PC acting funny...help appreciated!!
Post by robyn1112 on 26th January 2014, 10:12 pm
I believe I had a virus a few days ago, was able to do a system restore to a point 3 days prior. Definitely running better, but I'm pretty sure something is still lingering. Here are my logs. Thanks for the help!!!
Malwarebytes Anti-Malware 1.75.0.1300
Database version: v2014.01.25.03
Windows 7 Service Pack 1 x86 NTFS
Internet Explorer 11.0.9600.16476
Manager :: LAPTOP534 [administrator]
1/26/2014 1:37:48 AM
mbam-log-2014-01-26 (01-37-48).txt
Scan type: Full scan (C:\|)
Scan options disabled: P2P
Objects scanned: 360268
Time elapsed: 2 hour(s), 39 minute(s), 52 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 1
C:\AdwCleaner\Quarantine\C\Program Files\Vuze\.install4j\user\mism.exe.vir (PUP.Optional.Conduit.A) -> Quarantined and deleted successfully.
(end)
Results of screen317's Security Check version 0.99.79
Windows 7 Service Pack 1 x86 (UAC is enabled)
Windows Firewall Disabled!
avast! Antivirus
Antivirus out of date!
SUPERAntiSpyware
Malwarebytes Anti-Malware version 1.75.0.1300
Java 7 Update 51
Adobe Flash Player 10 Flash Player out of Date!
Adobe Flash Player 11.9.900.170
Adobe Reader XI
Mozilla Firefox (26.0)
Google Chrome 31.0.1650.63
Google Chrome 32.0.1700.76
Google Chrome plugins...
Comodo Firewall cmdagent.exe
Comodo Firewall cfp.exe
AVAST Software Avast AvastSvc.exe
AVAST Software Avast AvastUI.exe
Total Fragmentation on Drive C: 0%
# AdwCleaner v3.017 - Report created 24/01/2014 at 21:33:38
# Updated 12/01/2014 by Xplode
# Operating System : Windows 7 Home Premium Service Pack 1 (32 bits)
# Username : Manager - LAPTOP534
# Running from : C:\Users\Manager\Desktop\adwcleaner.exe
# Option : Scan
***** [ Services ] *****
***** [ Files / Folders ] *****
File Found : C:\windows\System32\Tasks\NCH Software
Folder Found C:\Program Files\NCH Software
Folder Found C:\Program Files\Vuze
Folder Found C:\ProgramData\NCH Software
Folder Found C:\Users\Manager\AppData\Roaming\NCH Software
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Found : HKCU\Software\APN PIP
Key Found : HKCU\Software\Classes\pokki
Key Found : HKCU\Software\Conduit
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Found : HKCU\Software\NCH Software
Key Found : HKCU\Software\Softonic
Key Found : HKLM\SOFTWARE\Classes\CLSID\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Found : HKLM\Software\Conduit
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0FF2AEFF45EEA0A48A4B33C1973B6094
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\305B09CE8C53A214DB58887F62F25536
Key Found : HKLM\Software\NCH Software
Key Found : HKLM\Software\PIP
Value Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
***** [ Browsers ] *****
-\\ Internet Explorer v11.0.9600.16428
-\\ Mozilla Firefox v26.0 (en-US)
[ File : C:\Users\Manager\AppData\Roaming\Mozilla\Firefox\Profiles\1sq3dlit.default\prefs.js ]
-\\ Google Chrome v32.0.1700.76
[ File : C:\Users\Manager\AppData\Local\Google\Chrome\User Data\Default\preferences ]
AdwCleaner[R0].txt - [2627 octets] - [24/01/2014 21:33:38]
########## EOF - C:\AdwCleaner\AdwCleaner[R0].txt - [2687 octets] ##########
robyn1112
Posts Posts : 43
Joined Joined : 2010-01-23
Points Points : 25728
Re: PC acting funny...help appreciated!!
