firefox\Profiles\uicjh6ra.default\prefs.js ]
Line Deleted : user_pref("browser.search.order.1,S", "WebSearch");
Line Deleted : user_pref("browser.search.defaultenginename,S", "WebSearch");
Line Deleted : user_pref("browser.search.selectedEngine,S", "WebSearch");
[ File : C:\Documents and Settings\Guest\Application Data\Mozilla\Firefox\Profiles\vhpz6xn4.default\prefs.js ]
[ File : C:\Documents and Settings\Kelly\Application Data\Mozilla\Firefox\Profiles\x9q3ahis.default\prefs.js ]
Line Deleted : user_pref("browser.search.selectedEngine", "AVG Secure Search");
-\\ Google Chrome v37.0.2062.120
[ File : C:\Documents and Settings\Colin Wood\Local Settings\Application Data\Google\Chrome\User Data\Default\preferences ]
Deleted [Search Provider] : [You must be registered and logged in to see this link.]
AdwCleaner[R0].txt - [12938 octets] - [02/10/2014 22:19:52]
AdwCleaner[S0].txt - [13046 octets] - [02/10/2014 22:31:00]
########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [13107 octets] ##########
Woody2run
Post by Woody2run on Fri 03 Oct 2014, 8:44 pm
MBAM Log
Scan Date: 02/10/2014
Scan Time: 23:17:11
Logfile: MBAM 2.10.2014.txt
Administrator: Yes
Version: 2.00.2.1012
Malware Database: v2014.10.02.09
Rootkit Database: v2014.09.19.01
License: Free
Malware Protection: Disabled
Malicious Website Protection: Disabled
Self-protection: Disabled
OS: Windows XP Service Pack 3
CPU: x86
File System: NTFS
User: Colin Wood
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 522500
Time Elapsed: 1 hr, 3 min, 30 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Warn
PUM: Enabled
Processes: 0
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 0
Folders: 0
Files: 0
Physical Sectors: 0
(end)
Many thanks in advance
Woody2run
Post by Woody2run on Fri 03 Oct 2014, 9:49 pm
Version: 6.2.7 (10.03.2014:1)
OS: Microsoft Windows XP x86
Ran by Colin Wood on 03/10/2014 at 12:15:08.54
~~~ Services
~~~ Registry Values
~~~ Registry Keys
~~~ Files
~~~ Folders
Successfully deleted: [Folder] "C:\Documents and Settings\Colin Wood\Local Settings\Application Data\cre"
Successfully deleted: [Folder] "C:\Program Files\myfree codec"
~~~ FireFox
Successfully deleted: [Folder] C:\Documents and Settings\Colin Wood\Application Data\mozilla\firefox\profiles\uicjh6ra.default\extensions\staged
Successfully deleted the following from C:\Documents and Settings\Colin Wood\Application Data\mozilla\firefox\profiles\uicjh6ra.default\prefs.js
user_pref("google.toolbar.search-icon", "data:image/x-icon;base64,AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7PT7/3zF6/9Ptu//RbHx/
Emptied folder: C:\Documents and Settings\Colin Wood\Application Data\mozilla\firefox\profiles\uicjh6ra.default\minidumps [5 files]
Scan was completed on 03/10/2014 at 12:31:41.75
End of JRT log
many thanks in advance
Woody2run
Post by Woody2run on Fri 03 Oct 2014, 9:56 pm
Results of screen317's Security Check version 0.99.88
Windows XP Service Pack 3 x86
Internet Explorer 8
Windows Firewall Enabled!
avast! Free Antivirus
Out of date Spybot installed!
Spybot - Search & Destroy 1.4
Windows Defender
Adobe Flash Player 10 Flash Player out of Date!
Adobe Flash Player 15.0.0.152
Adobe Reader 10.1.11 Adobe Reader out of Date!
Mozilla Firefox (32.0.3)
Google Chrome 37.0.2062.120
Google Chrome 37.0.2062.124
Windows Defender MSMpEng.exe
Windows Defender MSASCui.exe
Windows Defender MsMpEng.exe
AVAST Software Avast AvastSvc.exe
AVAST Software Avast AvastUI.exe
Total Fragmentation on Drive C:: 11% Defragment your hard drive soon! (Do NOT defrag if SSD!)
Woody2run
Post by Superdave on Sat 04 Oct 2014, 7:21 am
You should uninstall Spybot. It's is no longer effective.
