Wireless connections deactivated, malware detected
Post by Amelia84 on Sun 29 Dec 2013, 3:29 am
I started looking for malware on my computer because wireless connections were suddenly deactivated. I didn't change any settings, and didn't install any new programs or updates so after trying to deactivate and reactivate the network adapters a few times, I looked for a virus. I followed your guide and found a few things. Still not sure if both problems are related, but I figured I would ask for help and start by removing the malware.
Since the infected computer has no internet connection, I was unable to update the MalwareBytes database, which might be a problem. I have another computer I can use to transfer files, so if you know how to update MalwareBytes manually, that would be helpful.
I will be very glad for any help. I realize most of you are probably on a break, if I should come back later, please tell me.
Thank you in advance for any assistance.
AdwCleaner Log:
# AdwCleaner v3.016 - Bericht erstellt am 28/12/2013 um 09:03:00
# Aktualisiert 23/12/2013 von Xplode
# Betriebssystem : Windows 8.1 Enterprise  (64 bits)
# Benutzername : l.gal - SOL
# Gestartet von : E:\adwcleaner.exe
# Option : Suchen
***** [ Dienste ] *****
***** [ Dateien / Ordner ] *****
***** [ Verknüpfungen ] *****
***** [ Registrierungsdatenbank ] *****
***** [ Browser ] *****
-\\ Internet Explorer v11.0.9600.16384
-\\ Mozilla Firefox v26.0 (de)
[ Datei : C:\Users\l.gal\AppData\Roaming\Mozilla\Firefox\Profiles\l51wpr9b.default\prefs.js ]
AdwCleaner[R0].txt - [643 octets] - [28/12/2013 09:03:00]
########## EOF - C:\AdwCleaner\AdwCleaner[R0].txt - [702 octets] ##########
MalwareBytes Log:
Malwarebytes Anti-Malware 1.75.0.1300
Database version: v2013.04.04.07
Windows 8 x64 NTFS
Internet Explorer 11.0.9600.16384
l.gal :: SOL-[administrator]
28.12.2013 09:10:07
mbam-log-2013-12-28 (09-10-07).txt
Scan type: Full scan (C:\|)
Scan options disabled: P2P
Objects scanned: 462990
Time elapsed: 48 minute(s), 31 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 2
C:\Windows\WinSxS\x86_microsoft-windows-atl_31bf3856ad364e35_6.3.9600.16384_none_3fc0044d754c0225\atl.dll (Trojan.FakeMS) -> Quarantined and deleted successfully.
C:\Windows\WinSxS\x86_microsoft-windows-vcm-core-codecs_31bf3856ad364e35_6.3.9600.16384_none_01428598f4095f36\iccvid.dll (Trojan.FakeAlert) -> Quarantined and deleted successfully.
(end)
SecurityCheck Log:
Results of screen317's Security Check version 0.99.77
  x64 (UAC is enabled)
System Center Endpoint Protection
Windows Defender
Antivirus up to date!
Malwarebytes Anti-Malware version 1.75.0.1300
Mozilla Firefox (26.0)
Microsoft Security Essentials MSMpEng.exe
Microsoft Security Essentials msseces.exe
Common Files Microsoft Shared Microsoft Online Services smss.exe -?-
Common Files Microsoft Shared Microsoft Online Services csrss.exe -?-
Common Files Microsoft Shared Microsoft Online Services services.exe -?-
Common Files Microsoft Shared Microsoft Online Services MSOIDSVC.EXE
Common Files Microsoft Shared Microsoft Online Services MSOIDSvcm.exe
Common Files Microsoft Shared Microsoft Online Services audiodg.exe -?-
Total Fragmentation on Drive C:  %
Amelia84
Operating System : Windows 8.1
Re: Wireless connections deactivated, malware detected
Post by Superdave on Sun 29 Dec 2013, 5:21 am
Don't worry about the update. You can get the update after we establish a good connection to the internet. You can start by disconnecting the power supply to the modem for about 30 secs.
Please download Farbar Service Scanner and run it on the computer with the issue.
  • Press "Scan".
  • It will create a log (FSS.txt) in the same directory the tool is run.
  • Please copy and paste the log to your reply.
Tech Staff
Tech Staff
Post by Amelia84 on Sun 29 Dec 2013, 6:23 am
Thank you for responding so quickly.
I tried to shut off the computer and remove the battery for a while (it's a laptop), is it what you meant? I have built-in wifi and UMTS cards, both of which are deactivated, and the switches to reactivate are greyed out, as if the computer was in flight mode (which it isn't). Activating and reactivating flight mode has been known to solve some connectivity issues in Windows 8, so I tried that, but no luck there.
The JRT Log:
Version: 6.0.8 (11.05.2013:1)
OS: Windows 8.1 Enterprise x64
Ran by l.gal on 28.12.2013 at 20:06:06,84
~~~ Services
~~~ Registry Values
~~~ Registry Keys
~~~ Files
~~~ Folders
~~~ Event Viewer Logs were cleared
Scan was completed on 28.12.2013 at 20:08:29,03
End of JRT log
And the FSS Log:
Farbar Service Scanner Version: 05-12-2013
Ran by l.gal (administrator) on 28-12-2013 at 20:10:38
Running from "C:\Users\l.gal\Desktop"
Microsoft Windows 8.1 Enterprise  (X64)
Boot Mode: Normal
Internet Services:
Connection Status:
Localhost is accessible.
There is no connection to network.
Attempt to access Google IP returned error.