Post by Superdave on 27th January 2014, 6:36 pm
It shows that your AV is out-of-date. Please update it asap.
Remove the Adware:
  • Please close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Delete.
  • Confirm each time with OK
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
•Temporarily disable your Antivirus and any Antispyware real time protection before performing a scan. Click [You must be registered and logged in to see this link.] link to see a list of security programs that should be disabled and how to disable them.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83231
Post by robyn1112 on 27th January 2014, 7:59 pm
When I try to update my AV it tells me that access is denied. I tried both before and after running the 2 scans you recommended. Here are my logs from those:
# AdwCleaner v3.017 - Report created 27/01/2014 at 14:18:43
# Option : Clean
File Deleted : C:\windows\System32\Tasks\NCH Software
AdwCleaner[R1].txt - [1017 octets] - [27/01/2014 14:17:24]
AdwCleaner[S0].txt - [2886 octets] - [24/01/2014 21:35:31]
AdwCleaner[S1].txt - [942 octets] - [27/01/2014 14:18:43]
########## EOF - C:\AdwCleaner\AdwCleaner[S1].txt - [1001 octets] ##########
Version: 6.1.0 (01.07.2014:1)
OS: Windows 7 Home Premium x86
Ran by Manager on Mon 01/27/2014 at 14:46:33.71
~~~ Services
~~~ Registry Values
~~~ Registry Keys
Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\caphyon
~~~ Files
~~~ Folders
Failed to delete: [Folder] "C:\Program Files\coupons"
~~~ FireFox
Emptied folder: C:\Users\Manager\AppData\Roaming\mozilla\firefox\profiles\1sq3dlit.default\minidumps [241 files]
~~~ Event Viewer Logs were cleared
robyn1112
Posts Posts : 43
Post by Superdave on 27th January 2014, 11:27 pm
Ok. Don't forget to try to update it after we finish cleaning.
Malwarebytes' Anti-Rootkit
Please download [You must be registered and logged in to see this link.] and save it to your desktop.
  • Be sure to print out and follow the instructions provided on that same page for performing a scan.
  • Caution: This is a beta version so also read the disclaimer and [You must be registered and logged in to see this link.] all your data before using.
  • When the scan completes, click on the Cleanup button to remove any threats found and reboot the computer if prompted to do so.
  • Perform another scan with Malwarebytes Anti-Rootkit to verify that no threats remain. If they do, then click Cleanup once more and repeat the process.
  • If there are problems with Internet access, Windows Update, Windows Firewall or other system issues, run the fixdamage tool located in the folder Malwarebytes Anti-Rootkit was run from and reboot your computer.
  • Two files (mbar-log-YYYY-MM-DD, system-log.txt) will be created and saved within that same folder.
  • Copy and paste the contents of these two log files in your next reply.
Captain
Captain
Posts Posts : 4202
Post by robyn1112 on 28th January 2014, 3:22 am
Malwarebytes Anti-Rootkit BETA 1.07.0.1009
Database version: v2014.01.28.01
1/27/2014 8:31:13 PM
mbar-log-2014-01-27 (20-31-13).txt
Scan type: Quick scan
Scan options enabled: Anti-Rootkit | Drivers | MBR | Physical Sectors | Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken
Objects scanned: 225780
Time elapsed: 1 hour(s), 47 minute(s), 2 second(s)
Folders Detected: 0
Files Detected: 0
Physical Sectors Detected: 0
(end)
(c) Malwarebytes Corporation 2011-2012
OS version: 6.1.7601 Windows 7 Service Pack 1 x86
Account is Administrative
Internet Explorer version: 11.0.9600.16476
File system is: NTFS
Disk drives: C:\ DRIVE_FIXED, Q:\ DRIVE_FIXED
CPU speed: 1.895000 GHz
Memory total: 2072264704, free: 1246330880
Memory total: 2072264704, free: 1259323392
Downloaded database version: v2014.01.28.01
Downloaded database version: v2013.12.18.01
Initializing...