You will need to defrag your hard drive soon. Do not defrag if it is a SSD (Solid State Drive)
Remember that Avast will only offer protection for Windows XP for one year then you will need to find another AV.
Update your Adobe Reader. get.adobe.com/reader.
Be sure to uncheck the Free McAfee Security Scan so it isn't installed.
Malwarebytes' Anti-Rootkit
Please download Malwarebytes' Anti-Rootkit and save it to your desktop.
  • Be sure to print out and follow the instructions provided on that same page for performing a scan.
  • Caution: This is a beta version so also read the disclaimer and back up all your data before using.
  • When the scan completes, click on the Cleanup button to remove any threats found and reboot the computer if prompted to do so.
  • Perform another scan with Malwarebytes Anti-Rootkit to verify that no threats remain. If they do, then click Cleanup once more and repeat the process.
  • If there are problems with Internet access, Windows Update, Windows Firewall or other system issues, run the fixdamage tool located in the folder Malwarebytes Anti-Rootkit was run from and reboot your computer.
  • Two files (mbar-log-YYYY-MM-DD, system-log.txt) will be created and saved within that same folder.
  • Copy and paste the contents of these two log files in your next reply.
Tech Staff
Tech Staff
Post by Woody2run on Sun 05 Oct 2014, 8:50 pm
Hi Dave
Thank you for your help. All my data is backed up automatically on to an Seagate external hard drive. Should I remove that before starting this next scan?
Many thanks
Colin
Woody2run
Post by Superdave on Mon 06 Oct 2014, 4:21 am
Your external drive should be kept disconnected until you are ready to use it.
Tech Staff
Tech Staff
Post by Woody2run on Mon 06 Oct 2014, 7:57 pm
Hi Dave
The scan returned, no malware and no cleanup is required.
I can only find the one file requested below.
All you help is greatly appreciated cheers.
Colin
Malwarebytes Anti-Rootkit BETA 1.07.0.1012
(c) Malwarebytes Corporation 2011-2012
OS version: 5.1.2600 Windows XP Service Pack 3 x86
Account is Administrative
Internet Explorer version: 8.0.6001.18702
File system is: NTFS
Disk drives: C:\ DRIVE_FIXED, D:\ DRIVE_FIXED, E:\ DRIVE_FIXED
CPU speed: 3.391000 GHz
Memory total: 1073197056, free: 59768832
Downloaded database version: v2014.10.05.08
Downloaded database version: v2014.09.19.01
Initializing...
------------ Kernel report ------------
10/05/2014 22:12:30
------------ Loaded modules -----------
\WINDOWS\system32\ntoskrnl.exe
\WINDOWS\system32\hal.dll
\WINDOWS\system32\KDCOM.DLL
\WINDOWS\system32\BOOTVID.dll
ACPI.sys
\WINDOWS\system32\DRIVERS\WMILIB.SYS
pci.sys
isapnp.sys
ohci1394.sys
\WINDOWS\system32\DRIVERS\1394BUS.SYS
pciide.sys
\WINDOWS\system32\DRIVERS\PCIIDEX.SYS
intelide.sys
MountMgr.sys
ftdisk.sys
PartMgr.sys
VolSnap.sys
atapi.sys
disk.sys
\WINDOWS\system32\DRIVERS\CLASSPNP.SYS
fltmgr.sys
sr.sys
KSecDD.sys
WudfPf.sys
Ntfs.sys
NDIS.sys
Mup.sys
BTHidMgr.sys
aswVmm.sys
aswRvrt.sys
\SystemRoot\system32\DRIVERS\intelppm.sys
\SystemRoot\system32\DRIVERS\ati2mtag.sys
\SystemRoot\system32\DRIVERS\VIDEOPRT.SYS
\SystemRoot\system32\DRIVERS\HDAudBus.sys
