Toshiba satellite m110 shutdown issue
Post by Hrobakca on 16th November 2013, 9:13 am
got a older toshiba satellite m110 and it shutsdown after about 20-25 seconds its running 1.20 bios and i think it just needs a bios upgrade. i think the problem is a fan control issue. i found the download but the laptop shuts down before i can even try and upgrade bios
Hrobakca
Joined Joined : 2013-11-16
Points Points : 11193
Re: Toshiba satellite m110 shutdown issue
Post by Nazzgull on 16th November 2013, 10:57 am
Did you checked battery, AC adapter? Do you get any blue screen when restart occur?
Points Points : 40475
Post by Hrobakca on 17th November 2013, 12:04 am
no bsod just reboots
Hrobakca