------------ Kernel report ------------
01/27/2014 20:31:05
------------ Loaded modules -----------
\SystemRoot\system32\ntkrnlpa.exe
\SystemRoot\system32\halmacpi.dll
\SystemRoot\system32\kdcom.dll
\SystemRoot\system32\mcupdate_GenuineIntel.dll
\SystemRoot\system32\PSHED.dll
\SystemRoot\system32\BOOTVID.dll
\SystemRoot\system32\CLFS.SYS
\SystemRoot\system32\CI.dll
\SystemRoot\system32\drivers\Wdf01000.sys
\SystemRoot\system32\drivers\WDFLDR.SYS
\SystemRoot\system32\drivers\ACPI.sys
\SystemRoot\system32\drivers\WMILIB.SYS
\SystemRoot\system32\drivers\msisadrv.sys
\SystemRoot\system32\drivers\pci.sys
\SystemRoot\system32\drivers\vdrvroot.sys
\SystemRoot\System32\drivers\partmgr.sys
\SystemRoot\system32\DRIVERS\compbatt.sys
\SystemRoot\system32\DRIVERS\BATTC.SYS
\SystemRoot\system32\drivers\volmgr.sys
\SystemRoot\System32\drivers\volmgrx.sys
\SystemRoot\System32\drivers\mountmgr.sys
\SystemRoot\system32\DRIVERS\iaStor.sys
\SystemRoot\system32\drivers\amdxata.sys
\SystemRoot\system32\drivers\fltmgr.sys
\SystemRoot\system32\drivers\fileinfo.sys
\SystemRoot\System32\Drivers\PxHelp20.sys
\SystemRoot\System32\Drivers\Ntfs.sys
\SystemRoot\System32\Drivers\msrpc.sys
\SystemRoot\System32\Drivers\ksecdd.sys
\SystemRoot\System32\Drivers\cng.sys
\SystemRoot\System32\drivers\pcw.sys
\SystemRoot\System32\Drivers\Fs_Rec.sys
\SystemRoot\system32\drivers\ndis.sys
\SystemRoot\system32\drivers\NETIO.SYS
\SystemRoot\System32\Drivers\ksecpkg.sys
\SystemRoot\System32\drivers\tcpip.sys
\SystemRoot\System32\drivers\fwpkclnt.sys
\SystemRoot\system32\drivers\volsnap.sys
\SystemRoot\System32\Drivers\spldr.sys
\SystemRoot\System32\drivers\rdyboost.sys
\SystemRoot\System32\Drivers\mup.sys
\SystemRoot\System32\drivers\hwpolicy.sys
\SystemRoot\System32\DRIVERS\fvevol.sys
\SystemRoot\system32\DRIVERS\disk.sys
\SystemRoot\system32\DRIVERS\CLASSPNP.SYS
\SystemRoot\system32\DRIVERS\cdrom.sys
\SystemRoot\System32\Drivers\aswSnx.SYS
\SystemRoot\System32\DRIVERS\cmdguard.sys
\SystemRoot\system32\DRIVERS\CFRMD.sys
\SystemRoot\System32\Drivers\Null.SYS
\SystemRoot\System32\Drivers\Beep.SYS
\SystemRoot\System32\drivers\vga.sys
\SystemRoot\System32\drivers\VIDEOPRT.SYS
\SystemRoot\System32\drivers\watchdog.sys
\SystemRoot\System32\DRIVERS\RDPCDD.sys
\SystemRoot\system32\drivers\rdpencdd.sys
\SystemRoot\system32\drivers\rdprefmp.sys
\SystemRoot\System32\Drivers\Msfs.SYS
\SystemRoot\System32\Drivers\Npfs.SYS
\SystemRoot\system32\DRIVERS\tdx.sys
\SystemRoot\system32\DRIVERS\TDI.SYS
\SystemRoot\System32\DRIVERS\cmdhlp.sys
\SystemRoot\System32\Drivers\aswTdi.SYS
\SystemRoot\system32\drivers\afd.sys
\SystemRoot\System32\Drivers\aswrdr2.sys