\SystemRoot\system32\DRIVERS\usbuhci.sys
\SystemRoot\system32\DRIVERS\USBPORT.SYS
\SystemRoot\system32\DRIVERS\usbehci.sys
\SystemRoot\system32\DRIVERS\3xHybrid.sys
\SystemRoot\system32\DRIVERS\ks.sys
\SystemRoot\system32\DRIVERS\BdaSup.SYS
\SystemRoot\system32\DRIVERS\nic1394.sys
\SystemRoot\system32\DRIVERS\AGRSM.sys
\SystemRoot\system32\DRIVERS\USBD.SYS
\SystemRoot\System32\Drivers\Modem.SYS
\SystemRoot\system32\DRIVERS\fetnd5b.sys
\SystemRoot\system32\DRIVERS\serial.sys
\SystemRoot\system32\DRIVERS\serenum.sys
\SystemRoot\system32\DRIVERS\parport.sys
\SystemRoot\system32\drivers\wbscr.sys
\SystemRoot\system32\drivers\SMCLIB.SYS
\SystemRoot\system32\DRIVERS\imapi.sys
\SystemRoot\system32\drivers\pfc.sys
\SystemRoot\System32\Drivers\MxlW2k.SYS
\SystemRoot\system32\DRIVERS\cdrom.sys
\SystemRoot\system32\DRIVERS\redbook.sys
\SystemRoot\system32\DRIVERS\GEARAspiWDM.sys
\SystemRoot\System32\Drivers\VcommMgr.sys
\SystemRoot\system32\DRIVERS\audstub.sys
\SystemRoot\system32\DRIVERS\rasl2tp.sys
\SystemRoot\system32\DRIVERS\ndistapi.sys
\SystemRoot\system32\DRIVERS\ndiswan.sys
\SystemRoot\system32\DRIVERS\raspppoe.sys
\SystemRoot\system32\DRIVERS\raspptp.sys
\SystemRoot\system32\DRIVERS\TDI.SYS
\SystemRoot\system32\DRIVERS\ptilink.sys
\SystemRoot\system32\DRIVERS\raspti.sys
\SystemRoot\system32\DRIVERS\wanatw4.sys
\SystemRoot\system32\DRIVERS\termdd.sys
\SystemRoot\system32\DRIVERS\kbdclass.sys
\SystemRoot\system32\DRIVERS\mouclass.sys
\SystemRoot\system32\DRIVERS\swenum.sys
\SystemRoot\system32\DRIVERS\update.sys
\SystemRoot\system32\DRIVERS\mssmbios.sys
\SystemRoot\System32\Drivers\NDProxy.SYS
\SystemRoot\system32\drivers\HdAudio.sys
\SystemRoot\system32\drivers\portcls.sys
\SystemRoot\system32\drivers\drmk.sys
\SystemRoot\system32\DRIVERS\usbhub.sys
\SystemRoot\system32\drivers\MODEMCSA.sys
\SystemRoot\system32\drivers\aswSP.sys
\??\C:\Documents and Settings\All Users\Application Data\Trusteer\Rapport\store\exts\RapportCerberus\baseline\RapportCerberus32_80055.sys
\SystemRoot\System32\Drivers\Fs_Rec.SYS
\SystemRoot\System32\Drivers\Null.SYS
\SystemRoot\System32\Drivers\Beep.SYS
\SystemRoot\system32\DRIVERS\HIDPARSE.SYS
\SystemRoot\System32\drivers\vga.sys
\SystemRoot\System32\Drivers\mnmdd.SYS
\SystemRoot\System32\DRIVERS\RDPCDD.sys
\SystemRoot\System32\Drivers\Msfs.SYS
\SystemRoot\System32\Drivers\Npfs.SYS
\SystemRoot\system32\DRIVERS\rasacd.sys
\SystemRoot\system32\DRIVERS\ipsec.sys
\SystemRoot\system32\DRIVERS\msgpc.sys
\SystemRoot\system32\DRIVERS\tcpip.sys
\SystemRoot\system32\drivers\aswTdi.sys
\SystemRoot\system32\DRIVERS\ipnat.sys
\SystemRoot\system32\DRIVERS\netbt.sys
\SystemRoot\system32\DRIVERS\wanarp.sys
\SystemRoot\system32\drivers\aswRdr.sys
\SystemRoot\System32\drivers\afd.sys
\SystemRoot\system32\DRIVERS\netbios.sys
\SystemRoot\system32\DRIVERS\rdbss.sys
\SystemRoot\system32\DRIVERS\arp1394.sys
\??\C:\Program Files\Trusteer\Rapport\bin\RapportEI.sys
\SystemRoot\system32\DRIVERS\mrxsmb.sys
\SystemRoot\System32\Drivers\Fips.SYS
\SystemRoot\system32\drivers\aswSnx.sys
\SystemRoot\system32\DRIVERS\usbccgp.sys
\SystemRoot\system32\DRIVERS\usbscan.sys
\SystemRoot\system32\DRIVERS\hidusb.sys
\SystemRoot\system32\DRIVERS\HIDCLASS.SYS