Attempt to access Google.com returned error: Other errors
Attempt to access Yahoo.com returned error: Other errors
Windows Firewall:
Firewall Disabled Policy:
System Restore:
System Restore Disabled Policy:
Action Center:
Windows Update:
wuauserv Service is not running. Checking service configuration:
The start type of wuauserv service is set to Demand. The default start type is Auto.
The ImagePath of wuauserv service is OK.
The ServiceDll of wuauserv service is OK.
Windows Autoupdate Disabled Policy:
Windows Defender:
WinDefend Service is not running. Checking service configuration:
The start type of WinDefend service is set to Demand. The default start type is Auto.
The ImagePath of WinDefend: ""%ProgramFiles%\Windows Defender\MsMpEng.exe"".
Windows Defender Disabled Policy:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Defender]
"DisableAntiSpyware"=DWORD:1
Other Services:
File Check:
C:\Windows\System32\nsisvc.dll
[2013-08-22 14:25] - [2013-08-22 14:25] - 0029184 ____A (Microsoft Corporation) 6E2271ED0C3E95B8E29F3752B91B9E84
C:\Windows\System32\drivers\nsiproxy.sys => MD5 is legit
C:\Windows\System32\dhcpcore.dll
[2013-08-22 11:04] - [2013-08-22 11:04] - 0353792 ____A (Microsoft Corporation) A40B5232D325AC0200E73329F7F19F54
C:\Windows\System32\drivers\afd.sys => MD5 is legit
C:\Windows\System32\drivers\tdx.sys => MD5 is legit
C:\Windows\System32\Drivers\tcpip.sys
[2013-08-22 14:25] - [2013-08-22 14:25] - 2549600 ____A (Microsoft Corporation) C9436791C9DD3B5206DDBB1F75EE3E54
C:\Windows\System32\dnsrslvr.dll => MD5 is legit
C:\Windows\System32\mpssvc.dll => MD5 is legit
C:\Windows\System32\bfe.dll
[2013-08-22 10:56] - [2013-08-22 10:56] - 0827904 ____A (Microsoft Corporation) ACC04CBB75086D86031E0C63D0930B98
C:\Windows\System32\drivers\mpsdrv.sys => MD5 is legit
C:\Windows\System32\wscsvc.dll => MD5 is legit
C:\Windows\System32\wbem\WMIsvc.dll => MD5 is legit
C:\Windows\System32\wuaueng.dll
[2013-08-22 10:17] - [2013-08-22 10:17] - 3524096 ____A (Microsoft Corporation) B957B92C79A4CD138D5CFF1D20A9CF7B
C:\Windows\System32\qmgr.dll => MD5 is legit
C:\Windows\System32\es.dll => MD5 is legit
C:\Windows\System32\cryptsvc.dll => MD5 is legit
C:\Program Files\Windows Defender\MpSvc.dll => MD5 is legit
C:\Program Files\Windows Defender\MsMpEng.exe => MD5 is legit
C:\Windows\System32\ipnathlp.dll => MD5 is legit
C:\Windows\System32\iphlpsvc.dll => MD5 is legit
C:\Windows\System32\svchost.exe => MD5 is legit
C:\Windows\System32\rpcss.dll => MD5 is legit
**** End of log ****
Amelia84
Post by Superdave on Mon 30 Dec 2013, 5:10 am
* Go to Start > Run and type mrt.exe then press Enter on the keyboard).
* (Vista and Windows 7 users go to Start and type mrt.exe in the search box then press Enter on the keyboard.
* Click Next.
* Choose Full Scan and click Next.
* Once the scan is finished click View detailed results of the scan.
Look through the list and let me know if anything was found infected.
I need you to check these two services for me. Right-click on My Computer, click Manage, click Services and click on Windows Defender and make sure it's set to Auto. Also, click on Windows Update and click Start Service in the upper left hand corner.
Tech Staff
Tech Staff
Post by Amelia84 on Mon 30 Dec 2013, 8:20 am
mrt.exe did not find anything.
The services are running.
Edit: The internet connectivity problem was not related to the malware one. I'm feeling like a bit of an idiot. There was an external switch on my Dell to deactivate wireless connections. It isn't labeled and I had no idea it was there, but my boyfriend did, as he also has a Dell. I must have clicked on it by accident.
Which only leaves the question whether I can now consider my laptop clean. I will leave that one to you.
Last edited by Amelia84 on Mon 30 Dec 2013, 11:12 am; edited 1 time in total (Reason for editing : further information)
Amelia84
Post by Superdave on Mon 30 Dec 2013, 12:57 pm
Well, that is good news for both you and me. Let's run one more scan to see what turns up.
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by Amelia84 on Tue 31 Dec 2013, 5:22 am
ESET did not find anything, either.
Amelia84
Post by Superdave on Tue 31 Dec 2013, 6:34 am
Good, how's your computer running now?
Tech Staff
Tech Staff
Post by Amelia84 on Tue 31 Dec 2013, 10:03 am
It's doing fine now.
Amelia84
Post by Superdave on Tue 31 Dec 2013, 11:19 am
Ok, we'll do some cleanup and we're finished.
Go to Microsoft Windows Update and get all critical updates.
Safe Surfing!
Tech Staff
Tech Staff
Post by Amelia84 on Wed 01 Jan 2014, 12:32 am
Thanks a lot for your help!
Amelia84
Post by Superdave on Wed 01 Jan 2014, 4:44 am
You're welcome. I will lock this thread. If you need it re-opened, please send me a pm.Happy New Year.
Tech Staff
Tech Staff
Post by Sponsored content Today at 6:08 pm