\SystemRoot\System32\DRIVERS\netbt.sys
\SystemRoot\system32\DRIVERS\wfplwf.sys
\SystemRoot\system32\DRIVERS\pacer.sys
\SystemRoot\system32\DRIVERS\vwififlt.sys
\SystemRoot\system32\DRIVERS\inspect.sys
\SystemRoot\system32\DRIVERS\netbios.sys
\SystemRoot\system32\DRIVERS\wanarp.sys
\SystemRoot\system32\drivers\termdd.sys
\??\C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS
\??\C:\Program Files\SUPERAntiSpyware\SASDIFSV.SYS
\SystemRoot\system32\DRIVERS\rdbss.sys
\SystemRoot\system32\drivers\nsiproxy.sys
\SystemRoot\system32\drivers\mssmbios.sys
\SystemRoot\system32\DRIVERS\hmd.sys
\SystemRoot\System32\drivers\discache.sys
\SystemRoot\System32\Drivers\dfsc.sys
\SystemRoot\system32\DRIVERS\blbdrive.sys
\SystemRoot\System32\Drivers\aswSP.SYS
\SystemRoot\system32\DRIVERS\tunnel.sys
\SystemRoot\system32\DRIVERS\intelppm.sys
\SystemRoot\system32\DRIVERS\igdkmd32.sys
\SystemRoot\System32\drivers\dxgkrnl.sys
\SystemRoot\System32\drivers\dxgmms1.sys
\SystemRoot\system32\DRIVERS\usbuhci.sys
\SystemRoot\system32\DRIVERS\USBPORT.SYS
\SystemRoot\system32\DRIVERS\usbehci.sys
\SystemRoot\system32\drivers\HDAudBus.sys
\SystemRoot\system32\DRIVERS\rtl8192se.sys
\SystemRoot\system32\DRIVERS\vwifibus.sys
\SystemRoot\system32\DRIVERS\Rt86win7.sys
\SystemRoot\system32\drivers\i8042prt.sys
\SystemRoot\system32\DRIVERS\HpqKbFiltr.sys
\SystemRoot\system32\drivers\kbdclass.sys
\SystemRoot\system32\DRIVERS\SynTP.sys
\SystemRoot\system32\DRIVERS\USBD.SYS
\SystemRoot\system32\DRIVERS\mouclass.sys
\SystemRoot\system32\DRIVERS\GEARAspiWDM.sys
\SystemRoot\system32\DRIVERS\CmBatt.sys
\SystemRoot\system32\drivers\wmiacpi.sys
\SystemRoot\system32\drivers\CompositeBus.sys
\SystemRoot\system32\DRIVERS\AgileVpn.sys
\SystemRoot\system32\DRIVERS\rasl2tp.sys
\SystemRoot\system32\DRIVERS\ndistapi.sys
\SystemRoot\system32\DRIVERS\ndiswan.sys
\SystemRoot\system32\DRIVERS\raspppoe.sys
\SystemRoot\system32\DRIVERS\raspptp.sys
\SystemRoot\system32\DRIVERS\rassstp.sys
\SystemRoot\system32\drivers\swenum.sys
\SystemRoot\system32\drivers\ks.sys
\SystemRoot\system32\drivers\umbus.sys
\SystemRoot\system32\DRIVERS\usbhub.sys
\SystemRoot\System32\Drivers\NDProxy.SYS
\SystemRoot\system32\DRIVERS\stwrt.sys
\SystemRoot\system32\DRIVERS\portcls.sys
\SystemRoot\system32\DRIVERS\drmk.sys
\SystemRoot\system32\drivers\IntcHdmi.sys
\SystemRoot\System32\win32k.sys
\SystemRoot\System32\drivers\Dxapi.sys
\SystemRoot\System32\Drivers\crashdmp.sys
\SystemRoot\system32\DRIVERS\monitor.sys
\SystemRoot\System32\Drivers\dump_iaStor.sys
\SystemRoot\System32\Drivers\dump_dumpfve.sys
\SystemRoot\System32\TSDDD.dll
\SystemRoot\System32\cdd.dll
\SystemRoot\System32\ATMFD.DLL