\SystemRoot\system32\DRIVERS\UKBFLT.sys
\SystemRoot\System32\Drivers\Fastfat.SYS
\SystemRoot\system32\DRIVERS\kbdhid.sys
\SystemRoot\system32\DRIVERS\mouhid.sys
\SystemRoot\System32\Drivers\dump_atapi.sys
\SystemRoot\System32\Drivers\dump_WMILIB.SYS
\SystemRoot\System32\win32k.sys
\SystemRoot\System32\drivers\Dxapi.sys
\SystemRoot\System32\watchdog.sys
\SystemRoot\System32\drivers\dxg.sys
\SystemRoot\System32\drivers\dxgthk.sys
\SystemRoot\System32\ati2dvag.dll
\SystemRoot\System32\ati2cqag.dll
\SystemRoot\System32\atikvmag.dll
\SystemRoot\System32\atiok3x2.dll
\SystemRoot\System32\ati3duag.dll
\SystemRoot\System32\ativvaxx.dll
\SystemRoot\System32\ATMFD.DLL
\SystemRoot\system32\drivers\aswMonFlt.sys
\SystemRoot\system32\DRIVERS\AegisP.sys
\SystemRoot\system32\DRIVERS\ndisuio.sys
\SystemRoot\system32\DRIVERS\mrxdav.sys
\SystemRoot\system32\drivers\wdmaud.sys
\SystemRoot\system32\drivers\sysaudio.sys
\SystemRoot\system32\drivers\aswHwid.sys
\??\C:\WINDOWS\system32\drivers\CDAC15BA.SYS
\SystemRoot\System32\Drivers\HTTP.sys
\SystemRoot\system32\DRIVERS\srv.sys
\??\C:\WINDOWS\system32\STEC3.sys
\SystemRoot\System32\Drivers\Cdfs.SYS
\??\C:\WINDOWS\system32\FsUsbExDisk.SYS
\SystemRoot\system32\DRIVERS\usbprint.sys
\??\C:\WINDOWS\system32\drivers\mbamchameleon.sys
\??\C:\WINDOWS\system32\drivers\MBAMSwissArmy.sys
\WINDOWS\system32\ntdll.dll
----------- End -----------
Done!
<<<1>>>
Upper Device Name: \Device\Harddisk0\DR0
Upper Device Object: 0xffffffff87355ab8
Upper Device Driver Name: \Driver\Disk\
Lower Device Name: \Device\Ide\IdeDeviceP1T1L0-17\
Lower Device Object: 0xffffffff87335d98
Lower Device Driver Name: \Driver\atapi\
<<<2>>>
Physical Sector Size: 512
Drive: 0, DevicePointer: 0xffffffff87355ab8, DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\Disk\
--------- Disk Stack ------
DevicePointer: 0xffffffff87354e08, DeviceName: Unknown, DriverName: \Driver\PartMgr\
DevicePointer: 0xffffffff873599e8, DeviceName: \Device\00000082\, DriverName: \Driver\ACPI\
DevicePointer: 0xffffffff87335d98, DeviceName: \Device\Ide\IdeDeviceP1T1L0-17\, DriverName: \Driver\atapi\
------------ End ----------
Alternate DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\Disk\
Upper DeviceData: 0x0, 0x0, 0x0
Lower DeviceData: 0x0, 0x0, 0x0
<<<3>>>
Volume: C:
File system type: NTFS
SectorSize = 512, ClusterSize = 4096, MFTRecordSize = 1024, MFTIndexSize = 4096 bytes
<<<2>>>
<<<3>>>
Volume: C:
Scanning drivers directory: C:\WINDOWS\SYSTEM32\drivers...
Done!
Drive 0
This is a System drive
Scanning MBR on drive 0...
Inspecting partition table:
MBR Signature: 55AA
Disk Signature: 4CE04CD
Partition information:
Partition 0 type is Primary (0x7)
Partition is ACTIVE.
Partition starts at LBA: 63 Numsec = 263112507
Partition file system is NTFS
Partition is bootable
Partition 1 type is Extended with LBA (0xf)
Partition is NOT ACTIVE.
Partition starts at LBA: 263112570 Numsec = 225279495
Partition 2 type is Empty (0x0)
Partition starts at LBA: 0 Numsec = 0
Partition 3 type is Empty (0x0)
Disk Size: 250059350016 bytes
Sector size: 512 bytes
Scanning physical sectors of unpartitioned space on drive 0 (1-62-488377168-488397168)...