\SystemRoot\system32\drivers\luafv.sys
\??\C:\windows\system32\drivers\aswMonFlt.sys
\SystemRoot\System32\Drivers\aswFsBlk.SYS
\SystemRoot\system32\DRIVERS\Sftvollh.sys
\SystemRoot\system32\DRIVERS\lltdio.sys
\SystemRoot\system32\DRIVERS\nwifi.sys
\SystemRoot\system32\DRIVERS\ndisuio.sys
\SystemRoot\system32\DRIVERS\rspndr.sys
\SystemRoot\system32\drivers\HTTP.sys
\SystemRoot\system32\DRIVERS\bowser.sys
\SystemRoot\System32\drivers\mpsdrv.sys
\SystemRoot\system32\DRIVERS\mrxsmb.sys
\SystemRoot\system32\DRIVERS\mrxsmb10.sys
\SystemRoot\system32\DRIVERS\mrxsmb20.sys
\SystemRoot\system32\drivers\peauth.sys
\SystemRoot\System32\Drivers\secdrv.SYS
\SystemRoot\system32\DRIVERS\Sftfslh.sys
\SystemRoot\system32\DRIVERS\Sftplaylh.sys
\SystemRoot\System32\DRIVERS\srvnet.sys
\SystemRoot\System32\drivers\tcpipreg.sys
\SystemRoot\System32\DRIVERS\srv2.sys
\SystemRoot\System32\DRIVERS\srv.sys
\SystemRoot\system32\DRIVERS\Sftredirlh.sys
\SystemRoot\System32\Drivers\fastfat.SYS
\??\C:\windows\system32\drivers\mbamchameleon.sys
\??\C:\windows\system32\drivers\MBAMSwissArmy.sys
\Windows\System32\ntdll.dll
\Windows\System32\smss.exe
\Windows\System32\apisetschema.dll
\Windows\System32\autochk.exe
\Windows\System32\psapi.dll
\Windows\System32\urlmon.dll
\Windows\System32\rpcrt4.dll
\Windows\System32\gdi32.dll
\Windows\System32\clbcatq.dll
\Windows\System32\msvcrt.dll
\Windows\System32\sechost.dll
\Windows\System32\imagehlp.dll
\Windows\System32\ws2_32.dll
\Windows\System32\wininet.dll
\Windows\System32\imm32.dll
\Windows\System32\lpk.dll
\Windows\System32\iertutil.dll
\Windows\System32\user32.dll
\Windows\System32\setupapi.dll
\Windows\System32\normaliz.dll
\Windows\System32\comdlg32.dll
\Windows\System32\ole32.dll
\Windows\System32\shlwapi.dll
\Windows\System32\kernel32.dll
\Windows\System32\advapi32.dll
\Windows\System32\Wldap32.dll
\Windows\System32\difxapi.dll
\Windows\System32\usp10.dll
\Windows\System32\msctf.dll
\Windows\System32\oleaut32.dll
\Windows\System32\shell32.dll
\Windows\System32\nsi.dll
\Windows\System32\api-ms-win-downlevel-user32-l1-1-0.dll
\Windows\System32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
\Windows\System32\api-ms-win-downlevel-advapi32-l1-1-0.dll
\Windows\System32\cfgmgr32.dll
\Windows\System32\api-ms-win-downlevel-normaliz-l1-1-0.dll
\Windows\System32\api-ms-win-downlevel-version-l1-1-0.dll
\Windows\System32\wintrust.dll
\Windows\System32\api-ms-win-downlevel-ole32-l1-1-0.dll
\Windows\System32\devobj.dll
\Windows\System32\crypt32.dll
\Windows\System32\comctl32.dll
\Windows\System32\KernelBase.dll
\Windows\System32\msasn1.dll
----------- End -----------
Done!
<<<1>>>
Upper Device Name: \Device\Harddisk0\DR0
Upper Device Object: 0xffffffff87634030
Upper Device Driver Name: \Driver\Disk\
Lower Device Name: \Device\Ide\IAAStorageDevice-1\
Lower Device Object: 0xffffffff85b40028
Lower Device Driver Name: \Driver\iaStor\
<<<2>>>
Physical Sector Size: 512
Drive: 0, DevicePointer: 0xffffffff87634030, DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\Disk\
--------- Disk Stack ------
DevicePointer: 0xffffffff87634cc8, DeviceName: Unknown, DriverName: \Driver\partmgr\
DevicePointer: 0xffffffff85b40028, DeviceName: \Device\Ide\IAAStorageDevice-1\, DriverName: \Driver\iaStor\
------------ End ----------
Alternate DeviceName: \Device\Harddisk0\DR0\, DriverName: \Driver\Disk\
Upper DeviceData: 0x0, 0x0, 0x0
Lower DeviceData: 0x0, 0x0, 0x0
<<<3>>>
Volume: C:
File system type: NTFS
SectorSize = 512, ClusterSize = 4096, MFTRecordSize = 1024, MFTIndexSize = 4096 bytes
<<<2>>>
<<<3>>>
Volume: C:
Scanning drivers directory: C:\WINDOWS\SYSTEM32\drivers...
<<<2>>>
<<<3>>>
Volume: C:
Done!
Drive 0
Scanning MBR on drive 0...
Inspecting partition table:
MBR Signature: 55AA
Disk Signature: 8806E7E6
Partition information:
Partition 0 type is Primary (0x7)
Partition is ACTIVE.
Partition starts at LBA: 2048 Numsec = 614400
Partition file system is NTFS
Partition is bootable
Partition 1 type is Primary (0x7)
Partition is NOT ACTIVE.
Partition starts at LBA: 616448 Numsec = 458629120
Partition 2 type is Other (0x1c)
Partition starts at LBA: 459245568 Numsec = 4194304
Partition 3 type is Other (0x1c)
Partition starts at LBA: 463456256 Numsec = 24938864
Disk Size: 250059350016 bytes
Sector size: 512 bytes
Scanning physical sectors of unpartitioned space on drive 0 (1-2047-488377168-488397168)...
Done!
Scan finished
Removal queue found; removal started
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\MBR-0-i.mbam...
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\VBR-0-0-2048-i.mbam...
Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\MBR-0-r.mbam...
Removal finished
robyn1112
Posts Posts : 43
Post by Superdave on 28th January 2014, 6:20 pm
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Captain
Captain
Posts Posts : 4202
Post by robyn1112 on 28th January 2014, 10:02 pm
When I try to run the ESET Scanner, it gets to the point of downloading signature databases and then says "cannot get update, is proxy configured?"
I'm not sure what that means, sorry!!
robyn1112
Posts Posts : 43
Post by Superdave on 28th January 2014, 11:07 pm
What browser are you using?
Captain
Captain
Posts Posts : 4202
Post by robyn1112 on 28th January 2014, 11:40 pm
Firefox
robyn1112
Posts Posts : 43
Post by Superdave on 29th January 2014, 2:57 am
[You must be registered and logged in to see this link.] wrote:Firefox
This should fix the proxy problem.
In Internet Explorer
  • Tools Menu -> Internet Options -> Connections Tab ->Lan Settings > uncheck "use a proxy server" or reconfigure the Proxy server again in case you have set it previously
In Firefox
  • Tools Menu -> Options... -> Advanced Tab -> Network Tab -> "Settings" under Connection > Choose "No Proxy"
  • Click the apply button and restart that computer in normal mode.
Captain
Captain
Posts Posts : 4202