Done!
File "C:\WINDOWS\system32\config\system" is compressed (flags = 1)
Scan finished
Woody2run
Post by Superdave on Tue 07 Oct 2014, 6:10 am
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by Woody2run on Wed 15 Oct 2014, 2:28 am
Hi Dave
I have done the scan but it won't let me save the text file. When I last checked the computer as it was scanning, it had found 6 suspect applications. at the end of the scan it say it has found and cleaned 9 infected files as below :-
C:\AdwCleaner\Quarantine\C\Documents and Settings\Colin Wood\Application Data\SearchProtect\ffprotect\application.js.vir Win32/Conduit.SearchProtect.A potentially unwanted application deleted - quarantined
C:\AdwCleaner\Quarantine\C\WINDOWS\system32\roboot.exe.vir a variant of Win32/Systweak.A potentially unwanted application deleted - quarantined
C:\Documents and Settings\Colin Wood\Local Settings\Application Data\Viber\Helper.dll a variant of Win32/Toolbar.SearchSuite.P potentially unwanted application deleted - quarantined
C:\Documents and Settings\Colin Wood\My Documents\Downloads\rcp_dcomnew_util_300(1).exe Win32/Systweak.D potentially unwanted application deleted - quarantined
C:\Documents and Settings\Colin Wood\My Documents\Downloads\rcp_dcomnew_util_300.exe Win32/Systweak.D potentially unwanted application deleted - quarantined
C:\Documents and Settings\Colin Wood\My Documents\Downloads\ViberSetup.exe Win32/Toolbar.SearchSuite.P potentially unwanted application deleted - quarantined
C:\Program Files\Mozilla Firefox\components\sprotector.js Win32/Conduit.SearchProtect.A potentially unwanted application deleted - quarantined
C:\WINDOWS\CameraFixer.exe a variant of Win32/KillProc.A potentially unwanted application deleted - quarantined
C:\WINDOWS\system32\sasnative32.exe Win32/AdvancedSystemProtector.A potentially unwanted application deleted - quarantined
Have done something or has it not found any malware?
As always your help is much appreciated
Colin
Woody2run
Post by Superdave on Wed 15 Oct 2014, 6:39 am
How's your computer running now? Any other issues?
Tech Staff
Tech Staff
Post by Woody2run on Wed 15 Oct 2014, 8:30 am
Just done a restart, the original prob is still there :-
MAAgent.exe - Entry Point Not Found
The procedure entry point ?Openkey@CMAReistry@@PBDHK@Z could not be located in the dynamic link libarry MADRM.dll.
The message above stays on top of all windows I open.
Plus 2 more notices:-
RUNDLL
Error loading cmicnfg.cpl
The specified module could not be found.
Woody2run
Post by Woody2run on Wed 15 Oct 2014, 8:32 am
Adobe AIR
This application riquires a version of Adobe AIR which cannot be found. Please download the latest version of runtime from [You must be registered and logged in to see this link.]
or contact the application author for an updated version
Woody2run
Post by Woody2run on Wed 15 Oct 2014, 8:37 am
The computer runs okay apart from having to click twice to logout, it seems to start logging out but then stops but completes logging out by clicking a second time.
Thanks again
Colin
Woody2run
Post by Superdave on Wed 15 Oct 2014, 12:52 pm
This is a file for Argus Digital Camera or PolicyMaker™ Standard Edition. See here. Do you have either of these on your computer?
Tech Staff
Tech Staff
Post by Woody2run on Wed 15 Oct 2014, 9:37 pm
Not to my knowledge but I do have software for Samsung. It is mentioed in the comments on your link. The only reason I have the software is some phone numbers are stored on it. I will transfer the numbers I need, remove the software and let you know if it solves the problem.
Many thanks
Colin
Woody2run
Post by Woody2run on Wed 15 Oct 2014, 9:53 pm
Ps it is slow at start up but I think that is down to to many demanding programs starting up, I really need to sort that out but not sure how to remove them from start up.
Cheers
Woody2run
Post by Superdave on Thu 16 Oct 2014, 4:02 am
StartupLite
Download StartupLite by MalwareBytes to your Desktop.
Doubleclick StartupLite.exe to launch the program.
Ensure the Disable box is checked.
Click Continue.
A pop up message will tell you the unecessary startup items in your list have been disabled and ask you to restart your computer.
Re-start your computer.
Tech Staff
Tech Staff
Post by Sponsored content Today at 11:09 am
